Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Audi A4 B8 2013 overheating
    Jan 2018
    Cheshire UK
    Research shows its a common fault on the VAG range, mainly the Golfs. New thermostat and or water pump solves the issues.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  2. Likes Frikki liked this post
  3. #12
    ...and that's why we should always start with an autoscan. Special S4 you have here with a 1.8 TFSI
  4. #13
    Jul 2017
    Kenya
    Quote Originally Posted by Frikki View Post
    Wednesday,25,September,2019,11:18:29:62451
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
    VIN: WAUZZZ8K7DA042864   License Plate:
                    Address 01: Engine       Labels: 06L-906-264-CJE.clb
    Control Module Part Number: 8K0 906 264     HW: 8K0 906 264
      Component and/or Version: 1.8l R4 TFSI  H07 0008
               Software Coding: 0A190012242501022000
                Work Shop Code: WSC 06208 000 00000
                  ASAM Dataset: EV_ECM18TFS0218K0906264 002007 (AU48)
                           ROD: EV_ECM18TFS0218K0906264.rod
                          VCID: 6E843ACB60183A477C1-803A
    17789 - Insufficient Engine Cooling / Coolant Flow
              P00B7 00 [032] - -
                        Mileage: 147555 km
                        Date: 2019.09.19
                        Time: 21:39:16
                        Engine speed: 725.00 /min
                        Normed load value: 10.2 %
                        Vehicle speed: 1 km/h
                        Coolant temperature: 78 C
                        Intake air temperature: 53 C
                        Voltage terminal 30: 13.945 V
                        Engine: operating status: IS
                        Engine temp. management actuator: raw value: 2121
                        Engine temperature management actuator: stop open: 131
                        Engine temperature management actuator: after-run stop: 3962
                        RVC_SP: 4.00
                        RVC_AV: 132.45
                        RVCPWM: 0.000 %
    16986 - Insufficient Engine Cooling / Coolant Flow
              P00B7 00 [096] - -
                        Mileage: 147555 km
                        Date: 2019.09.19
                        Time: 21:39:13
                        Engine speed: 730.25 /min
                        Normed load value: 9.4 %
                        Vehicle speed: 2 km/h
                        Voltage terminal 30: 13.867 V
                        Engine temp. management actuator: raw value: 2116
                        RVC_SP: 129.25
                        RVC_AV: 132.13
                        RVCPWM: 13.062 %
    Hello.. coolant pump on this EA888 gen3 CJEB is mechanical but integrated with electric engine temperature management module [thermostat]....so it is advisable to log coolant temperature at engine and radiator outlet as well as thermostat duty cycle in real time
    with engine running to see how the thermo regulates temperature..... also check water pump weep hole for small leakage[ if any is found,replace the whole unit>>>that's thermo + water pump....cheap at ecstuning.com
  5. Likes Uwe, Frikki liked this post
  6. #14
    Mar 2019
    South Africa
    Thanks. So you agree with morski that we should change complete housing with pump and thermostat to solve problem. Many thanks to all members.
  7. #15
    I've fixed the thread topic.
  8. Likes Frikki liked this post
  9. #16
    Mar 2019
    South Africa
    Thanks guys. Fitted new complete waterpump. Car sorted. Many thanks.
  10. Likes Uwe, Fredrick Awuor liked this post
