Results 1 to 7 of 7
Thread: Steering module replacement help needed skoda octavia 3
    Sep 2018
    Portugal
    Hi there people . I received this car already with new steering module installed with default coding..... I installed old module to read oem coding,
    now after coding new one cruise control do not work , in ECU was an strange error
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 AG    HW: 03L 906 023 AG
       Component: R4 1.6l TDI   H23 9979
       Revision: --H23---    Serial number:
       Coding: 00114016034400080000
       Shop #: WSC 80093 222 69422
       ASAM Dataset: EV_ECM16TDI02103L906023AG 003014
       ROD: EV_ECM16TDI02103L997557M.rod
       VCID: EB96B06402AFB317D0-80BE
    6058 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [037] - -
                        Mileage: 201030 km
                        Date: 2019.09.23
                        Time: 15:10:12
                        Coolant temperature: 56 C
                        Intake air temperature: 32 C
                        Voltage terminal 30: 12.198 V
                        Driver request torque-TQI_DRIV_SUB: 0.00 Nm
                        Control Module temperature-TECU: 48 C
    after i found ECU coding is wrong , CCS are not coded ( why and how it happened i don't know ) i coded ECU now car are clean have not any error but Cruise Control
    not working, with old module all is fine (just srs lamp )
    Just one thing car have CCS switch on turn signal stalk and i coded it as ccs on turn signal....
    Can some one help me and drive me to point where i am wrong and where is my mistake?
    Log with full scan before and after ecu coded with oem coding on steering module
    thanks in advance for help...
    Chassis Type: 1Z-SK35 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72 77
    VIN: TMBBT61Z3B2017981   Mileage: 201030km-124914miles
              U0235 00 [037] - -
                        Mileage: 201030 km
                        Date: 2019.09.23
                        Time: 15:10:12
       Part No SW: 1K0 907 379 AS    HW: 1K0 907 379 AS
       Component: ESP MK60EC1   H30 0105
       Revision: 00H30001
       Coding: 113B201C09230001881404EC901A0041300000
       Shop #: WSC 73430 790 00999
       VCID: 8346F8C4023F5B5708-80D6
       Part No SW: 3T0 907 044 AR    HW: 3T0 907 044 AR
       Component: Climatronic   H15 0401
       Revision: 00005001
       Coding: 0000000002
       VCID: 8248FDC01525525F03-80D6
       Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
       Component: BCM PQ35  H   103 0615
       Revision: 00103 AD
       Coding: 40180AB8E05BB1C04008008011000124427000AE526D81605C0440000040
       VCID: B83C5F280B79C88FED-80EC
       Subsystem 1 - Part No: 1Z1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 28061  22  0601
       Coding: 00D7B7
       Component: RLS 180610 05  54  0403
       Coding: 0730ED
       Subsystem 3 - Part No: 1Z0 951 171
       Component: Innenraumuebe  008 5101
    Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
       Part No SW: 1Z0 919 475 B    HW: 1Z0 919 475
       Component: PARKHILFE 4K  H06 0006
       Revision: --------    Serial number: 66631017013471
       Coding: 100001
       VCID: C0CC37C853A9804F55-8094
       Component: Q6 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PC1YJCVG
       Coding: 0020790
       VCID: BD324E3CE45BEDA73E-80E8
       Subsystem 1 - Serial number: 6332MSME54316D317
       Subsystem 2 - Serial number: 6342MSME54422E45C
       Subsystem 3 - Serial number: 6351HSME2256746CB
       Subsystem 4 - Serial number: 6361HSME2257226B5
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20190816100343
       Coding: 5080140000
       Shop #: WSC 01286 386 08256
       ROD: EV_SMLSNGVOLWS.rod
       Part No SW: 1Z0 920 843 M    HW: 1Z0 920 843 M
       Component: KOMBI         H04 0406
       Coding: 110B00
       Shop #: WSC 73430 031 00999
       ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
       VCID: C2C83DC055A5925F43-8096
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 0602
       Revision:   H27       Serial number: 190610F1000411
       Coding: E9A07F0600060200001302
       VCID: ED92BE7CF4BBBD27CE-80B8
       Component: IMMO          H04 0406
       VCID: EA98B5600D55AA1FAB-80BE
       Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
       Coding: 0004342
       VCID: F6A0911081ED7EFF3F-80A2
       Part No: 1K0 909 144 J
       Revision: 00H17000
       VCID: B12A620C280319C7AA-80E4
       Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
       Coding: 0004342
       VCID: C8DC2FE8BB99B80F9D-809C
       Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
       Component: SWING         009 0065
       Revision: 0I001001    Serial number: SKZ1Z2K8391198
       Coding: 0D0004000001
       VCID: B12A620CE80319C7AA-80E4
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Coding: 0000144
       Shop #: WSC 73430 790 1012551
       VCID: B2286D002D0522DFD3-80E6
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0000144
       VCID: B3266804D21F2BD7D8-80E6
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668224010
       Coding: 0600000000010110
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: B2286D00E50522DFD3-80E6
    End----------(Elapsed Time: 01:08, VBatt start/end: 12.7V/12.6V)-----------
    Address 16,5K0 953 569 AL,recoded (Long Coding),from,5080140000,to,108A140000,(01286/386/08256),
    Address 01: DTCs cleared
    Address 16,5K0 953 569 AL,recoded (Long Coding),from,108A140000,to,5080140000,(01286/386/08256),
    Address 16: DTCs cleared
    Address 01,03L 906 023 AG,recoded (Long Coding),from,00114016034400080000,to,00114016032400080000,(80093/222/69422),
    Address 01,03L 906 023 AG,recoded (Long Coding),from,00114016034400080000,to,00114016032400080000,(80093/222/69422),Monday,23,September,2019,16:23:17:10947
    VCDS Version: 19.6.0.6  HEX-NET CB: 0.4505.4
    VIN: TMBBT61Z3B2017981   License Plate:
    Mileage: 201030km-124914mi   Repair Order:
       Coding: 00114016032400080000
       Revision: 00H30001
       Revision: 00005001
       Coding: 0000000002
       Revision: 00103 AD
       Coding: 00D7B7
       Coding: 0730ED
       Coding: 100001
       Coding: 0020790
       Coding: 5080140000
       Coding: 110B00
       Coding: 0004342
       Revision: 00H17000
       Coding: 0004342
       Coding: 0000144
       Coding: 0000144
       ROD: UHVNA.rod
    End----------(Elapsed Time: 01:09, VBatt start/end: 12.5V/12.4V)-----------
    Looks like the engine ECU thinks the car has ACC not CCS - maybe a coding problem on the engine ECU?
  3. Likes Jack@European_Parts, Uwe liked this post
    Oct 2014
    Chassis Type: 1Z-SK35 (7N0) is a MK2 facelift Octavia not a MK3, might be worth getting the thread title updated to avoid confusion.
    I'd start by checking the ECU coding, as Dave mentioned it appears to think it has adaptive cruise which is unlikely given it was never an option
    Sep 2018
    Portugal
    No , now ecu have not errors and with old steering control module works fine and with new one don't that is strange
    Have you compared the coding of the old steering module and the new one? Maybe use hadez16's compare tool...
  7. Likes Uwe liked this post
    Use Long Coding help for engine, go to Byte 5, change pull-down menu to 20
  9. Likes Uwe liked this post
  10. #7
    Sep 2018
    Portugal
    Hi guys sorry for late answer
    Of course compared and all codings are alright and new module accepted well without coding or any errors, on copy past and manual coding by parameters ...
    Yes that resulted as wrote early because in ecu coding Byte 5 was 44 and it must be 24 and as you said it is changed in pull down menu....
    But one thing is strange on OLD UNIT CC WORKS WELL ON NEW NOT and with any steering unit i have not any error on car (just srs on old unit ).....
