- Aug 25, 2015
- 51
- 17
- Birmingham, England
- C?ID=253973
I have recently bought 2017 Tiguan. Did my first scan and all is good except two modules where it says interface not compatible. I am trying to do some instrument tweaks like needle sweep,refuel quantity in AID but it won't accept any changes and every time I get Coding rejected, Error 31: Request out of range message. I have genuine Hex+Can cable and running the latest vcds software. Any suggestions will be highly appreciated. Thanks
Thursday,19,September,2019,11:53:05:25423
VCDS Version: 19.6.1.0
Chassis Type 5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 4B 52 5F A5 BB BC
CA
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 HT HW: 04L 907 309 P
Component: R4 2.0l TDI H25 3617
Revision: B4H25---
Coding: 0125001203661D082000
ASAM Dataset: EV_ECM20TDI01104L906026HT 004003
ROD: EV_ECM20TDI01104L906026GP_004.rod
VCID: 0305DF368A76575784-8056
Part No SW: 0DL 300 011 N HW: 0GC 927 711 G
Component: GSG DQ500 H06 2002
Revision: 00H06V07
VCID: 33654FF69A5627D754-8066
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 60477000000313
Coding: 0AEE929A34200B714780070562CA4950492CD0E2E046927D38625078C22A4200002F641A1B13111435351919323200
VCID: 77FDBBE6CEAE0BF7A8-8022
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 N HW: 5NA 907 044 N
Component: AC Automat H35 4301
Revision: 20K08000 Serial number: 00000E00420403
Coding: 0012012420211001110510000010102A
ASAM Dataset: EV_ACClimaPrehVW37X 002023
ROD: EV_ACClimaPrehVW37X.rod
VCID: 4A9B3212EDDC461F07-801E
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
263425 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Reset counter: 58
Mileage: 67586 km
Date: 2019.09.19
Time: 11:45:29
Outside air temperature: 19.5 °C
Voltage terminal 30: 12.2 V
System run time-Engine running time: 61 s
Air quality status: ERROR
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001704700445
ROD: EV_BCMBOSCH_017.rod
VCID: 7F0D53C6E69E33B7E0-802A
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 161220 033 0372
Serial number: 00000001612140479964
Component: RLHS 042 0105
Serial number: S3Y17M02D23H21M07S38
Coding: 00A8DD
Serial number: 000000000ZY170231E3D
Serial number: 00000000000068556361
Part No SW: 3Q0 919 294 A HW: 3Q0 919 294
Component: PDC 8 Kanal H07 0020
Serial number: 002812167478081
Coding: 0071451811
ASAM Dataset: EV_EPHBO18VW3260000 007015
ROD: EV_EPHBO18VW3260000_007.rod
VCID: 377D7BE68E2ECBF768-8062
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 J HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0156
Coding: 320147C158FF8728749C8065804085
ASAM Dataset: EV_ACCMRRCONTIVW376 001011
ROD: EV_ACCMRRCONTIVW376_001.rod
VCID: 3B7567D6B206EF978C-806E
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2MP50/
Coding: 98CCC0C00C0000005C5400CF008800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 102FE07ACB003CCF09-8044
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 5NC857705C0044R01024
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 5NC857706C0044R00588
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 002 302 17
Serial number: 3570000000084D9CC12X
Subsystem 4 - Part No SW: ----------- HW: 480 002 402 17
Serial number: 35800000000404E48029
Subsystem 5 - Part No SW: ----------- HW: 480 401 502 17
Serial number: 3510001C32537332E54U
Subsystem 6 - Part No SW: ----------- HW: 480 401 702 17
Serial number: 3520001BB2537335679/
Subsystem 7 - Part No SW: ----------- HW: 480 401 702 17
Component: FrontSensor_D 000 6149
Serial number: 3550001A72537334364S
Pedestrian Protection Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 401 702 17
Component: PedP_Sensor_D 000 6149
Serial number: 2280001A12537335D27V
Subsystem 9 - Part No SW: ----------- HW: 480 401 702 17
Component: PedP_Sensor_P 000 6149
Serial number: 2290001A12537335825P
Pedestrian Protection Center:
Subsystem 10 - Part No SW: ----------- HW: 480 401 702 17
Component: PedP_Sensor_C 000 6149
Serial number: 2300001A32537331C35K
Subsystem 11 - Part No SW: ----------- HW: 480 001 302 17
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000C7D5D512C
Subsystem 12 - Part No SW: ----------- HW: 480 001 302 17
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000CEB306124
Part No SW: 5Q0 953 521 R HW: 5Q0 953 569 A
Revision: FF034034 Serial number: 20170220501272
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
VCID: 4189153ED0EA8547D6-8014
Part No SW: 5NA 920 791 A HW: 5NA 920 791 A
Component: KOMBI 408 2170
Coding: 27A400086F84060001886B031401000000000000
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005928965
Coding: 030500045F087300FB07225E1E0F00010001050000000000000000000000
ROD: EV_GatewNF.rod
VCID: 2F6D4386767E033730-807A
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170000325700107062
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 1158373104
Serial number: HA1-00031.01.17
Coding: 0101
Component: TSG FS 020 0041
Serial number: 310117EAT09337
Coding: 003F0220D001048000001000
VCID: 43851F36CAF69757C4-8016
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 4581012EC4C2A967EA-8010
Address 4B: Multifunc. Module
Interface not compatible.
Component: TSG BFS 020 0041
Serial number: 040217EB403449
Coding: 003F0020DE01048000001000
VCID: 428B1A32D5EC9E5FCF-8016
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0751
Coding: 02730601FF00000051110101008808001F0106E6012000008F
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 316945FE604A15C726-8064
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL07BSM
Subsystem 2 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
1539 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 97
Mileage: 67550 km
Date: 2019.09.18
Time: 00:00:49
Voltage terminal 30: 8.4 V
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 21021712K23255
Coding: 0003070600000401000213448050A90094000E200040
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 020217EB129982
Coding: 002A00200100048000001000
Component: TSG HBFS 020 0041
Serial number: 240117EAN03474
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:03)--------------------------
