Results 1 to 9 of 9
Thread: Audi A3 Tail lights conversion US to europe(stoplight and indicators)
    Aug 2015
    Belgium
    I have a customer who imported an Audi A3 from the US to europe.
    We had to change the tail lights from Us ones to EU ones.
    When braking the stop light illuminiates together with the indicators.(orange lights)
    When using the indicators, the stop lights flash together with the indicator lights. We cannot pass MOT because of this. Here when using the indicators only the indicator lights should flash.
    I am pretty sure it can be adapted in the central electrics module in the menu adaptations, I can login in developer mode and change about a million things. But have no idea where I can change this feature.
    Would be usefull to make a Control Module Map?
    Is there somebody who can help me with this? I would be very gratefull.
    Attached a full scan.
    Many thx
    Floris
    Tuesday,24,September,2019,15:00:17:07138
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUACGFF3F1090938   License Plate: FRT543
    Mileage: 55413km-34432mi   Repair Order:
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 3C 42 44 52 55 5F 6C BB BC
    VIN: WAUACGFF3F1090938   Mileage: 55413km-34432miles
    Address 01: Engine (J623-CNSB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 D    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 0A1D00322424000F2000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM18TFS0208V0906264D 001004
       ROD: EV_ECM18TFS0208V0906264D.rod
       VCID: 3D7AB499AC6A4CA7B2-8068
    Readiness: 0010 0101
       Part No SW: 0D9 300 041 R    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4511
       Revision: 05853104    Serial number: TFK01410061237
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 275676F15EF6F677F8-8072
              P1734 00 [002] - -
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 63334000000160
       Coding: 13FF6A9234290A6C0180020381CB29C8562C5080408194B4024100588208
       ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
       VCID: 4894D54DF3A8190F11-801C
       Component: AC Automat    H13 0060
       Revision: 20027000    Serial number: 00000000511862
       Coding: 03000014010000000000000000001400
       VCID: 336E92A19A2E8AD754-8066
       Serial number: 0428CE57000000000001
       Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
       Component: BCM MQBAB MNA H18 0137
       Serial number: 01011432400594
       Coding: 04141A46C04122F541C04004511007000000000000000000000000000000
       Shop #: WSC 56814 002 1048576
       ROD: EV_BCMBOSCH_013.rod
       VCID: 79F26089F8C2B087DE-802C
       Component: WWS371 141119  042 0585
       Serial number:         141127124241
       Coding: 0A47F7
       Serial number: 23483321
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 27 09 2014  00001186
       Serial number: 00000000000061107226
       Sun Roof:
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST0001MOAL00000
       Coding: 101F00
    11018 - Bulb for Left Brake Light
              B12C2 15 [008] - Open or Short to Plus
                        Reset counter: 124
                        Mileage: 55374 km
                        Date: 2019.09.04
                        Time: 08:26:56
    18698 - Left LED Module for DRL and Parking Lights
              B12EC F2 [009] - Voltage Supply Open or Short to Plus
                        Fault Frequency: 20
                        Reset counter: 87
                        Mileage: 55374 km
                        Date: 2019.09.09
                        Time: 14:22:22
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39331433103118
       Coding: 0010150011
       VCID: 4280C765D594335FCF-8016
       Serial number: 003GCR010FD1
       Coding: 9DCCFCC0000000005000001AC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4796D671FEB6167718-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34178311B01121441384
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34178312B02121470230
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 6940000Y14000198TL0/
       Coding: 303139
       Subsystem 4 - Part No SW: -----------    HW: 480 002 211 14
       Serial number: 3570000000030841E114
       Subsystem 5 - Part No SW: -----------    HW: 480 002 211 14
       Serial number: 35800000000F0841E11H
       Subsystem 6 - Part No SW: -----------    HW: 480 401 811 14
       Serial number: 351000299188FC152285
       Subsystem 7 - Part No SW: -----------    HW: 480 401 811 14
       Serial number: 3520002B9188FC137348
       Subsystem 8 - Part No SW: -----------    HW: 480 400 910 14
       Serial number: 3550002B918166A241B%
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 400 910 14
       Serial number: 3560002B7175A92120A
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 02121408490287
       Coding: A018
       ROD: EV_SMLSKLOMQB_010_AU37.rod
       VCID: 7CFC799DF7F085AFC5-8028
    No ASAM data for: "EV_SMLSKLOMQB" (AU37)
       Part No SW: 8V0 920 960 H    HW: 8V0 920 960 H
       Component: KOMBI         H01 4291
       Coding: 0BF419092B88D7050200A8001800000000000000
       VCID: 4084CD6DDB98214FD9-8014
       Revision: --------    Serial number: 23111410800396
       Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72E057A5A5B4C3DF9F-8026
       Serial number: 24 11 2014  F0075865
       Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
       Component: SWA Master    H05 0071
       Serial number: 0352037243
       Coding: 030211
       ROD: EV_LaneChangAssis_VW51.rod
       VCID: 3874A58D8348698F61-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0071
       Serial number: 0352208194
       Coding: 030211
       Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
       Serial number: 131114BKA12546
       Coding: 00100F204000048000000002
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0102
       VCID: 438EC261CA8E3A57C4-8016
       Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
       Serial number: 151114BKF04984
       Coding: 001007204000048000000002
       VCID: 3F86CE91A6665EB7A0-806A
       Coding: 011A000101000000
       VCID: 75EA6CB9D4DAD4E7BA-8020
       Part No SW: 8V0 035 844     HW: 8V0 035 844
       Component: MU-S-S-US     013 0626
       Serial number: A7A02611140234
       Coding: 01730100FF0A000011110001001A00002F0001440100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE.rod
       VCID: 76E86BB5C9DCDFFFB3-8022
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9EY307ZPP
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Serial number: C1000018101400020047
              B11CF 53 [009] - Deactivated
                        Reset counter: 84
                        Mileage: 55374 km
                        Date: 2019.09.03
                        Time: 17:06:26
                        Voltage terminal 30: 12.4 V
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
       Component: MQB RVC Mid   H07 0140
       Coding: 027300010201000300
       ASAM Dataset: EV_2CamSysRearPASE 006016
       ROD: EV_2CamSysRearPASE.rod
       VCID: 30649DAD6B38B1CF29-8064
       Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0028
       Serial number: 191114BKI01492
       Coding: 000007204000048000000002
       Component: TSG HBFS      020 0028
       Serial number: 191114BKI01494
    End-------------------------(Elapsed Time: 04:25)--------------------------
    Quote Originally Posted by floflo001 View Post
    Probably.
  3. Likes floflo001 liked this post
    Oct 2017
    Northwest UK
    I've not got my WD's to hand but from memory I can recall that there are differences in the wiring of NAR and Euro models. Whether or not this affects the coding remains to be seen. DV52 is the man for the Leuchte sets. Please post some admaps.
  5. Likes Uwe, floflo001 liked this post
  6. #4
    Aug 2015
    Belgium
    Attached a control module map central elec 09 with login S12345 (develop mode)
    Hope you can help...
    	SW:5Q0-937-085-AB   HW:5Q0-937-085-AB ---  Cent. Elect. --- SA: S12345
    	Component:BCM MQBAB MNA H18 0137, Coding:04141A46C04122F541C04004511007000000000000000000000000000000
    	EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
    	Thursday,26,September,2019,08:09:32:07138
    	VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,12
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8 ,12
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,not active ,12
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,active ,12
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,1000 ms,12
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,1000 ms,12
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,1000 ms,12
