Audi A6 C7 modul 5F RMC -help
CuturiloD
Serbia
C?ID=361908
Hello everyone,
I have problem with Long coding and adaptation with 5F modul in my car.
I don’t have any explanation for long coding also for adaptation.
If someone have info for my modul...
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Hi Team! :cool:
Here is Auto Scan from our user:
Tuesday,24,September,2019,16:50:39:48786
VIN: WAUZZZ4GXFN075726   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 36 3B 3C 42 44 46 52
          53 55 5F 62 6C 6D 72 85 8B 8E 8F 90 AC
VIN: WAUZZZ4GXFN075726   Mileage: 152168km-94552miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 0655
   Revision: 85H23---
   Coding: 0A25401A234401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002002
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79AFEF19E952BBEF8D7-802C
Address 02: Auto Trans (J217)       Labels:| 0CJ-927-156.clb
   Part No SW: 4G0 927 153 L    HW: 0CK 927 156 Q
   Component: 0CK 20TDI RdW H01 0002
   Revision: --H01---    Serial number: 0000000191
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002014
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 323D183574A488B70CD-8066
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 06A29E49604579929B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FDB4101B7F655DFF33-806A
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01A8700E000000000000
   VCID: 7AADF015ECD4B0F784D-802E
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 02031500110355
   Coding: 34110908250000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 619FA77961C2432FA57-8034
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001021731202
   Coding: 0105001440349FE2C1014083A0001800CF9CC3082E08020100000494E10114020040002C030000
   VCID: 71BFD739B1A2F3AF357-8024
   Component: WWS57X 150211  H37 0080
   Serial number:         150216124312
   Coding: 0045F7
   Serial number: 23783453
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 26 02 2015  00000172
   Serial number: 70884397000000000001
   Component: ACC3          H21 0053
   Coding: 7A04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   VCID: 290FFF595972CB6FBD7-807C
   Revision: --------    Serial number: 003P1003J2GQ
   Coding: 30333130313630323437554A304C34473053
   VCID: 3B233511A3EE49FFDFB-806E
   Serial number: 3575HRB405R33HNKA83Q
   Serial number: 3585HRB4055373K63137
   Serial number: 3515JRB405V35IMQ80V9
   Serial number: 3525JRB405136K44BPC
   Serial number: 3554VRB4055352USNH2
   Serial number: 3564VRB405L352USD9A2
   Revision: --------    Serial number: 90372OC40003T
   Coding: 0000DC
   VCID: 372B29219F466D9F3B3-8062
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
   Serial number: 14 02 2015  B0046748
   Part No SW: 4G8 920 933 F    HW: 4G8 920 933 F
   Component: TDieRdwAcc    H08 0043
   Revision: 04001037    Serial number: 658050315596015
   Coding: 138E0A004F452008010400
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 33331D318BBE81BF07B-8066
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20140912135011
   Coding: 5D3F01
   VCID: 2615F46548ECE417905-8072
   Part No SW: 4G0 907 468 AE    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001752716
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 001024
   VCID: 73B3DD31CB3EC1BFC7B-8026
   Serial number: 6114185803
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 1412220000000000033D
   Revision: AA001002
   Coding: 04018264747464545425363E00
   VCID: 7CA1F60DE6E08EC7961-8028
   Revision: AA000000    Serial number: 00000138195316
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77ABE921DFC6AD9FFB3-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA82093LMG
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3635242598CC9497205-8062
   Component: SWA Master    H06 0060
   Serial number: 0366301422
   Coding: 040311
   VCID: 392F2F19A9D27BEFCD7-806C
   Component: SWA Slave  H06 0060
   Serial number: 0367089970
   Coding: 040311
   Component: TSG FA        H04 0507
   Coding: 011F17015E00628002080013
   VCID: 45D753E9D5AA0F0FB9F-8010
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0020537707
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0362711599
