Results 1 to 10 of 12
Thread: 00301 – ABS return flow pump (V39), Pump works, ECU is rebuilt, BRAKE light at 10 mph
    Aug 2016
    00301 – ABS return flow pump (V39) 35-00 - - Pump works, controller is rebuilt, BRAKE light comes on at 10 mph
    I’m stumped. The ABS rebuilder has graciously tested the ABS controller twice, and it works for them. Since rebuilding, it now exhibits a new error: 00301 – ABS return flow pump (V39) 35-00 - - . However, the ABS pump appears to rotate when 12VDC is applied directly to the contacts.
    So the rebuilder says the ABS controller is fine – but it does not appear to turn the ABS pump, which runs great on 12VDC.
    The 2005 8H Audi S4 cabriolet first exhibited an Intermittent error code: 01435 - Brake Pressure Sensor 1 (G201) 57–00 Electric Circuit Failure, also 48-00 Supply Voltage. The ABS controller (only) for 0 265 225 239, Esp 012 09A, 487289, Bosch part # 0 265 950 106, Bosch 5.7, was removed and sent to BBA for remanufacture.
    Before sending the ABS controller in, the driver complained of a soft brake pedal, so the car was sent to the dealer for a brake fluid replacement and mechanical component check, with the understanding that the ABS controller was not operational (but was communicating). The car appeared to drive and brake acceptably, with the brake sensor error code 01435 - Brake Pressure Sensor 1 (G201) 57–00 Electric Circuit Failure still showing. The sensor tested normally when disconnected from the harness.
    While waiting on the controller, the tires were replaced and the wheels were refinished.
    Upon reinstallation of the remanufactured ABS controller, a new error code appeared as stated by VAG-COM: 00301 – ABS return flow pump (V39) 35-00 - - . The controller was sent back to BBA for warranty repair.
    After reinstalling the ABS controller, the car still exhibits a 00301 error code, as before, starting when the car reaches 10 mph. This code coincides with a flashing red BRAKE light accompanied by the solid yellow electronic stability program (ESP) light and solid yellow ABS light. The flashing BRAKE light disappears after turning the car off and restarting, but the ABS light, the electronic stability program light and the error code (within VAG-COM) remain. Brake pressures, switches and wheel speed sensors appear to have normal values, as do all other measuring blocks through 6. The pump makes noise when 12VDC is applied directly to the spring electrical contact tangs, both polarities (with the ABS controller removed).
    • The Ross-tech VAG-com ABS function test cannot make the return flow pump run with the controller connected in the car. The function test does trigger the 00301 error code.
    • The pump runs consistently when tested directly from the spring contacts with 12VDC.
    • Resistance on pump contacts (isolated) is 0.4 ohms.
    • The contacts between the ABS valve block and the controller have been checked, cleaned, and make good electrical and mechanical contact.
    • The wiring harness and connector has tested successfully for the following: positive voltage picked up at pins 2, 6, and 23, and good grounds at pin 1 and pin 5.
    • The wiring harness contacts and fuses are verified through the Bentley factory manual for the 2005 Audi S4 cabriolet.
    • The previous error code which the ABS controller exhibited as sent to BBA rebuilder, 01435 – Brake Pressure Sensor 1, has not returned. The sensor returns normal values as I step on the brake.
    • The car had never before exhibited an error code related to 00301, and that is the only related code present now.
    • No germane warning lights or error codes are present after clearing codes. They occur after driving. Only 00301 remains.
    • The BRAKE, ABS and ESP lights activate consistently at around 10 mph.
    • Brake pressures, switches and wheel speed sensors appear to have normal values.
    • The car does exhibit typical radio codes and comfort / convenience code error messages, as it has for several years. These do not appear to be a part of the problem.
    • Fuses checked (for resistance, not just visually): 50 amp fuse S123 (50A) in driver’s side dash panel, in relay carrier (4-pin) with threaded connection, S7 (10A) S13 (10A), S14 (10A) and S242 (25A), aka fuse 42 in block.
    • Have not yet checked fuse S102 (15A) - the ECM fuse, within the plenum chamber. It is not likely to be the cause, as there is no ECM code.
    • The ABS controller has been recoded, no change was seen.
    • Brake fluid is full.
    Thoughts? I hate to send the valve block in if there is a simple answer. Is there some secret code that turns the pump off, once it has malfunctioned? And what physical happening triggers 00301 – ABS return flow pump (V39) 35-00 ? Pump current or resistance outside parameters, or lack of a successful test at 10 mph?
    i have a full diagnostic scan, but I have not yet posted it...unremarkable except for the ABS code.
