Hello all, NEW to the forum so sorry for mistakes if there will be some
I need help with CH/LH options on my Audi A3 8V 2013 who doesn't have AUTOmatic headlights.
here is my auto-scan:
Thursday,19,September,2019,15:50:53:60999
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8V4E1043014 License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V4E1043014 Mileage: 72211km-44869miles
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H22 7544
Revision: 83H22---
Coding: 02190012030401082000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TDI01104L906021DS 002012
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79AE16DB7957B6BF8D7-802C
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 61244000000374
Coding: 13F162A224240A6F0177060141C729C846245080608294F2006100040608
VCID: 7BA20CD3736B84AF9FB-802E
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000317145
Coding: 03000104002000011000000000001100
VCID: 323CE1F7E4A185E70CD-8066
Serial number: 3DE88927000000000001
328964 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator stuck
Reset counter: 172
Mileage: 71605 km
Date: 2019.09.09
Time: 07:02:20
Voltage terminal 30: 14.3 V
Interior temperature: 24.2 °C
Outside air temperature: 20.5 °C
Front air distribution flap: actual value: 0
Front air distribution flap: actual value: 100.0 %
Front air distribution flap: specified value: 99
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011412500024
Coding: 04040A42C24120DD43804004001807A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 140422 042 0585
Serial number: 140429093627
Coding: 0A47F7
Subsystem 2 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
Serial number: 17 07 2013 00000412
Subsystem 3 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20728339
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831411901120
Coding: 0000040001
ASAM Dataset: EV_EPHVA14AU3700000 002018
VCID: 3828D3DF02DD6FB7329-806C
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 014 0385
Serial number: 003MMR019AZ0
Coding: 98CCC000000000005C540000004800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 00587B3F1A8DE777CA9-8054
Subsystem 1 - Part No SW: ----------- HW: 480 000 705 14
Serial number: 357670000009B790CF05
Subsystem 2 - Part No SW: ----------- HW: 480 000 705 14
Serial number: 3586700000024590CF0X
Subsystem 3 - Part No SW: ----------- HW: 480 402 804 14
Serial number: 3516502B9157E992924I
Subsystem 4 - Part No SW: ----------- HW: 480 402 804 14
Serial number: 3526502C1157E99431AD
Subsystem 5 - Part No SW: ----------- HW: 480 401 103 14
Serial number: 3556502A114476B4506%
Part No SW: 8V0 953 521 BT HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 08051404220060
Coding: 8008
VCID: 0D46520B5DDFBA1FB1F-8058
Part No SW: 8V0 920 870 H HW: 8V0 920 870 H
Component: KOMBI H03 2220
Coding: 078419002A80000801008800100000
VCID: 40D8BB3F5A0D27778A9-8014
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M
Component: GW MQB High 212 2163
Revision: -------- Serial number: 10051410800070
Coding: 030100040B0876005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti_010.rod
VCID: 3FDAB8C327F3588FF33-806A
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Serial number: 12 04 2014 B0253472
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 9565363303
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 08051404080367
Coding: 001C0E204000040000001002
VCID: 3E24C5C720F95187F85-806A
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41DEBE3B51072E7F857-8014
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 07051406070833
Coding: 001C06204000040000001002
VCID: 3D26C2CB2DFF4A9FE1F-8068
Component: LWR-ECU 005 0080
Coding: 0198000001000000
VCID: 75B61AEB554FD2DFE9F-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-ENT1.clb
Part No SW: 8V0 035 889 B HW: 8V0 035 889
Component: MU-E--ER 180 0150
Revision: -------- Serial number: 000090729701000
Coding: 01730100FF00000010110001000A0000000001040100010000
ASAM Dataset: EV_MUEnt4CCONT 004052
ROD: EV_MUEnt4CCONT.rod
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY3038YU
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 HW: 8V0 919 614
Component: ControlUnit_B H33 0037
Serial number: C1000013031400010210
Part No SW: 5Q0 959 395 B HW: 5Q0 959 395 B
Component: TSG HFS 020 0025
Serial number: 27041401100707
Coding: 000C06204000040000001002
Component: TSG HBFS 020 0025
Serial number: 27041402090705
End----------(Elapsed Time: 01:16, VBatt start/end: 12.1V/12.1V)-----------
