Results 1 to 4 of 4
Thread: Passat B6 ipcu webasto convert to parking heater
    Sep 2019
    Norway
    I have rebuilt my webasto from additional heaters to parking heaters but am struggling to get the coupe fan to start with the ipcu relay so I wonder if I need any programming in vcds. the webasto itself starts but not the fan.
    car passat b6 2006
    THERMOTOP V
    the webasto manual says i have to do this but im not able to see anything under item 15 just error
    Adjustment of passenger compartment monitoring with VAG5052 Tester.
    The following steps must be carried out with the VAG Tester :
    - Connect the VAG tester.
    - Open Item 46 (Central Module of Comfort System)
    - Go to Item 10 (Adjustment)
    - Follow the request for the code entry and enter the code 15
    - Reduce the sensitivity of the passenger compartment monitoring to 50 %
    - Save this setting
    Wednesday,25,September,2019,17:15:40:02378
    VCDS Version: 19.6.0.4 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZ3CZ6E239008   License Plate: XK14089
    Mileage: 265580km-165023mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 18 19 22 25 42 44 46 52 53 55 56 62 69
              72 77
    VIN: WVWZZZ3CZ6E239008   Mileage: 265580km-165023miles
    Address 01: Engine        Labels: 03G-906-018-BKP.clb
       Part No SW: 03G 906 018 CR    HW: 03G 906 018 CR
       Component: R4 2.0l PPD1.5 G    9674
       Revision: --H15---    Serial number: VWZCZ000000000
       Coding: 0000172
       Shop #: WSC 66565 257 00032
       VCID: 77ABEAAEA3CDD01FFBD-8022
    17054 - Glow Plug Module 1; Glow Plug Circuit
                P0670 - 006 - Electrical Malfunction - Intermittent
                        Fault Status: 00010001
                        Reset counter: 154
                        Mileage: 265549 km
                        Date: 2019.09.20
                        Time: 15:00:03
                        Text:      0    Nm
                        Text:  0.0    %
                        Voltage: 12.43 V
                        Bin. Bits: 10110000
                        Temperature: 16.0C
    18000 - Altitude Sensor / Boost Pressure Sensor
                P1592 - 006 - Implausible Correlation
                        Fault Status: 01000001
                        Reset counter: 157
                        Text:      0    Nm
                        Text:  0.0    %
                        Voltage: 12.20 V
                        Text:    934    hPa
                        Text:   1337    hPa
    Readiness: N/A
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
       Component: ESP 440 C2     H015 0004
       Revision:  H015       Serial number: 0667495512
       Coding: 0029998
       Shop #: WSC 05311 000 00000
       VCID: 323D1BBA082FF5370C3-8066
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
       Component: ClimatronicPQ46 050 0404
       Revision: 00050005    Serial number: 00000000000000
       VCID: 629DABFA184F25B7BC3-8036
       Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
       Component: Bordnetz-SG     H37 1301
       Revision: 00H37000    Serial number: 00000005601082
       Coding: EF8A8F0700041A006400000046000000001B5D435C0000
       Shop #: WSC 11111 111 45725
       VCID: 303911B20623C7277A7-8064
       Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 11111
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 11111
       Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
       Component: 04 AIRBAG VW8   029 2521
       Revision: 09029000    Serial number: 003A2P8KNA8N
       Coding: 0012340
       VCID: 2D0708C61111AACF511-8078
       Subsystem 1 - Serial number: 6332MSME0F426B2E
       Subsystem 2 - Serial number: 6342MSME0E3A344B
       Subsystem 3 - Serial number: 6351HTS6OLLESH13
       Subsystem 4 - Serial number: 6361HTS6OLL2ULM2
       Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
       Revision: 00005000    Serial number: 3C9953507P
       Coding: 0000112
       VCID: 2E050FCA1C17D1D768B-807A
       Part No SW: 3C0 920 870 QX    HW: 3C0 920 870 QX
       Revision: V0034000    Serial number: 00000000000000
       Coding: 0005105
       Shop #: WSC 12345 111 45725
       VCID: 094F9C56C539D6EF9D9-805C
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 1K0 815 071 R
       Component: Zuheizer        050 2302