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,1000 ms,12
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1000 ms,12
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,active ,12
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,12
    IDE01550-Service position,133.30 °,2
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,4
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,4
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,4
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,4
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,4
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,4
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,4
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,not active ,8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,8
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,8
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.25 °,14
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,14
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,14
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,14
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,14
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,14
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °,14
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,14
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °,14
    IDE03638-ENG116676-static AFS light-Upper speed threshold,32.00 km/h,14
    IDE03638-ENG116674-static AFS light-Vorschrift,OFF ,14
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,SMLS ,8
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.25 ,8
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,1.00 %,8
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,separate ,14
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung aktivieren ,14
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,60 km/h,14
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,Parklichtfunktion USA und Kanada ,14
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,active ,14
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,not active ,14
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,active ,14
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,6400 lx,8
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,20 seconds ,8
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,60 seconds ,8
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
    IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,8
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
    IDE04927-ENG126845-Window heater-FSH Automatik,not active ,8
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,8
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,4
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,4
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,4
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,4
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm ,4
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,4
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,4
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,8
    IDE05142-ENG116706-Access control-Autounlock NAR,active ,8
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,8
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8
    IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,8
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active ,8
    IDE05142-ENG115755-Access control-Notschließfunktion,not active ,8
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,nur wenn freigegeben ,8
    IDE05142-ENG115758-Access control-Valet Parking,not active ,8
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,8
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,active ,8
    IDE05144-Read parameter address,00 00 00 ,3
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10,37 ,560
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11,41 ,560
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12,00 ,560
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13,00 ,560
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16,08 ,560
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17,18 ,560
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48 ,560
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20,09 ,560
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21,19 ,560
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1C ,560
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C ,560
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4,48 ,560
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5,4C ,560
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6,49 ,560
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7,4D ,560
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8,00 ,560
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9,00 ,560
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,minimize ,560
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,minimize ,560
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,minimize ,560
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,minimize ,560
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,minimize ,560
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,minimize ,560
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,minimize ,560
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,minimize ,560
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,minimize ,560
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,minimize ,560
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,minimize ,560
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,minimize ,560
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10,100 ,560
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11,100 ,560
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12,0 ,560
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13,0 ,560
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16,70 ,560
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17,70 ,560
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2,30 ,560
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100 ,560
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100 ,560
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100 ,560
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27,100 ,560
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3,30 ,560
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30,100 ,560
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31,100 ,560
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32,100 ,560
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33,100 ,560
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34,100 ,560
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4,100 ,560
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5,100 ,560
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100 ,560
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100 ,560
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2,30 ,560
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0 ,560
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0 ,560
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23,100 ,560
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24,100 ,560
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3,30 ,560
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4,100 ,560
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5,100 ,560
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6,127 ,560
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7,127 ,560
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16,70 ,560
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17,70 ,560
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18,100 ,560
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19,100 ,560
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2,100 ,560
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3,100 ,560
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,1E ,560
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,1F ,560
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,00 ,560
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,00 ,560
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,41 ,560
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,41 ,560
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,41 ,560
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,41 ,560
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A ,560
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,2B ,560
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,2D ,560
