Results 1 to 5 of 5
Thread: Audi A5 2011 Gearbox Malfunktion!
    Jan 2015
    Sweden
    Hello All!
    I have a Audi A5 with multiple error codes from gearbox, and message on dashboard regarding "Gearbox Malfunction"
    Gearbox goes into fail safe mode from time to time and the customer can restart it after 5 minutes or so and then drive it for a while.
    I have tried to find solution on some forums but just become confused about repair methode, so I try this way.
    Kind regard and thanks in advance
    Monday,23,September,2019,13:04:40:01232
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUZZZ8T4CA011899   License Plate: MSA673
    Mileage: 143420km-89117mi   Repair Order:
    Chassis Type: 8T-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 62 69 72
              77
    VIN: WAUZZZ8T4CA011899   Mileage: 143420km-89117miles
    Address 01: Engine (------CDNC)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8K5 907 115     HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0008
       Revision: ECH09---
       Coding: 1A250013243601022000
       Shop #: WSC 10017 002 1048576
       ASAM Dataset: EV_ECM20TFS0118K5907115 001010
       ROD: EV_ECM20TFS0118K5907115.rod
       VCID: 6FD59001B699DC3770-803A
    8172 - Selector Lever
              P0919 00 [032] - Malfunction
                        Mileage: 143400 km
                        Date: 2018.09.20
                        Time: 14:55:28
                        Engine speed: 836.00 /min
                        Normed load value: 9.8 %
                        Vehicle speed: 18 km/h
                        Coolant temperature: 96 °C
                        Intake air temperature: 32 °C
                        Voltage terminal 30: 14.512 V
       Part No SW: 8K1 927 156 P    HW: 0B5 927 156 F
       Component: 0B5 20TFSIRdW H10 0008
       Revision: --H10---    Serial number: 0000000228
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501 A02196
       ROD: EV_TCMDL501.rod
       VCID: 42B309B5D58B015FCF-8016
    17598 - Selector Lever Sensor
              P179E 00 [032] - Electrical Malfunction
                        Reset counter: 39
                        Mileage: 143398 km
                        Date: 2018.09.20
                        Time: 14:53:08
                        Engine speed: 1565 /min
                        Transmission input speed: 1565 /min
                        Transmission output speed: 606 /min
                        Engine torque: 20 Nm
                        Transmission fluid temperature: 49 °C
                        Accelerator position: 10.4 %
                        Clutch status: Kupplung 2 kann Moment übertragen
                        Voltage terminal 30: 15.100 V
                        Supply voltages of sensors: status-Sensor Supply SV1: sensor supply correct
                        Supply voltages of sensors: status-Sensor Supply SV2: sensor supply correct
                        Supply voltages of sensors: status-Sensor Supply SV3: sensor supply correct
                        Sensors for driving mode: error status-FID 149: passive or deactive
                        Sensors for driving mode: error status-FID 161: passive or deactive
                        Sensors for driving mode: error status-FID 162: passive or deactive
                        Sensors for driving mode: error status-FID 163: passive or deactive
                        Sensors for driving mode: error status-FID 164: passive or deactive
                        Sensors for driving mode: error status-FID 165: passive or deactive
                        Sensors for driving mode: error status-FID 166: passive or deactive
                        Sensors for driving mode: error status-FID 167: passive or deactive
                        Sensors for driving mode: error status-FID 168: passive or deactive
                        Sensors for driving mode: error status-FID 169: passive or deactive
                        Sensors for driving mode: lock of diagnostics-FID 149: not locked
                        Sensors for driving mode: lock of diagnostics-FID 161: not locked
                        Sensors for driving mode: lock of diagnostics-FID 162: not locked
                        Sensors for driving mode: lock of diagnostics-FID 163: not locked
                        Sensors for driving mode: lock of diagnostics-FID 164: not locked
                        Sensors for driving mode: lock of diagnostics-FID 165: not locked
                        Sensors for driving mode: lock of diagnostics-FID 166: not locked
                        Sensors for driving mode: lock of diagnostics-FID 167: not locked
                        Sensors for driving mode: lock of diagnostics-FID 168: not locked
                        Sensors for driving mode: lock of diagnostics-FID 169: not locked
                        W006_Vwh_PrzWh_Whs1-Data: 38.70 %
                        W007_Vwh_PrzWh_Whs2-Data: 95.85 %
    17601 - Selector Lever Sensor
              P179F 00 [032] - Malfunction
                        Reset counter: 39
                        Mileage: 143398 km
                        Date: 2018.09.20
                        Time: 14:53:02
                        Engine speed: 1600 /min
                        Transmission input speed: 1600 /min
                        Transmission output speed: 621 /min
                        Engine torque: 108 Nm
                        Accelerator position: 22.0 %
                        Sensors for driving mode: lock of diagnostics-FID 169: currently locked
                        W007_Vwh_PrzWh_Whs2-Data: 40.90 %