    RichS
    Aug 2016
    00301 S4 ABS - scan
    Here is the scan - unremarkable, save for the 00301 code. I am not sure I have used the correct method in loading the scan...I'll keep trying until it appears.
    I'm having a little trouble, but here is a link to the scan on imgur .
    https://imgur.com/a/WT0jmGR
    Last edited by RichS; 09-22-2019 at 03:04 PM. Reason: image posting operator error
    Aug 2016
    Next steps - Could it be there is air in the ABS? the dealer bled the system, but the ABS controller was generating error codes at that time. I will attempt to bleed the ABS through the pressure sensor. The other lines should have bled, but the pressure sensor is way up high on the valve block.
    Is the ESP module been under water?
    Aug 2016
    As far as I know, the major components of the ESP - the steering wheel sensor, the steering column control module, the sender for the rotation rate - have never been under water. The ABS controller is just back from BBA as remanufactured. Good to hear from you, Jack - thanks.
    Aug 2016
    Update: During one Ross-Tech VCDS ABS brakes output test, the ABS pump ran for about 10 seconds, decreasing in speed as the 10 seconds went by. The car then has no error codes until it got to about 20 mph, then the previous symptoms - amber ESP, amber ABS and flashing red brake light - returned. Subsequent tests would not trigger more than a quick bump on the pump.
    Is it possible to apply 12VDC directly to the Bosch 5.7 pump motor contacts for 10 seconds at a time without damaging or overpressurizing the system? i did this before for about 1 second. Would it help for me to exercise this pump?
    Not sure if it matters - but the brake pressure is 120+ bar when pressed hard, no difference between strokes.
  7. #7
    Quote Originally Posted by RichS View Post
    We would much prefer the actual text of the scan rather than a picture of that text. Please see: How to Post an Auto-Scan.
  8. #8
    Aug 2016
    S4 Cabriolet 2005 8H ABS return pump (V39) 00301 Scan - Stumped, update
    Here we go with the scan - thank you, Uwe! Good to hear from you!
    Friday,20,September,2019,13:20:29:29481
    VCDS Version: 19.6.1.0 (x64)
    VIN: WUARL48H95K902547   License Plate:
    Mileage: 195840km-121689mi   Repair Order: 9-20-19 1 pm post drive v39 abs pump
    Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
              63 65 67 73 75 76 77
    VIN: WUARL48H95K902547   Mileage: 195840km-121689miles
    Address 01: Engine        Labels: 079-910-560-BBK.lbl
       Part No SW: 8H0 910 560 L    HW: 8E0 907 560
       Component: 4.2L V8/5V      G   0010
       Revision: 00000000    Serial number: AUX6Z0D0436780
       Coding: 0007774
       Shop #: WSC 00672 785 00200
       VCID: 316933DDAB5A73C726-5140
    Readiness: 0010 1101
       Part No SW: 8E0 910 156 R    HW: 09L 927 156
       Component: AG6 09L 4.2L5V USA  0060
       Revision: --H01---    Serial number:        0098085
       Coding: 0001002
       VCID: 356107CD5F325FE77A-5140
       Part No: 8E0 614 517 Q
       Component: ABS/ESP allrad      4533
       Coding: 04597
       Shop #: WSC 00672
       VCID: 366300C1123454FF73-5106
    00301 - ABS Return Flow Pump (V39)
                35-00 - -
       Part No: 8E0 820 043 AM
       Component:   A4 Klimaautomat   2831
       Coding: 00100
       Shop #: WSC 00672
       VCID: 6CD7E2A91CF8DE2F55-517C
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  USA 0517
       Coding: 01013
       Shop #: WSC 00672
       VCID: 356107CD0F325FE77A-4B1A
    Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
       Part No SW: 8E0 035 593 E    HW:
       Component: SDAR XM
       Revision:             Serial number: AUZ4Z7D2021424
       VCID: 2B5521B5897619171C-517C
    02633 - Antenna for Satellite Tuner
                009 - Open or Short to Ground
    Address 15: Airbags        Labels: 8H0-959-655-84.lbl
       Part No: 8H0 959 655 D
       Component: Airbag 8.4EC        0015
       Coding: 0010105
       VCID: 3B7511F5791689978C-515E
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 01141
       Shop #: WSC 00672
       VCID: 3E7318E13A049CBFAB-4B00
       Part No SW: 8H0 920 980 S    HW: 8H0 920 980 S
       Component: KOMBI+WFS 3     H12 0020
