- Joined
- May 27, 2017
- Messages
- 3,342
- Reaction score
- 2,092
- Location
- Finland
- VCDS Serial number
- C?ID=280813
could someone with erWin or dealer portal access check for me if there's a TPI for DSG flash for DQ500 gearbox, please? And if yes, to what version the update is suggested?
Car is : VW Tiguan 2017 190TDI DFHA engine DSG DQ500 4Motion
Symptoms : Jerky gear changes from 1->2->3. Slow gear changes. Jerky downshifts.
Basic settings and adaptation drive done and no change basically.
Thank you in advance.
Autoscan :
Autoscan :
Wednesday,25,September,2019,19:37:20:18875
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVGZZZ5NZHW310427 License Plate: xxx-xxx
Mileage: 79484km-49389mi Repair Order:
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 22 29 39 3C 42 44 47 52
55 5F 69 6C 6D A5 BB BC CF D6 D7
VIN: WVGZZZ5NZHW310427 Mileage: 79484km-49389miles
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DFHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 EJ HW: 04L 907 309 P
Component: R4 2.0l TDI X24 3015
Revision: B4X24---
Coding: 0125003A04761D082000
ASAM Dataset: EV_ECM20TDI01104L906026EJ 004002
ROD: EV_ECM20TDI01104L906026EJ_004.rod
VCID: 76B5E6CBA843A607E05-8022
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 011 A HW: 0DE 927 711
Component: GSG DQ500 H12 1410
Revision: 00H12V32
VCID: 2615F68B38639687905-8072
Part No SW: 5Q0 614 517 BH HW: 5Q0 614 517 AD
Component: ESC H25 0507
Revision: 00000000 Serial number: 61576000000096
Coding: 0AEE6B9A54210B6C477B670262CA4950D62AD0E2E646927D38625078C2AA02
VCID: 78A9E8F3A257D077F29-802C
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 L HW: 5NA 907 044 L
Component: AC Automat H35 4003
Revision: 20K08000 Serial number: 00000B00147934
Coding: 0002010420411101110510400010102A
ASAM Dataset: EV_ACClimaPrehVW37X 002014
ROD: EV_ACClimaPrehVW37X.rod
VCID: 48C95833923760F7429-801C
Subsystem 1 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 00000000000000000000
263425 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Fault Frequency: 28
Reset counter: 194
Mileage: 78849 km
Date: 2019.09.20
Time: 17:28:51
Outside air temperature: 8.5 °C
Voltage terminal 30: 12.9 V
System run time-Engine running time: 253 s
System run time-Terminal 15 on: 253 s
Air quality status: ERROR
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001616700623
ROD: EV_BCMBOSCH_017.rod
VCID: 7EA5FEEB8073EE47B85-802A
Subsystem 1 - Part No SW: 5NB 955 119 HW: 5NB 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 160523 033 0372
Serial number: 00000001605180309405
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y16M06D13H18M41S51
Coding: 03A8DD
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 3Q0 919 298 B HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0029
Serial number: 002605167478042
Coding: 0231567A51
ASAM Dataset: EV_EPHBO2CVW3260000 010016
ROD: EV_EPHBO2CVW3260000.rod
VCID: 3C2134E3D6EF3C57D61-8068
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 H HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0155
Coding: 320C47DB1CFF8728749C8065304085
ASAM Dataset: EV_ACCMRRCONTIVW376 001010
ROD: EV_ACCMRRCONTIVW376_001.rod
VCID: 392F2DF7D9DD097FCD7-806C
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0315
Serial number: 003TDR1V63SC
Coding: 98CCC0C00C0000005C5400CF000800000065
VCID: 1079B053AAE7E8375A9-FFFE
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 5NB857705C0161Q00678
Coding: 80000D
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 5NB857706C0166Q00679
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 001 506 16
Serial number: 357000000000741C4C1D
Subsystem 4 - Part No SW: ----------- HW: 480 001 506 16
Serial number: 358000000006741C4C1K
Subsystem 5 - Part No SW: ----------- HW: 480 401 106 16
Serial number: 3510001BD20FC483F79N
Subsystem 6 - Part No SW: ----------- HW: 480 401 106 16
Serial number: 3520001BD20FC483D309
Subsystem 7 - Part No SW: ----------- HW: 480 401 206 16
Component: FrontSensor_D 000 6149
Serial number: 3550001BD20FC482B3CL
