VW Golf MK7 (2019) - Central Electronics long coding - all zeros
nibose
Perth, Australia
C?ID=371170
Hi Everyone,
I'd recently purchased a VCDS cable and am slowly learning how things work. I performed an auto scan but found the central electronics long coding displayed as zeros, instead of the coding information. The other modules display correct. I'm posting my autoscan
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 47 52 5F A5
VIN: <edited>   Mileage: 2015km-1252miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---
   Coding: 0125003224641D083000
   Shop #: WSC 00028 028 00031
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6D87C8471D19A32F11F-8038
   CAN Converter 01:
   Part No SW: 0CW 300 041 Q    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005008    Serial number: CU501809226194
   Shop #: WSC 00028 028 00025
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 43D34EFF6B1D855F97B-8016
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 62758000001212
   Coding: 01FA8AA12423216F4780060060C72980512484E26006947338225038C2A2430B00000012121212B835351919323200
   VCID: 77ABEA2F6F4519FFFB3-8022
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0494382608
   Coding: 132C0C0723
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 0012000420010000110500401210142A
   VCID: 6C81C5432603AA27061-8038
   Geber f�r K�ltemitteldruck/K�ltemitteltemperatur:
   Part No SW: 5Q0 937 084 DA    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H38 0273
   Serial number: 00001827100516
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7AADF31B5C57049784D-802E
   Component: WWS    180903  042 0551
   Serial number:         180906231320
   Component: RLHS  052 0107
   Serial number: SBY18M10D01H22M30S34
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000029091804400738
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417618267
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF74B7A16167CF157-8004
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 330067C15DFFC728949C810580400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: 44D14DE36E138267AE1-8010
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4LAHN$
   Coding: 98CCC000000000005C000000008800000065
   Shop #: WSC 00028 028 00010
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 094F9CD709B11F0F9D7-805C
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169677E02101830179
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169676E04101820994
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 609 18
   Serial number: 35700000000B9B40A33N
   Subsystem 4 - Part No SW: -----------    HW: 480 002 609 18
   Serial number: 35800000000F0944443G
   Subsystem 5 - Part No SW: -----------    HW: 480 400 410 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A52C8C773144%
   Subsystem 6 - Part No SW: -----------    HW: 480 400 410 18
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001142B72252270D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 709 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001B92E18363327/
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         403 4191
   Coding: 27A50118678C000801887B0B5401000080000000
   VCID: 2B03065FE38D6D1F4FB-807E
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 03101811601884
   Coding: 030100347F085708FB00025C1C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3D2738070DF9F3AFE1F-8068
   Component: 1-01-02-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39180001904730068382
   Coding: 2CFFFF
   Serial number: 5687909104
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H07 0021
   Serial number: 18000319799012
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1437C1A107CF757-8064
   Component: HRE_Master    H12 0081
   Serial number: 0494054096
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0494018176
   Coding: 020112
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000346019991
   Coding: 00311320D001048000001000
   VCID: 48C959D3523BA607429-801C
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000010206048
   Coding: 0D0000
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 93170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1DD237E3372E7DE1-8020
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD0397UU
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 2E050F4BD09F1837685-807A
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000342857500
   Coding: 00311120DE01048000001000
   VCID: 47CB5AEF5F25A97F4B3-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000010199698
   Coding: 050000
   Part No SW: 5NA 035 045 C    HW: 5NA 035 045
   Component: MU-H-N-RW     H55 1161
   Serial number: A849J0JB002070
   Coding: 027310080000000051510002000808001F0100F601200402DF
   VCID: 3829291322DBD687329-806C
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV2773576
   Subsystem 2 - Part No SW: V03 959 806 FQ    HW: -----------
   Component: ROW 2019/2020  --- 0079
   Component: Gracenote2  --- 4013
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 1272
   Serial number: 23081841K12006
   Coding: 000307000000010100022354C150A90098000E000000
   VCID: 084999D312BB6607829-805C
End----(Elapsed Time: 01:31, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Mika_M
C?ID=183725
It's perfectly normal. Nowadays that module 09 stores it's setup in adaptation channels. Coding is still there but it is all zeroes and that's how it's supposed to be.
nibose
Perth, Australia
C?ID=371170
So does this mean the "zeros" are not masked coding, just as it is for the Skoda BCM byte-18? I am trying to get light assist coded
PetrolDave
Westbury, UK
C?ID=1423
As Mika_M said there is no coding on the newer 09 modules so there's nothing masked :thumbs:
