Results 1 to 4 of 4
Thread: JETTA 2.0 TSI 200HP - TURN OFF TRACTION CONTROL
    Jul 2019
    Brazil
    Question JETTA 2.0 TSI 200HP - TURN OFF TRACTION CONTROL
    Hello!
    I need to turn off Jetta's traction control.
    Would it be possible through VCDS?
    AUTOSCAN:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4F 52 56 62 72
    77
    VIN: 3VWLN61K2BM056858 Mileage: 83230km-51716miles
    Thanks.
    Jun 2014
    Swansea, UK
    You've only posted the installation list.
    Please can you post a full, unedited Auto-Scan?
  3. Likes PetrolDave liked this post
    You've posted only the CAN Gateway installation list, what we need is the full unedited Auto-Scan - see my signature for a link to a How-To.
    ** edit ** Looks like Mike@Gendan and I posted simultaneously
  5. Likes Mike@Gendan liked this post
  6. #4
    Jul 2019
    Brazil
              77
    Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
       Part No SW: 06J 906 027 AP    HW: 06J 907 309 A
       Component: MED17.5.2        04 8417
       Revision: P3H06---    Serial number:
       Coding: 0403000C1C070160
       VCID: 79BAFB0B302DB087DE-802C
                   U1017 - 015 -  - Intermittent
                        Fault Status: 00101111
                        Mileage: 83207 km
                        Date: 2019.09.05
                        Time: 17:02:52
                        RPM: 1982 /min
                        Load: 21.2 %
                        Speed: 16.0 km/h
                        Temperature: 87.0C
                        Temperature: 57.0C
                        Absolute Pres.: 940.0 mbar
                        Voltage: 13.589 V
       Part No SW: 02E 300 054 M    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2608
       Revision: 05351112    Serial number: 00001010220263
       VCID: 200CF66FF337014FB9-8074
    18255 - Please check DTC Memory of ABS Controller
                P1847 - 000 -  - Intermittent
                        Fault Frequency: 255
                        Reset counter: 1
                        Mileage: 83207 km
                        Date: 2019.09.05
                        Time: 17:02:53
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: A43B600D09270000251306E990210041210000
       VCID: 76A0F037C133DFFFB3-8022
    03409 - Rolling Mode recognized
                        Reset counter: 232
                        Mileage: 83207 km
                        Date: 2019.09.05
                        Time: 15:44:19
                        Count: 14
                        Count: 4096
                        Count: 396
                        Count: 43264
                        Count: 257
                        Count: 65024
    01169 - Door Contact Switch Driver Side (F2)
                        Reset counter: 232
                        Mileage: 83213 km
                        Date: 2019.09.05
                        Time: 17:07:42
                        Count: 7
                        Count: 2
                        Count: 20992
                        Count: 147
                        Count: 48385
                        Count: 254
                        Fault Status: 00100011
                        Reset counter: 192
                        Mileage: 83207 km
                        Date: 2019.09.05
                        Time: 17:02:52
                        Count: 320
                        Count: 2
                        Count: 4608
                        Count: 83
                        Count: 48897
                        Count: 254
                        Reset counter: 192
                        Mileage: 83207 km
                        Date: 2019.09.05
                        Time: 17:02:52
                        Count: 320
                        Count: 2
                        Count: 4608
                        Count: 67
                        Count: 48897
                        Count: 254
       Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
       Component: Climatronic   H17 1010
       Revision: 00003001
       Coding: 0000000002
       Shop #: WSC 00066 000 00146
       VCID: 6E90D857B163E73F7B-803A
       Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
       Component: BCM PQ35 M    011 0045
       Revision: BC011001
       Coding: 08000A2A802DE3C040080080140081240371008850A08D605C8000000040
       VCID: 3B362103BA9142978C-806E
       Component: RLS 231210 05  54  0403
       Coding: 03302D
       Subsystem 2 - Part No: 1K8 951 171
                        Fault Status: 00101010
                        Reset counter: 196
                        Mileage: 81672 km
                        Date: 2019.07.24
                        Time: 13:58:38
                        Voltage: 13.50 V
                        Reset counter: 232
                        Mileage: 75544 km
                        Date: 2018.09.16
                        Time: 19:35:34
                        Voltage: 14.25 V
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 5C6 919 475     HW: 7E0 919 475 A
       Component: PARKHILFE 8K  H10 0005
       Revision: --------    Serial number: 84091034001092
       Coding: 108101
       ASAM Dataset: EV_EPHVA18VW3610000 001003
       ROD: EV_EPHVA18VW3610000.rod
       VCID: 71AAC32BA05DF8C766-8024
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Component: AirbagVW10    012 0612
       Serial number: 003G6D03GMC5
       Coding: 00003142
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 32280C2765DB83DF5F-8066
       Serial number: 3572MSME54292359ZZZW
       Serial number: 3582MSME3D322359ZZZY
       Serial number: 3516KSME7510130DZZZJ
       Serial number: 3526KSME5D1B130DZZZ.