   Coding: 0100063800B93080C32008840C010E470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00011413809
   Coding: 011F17015E00628002080002
   VCID: 46D554E5E8AC0417B05-8012
   Revision: --------    Serial number: 00000001381341
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070B496D9AD74F51F-8078
   Coding: 04FA02102A600200
   VCID: 34311E2D8EB086871E1-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G1 035 193 A    HW: 4G1 035 193 A
   Component: RMC Cnct Nav  H61 0139
   Coding: 0100000101D5DF474C2B060301010000000001
   VCID: 221DE87524C41837FCD-8076
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464B/0F2705992
   Subsystem 3 - Part No SW: 4G1 919 610 E    HW: 4G1 919 610 E
   Serial number: 90349OC50006O
   Coding: 010F15004000628002080002
   VCID: 49CF5FD9F9B2EB6F5D7-801C
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 027502010201000300
   Shop #: WSC 79104 790 00000
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914_VW51.rod
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002001    Serial number: 044500038
   Coding: 111104C000
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   Component: DPC-SG        H27 0081
   Coding: 7A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C01064D5680DE47461-8078
   Coding: 7A04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 270BF9614F66FD1FAB3-8072
   Component: BV-SG         H33 0090
   Serial number: 005000620503157
   Coding: 04C099181211
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 00660600031F0376000308014248D2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F173971A2B3AF757-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150360032
   ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 02:00, VBatt start/end: 12.3V/12.2V)-----------
and screen photos:
I'll send PLA. and CSV. file to support. Any help about this problem would be appreciated. :)
Dana
Western PA, USA
Boki Ar
C?ID=57300
Thank You Dana.
As I know, he want to turn ON few function:
- Side assist
- Lane assist
- Traffic sign recognition
Regards,
B
CuturiloD
Serbia
C?ID=361908
Thank You @BokiAr for support.
As Boki was write with modul 5F I have few issuse:
- Side assist,
- Lane assist,
- Traffic sign recognition.
All of this function is working well done, but I don't have option on my display to change, for example brightness for side assist, turn ON/OFF line assist, etc.
Unfortunately I have RMC main unit.
NEtech
C?ID=56995
I have not seen any Autoscan with RMC that has PR-QR9 (Traffic sign recognition).
Do you have that ?
For PR-7Y4/7Y5, try in [5F] either:
Byte 8 Bit 0 active
or
Byte 8 Bit 0 and Bit 1 active
CuturiloD
Serbia
C?ID=361908
Thank You for suggestion. I will try this coding when I come home.
I was coding modules 17, 85 and 8E.
When I pass by the traffic sign (only speed limit), then I have traffic sign on my instrument cluster.
hadez16
C?ID=289891
Coding is not enough for RMC. In terms of retrofitting RMC is highly parameter-driven.
You need to upload parameter sets what cannot be done with VCDS.
Coding is just for having the menu options enabled.
CuturiloD
Serbia
C?ID=361908
I was try to coding 5F module as You suggested, but unfortunately without any success.
On MMI display I don t have any changes.
Here is the pictures
torrebasetez
Spain
C?ID=354490
Hi. I had before rmc 5f with lane assist and side assist and could regulate intensity. change to mib2. I can search for old coding of rmc 5f.
torrebasetez
Spain
C?ID=354490
I also enabled recognition signals with vcds in RMC 5f but had triangle error in fis. with mib2 use vcp and everything ok with traffic signal recognition
CuturiloD
Serbia
C?ID=361908
Hi.
I would be grateful if You could find old coding for your RMC 5F
CuturiloD
Serbia
C?ID=361908
I was also enabled TSR with VCDS and I also have triangle error in FIS.
So, I need to find someone who can finish it using VCP?
hadez16
C?ID=289891
Hi.
Lane Assist coding in RMC is Byte 8 Bit 0
But as I said, you need VCP for parameters.
CuturiloD
Serbia
C?ID=361908
Hi, now I understand, thank You.
Where I can to find parameters what I need?
fixhdd
Asia
C?ID=324569
No solution. I have the same fault as you. Thank you
AINils
Germany (AIB)
C?ID=56975
RMC doesn't support PSD, so TSR won´t work cerrectly with this Navigation Unit
