Results 1 to 3 of 3
Thread: VW Tiguan 2010 5N
    Sep 2019
    Ecuador
    VW Tiguan 2010 5N
    Hello, This is my first post and hope to learn a lot from this amazing community. The problem that we have with this VW Tiguan is that we wanted to change the Instrument Cluster with a used one. One of the mechanics who was given this job installe the used Instrument Cluster wihout making an Autoscan first, so the ABC control module has lost its coding. Can somebody help me to figure out the code that we need? Thanks for your help!!
    Wednesday,18,September,2019,16:43:24:09355
    VCDS Version: 18.9.1.0 (x64) Data version: 20190114 DS296.0
    VIN: WVGZZZ5NZ9W519664   License Plate:
    Chassis Type: 5N (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 53 56 62 72
    VIN: WVGZZZ5NZ9W519664   Mileage: 105070km-65287miles
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 HC    HW: 03L 906 022 G
       Component: R4 2,0L EDC 0000AG  3018
       Revision: 13H01---    Serial number: VWX7Z0H83NG0WO
       Coding: 0000175
       Shop #: WSC 03428 873 89750
       VCID: 6DDB356474B5752206-8038
    6 Faults Found:
    000115 - Sensor for Ambient Air Temperature (G17)
                   P0073 - 000 - Signal too High
                        Mileage: 105077 km
                        Time: 01:11:00
                        Voltage: 10.94 V
                        Temperature: 24.3°C
                        Temperature: 22.5°C
                        Temperature: 31.5°C
                        Temperature: 36.9°C
                   U1017 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 105077 km
                        Time: 01:11:01
                        Voltage: 10.94 V
                        Torque: 219.0 Nm
                        Hex Value: 0xFF02
                        Bin. Bits: 00000111
                   U1017 - 000 -
                        Mileage: 105077 km
                        Time: 01:11:01
                        Voltage: 10.87 V
                        Bin. Bits: 00000111
                        Bin. Bits: 00000000
                        (no units): 0.0
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 000 - Supply Voltage - Intermittent
                        Mileage: 105077 km
                        Time: 04:08:20
                        Voltage: 7.37 V
                        Load: 100.0 %
                        Load: 100.0 %
                        Mass Air / Rev.: 1040.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 000 - Implausible Signal - Intermittent
                        Mileage: 105077 km
                        Time: 04:12:33
                        Voltage: 6.08 V
                        Load: 100.0 %
                        Load: 100.0 %
    000258 - Mass Air Flow Sensor (G70)
                   P0102 - 000 - Signal too Low - Intermittent
                        Voltage: 4.94 V
                        Load: 100.0 %
                        Load: 100.0 %
                        Mass Air / Rev.: 750.0 mg/str
       Part No SW: 09G 927 750 FD    HW: 09G 927 750 FD
       Component: AQ 250 6F           1124
       Revision: 00H76000    Serial number:
       Coding: 0000328
       VCID: 78F514300BF7C08AE5-802C
    Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
       Part No SW: 5N0 614 517 K    HW: 5N0 614 517 K
       Component: J104    C2 450 V1   0006
       Revision: --H12---    Serial number: 00000001349098
       Coding: 0010000
       Shop #: WSC 03128 229 100586
       VCID: 3669DA084163F6FA37-8062
    7 Faults Found:
                        Fault Frequency: 17
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 01:11:03
                        Hex Value: 0x0000
                        Voltage: 10.75 V
                        Bin. Bits: 00011111
                        Count: 166
                        Hex Value: 0x0000
    00532 - Supply Voltage B+
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 04:07:29
                        Hex Value: 0x0000
                        Voltage: 7.75 V
                        Bin. Bits: 00000010
                        Count: 112
                        Hex Value: 0x0000
    03201 - Adaptation Overboost
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 04:07:29
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 04:07:29
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 04:07:29
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 04:07:29
    00810 - Sensor 1/2 for Brake Pressure
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 04:07:29
       Part No SW: 1K0 907 044 CT    HW: 1K0 907 044 CT
       Component: ClimatronicPQ35 133 1213
       Revision: 00133026    Serial number: 00000000000000
       VCID: 7BFF0B3C3AC1EB9288-802E
                013 - Check DTC Memory
                000 -  -  - Intermittent
                014 - Defective
       Revision: 00H54000    Serial number: 00000008938875
       Coding: 01880FA300041C0047190000140000000009FF475C400104420000000000
       Shop #: WSC 01367 785 00200
       VCID: 336FE31C5211E3D210-8066
       Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 200908  012 0203
       Coding: 00038805
       Shop #: WSC 01367
                        Reset counter: 166
                        Mileage: 105077 km
                        Voltage: 8.80 V
                        Reset counter: 166
                        Mileage: 105077 km
                        Voltage: 5.00 V
    01598 - Drive Battery Voltage
                        Reset counter: 166
                        Mileage: 94403 km
                        Voltage: 13.00 V
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__200 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DPK4WKVS
       Coding: 0012336
       VCID: 3B7FCB3C7A412B92C8-806E
       Subsystem 1 - Serial number: 6333FTS600092428
       Subsystem 2 - Serial number: 6343FTS645642408
       Subsystem 3 - Serial number: 6353ETS62PN3VVNR
       Subsystem 4 - Serial number: 6363ETS645N7VVNR
                        Reset counter: 166
                        Mileage: 105077 km
                        Time: 03:56:10
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                        Fault Status: 11100001