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160617400541
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
VCID: 41DF4517B10D51BF857-8014
Part No SW: 5NA 920 790 A HW: 5NA 920 790 A
Component: KOMBI 405 2153
Coding: 07A500086F88000801883B0B1401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009052
VCID: 40D94013BA0758B78A9-8014
16777020 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Fault Frequency: 22
Reset counter: 201
Mileage: 78736 km
Date: 2019.09.18
Time: 16:25:42
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 G HW: 5Q0 963 272 G
Component: STH-MQB 008 0075
Coding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
VCID: 3A2D32FBDCDB0267C4D-806E
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000050175
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005002497
Coding: 030500341F087300FB07225E1E0F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7CA1F4E3966FFC57961-8028
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160001037370086211
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 8958780404
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00002.04.16
Coding: 0101
VCID: 4ACD623B8C3B92E754D-801E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH05 0012
VCID: 45D75107A5257D9FB9F-8010
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 E HW: 3Q0 907 566
Component: MRR1Rear H21 0510
Revision: --------
Coding: 16C002
Shop #: WSC 00046 000 00000
Component: TSG FS 020 0041
Serial number: 300516EEU15285
Coding: 003F0B20D000048000001000
VCID: 43D34F1FAB1143AF97B-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000860713
Coding: 01010011004001
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008_VW37.rod
VCID: 3D2739E7CDF5355FE1F-8068
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 466 C HW: 3Q0 035 466 C
Component: MIB2_amp_P_VW H45 0210
Revision: 00000001 Serial number: VWZ8Z1GAT00N6GR
Coding: 1284010001A00A2AAA0000000000
ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
VCID: 2F3B13AF1799D7CF633-807A
Component: TSG BFS 020 0041
Serial number: 220516EEL28614
Coding: 003F0120DE00048000001000
VCID: 42DD4A1BB40B4AA79CD-8016
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0051
Coding: 08AA00104B200201
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
Part No SW: 3Q0 035 840 B HW: 3Q0 035 840 B
Component: MU-S--ER 710 0757
Coding: 02730600000000005111000200080A001F0106E40120000003
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 2A0D02BB2C7BB2E7B4D-807E
Subsystem 1 - Part No SW: 7C0 919 606 HW: 7C0 919 606
Component: ABT_HIGH H54 1031
Serial number: VWZ8Z9SGY005RH
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0204
Revision: 8A001003 Serial number: 0407247491
Coding: 0100000202000000
VCID: 3B2337FFD3E13B6FDFB-806E
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H09 0170
Coding: 01230601A3002017000040
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
VCID: 77ABEBCFAF49DF0FFB3-8022
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30718393900000
Coding: 0A80
ASAM Dataset: EV_DeckLidCONTIAU736 001012
VCID: 3FDB43EFC7F9274FF33-806A
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H06 0272
Serial number: 07061611K13443
Coding: 000307060000040100220047C056A90088000E200040
Shop #: WSC 25768 001 104857
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 030616EF218555
Coding: 002E01200101048000001000
Component: TSG HBFS 020 0041
Serial number: 190516EEI19186
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 E HW: 3Q0 907 590
Revision: --------
Coding: 16C002
VCID: 372B2BCFEFC91F0F3B3-8062
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 1675C64B88030607005-8042
0774 - Light Bulb for Low Beam
C1198 29 [008] - Signal Implausible
Reset counter: 190
Mileage: 78901 km
Date: 2019.09.20
Time: 18:01:24
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
ROD: EV_LEDModLeftMELCOAU736_VW48.rod
Reset counter: 190
Mileage: 78901 km
Date: 2019.09.20
Time: 18:01:24
End----(Elapsed Time: 04:16, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