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101130301752
       Coding: 089A140000
       Shop #: WSC 00066 000 00195
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 76A0F037C933DFFFB3-8022
       Component: E221__MFL-TAS  H06 0010
       Coding: 830000
       Part No SW: 5C6 920 870     HW: 5C6 920 870
       Component: KOMBI         H20 0420
       Coding: 171B00
       VCID: 689CAE4F9387390F31-803C
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 04011101200539
       Coding: 351002
       VCID: 312A032B68DDB8C726-8064
       Component: IMMO          H20 0420
       VCID: 6A98D4478D8B0B1F27-803E
       Revision: A1001003    Serial number: 7668787325
       VCID: 271EED735619F677F8-8072
       Part No SW: 3C0 959 701 C    HW: 3C0 959 793 A
       Component: TUER-SG FT    002 0337
       Revision: 12101005    Serial number: 0001704151
       Coding: 0010B7
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: 281CEE4F5307F90FF1-807C
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1409
       Serial number: 00000005325465
       Coding: 000090
    67334 - Locking Module for Central Locking
              B122F 29 [008] - Signal Implausible
                        Reset counter: 232
                        Mileage: 59272 km
                        Date: 2022.10.13
                        Time: 18:49:59
    131584 - Motor for Rear Window Regulator
              B11EE 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 232
                        Mileage: 83079 km
                        Date: 2019.09.05
                        Time: 11:29:11
    131585 - Motor for Rear Window Regulator
              B11EE 01 [008] - Electrical Failure
                        Reset counter: 232
                        Mileage: 83079 km
                        Date: 2019.09.05
                        Time: 11:29:11
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       VCID: 312A032BA8DDB8C726-8064
                        Fault Status: 00101101
                        Reset counter: 232
                        Mileage: 83228 km
                        Date: 2019.09.05
                        Time: 17:28:42
                        Voltage: 13.25 V
                            DU
                        Temperature: 56.0C
                        RPM: 1216 /min
                        Speed: 17.0 km/h
                        Speed: 17.0 km/h
       Component: EZE_2         H35 0614
       Coding: 01030100
       VCID: 6FAEC553BE69EE3770-803A
       Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.019  H08 0006
       Serial number:     WRH0000Z1MS
       Coding: 180000
       Part No SW: 3C0 959 702 C    HW: 3C0 959 792 A
       Component: TUER-SG BT    002 0337
       Revision: 14101005    Serial number: 0001800312
       Coding: 0010B6
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide_VW32.rod
       VCID: 291AEB4B480DC007EE-807C
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1409
       Serial number: 00000005379871
       Coding: 000090
       Part No SW: 5K0 035 190     HW: 5K0 035 190
       Component: Radio RCD510  041 0167
       Revision: 00000001    Serial number: VWZ1Z3K3573441
       Coding: 0100041004
       VCID: 6288BC677DBB535FEF-8036
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668878450
       Coding: 0A00000000010100
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
    9457425 - Left audio channel for speech/telephone
              B104F 11 [001] - Short to GND
    9457169 - Right audio channel for speech/telephone
              B104E 11 [001] - Short to GND
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.1V/12.1V)-----------