       Part No SW: 8K0 907 379 BS    HW: 8K0 907 379 BS
       Component: ESP8 quattro  H09 0090
       Coding: 09DD4C
       VCID: 0B2DE491AA418017FC-805E
                        Fault Status: 00101101
                        Reset counter: 41
                        Mileage: 143400 km
                        Date: 2018.09.20
                        Time: 14:55:28
                        Hex Value: 0x1340
                        Hex Value: 0x4006
                        Hex Value: 0x121A
                        Hex Value: 0x02B8
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 EE    HW: 8K0 907 064 EE
       Component: BCM2 2.0      H10 0530
       Coding: 01A40000000000000000
       VCID: 77C5A861C6C994F7A8-8022
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0511000061596008
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000234718004
                        Reset counter: 41
                        Mileage: 143400 km
                        Date: 2018.09.20
                        Time: 14:55:33
       Part No SW: 8K1 820 043 L    HW: 8K1 820 043 L
       Component: KLIMA 1 ZONE  H02 0033
       Revision: A1000000    Serial number: 01251020110903
       Coding: 642002C000
       VCID: 31515679682D8AC726-8064
       Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
       Component: BCM1 1.0      H14 0103
       Revision: 08014001    Serial number: 00000326047802
       Coding: 2600C0108034AFC00081400300001D0D0F1C630826090201000004000400030100000024000000
       Shop #: WSC 40480 222 82201
       VCID: 78C7AB5DCBD79B8FA1-802C
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 201011  H15 0070
       Serial number: SWF11100200218
       Coding: 00FD11
       Component: G397_RLFS  H06 0001
       Serial number: 10026070
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001310111404
       Component: Humidity_Sens  H02 0002
       Serial number: FC2803D5000000000001
                        Reset counter: 41
                        Mileage: 143400 km
                        Date: 2018.09.20
                        Time: 14:55:33
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003KFD805B6
       Coding: 30523938363030303030554A304C38543053
       VCID: 48A71B9DF3B72B0F11-801C
       Serial number: 6334MSME6422792DI
       Serial number: 6344MSME6433313B8
       Serial number: 6352QSME62673468J
       Serial number: 6362QSME62672648J
       Serial number: 63732SME16612C66$
       Serial number: 63832SME5967205E5
    Address 16: Steering wheel        Labels: None
       VCID: 5599C2E9BC0586E79A-8000
       Part No SW: 8T0 920 930 B    HW: 8T0 920 930 B
       Component: KOMBIINSTR.   H23 0639
       Revision: 00000000    Serial number: JS1361EAC
       Coding: 1307310003010008010000
       VCID: 355962699C45A6E77A-8060
    Address 19: CAN Gateway
  2. Likes Dana liked this post
  3. #2
    16.4905° S, 151.7375° W
    Thank you for posting your question and the Auto-Scan. The fault codes below can set when there is a concern with the G676-Gear Sensor.
    ref:
    P179E 00 - Selector Lever Sensor: Electrical Malfunction
    P179F 00 - Selector Lever Sensor: Malfunction
    - Factory documentation states that "In the event of a fault, the gearbox switches to emergency mode. Once the vehicle comes to a standstill, no gear can be engaged."
    - You can use VCDS to check the Advanced Measuring Values in the [02-Auto Trans] to try and evaluate the Selector Lever values/G676.
    Have a look at the [Selector lever position] and [Transmission position], then try and see if these value changes when attempting to shift after clearing the fault code.
    Once the concern has been corrected, you will need to calibrate the G676, please see this Ross-Tech wiki page ...
    7-Speed S-Tronic Direct-Shift Gearbox (DSG/0B5)
    This fault code in the [01-Engine] controller is for information purposes and will clear when the concern in the [02-Auto Trans] has been corrected.
    P0919 - Selector Lever: Malfunction
    Bye the way...
    There is a TSB/TPI document that maybe helpful too. Official Factory Repair Information This document makes mention of the replacement of the G676 sensor.
    Technical product information, Transaction No.: 2027068
    Gearbox in emergency operation (P179E, P179F) - 0B5 gearbox
    If the Mechatronic controller is replaced, it will be necessary for the vehicle to have the end-of-line programing / Parameterization, this is completed with an online connection to the manufacture, VCDS does not perform these online functions at this time.
    Hope this helps,
    drpeter
    0B5 = Stone cold POS!
    Dont expect the TSB to be anything other than a temporary solution to kicking the can you might say, right everyone?
  5. Likes DrPeter, Golftwincharged liked this post
  6. #4
    Jun 2016
    Guyana
    I've had 3 occasions with this same fault code/s and indeed , confirmed this is the fault of the G676 sensor which needs replacing, unforntuately its quite some work to have replaced, which requires special tools, Good luck!
  7. Likes Jack@European_Parts, Dana, Uwe liked this post
  8. #5
    Jan 2015
    Sweden
    OK, thanks! My suspicion was also that it concerned the sensor deep inside the gearbox after reading a lot with help from doctor Google. I will talk with the customer to see what will happen next.
    I have already performed the basic setting of the gearbox a couple of weeks ago and after that it started to work OK for a while. But since two weeks it came back
    Thanks for your help.
    Have a nice weekend
    //Kjell
  9. Likes Dana liked this post
