Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: EGR Issue on Mk6 GTD
    Verified VCDS User ak77's Avatar
    Jan 2015
    Australia
    Hi Team,
    I'm having an issue with my mk6 GTD for the last week or so, where the car after a certain amount of km traveled goes in to limp mode and drops RPM. Flashing glow plug appears but no MIL light. Wife drives it to work and at end of shift starts the car no problem and doesn't experience any issues after number of hours, and no flashing spiral indicator. Drives home fine with no power loss or any issues.
    I have scanned the car last week and today to show this issue. I'm not sure how to interpret this data. EGR valve was the only error last week now it looks like an EGR cooler two.
    Two weeks ago car had a flat battery. As potential symptom I though I mention this. Most data on VCDs was in red due to low voltage.
    I would appreciate any advice regarding this.
    Latest scan posted first.
    Al
    Tuesday,24,September,2019,13:46:36:41771
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
    VCDS Version 19.6.1.0
    VIN: WVWZZZ1KZCW064629   License Plate: GTDSILVER
    Mileage: 98190km-61012mi   Repair Order: Silver3
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
    VIN: WVWZZZ1KZCW064629   Mileage: 98190km-61012miles
    Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 BC    HW: 03L 907 309 R
       Component: R4 2,0L EDC   H23 7819
       Revision: 42H23---    Serial number: 00000000000000
       Coding: 001D0012042500080000
       ASAM Dataset: EV_ECM20TDI01103L906018BC 003005
       ROD: EV_ECM20TDI01103L906018BB_003_VW36.rod
       VCID: 6CD7F7908728DC2F55-8039
    4875 - Coolant Pump 2
              P261A 00 [096] - Open circuit
                        Mileage: 97929 km
                        Date: 2019.09.20
                        Time: 16:48:54
                        Engine speed: 799.50 /min
                        Normed load value: 22.7 %
                        Coolant temperature: 77 C
                        Intake air temperature: 27 C
                        Voltage terminal 30: 14.020 V
                        Unlearning counter according OBD: 38
                        Coolant temperature at radiator outlet: actual value: 65.7 C
                        Bypass valve for EGR cooler: status-Bits 0-7: 1
                        exh.gas recirc.: shut-off conditions-Bits 0-7: 0
                        exh.gas recirc.: shut-off conditions-Bits 0-7: 7
                        EGR cooling function: status-Bits 0-7: 0
                        exh.gas recirc. (EGR) cooler pump: specified value: 80.00 %
                        Temp sensor for EGR after cooler: raw value: -270.6 C
                        Exh.gas temp.sen 1: 71.1 C
    4891 - EGR Valve (N18)
              P0403 00 [096] - Malfunction
    4892 - EGR Valve (N18)
                        Mileage: 98136 km
                        Date: 2019.09.23
                        Time: 16:24:48
                        Engine speed: 1788.00 /min
                        Vehicle speed: 91 km/h
                        Coolant temperature: 79 C
                        Intake air temperature: 32 C
                        Voltage terminal 30: 14.040 V
                        Air mass: actual value (mg/stroke): 258.6 mg/stroke
                        EGR Vacuum Regulator Solen.val.: activation: 15.00 %
                        EGR Solen.val.: actual value: 34.50 %
                        EGR valve: offset closed: 1.27 %
                        Actuator for high pressure EGR: status-Bits 0-7: 55
                        Actuator for high pressure EGR: status-Bits 0-7: 0
                        Actuator for high pressure EGR: status-Bits 0-7: 7
                        High press EGR actuator: actual unconditioned volt val: 2927.4 mV
       Part No SW: 02E 300 057     HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2701
       Revision: 05351113    Serial number: 00001107060358
       VCID: 56A3B578E1A476FF93-8003
       Revision: 00H31001
       Coding: 163B600D092880FE681106E690220182350800
       VCID: 7BF5C4CCFA464B97CC-802F
       Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
       Revision: 00001003
       Coding: 0000001002
       VCID: 000FB3209BA0284F99-8055
       Part No SW: 1K0 937 086 M    HW: 1K0 937 086 M
       Component: BCM PQ35  M   110 0651
       Revision: 00110 AC
       Coding: 4C180A3A8025F1C0400800C0340001E449510488536D8560648000200040
       VCID: 3A7B01C8B5FCB29F97-806F
       Subsystem 1 - Part No: 5K2 955 119
       Component: Wischer 11071  26  0512
       Coding: 009795
       Component: RLS 160711 05  54  0403
       Coding: 0230AD
       Component: LIN BACKUP HO  H1 9005
                        Reset counter: 101
                        Mileage: 97692 km
                        Date: 2014.02.08
                        Time: 00:44:15
                            Term 15 Off
                        Voltage: 12.45 V
                            Term 50 Off
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Serial number: 003G5RA7ZZGP
       Coding: 00003956