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,2F ,560
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C ,560
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,02 ,560
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,03 ,560
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,04 ,560
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,05 ,560
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,06 ,560
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,03 ,560
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,04 ,560
    IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
    IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
    IDE05145-ENG116062-Light configuration-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,560
    IDE05145-ENG116081-Light configuration-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,560
    IDE05145-ENG116100-Light configuration-Lasttyp 12,not active ,560
    IDE05145-ENG116119-Light configuration-Lasttyp 13,not active ,560
    IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
    IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
    IDE05145-ENG116176-Light configuration-Lasttyp 16,Unknown (56),560
    IDE05145-ENG116195-Light configuration-Lasttyp 17,38 - LED Blinkleuchten ,560
    IDE05145-ENG116214-Light configuration-Lasttyp 18,Unknown (56),560
    IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
    IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,560
    IDE05145-ENG116252-Light configuration-Lasttyp 20,39 - LED Bremsleuchten ,560
    IDE05145-ENG116271-Light configuration-Lasttyp 21,39 - LED Bremsleuchten ,560
    IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
    IDE05145-ENG116309-Light configuration-Lasttyp 23,37 - allgemeine LED bis 12W ,560
    IDE05145-ENG116328-Light configuration-Lasttyp 24,37 - allgemeine LED bis 12W ,560
    IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
    IDE05145-ENG116366-Light configuration-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116385-Light configuration-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15 ,560
    IDE05145-ENG116404-Light configuration-Lasttyp 28,8 - allgemeine Glühlampe 12W ,560
    IDE05145-ENG116423-Light configuration-Lasttyp 29,8 - allgemeine Glühlampe 12W ,560
    IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,560
    IDE05145-ENG116442-Light configuration-Lasttyp 30,46 - LED Kleinleistung ,560
    IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
    IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
    IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
    IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
    IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,560
    IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,560
    IDE05145-ENG115986-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht ,560
    IDE05145-ENG116005-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht ,560
    IDE05145-ENG116024-Light configuration-Lasttyp 8,46 - LED Kleinleistung ,560
    IDE05145-ENG116043-Light configuration-Lasttyp 9,46 - LED Kleinleistung ,560
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,only_if_closed ,560
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,560
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,560
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0 ,560
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,13 ,560
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,14 ,560
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,0 ,560
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,0 ,560
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,24 ,560
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,24 ,560
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,24 ,560
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,24 ,560
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,8 ,560
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,26 ,560
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,26 ,560
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,8 ,560
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,45 ,560
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,45 ,560
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,45 ,560
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,45 ,560
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,45 ,560
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,46 ,560
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,15 ,560
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,15 ,560
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,2 ,560
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,4 ,560
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,30 ,560
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,30 ,560
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,30 ,560
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,8 ,560
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,8 ,560
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15 ,560
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15 ,560
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0 ,560
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,0 ,560
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,3 ,560
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,5 ,560
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,6 ,560
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,7 ,560
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,6 ,560
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,7 ,560
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,30 ,560
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0 ,560
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0 ,560
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,9 ,560
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,10 ,560
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,13 ,560
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,30 ,560
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,30 ,560
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,30 ,560
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,30 ,560
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,30 ,560
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,8 ,560
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0 ,560
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0 ,560
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,5 ,560
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,2 ,560
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,4 ,560
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,2 ,560
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,4 ,560
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,20 ,560
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,3 ,560
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,5 ,560
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,6 ,560
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,20 ,560
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,20 ,560
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,7 ,560
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,26 ,560
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,26 ,560
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
    IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
    IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
    IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
    IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
    IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
    IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
    IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
    IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
    IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
    IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
    IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
    IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
    IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
    IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
    IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
    IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
    IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
    IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
    IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
    IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
    IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
    IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
    IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
    IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
    IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
    IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
    IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
    IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
    IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
    IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
    IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
    IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
    IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
    IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
    IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,20.00 °C,24
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,19.00 °C,24
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,28.00 °C,24
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,27.50 °C,24
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,24
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,41.00 °C,24
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,40.50 °C,24
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,50.00 °C,24
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,49.00 °C,24
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,63.00 °C,24
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,62.50 °C,24
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,not active ,8
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,8
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,8
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,active ,8
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,50 %,8
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active ,4
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,4
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,4
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
    IDE07356-Position during interval mode,21.69 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
    IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
    IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,not active ,8
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,not active ,8
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,not active ,8
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,8
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,8
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,active ,8
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,active ,8
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active ,8
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,8
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,not active ,8
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active ,8
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not active ,8
    IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active ,8
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active ,8
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,8
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,8
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,8
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,8
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,not active ,8
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,500 ms,8
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,8
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,8
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,800 ms,8
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,8
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,8
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,Not Present ,8
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,not active ,8
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
    IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
    IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,2
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
    IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
    IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
    IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
    IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
    IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
    IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
    IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
    IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
    IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
    IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
    IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
    IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
    IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
    IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
    IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
    IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
    IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
    IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,20
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,active ,20
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,20
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,2
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,2
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,2
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
    IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
    IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
    IDE09733-ENG147405-LED bar setting values-Lockout time,0 s,10
    IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
    IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
    IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
    IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
    IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
    IDE10298-Alternating park position 1,18.69 °,2
    IDE10299-Alternating park position 2,21.69 °,2
    MAS01490-Energy management,active ,1
    MAS05055-lower turn position,27.69 °,2
    MAS05056-upper turn position,166.30 °,2
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
    ENG122934-erase_error_table,55 00 00 ,3
    ENG122933-error_mask,0 bit,2
    ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay,10 ,2
    ENG117283-ENG108451-Frontwaschfunktion-reserve,0 ,2
    ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,100.00 %,22
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,95.00 %,22
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,80.00 %,22
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,40.00 %,22
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,20.00 %,22
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,10.00 %,22
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,5.00 %,22
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,3.00 %,22
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,1.00 %,22
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,100 ,12
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,150 ,12
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,6.00 %,12
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,6.00 %,12
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,16.00 %,12
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,30.00 %,12
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,60.00 %,12
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms,10
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms,10
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms,10
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms,10
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.00 ,10
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links Dunkelphase ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,100 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam ,16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell ,16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,100 ,16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,1F ,16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41 ,16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam ,16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,minimize ,16
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,minimize ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,70 ,16
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,70 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,08 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,Unknown (56),16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Brake light ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Blinken links aktiv (beide Phasen) ,16
