- Joined
- Sep 23, 2019
- Messages
- 11
- Reaction score
- 2
- Location
- Raleigh, NC, USA
- VCDS Serial number
- C?ID=31154
Long time, casual user, but just signing up for forums and don't have it with me right now to be "verified"...
Where do I go to find helpful sensors/values for diagnosing HVAC only blowing hot air (no AC in summer)?
VCDS showed no fault codes in any controller.
I assume some of the things I want to check are the following - where do I find those? What else should I also be checking?
1.) Bad air temp sensor (had this problem in B5S4 before)
2.) Bad AC Pressure Sensor (G395, TSB 87D9)
3.) Actual leak/low pressure
Wihtout a fault code, I figured it made sense to check values of these sensors to see if they are reasonable. When my temp sensor read low before, it never threw a code, but was low enough to cause the AC to not turn on. I'm wondering if something similar. Others pointed me to the TSB for bad AC pressure sensor, turns out mine is not in the known-fault production range. I was thinking if that read low pressure to cause AC to not turn on, I would have gotten a code for that though (regardless if due to bad sensor or actual low pressure???)
All advice welcomed!
Thanks,
Mark
Thanks,
Mark
