ABS coding lost seat 2009 (ABS8.2)
Hico61
den haag
C?ID=367415
Thursday,26,September,2019,10:44:54:11846
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Autobedrijf Hico
Workshop Code: 202 01034 034567
VIN: VSSZZZ6JZAR004418   License Plate:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZAR004418   Mileage: 325370km-202175miles
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 BK    HW: 03C 906 024 BK
   Component:       BXW   MM4HV G 4119
   Revision: --H11---    Serial number:
   Coding: 0000071
   Shop #: WSC 06402 785 00200
   VCID: 68884C8B0E613F27629-5184
28793 - No Communication with ABS Brake Control Module
            U0121 - 000 -  - Intermittent
                    Reset counter: 226
                    Mileage: 325374 km
                    Date: 2014.02.10
                    Time: 03:04:22
                    Bin. Bits: 00000000
                    Lambda: 0.0 %
                    Temperature: 34.0°C
                    Absolute Pres.: 1026.2 mbar
Readiness: 0010 0001
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 S    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Shop #: WSC 13765 790 00015
   VCID: 4EC49A138095C117085-801A
03190 - Incorrect Vehicle Type
                    Reset counter: 226
                    Mileage: 325374 km
                    Date: 2014.02.16
                    Time: 10:02:02
                    Hex Value: 0x0004
                    Hex Value: 0x0000
                    Hex Value: 0x3028
                    Hex Value: 0x1694
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7E00
                    Hex Value: 0x0000
                    Reset counter: 186
                    Mileage: 325374 km
                    Date: 2014.02.16
                    Time: 10:12:54
                    Hex Value: 0x0005
                    Hex Value: 0x0000
                    Hex Value: 0x3013
                    Hex Value: 0x1495
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045     HW: 6J0 820 045
   Component: J301  Klimaanlage   0280
   Revision: 00 23 08    Serial number: 0000000142739-
   VCID: 63925BA7F7575C7FB7B-8036
   Part No SW: 6R0 937 087 B    HW: 6R0 937 087 B
   Component: PQ25 BCM      H08 0025
   Revision: BF008001    Serial number: 9955A133092524
   Coding: 3B882BE888610100003000007E0B1CC800C0400F608C00002000
   Shop #: WSC 64564 324 38760
   VCID: 3C20C0DB26694387D61-8068
   Subsystem 1 - Part No SW: 6R0 959 801 A    HW: 6R0 959 801 A  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  001 0238
   Coding: 020000
   Subsystem 2 - Part No SW: 6R0 959 802 C    HW: 6R0 959 802 C  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  001 0242
   Coding: 020000
   Subsystem 3 - Part No SW: 6R0 959 811     HW: 6R0 959 811
   Component: J388__TSG_HL  001 0245
   Subsystem 4 - Part No SW: 6R0 959 812     HW: 6R0 959 812
   Component: J389__TSG_HR  001 0246
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10AirbagA09 H09 0018
   Revision: --------    Serial number: 003DW002XWE0
   Coding: 003039
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 42DCBE23440D35779CD-8016
   Serial number: 3496GRB401N945FV3K1K
   Serial number: 3506GRB402J99380TJSQ
   Part No SW: 6J0 920 801     HW: 6J0 920 801
   Component: KOMBI         X07 0110
   Coding: 110A00
   VCID: 649058BBFED95B474E1-8030
   Part No SW: 6N0 909 901     HW: 6R0 937 087 B
   Component: GW-K-CAN TP20 0025
   Coding: 022200
   VCID: 70B824EB3AA1F7E73A9-8024
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          X07 0110
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10121
   Shop #: WSC 06402
   VCID: 2E04FA93E955A117685-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Shop #: WSC 77005 000 00000
   VCID: 70B824EB36A1F7E73A9-8024
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J0 035 153     HW: 6J0 035 153
   Component: Radio         H11 0027
   Revision: R0000000    Serial number: SEZAZ1I7243679
   Coding: 0503040002
   Shop #: WSC 04941 000 00000
   VCID: 619E51AFE14B4E6FA57-8034
End----(Elapsed Time: 01:21, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
NEtech
C?ID=56995
You have the coding from that car, in the Autoscan you made on 20.Sep.
100200DB006D00B6082900E300D900000000
Hico61
den haag
C?ID=367415
yes bad hi dont accept dis code we chanch di abs modul bad we can codin het mit vcds hi gift dis code
CODING REJEVTED
ERROR 22:CONDITIONS NOT CORRECT ORREQUEST SEQUENCE ERROR
Boki Ar
Arandjelovac, Serbia
C?ID=57300
VBatt start/end: 11.6V/11.6V. Please connect a charger.
