Results 1 to 4 of 4
Thread: AUDI A3 8V 2013 CAN'T ACTIVATE COMING HOME/LEAVING HOME OPTION
    Sep 2019
    Croatia
    Hello all, NEW to the forum so sorry for mistakes if there will be some
    I need help with CH/LH options on my Audi A3 8V 2013 who doesn't have AUTOmatic headlights.
    here is my auto-scan:
    Thursday,19,September,2019,15:50:53:60999
    VIN: WAUZZZ8V4E1043014   License Plate:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
    VIN: WAUZZZ8V4E1043014   Mileage: 72211km-44869miles
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 7544
       Revision: 83H22---
       Coding: 02190012030401082000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TDI01104L906021DS 002012
       ROD: EV_ECM20TDI01104L906021DS_002.rod
       VCID: 79AE16DB7957B6BF8D7-802C
       Revision: 00000000    Serial number: 61244000000374
       Coding: 13F162A224240A6F0177060141C729C846245080608294F2006100040608
       VCID: 7BA20CD3736B84AF9FB-802E
       Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
       Revision: 20026000    Serial number: 00000000317145
       Coding: 03000104002000011000000000001100
       VCID: 323CE1F7E4A185E70CD-8066
       Serial number: 3DE88927000000000001
    328964 - Motor for Front Air Distribution Flap
              B1091 71 [008] - Actuator stuck
                        Reset counter: 172
                        Mileage: 71605 km
                        Date: 2019.09.09
                        Time: 07:02:20
                        Voltage terminal 30: 14.3 V
                        Interior temperature: 24.2 °C
                        Outside air temperature: 20.5 °C
                        Front air distribution flap: actual value: 0
                        Front air distribution flap: actual value: 100.0 %
                        Front air distribution flap: specified value: 99
       Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
       Component: BCM MQBAB H   H16 0124
       Serial number: 00011412500024
       Coding: 04040A42C24120DD43804004001807A80000000000000000000000000000
       ROD: EV_BCMBOSCH_012.rod
       Component: WWS371 140422  042 0585
       Serial number:         140429093627
       Coding: 0A47F7
       Light switch:
       Subsystem 2 - Part No SW: 8V0 941 531 J    HW: 8V0 941 531 J
       Serial number: 17 07 2013  00000412
       Subsystem 3 - Part No SW: 8U0 955 559     HW: 8U0 955 559
       Serial number: 20728339
       Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H09 0033
       Revision: --------    Serial number: 60831411901120
       Coding: 0000040001
       ASAM Dataset: EV_EPHVA14AU3700000 002018
       VCID: 3828D3DF02DD6FB7329-806C
       Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
       Component: AirbagVW20    014 0385
       Serial number: 003MMR019AZ0
       Coding: 98CCC000000000005C540000004800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 00587B3F1A8DE777CA9-8054
       Subsystem 1 - Part No SW: -----------    HW: 480 000 705 14
       Serial number: 357670000009B790CF05
       Subsystem 2 - Part No SW: -----------    HW: 480 000 705 14
       Serial number: 3586700000024590CF0X
       Subsystem 3 - Part No SW: -----------    HW: 480 402 804 14
       Serial number: 3516502B9157E992924I
       Subsystem 4 - Part No SW: -----------    HW: 480 402 804 14
       Serial number: 3526502C1157E99431AD
       Subsystem 5 - Part No SW: -----------    HW: 480 401 103 14
       Serial number: 3556502A114476B4506%
       Part No SW: 8V0 953 521 BT    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 08051404220060
       Coding: 8008
       ROD: EV_SMLSKLOMQB_010_AU37.rod
       VCID: 0D46520B5DDFBA1FB1F-8058
       Part No SW: 8V0 920 870 H    HW: 8V0 920 870 H
       Component: KOMBI         H03 2220
       Coding: 078419002A80000801008800100000
       VCID: 40D8BB3F5A0D27778A9-8014
       Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2163
       Revision: --------    Serial number: 10051410800070
       Coding: 030100040B0876005B000248080B00000001000000000000000000000000
       ASAM Dataset: EV_GatewConti 010015
       ROD: EV_GatewConti_010.rod
       VCID: 3FDAB8C327F3588FF33-806A
       Serial number: 12 04 2014  B0253472
       Serial number: 9565363303
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 08051404080367
       Coding: 001C0E204000040000001002
       VCID: 3E24C5C720F95187F85-806A
       Component: EPS_MQB_ZFLS  123 1043
       Coding: 8103
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 41DEBE3B51072E7F857-8014
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 07051406070833
       Coding: 001C06204000040000001002
       VCID: 3D26C2CB2DFF4A9FE1F-8068
       Coding: 0198000001000000
       VCID: 75B61AEB554FD2DFE9F-8020
    Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-ENT1.clb
       Part No SW: 8V0 035 889 B    HW: 8V0 035 889
       Component: MU-E--ER      180 0150
       Revision: --------    Serial number: 000090729701000
       Coding: 01730100FF00000010110001000A0000000001040100010000
       ASAM Dataset: EV_MUEnt4CCONT 004052
       ROD: EV_MUEnt4CCONT.rod
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9EY3038YU
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614     HW: 8V0 919 614
       Component: ControlUnit_B  H33 0037
       Serial number: C1000013031400010210
       Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0025
       Serial number: 27041401100707
       Coding: 000C06204000040000001002
       Component: TSG HBFS      020 0025
       Serial number: 27041402090705
    End----------(Elapsed Time: 01:16, VBatt start/end: 12.1V/12.1V)-----------
    ^^^ so- coming home should be able to be implemented - but without a light sensor, traditional leaving home isn't possible.
    However, it is possible to implement a form of leaving home on MQB vehicles (like yours) by programming into the relevant exterior lamps the "Leuchte" command for the interior light. This will mean that when you unlock the car with your remote, both the interior light and the programmed exterior lights will illuminate (regardless of ambient light conditions). BUT (and there is always a but) the length of time that the LH lights are illuminated won't be as long as traditional LH function.
  3. Likes Uwe liked this post
    Sep 2019
    Croatia
    Tried with "Leuchte" function but it is now working now when I put lights on 0 there is low beam + position lights ( i guess tiny led lights) are both working and before adaptation, there was only LED tiny light.
    Not entirely sure that I understand - but all the information that's needed is in your BCM (the module @ address hrex09). Probably the best way to move forward is for you to post-up a copy of the adaptation channel map for the BCM on your car.
    If you are not familiar with this process - from the Main Screen, select Applications- then select Controller Channel Map -then setup the parameters in the dialogue box as shown below -then press the Go button
    After the process is completed - exit VCDS -then navigate to C:/VCDS/Logs on your laptop- there should be a new file in this place titled adpmap-09-5Q0-937-084-AE_WAUZZZ8V4E1043014.CSV - open this file with an application like MS notepad - copy the entire contents of the file to the clipboard.
    Finally, start a new post here and as a personal favor to me and because I like denying Uwe his normal pleasure of adding code tags to posted data -first type "[code]" -then paste the data from the clipboard- then type "[/code]"
  6. Likes Uwe, PetrolDave, Bruce liked this post
