Retrofit Cruise Control - Fabia 3
Charcoal75
North Yorkshire, UK
C?ID=376403
I have just purchased a genuine Skoda cruise control retrofit kit for my wife’s Fabia 3.
The kit comprises new steering column stalks to replace the factory fit stalks which only support speed control. The kit comes with activation software.
The car already has the correct BCM.
I am new to Ross-Tech having just purchased a Hex-V2 kit and have little knowledge of how to do the necessary coding once the hardware is installed and I am therefore seeking of some help with this project.
PetrolDave
Westbury, UK
C?ID=1423
Might be also worth joining briskoda.net and asking on the Fabia forum as there is almost certain to be someone on there in the UK who has done the cruise retrofit on a Fabia 3 using VCDS.
Charcoal75
North Yorkshire, UK
C?ID=376403
I hope ths is OK Mike
Wednesday,25,September,2019,10:36:54:15046
VIN: TMBFB6NJXGZ043405   License Plate:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: TMBFB6NJXGZ043405   Mileage: 16536km-10274miles
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 A    HW: 04C 907 309 J
   Component: R3 1.0l MPI   H24 8994
   Revision: 31H24000
   Coding: 01110072020405080000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM10MPI01104C906057A 001015
   ROD: EV_ECM10MPI01104C906057A.rod
   VCID: 2313EFFB7B56547FF7B-8076
4651 - Implausible Data Received from ESP Control Module
          U0416 00 [039] - -
                    Mileage: 16536 km
                    Date: 2019.09.25
                    Time: 10:34:40
                    Engine speed: 792.50 /min
                    Normed load value: 25.9 %
                    Coolant temperature: 51 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 15.007 V
                    Mass flow through throttle valve: 7.0 kg/h
Readiness: 1110 0001
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08504620150709
   Coding: 43F5247D492733C3091810690056C22492CC9008000DCAF98F00
   Shop #: WSC 13765 031 00063
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   VCID: 372B2BABDFCE28DF3B3-8062
1031 - Vacuum sensor
          C10A3 01 [009] - Electrical Failure
          [VacSent1Sensor]
                    Reset counter: 129
                    Mileage: 16536 km
                    Date: 2019.09.25
                    Time: 10:34:38
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6V0 820 045 A    HW: 6V0 820 045 A
   Component: AC Manuell    H01 0108
   Serial number:  1506201B-0048
   Coding: 100000001000100000
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 303910B73AA0FFE77A9-8064
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 D    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0094
   Serial number: 001378122834
   Coding: 0F0008404205405303A04080B10703080000D800D6013500000000000000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006_VW26.rod
   VCID: 313F15B331AAF6EF757-8064
   Subsystem 1 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY150752CAB
   Subsystem 2 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000032619022
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 3K  H10 0048
   Revision: --------    Serial number: 39231519501291
   Coding: 0001050001
   ROD: EV_EPHVA14AU3700000_SK25.rod
   VCID: 3A2D329FECDC35B7C4D-806E
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 13061503213006
   Coding: 00000000FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 F    HW: 6C0 959 655 F
   Component: VW20Airbag73D 001 0360
   Revision: --------    Serial number: 003RJ004578U
   Coding: 88CCC000000000005C5400CF008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 363526AFD8C4D1D7205-8062
   Subsystem 1 - Part No SW: -----------    HW: 410 822 306 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00AF1B7F3F170E7
   Subsystem 2 - Part No SW: -----------    HW: 410 822 306 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00A91B7F3F380F6
   Subsystem 3 - Part No SW: -----------    HW: 442 150 907 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00B91B6A762D16N
   Subsystem 4 - Part No SW: -----------    HW: 442 151 407 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C11B0CBA43017
   Part No SW: 6V0 920 940 A    HW: 6V0 920 940 A
   Component: KOMBI         205 1420
   Coding: 272501002180260001887A011000000000000000
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 353721A3C5C2DACF29F-8060
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 129
                    Mileage: 16536 km
                    Date: 2019.09.25
                    Time: 10:34:41
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 089
   Component: GW MQB A0     H08 0094
   Revision: --------    Serial number: 001378122834
   Coding: 030100042F0A640000000000000000010001050000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_SK25.rod
   VCID: 2615F6EF0864A157905-8072
   Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D1449010715
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 22182A40572821386123
   Part No SW: 6C2 909 144 AG    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3232
   Serial number: CF7G1115
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6E85CECFE014A917285-803A
   Part No SW: 5Q0 035 842 A    HW: 5Q0 035 842 A
   Component: MU-S-D-ER     H24 0241
   Serial number: SKZAZ2R8697921
   Coding: 03620000BE00000011111204008808002F0100C60120010000
   ROD: EV_MUStd4CTSAT_SK26.rod
   VCID: 2D0709C32D92920F51F-8078
   Subsystem 1 - Part No SW: 6V0 919 604     HW: 6V0 919 604
   Component: ABTm_Std2  H41 1028
   Serial number: SKZ8Z9RFF000MD
0012 - Digital Radio Antenna
          B1103 11 [009] - Short to Ground
                    Reset counter: 129
                    Mileage: 16536 km
                    Date: 2019.09.25
                    Time: 10:34:38
                    Voltage terminal 30: 14.9 V
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Electrical OK
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Electrical OK
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
End----------(Elapsed Time: 00:47, VBatt start/end: 15.0V/14.9V)-----------
darkchina811
ITALY
C?ID=333184
you should have an "activation document" which contains a code for performing the SVM, but it needs to be done with a dealer-level diagnostic cable. VCDS cannot perform SVM.
That's less a question of the cable and more a question of access to the mothership's servers.
darkchina811
ITALY
C?ID=333184
how so? if I had a geko account, would VCDS be able to access it?
No, VAG won't let other software access their server. But having one one of their cables in not a requirement. ODIS will run through a generic J2534 cable, and it would certainly be feasible for us to make a J2534 driver for our current interfaces -- if there was a compelling business reason do that. Anyway, the cable is not the determining factor.
darkchina811
ITALY
C?ID=333184
I didn't know that. I also heard that starting from 2020 ODIS won't work with VAS5054A anymore, it will require the "newer" interface.