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 316926E4608A71C726-8065
       Serial number: 3572MSME25256661ZZZQ
       Serial number: 3582MSME75242361ZZZO
       Component: S.Sens.Fahr.H  ----
       Serial number: 3522QSME540B1D34ZZZX
       Coding: 2020200000000000000000
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Revision: --------    Serial number:  90422KGD000X5
       Coding: 1892140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76E3D5F8C96416FFB3-8023
       Component: E221__MFL-TAS  H08 0010
       Serial number: 0069287
       Coding: 830000
       Part No SW: 5K6 920 872 A    HW: 5K6 920 872 A
       Coding: 170B01
       VCID: 33652CEC9A9643D754-8067
       Revision:   H42       Serial number: 140711F2003599
       Coding: 350003
       VCID: 356112F49CE25DE77A-8061
       Component: IMMO          H03 0607
       VCID: 6ADBF1888DDCC21F27-803F
       Revision: A1001003    Serial number: 7660458576
       VCID: 2959CE84405A0907EE-807D
       Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
       Component: Tuer-SG         009 2106
       Coding: 0000692
       VCID: 377D18FC46EEAFF768-8063
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 70     3201
       Revision: 00H20000
       VCID: 34672FF0579844EF4D-8061
       Component: Tuer-SG         009 2120
       Coding: 0000692
       VCID: 326B29E8AD8C4ADF5F-8067
       Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
       Component: Radio RCD510  052 0208
       Revision: 00000001    Serial number: VWZ1Z3L1610091
       Coding: 01000400040005
       VCID: 2345DCAC2276D357A4-8077
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 356112F45CE25DE77A-8061
       Coding: 0000144
       VCID: 366315F841E456FF73-8063
       Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
       Component: TELEFON       H09 2730
       Revision: 1B001001    Serial number: 00007660438729
       Coding: 0A01000000010101
       ASAM Dataset: EV_UHVNA A01015
       ROD: UHVNA.rod
       VCID: 34672FF09F9844EF4D-8061
    End-------------------------(Elapsed Time: 03:59)--------------------------
    Old scan here.
    Thursday,12,September,2019,13:29:28:41771
    Mileage: 97180km-60384mi   Repair Order: Gtd3
    VIN: WVWZZZ1KZCW064629   Mileage: 97180km-60384miles
                        Mileage: 97140 km
                        Date: 2019.09.11
                        Time: 16:32:12
                        Engine speed: 1804.50 /min
                        Normed load value: 0.4 %
                        Vehicle speed: 92 km/h
                        Intake air temperature: 28 C
                        Air mass: actual value (mg/stroke): 244.2 mg/stroke
                        EGR Solen.val.: actual value: 41.21 %
                        EGR valve: offset closed: 1.62 %
                        High press EGR actuator: actual unconditioned volt val: 2715.4 mV
       Revision: 00H31001
       Revision: 00001003
       Coding: 0000001002
       Revision: 00110 AC
       Coding: 009795
       Coding: 0230AD
       Component: DWA-Sensor 00  00 0104
       Component: LIN BACKUP HO  H11 9005
       Coding: 00003956
       Serial number: 3512QSME461D5B5CZZZ5
       Coding: 1892140000
       Coding: 830000
       Coding: 170B01
       Coding: 350003
       Coding: 0000692
       Revision: 00H20000
       Coding: 0000692
       Coding: 0000144
       Coding: 0000144
       ROD: UHVNA.rod
    End-------------------------(Elapsed Time: 03:52)--------------------------
    Mar 2019
    Poland
    Hello, get ready to replace the EGR valve, I recommend the original VAG part from my own experience.
  3. Likes Uwe liked this post
    Jan 2015
    Australia
    I'm really not happy about this I hope its not both . Been quoted $840 for cooler and $430 for EGR valve. I can buy entire engine for that much ahhah
    Need to work out alternative...
    How do I know if its one and not the other ?
    Mar 2019
    Poland
    You can try to clean the EGR valve, it's a lot of work and the effect is not always satisfactory. The price is really crazy for you.
    Nov 2016
    Ireland
    A quick pressure test will rule the EGR cooler in or out..... It'll be losing coolant too if cooler is gone.... Looks like u have an issue with the little electric EGR cooling pump? (4875 coolant pump 2)
    Jan 2015
    Australia
    I'm not loosing coolant. But I have noticed my thermostat is taking long time to come to temperature . I will look at cleaning the valve first .
    Are there any stats, measuring blocks I should be looking at or comparing against. Does anyone know of other diagnostic measures?
    Jan 2015
    Australia
    Can somebody tell me about these details?
    Mileage: 98136 km
    Date: 2019.09.23
    Time: 16:24:48
  9. #8
    Quote Originally Posted by ak77 View Post
    There both in the same part! 03L 131 527AX is a EGR cooler with EGR valve
  10. #9
    Jul 2016
    Australia
    Just before you do anything, you're from Australia... Did you get the diesel gate software update carried out??
  11. #10
    Jan 2015
    Australia
    Sorry my bad, EGR Throttle Valve . $430