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,Blinken links Hellphase ,16
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,Blinken links Dunkelphase ,16
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,minimize ,16
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,minimize ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,70 ,16
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,70 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,41 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,18 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,38 - LED Blinkleuchten ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Brake light ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Blinken rechts aktiv (beide Phasen) ,16
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,Blinken rechts Hellphase ,16
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,Blinken rechts Dunkelphase ,16
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,minimize ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,100 ,16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,41 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,Unknown (56),16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Brake light ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links aktiv (beide Phasen) ,16
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,Blinken links Hellphase ,16
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,minimize ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,100 ,16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,41 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Brake light ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts aktiv (beide Phasen) ,16
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,Blinken rechts Hellphase ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts Dunkelphase ,16
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,Blinken rechts Dunkelphase ,16
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,minimize ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,39 - LED Bremsleuchten ,16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,minimize ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,39 - LED Bremsleuchten ,16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,100 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,37 - allgemeine LED bis 12W ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,37 - allgemeine LED bis 12W ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Parking light right ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,Coming Home oder Leaving Home aktiv ,16
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,minimize ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,Left high beam ,16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15 ,16
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,8 - allgemeine Glühlampe 12W ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,Daytime running lights ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,8 - allgemeine Glühlampe 12W ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,Daytime running lights ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,30 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,30 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,100 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Coming Home oder Leaving Home aktiv ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,Blinken links aktiv (beide Phasen) ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,03 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,Ambientelicht 1 ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,04 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 1 ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,05 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 1 ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,06 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 1 ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,30 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,30 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,100 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Coming Home oder Leaving Home aktiv ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Daytime running lights ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,Blinken rechts aktiv (beide Phasen) ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,100 ,16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,100 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,48 ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Coming Home oder Leaving Home aktiv ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,100 ,16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,100 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Coming Home oder Leaving Home aktiv ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,127 ,16
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,49 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Coming Home oder Leaving Home aktiv ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,127 ,16
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,4D ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Coming Home oder Leaving Home aktiv ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,03 ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,46 - LED Kleinleistung ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Ambientelicht 1 ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,04 ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,46 - LED Kleinleistung ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Ambientelicht 2 ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
    ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
    ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
    ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
    ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
    ENG122927-RLS_close_glazing,2.00 s,1
    ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3
    ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3
    ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2
    ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2
    ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2
    ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2
    ENG122929-RLS_LIN_Communication,4 s,1
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,100 lx,1
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,200 lx,1
    ENG122930-RLS_tunel_gateway_recognize,5 s,1
    ENG122935-RLS_Washer_Front,15 s,1
    ENG122926-RLS_wiper_position_parking,15 s,1
    ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,42 ,3
    ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,62 ,3
    ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
    Elapsed Time: 02:10
  7. Likes Bogdan.audi liked this post
  8. #5
    Aug 2015
    Belgium
    Just to give you an update. By creating a control module map, i managed to see the logic in the programming. I used excel and a search function and managed to program everything to european spec. There were about 8 fields I needed to change. So everything aok... thx for the help!
    PS:There was no wiring difference.
    Regards,
    Floris
  9. Likes Uwe, D-Dub liked this post
  10. #6
    Quote Originally Posted by floflo001 View Post
    It could help others who need to make the same change if you would share the changes you had to make
  11. Likes Uwe liked this post
  12. #7
    Aug 2015
    Belgium
    ok these are the changes:
    the ones I list you need to put on inactive in developper mode:
    Hope this clear, but if you look at the list long enough you will see the logic
    enjoy!
  13. #8
    ^^^^^ wow - I'm impressed!!!
    For anyone not familiar with Leuchte-programming to go from a complete novice to successfully achieving the outcome that you describe - simply by looking long enough at an admap - is well ........ (Alan) "Turing" like. Do you work for a secret European code-breaking organization (rhetorical question - because you wouldn't respond if you did)?
    You must have a remarkable ability to make sense of subtle patterns (I'm green with envy) - respect!!
    PS: You even managed to apply the appropriate "Links" "Rechts" function to the correct left-right Leuchte-set - so you were also able to decode the nomenclature in the Leuchte-set name (amazing for a complete novice) - double respect !!
  14. Likes PetrolDave, D-Dub, Bogdan.audi, andyhud liked this post
  15. #9
    Aug 2015
    Belgium
    Thx for the nice words!
    Enjoy the weekend!