       Revision: 00050000    Serial number: 09009839000000
       Coding: 0000011
       VCID: 34311DA2F23BFB071EF-8060
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C065110B11
       Coding: FDFD8C04CE2102
       VCID: 211FE4F65DC97EAFE59-8074
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 F
       Component: Haldex 4Motion      0115
       Part No SW: 3C0 959 433 M    HW: 3C0 959 433 M
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 00801 218 86961
       Subsystem 1 - Part No: 3C0 905 861 D
       Component:    ELV          024 0370
       3C0905861D     ELV          024 0370
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2801
       Coding: 0000245
       VCID: 363527AAE447E91720B-8062
       Part No: 1K1 909 144 K
       VCID: 33331EBEF735FC3F075-8066
       Component:    KSG PQ46 ELV 042 0472
       Coding: 18910A0851030E7630049415F0020F02403D40
    00956 - Key 2
                        Fault Status: 01100101
                        Reset counter: 155
                        Mileage: 265568 km
                        Date: 2019.09.21
                        Time: 11:47:08
       Part No: 1K0 959 702 K
       Coding: 0000244
       VCID: 372B2AAEE34D101F3BD-8062
       Revision:   013
       Coding: 0000012
    Address 55: Headlight Range        Labels: 5M0-907-357-V1.lbl
       Part No SW: 5M0 907 357     HW: 5M0 907 357
       Component: AFS-Steuergeraet    0003
       Revision:   H09       Serial number:
       VCID: 71BFD4B6CDA98E2F359-8024
       Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    X018
       Coding: 00000035
       Subsystem 2 - Part No: 7L6 941 330
       Component: AFS-Lst.-Modul r    X018
       Coding: 00000035
    Address 56: Radio
       Part No: 3C9 959 703
       Component: Tuer-SG         021 2507
       Coding: 0000144
       VCID: 70B9D1B2C6A387273A7-8024
    Address 69: Trailer        Labels: 1K0-907-383-V1.clb
       Part No SW: 1K0 907 383     HW: 1K0 907 383
       Component: ANHAENGERELEKTR 001 0020
       Shop #: WSC 05314 000 00000
       VCID: 6A8DC3DAE07F7DF7743-803E
    00576 - Terminal 15
                        Reset counter: 193
                        Mileage: 262140 km
                        Date: 2019.09.19
                        Time: 20:03:00
       Part No: 3C9 959 704
       Coding: 0000144
    Address 77: Telephone        Labels: 3C0-035-729.lbl
       Part No SW: 3C0 035 729 E    HW: 3C0 035 729 E
       Component: Telefon             6009
       Revision: 00009000    Serial number: 0000000736083
       Coding: 0016023
       VCID: 2517F0E649E1928F991-8070
    01530 - Radio Mute Switch
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 150
                        Mileage: 265505 km
                        Date: 2019.09.18
                        Time: 22:23:19
    00385 - Positive Output Audio Channel for Speech/Telephone
                        Reset counter: 150
                        Mileage: 265505 km
                        Date: 2019.09.18
                        Time: 22:23:19
    00386 - Negative Output Audio Channel for Speech/Telephone
                        Reset counter: 150
                        Mileage: 265505 km
                        Date: 2019.09.18
                        Time: 22:23:19
    01524 - Antenna for Telephone
                        Reset counter: 150
                        Mileage: 265505 km
                        Date: 2019.09.18
                        Time: 22:23:19
    End----------(Elapsed Time: 01:29, VBatt start/end: 12.3V/12.3V)-----------
    Wednesday,25,September,2019,17:22:09:02378
    Adaptation Channel 015:
    Stored value
      ERROR:
      Channel 15
      Not
      Available
    Those instructions seem to be to reduce the sensitivity of the Interior Monitor, so that your car's alarm won't go off spuriously when the Webasto runs. But from what I see in your scan, it looks like your car does not have an interior monitor, so those instructions would not apply.
    I also don't think they have anything to do with the functionality of the Webasto itself.
    Sep 2019
    Norway
    I was also thinking that it was not important but do you know what is wrong?
    Quote Originally Posted by hyrt11 View Post
    No, I have zero experience with Webasto heaters. They basically do not exist in NAR cars.