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 01:11:21
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 01:11:21
    00589 - Airbag Igniter 1; Passenger Side (N131)
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 01:11:21
       Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
       Coding: 0010012
       VCID: 77F7170C06E9CFF2EC-8022
       Part No SW: 5N0 920 870 D    HW: 5N0 920 870 D
       Component: KOMBIINSTRUMENT VDD 2420
       Revision: V0004000    Serial number: VWX7Z0H83NG0WO
       Coding: 0001102
       Shop #: WSC 32662 210 01865
       VCID: 3163E914A80DD1C262-8064
    00771 - Fuel Level Sensor (G)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 00:05:53
    00438 - Fuel Supply Sensor 2 (G169)
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 00:05:53
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 00:05:53
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 090908F1002178
       Coding: FD827F060002026002
       VCID: 356BDD045C65FDE23E-8060
       Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
       Component: Haldex 4Motion      0041
       Coding: 0000005
       VCID: 4B9F9BFC2AE19B1278-801E
       Component: IMMO            VDD 2420
       Part No SW: 5N0 959 701     HW: 5N0 959 701
       Component: Tuer-SG         006 1205
       Coding: 0000188
       VCID: 72E126186D8BAADADB-8026
       Part No SW: 5N1 909 144 G    HW: 5N1 909 148 E
       Component: J500__APA-BS KL.097 0401
       Revision: 1AH01251    Serial number: 00080510010602
       Coding: 0000258
       Shop #: WSC 01287 785 00200
    01288 - Terminal 30; Steering Assist
                        Fault Status: 00101011
                        Fault Priority: 9
                        Reset counter: 166
                        (no units): 2.0
                        Voltage: 11.40 V
    02546 - Steering Limit Stop
                        Fault Status: 11100101
                        Reset counter: 126
                        (no units): 4.0
                        Voltage: 12.40 V
                        Reset counter: 166
                        Mileage: 105077 km
                        Time: 04:13:19
                        Voltage: 0.10 V
                        Voltage: 6.10 V
                        Voltage: 0.10 V
                            Not Occup.
                            Not Occup.
    01312 - Powertrain Data Bus
                        Reset counter: 166
                            Term 15 Off
                        Speed: 50.0 km/h
                        (no units): 4.0
                        Voltage: 14.10 V
       Component:    KSG PQ35 G2  020 0205
       Coding: 81800A0052830C7F3F04840570084FCEF0FC00
       VCID: 030F73DC42319352C0-8056
       Subsystem 2 - Part No: 1K8 951 171
       Component: DWA-Sensor      001 0104
    01134 - Alarm Horn (H12)
                        Reset counter: 126
                        Mileage: 105077 km
                        Time: 01:12:47
                        Fault Status: 00110010
                        Reset counter: 166
                        Mileage: 105077 km
                        Time: 04:04:09
       Part No SW: 5N0 959 702     HW: 5N0 959 702
       Coding: 0000188
       VCID: 73EF231C1291A3D2D0-8026
       Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
       Component: J540 EPB3  VW-09384 0005
       Revision:   H09       Serial number: 00000000134967
       Coding: 0010000
       VCID: 2E59F268B933CE3A7F-807A
                        Fault Status: 11101101
                        Fault Frequency: 11
                        Reset counter: 126
                        Mileage: 105077 km
                        Voltage: 10.60 V
                        Count: 71
                        Hex Value: 0x12C1
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                000 -  -  - MIL ON
                        Fault Status: 11110000
                        Reset counter: 126
                        Mileage: 277995 km
                        Voltage: 10.60 V
                        Count: 100
                        Hex Value: 0x1251
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                000 -  -  - MIL ON
                        Reset counter: 126
                        Mileage: 277995 km
                        Voltage: 10.60 V
                        Count: 43
                        Hex Value: 0x1251
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Fault Status: 11110101
                        Reset counter: 126
                        Mileage: 277995 km
                        Voltage: 10.60 V
                        Count: 101
                        Hex Value: 0x1251
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Reset counter: 166
                        Mileage: 105077 km
                        Voltage: 8.30 V
                        Count: 50
                        Hex Value: 0x1241
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
       Component: Radio PM6       125 0037
       Revision: 00125000    Serial number: VWZ5Z7H2261149
       Coding: 0040401
       VCID: 2A51FE7885DBA21AA3-807E
                        Reset counter: 166
                        Mileage: 105077 km
                        Time: 03:56:25
       Part No SW: 5N0 959 703     HW: 5N0 959 703
       Component: Tuer-SG         006 1301
       Coding: 0000144
       Shop #: WSC 01367 785 1012552
       VCID: 74ED2000179FA4EAC9-8020
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
       Part No SW: 5N0 959 704     HW: 5N0 959 704
       Coding: 0000144
       VCID: 75EB1D041CE5BDE2FE-8020
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
    End-------------------------(Elapsed Time: 02:02)--------------------------
    VCDS seems to be working fine (despite needing an update). Moving to Car Repair Support.
    Sep 2019
    Ecuador
    Well, I managed to programm everything with an old autoscan that we had from the same car. The only thing that we have now is this code:
    Reset counter: 126
    Mileage: 105077 km
    Date: 2000.00.0
    I tried to go to channel 21, but there is no communication. Any suggestions on how to do the basic setting?
    Thanks for your help.