       Revision: 0020        Serial number: AUX6Z0D0436780
       Coding: 0001231
       Shop #: WSC 19346 002 1048576
       VCID: 3F8D65E56D0E95B7A0-515E
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8E2.lbl
       Coding: 0001231
    Address 26: Auto Roof        Labels: 8H0-959-255.lbl
       Part No: 8H0 959 255
       Component:  VSG  B6 CABRIO     6389
       VCID: 73E5F9D511C601D794-5140
       Part No: 8H0 959 760
       Component: Sitzmemory EE H06   0010
       Coding: 00002
       Shop #: WSC 00065
       VCID: 74E7FAC944C806EF8D-4B00
    02011 - Right Entry Assistance Control Module (J573)
                49-00 - No Communications
    02010 - Left Entry Assistance Control Module (J572)
                79-00 - Please Check Fault Codes
    Address 37: Navigation        Labels: None
       Part No SW: 8H0 035 192 B    HW: 8H0 035 192 B
       Component: RNS-E US3       H53 0110
       Revision:      03S    Serial number: AUZBZ7E1700297
       Coding: 0419133
       Shop #: WSC 03751 444 57240
       VCID: 2643D0819294247FC3-517C
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 89
                        Date: 2004.06.22
                        Time: 00:38:05
                        Mileage: 655350 km
                        Count: 2206
                        Clock: 00:37
       Part No: 8H0 959 433 E
       Component: Komfortgerát T7B    3320
       Coding: 11788
       Shop #: WSC 00672
       VCID: 366300C1123454FF73-4B1A
       Subsystem 1 - Part No: 8H1959801B
       Component: Tőrsteuer.FS BRM 3020
       Subsystem 2 - Part No: 8H1959802B
       Component: Tőrsteuer.BF BRM 3020
       Subsystem 3 - Part No: 8H0959801A
       Component: Tőrsteuer.HL BRM 0002
       Subsystem 4 - Part No: 8H0959802A
       Component: Tőrsteuer.HR BRM 0002
       Part No: 4Z7 907 357
       Coding: 00070
       Shop #: WSC 00672
       VCID: 0407AA091468366FBD-4B1A
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0419133
       VCID: 2643D0819294247FC3-5198
                        Reset counter: 89
                        Date: 2004.06.22
                        Time: 00:38:05
                        Mileage: 655350 km
                        Count: 2206
                        Clock: 00:37
    Address 63: Entry Assist,D        Labels: None
       Part No: 8H0 959 760 A
       Component: EasyEntry F M H13   0010
       Coding: 00006
       Shop #: WSC 00065
       VCID: 356107CD0F325FE77A-4B00
    End-------------------------(Elapsed Time: 05:52)--------------------------
  9. Likes Uwe liked this post
  10. #9
    Aug 2016
    S4 8H cab 2005 ABS 00301 return flow pump (V39) - Is the answer 42?
    More observations: The isolated ABS pump motor draws from 11 amps at starting inrush to 5 amps after 20 seconds. It draws slightly less when the opposite polarity is applied. I re-checked pins pins 2, 6, and 23 for voltage, and good grounds at pin 1 and pin 5, plus the parking brake circuit pin 38 as well - all have the proper ground or voltage. tested cold as well as hot, with the ABS controller physically removed so that I could access the spring pins.
    The system started off this morning, cold, by passing the VCDS ABS function test (Hurray!) which operated the pump for about 10 seconds. All codes cleared. It then failed on the road again as before, but at a higher MPH - this time 20 MPH. I threw the controller in the freezer for 2 hours and tried again - it didn't pass the functional test, but it ran for 5 seconds before stopping.
    What causes the function test to turn on the ABS pump, and when does it stop the pump? What stops it - a pressure reading? Time?
    When it fails (red BRAKE light begins flashing) on the road, I hear a click at the same time from near the a pillar below the dash. Sound like a relay. That click happens at 10 MPH regardless. What turns on at 10 MPH? Auto locking? Cabriolet top actuation denial? How does all this stuff work? What is the meaning of life? Is the answer really 42? Wait...must take break...family looking at me funny...
    Cheers,
    RichS
  11. Likes NZDubNurd liked this post
  12. #10
    Mechanical fault in manifold or for return of pump flow being faulty pump?
    Weak grounds?
    Did you check fuses yet or for firmware updates?
    http://wiki.ross-tech.com/wiki/index.php/00301
