Results 1 to 7 of 7
Thread: A6 2014 ABS coding
Hybrid View
    Verified VCDS User Pedja's Avatar
    Dec 2015
    Serbia
    A6 2014 ABS coding
    please help coding.
    Friday,20,September,2019,09:25:49:64546
    VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
    VIN: WAUZZZ4G1EN161697   License Plate: 4G NIKOLA KARAVAN
    Mileage: 188378km-117052mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 3B 42 44 46 52 53 55 56
              5F 62 69 6C 6D 72
    VIN: WAUZZZ4G1EN161697   Mileage: 188378km-117052miles
    Address 01: Engine (J623-CGLD)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 HA    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9978
       Revision: 45H25---
       Coding: 12034012243401080000
       Shop #: WSC 44623 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018HA 003011
       ROD: EV_ECM20TDI01103L906018HA.rod
       VCID: 70ACD6A1AB5F31CF69-8024
              U1113 00 [039] - -
                        Mileage: 188378 km
                        Date: 2019.09.18
                        Time: 00:15:22
                        Engine speed: 889.00 /min
                        Normed load value: 31.4 %
                        Coolant temperature: 54 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 13.660 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 129
                        Cruise Control System (CCS): status-Bits 0-7: 44
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
              U1113 00 [039] - -
                        Mileage: 188378 km
                        Date: 2019.09.18
                        Time: 00:15:22
       Part No SW: 4G1 927 155 P    HW: 0AW 927 156 K
       Component: 0AW_20TDI_RdW H06 0004
       Revision: --H06---    Serial number: 0000001515
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_TCMVL381 A02433
       ROD: EV_TCMVL381.rod
       VCID: 393A2B85B8A5B0879E-806C
       Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
       Component: ESP PREMIUM   H09 0450
       Coding: 00000000000000000000
       VCID: 3A383489BDA3BB9F97-806E
       Part No SW: 4H0 907 064 EN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0521
       Coding: 01A93006000000000000
       VCID: 79BAEB85F0257087DE-802C
       Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
       Component: KLIMA 4 ZONEN H14 0096
       Serial number: 06051400041985
       Coding: 34020078A1
       ASAM Dataset: EV_AirCondiComfoUDS 004003
       ROD: EV_AirCondiComfoUDS_004.rod
       VCID: 6A98C4C98D83CB1F27-803E
       Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
       Revision: 20012002    Serial number: 00000001740894
       Coding: 2600201040349FE00181008300001D0C0F9CE70826090201000008606101
       VCID: 6E90C8D9B96B273F7B-803A
       Component: WWS57X 140423  H37 0080
       Serial number:         140426024437
       Coding: 0045F7
       Serial number: 22599590
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
       Component: E1 - LDS  H07 0044
       Serial number: 30 04 2014  00000454
       Serial number: 5AA88827000000000001
       Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
       Revision: 11001001    Serial number: 61061412801817
       Coding: A9C308
       VCID: 71AAD3A5A05538C766-8024
       Revision: --------    Serial number: 003JG00HUJFX
       Coding: 3032343631324E303039554A304C34473053
       VCID: 362020B989BB5FFF73-8062
       Serial number: 3575HRB405N2M1H61P9I
       Serial number: 3585HRB405F2KAFQ6G2P
       Serial number: 3515JRB401652JN2HH94
       Serial number: 3525JRB400O52JN2J95C
       Serial number: 3554VRB401450VL051I4
       Serial number: 3564VRB401I50VVKCH3E
       Revision: 00000000    Serial number: 20171005000023
       Coding: 000015
       Shop #: WSC 28528 002 1048576
       VCID: 302C16A163DF71CF29-8064
       Subsystem 1 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
       Part No SW: 4G8 920 932 S    HW: 4G8 920 932 S
       Component: TDieRdw       H58 0622
       Revision: 29460237    Serial number: 658080514596026
       Coding: 13AF10000B4100080D0000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 3FCE459DA6819EB7A0-806A
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001384038
       Coding: 00CD074400
       VCID: 72A8DCA9A55303DF9F-8026
       Serial number: 2319113303
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 1402270000000000046F
       Part No SW: 4G0 919 158 M    HW: 4G0 919 158 M
       Component: KLIMA FOND    H08 0096
       Serial number: 07051400041601
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
       Component: SARA 3D       H03 0056
       Revision: --------    Serial number: EJ1BPA7209V325
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 332619AD9AC94AD754-8066
       Coding: 011C16005C00620002080002
       VCID: 47DE5D7DF651D67718-8012
       Component: RCEPS         H40 0010
       Revision: 00001000    Serial number: 0028536754
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 32281CA965D343DF5F-8066
       Revision: 00002001    Serial number: 0335436500
       Coding: 013A0620A0B930808320090420010F470000000000000000000000000000
       Coding: 011C16005E00620002080002
       VCID: 46C05079F15BCF7FE3-8012
       Component: EPB-4         H03 0015
       Revision: --------    Serial number: 00000001059778
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D120FD57CED1C2702-8078
       Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
       Serial number: 140505-0002-063
       Coding: 112296101002A300
       ROD: EV_HeadlRegulBasic.rod
       Part No SW: 4G0 035 056 J    HW: 4G0 035 056
       Component: Radio U STD   H60 0133
       Revision: AB001007    Serial number: 230EV0E3057349
       Coding: 010003020100000001
       VCID: 281CFEC15B0F390FF1-807C
       Part No SW: 4G0 035 666 N    HW: 4G0 035 666 H
       Component: H-BN-EU       H52 0939
       Revision: --------    Serial number: 189EA0E7581784
       Coding: 050100010103A1EF0580AB3E00000003E00001020000000000
       VCID: 332619AD92C94AD754-8066
       Subsystem 1 - Part No: 8R0 060 884 BK
       Component: EUR 2014  1703
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDED004HR3.
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
       Serial number: 90349NE7000OI
       Component: CD-Database  5571
                        Reset counter: 129
                        Mileage: 188378 km
                        Date: 2019.09.18
                        Time: 00:13:44
                        Bin. Bits: 00000000 10000000
                        Bin. Bits: 00000000 00000000
       Coding: 010814004000620002080002
       VCID: 49DA5B45E04520070E-801C
    Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
       Part No SW: 4G8 907 383     HW: 4G8 907 383
       Component: Anhaenger     H11 0100
       Revision: 5G001001    Serial number: 00008200348043
       Coding: 0109080000000000
       VCID: 71AAD3A5A85538C766-8024
       Part No SW: 4G0 907 441 B    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0061
       Revision: --H08---    Serial number: 525 PA8J44G0MQ
       Coding: 1090005
       VCID: 2600F0F9911B2F7FC3-8072
       Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0143
       Revision: 14003001    Serial number: 124401188
       Coding: 097205C011
       ROD: EV_HDSGAu571.rod
       VCID: 352227B594BD54E77A-8060
    0004 - No Basic Setting
              B2010 00 [137] - -
              [Steuergerät nicht kalibriert]
                        Reset counter: 129
                        Mileage: 188378 km
                        Date: 2019.09.18
                        Time: 00:13:41
                        Voltage terminal 30: 12.17 V
    0114 - Load Space Cover
              B12EF 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 129
                        Mileage: 188378 km
                        Date: 2019.09.18
                        Time: 00:13:41
    End----(Elapsed Time: 01:59, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    I am not sure, but you could try:
    06A1C7016085E380EB00
    Before Coding, first use Security Access: S11820
    Dec 2015
    Serbia
    does not accept encoding
    Was SA accepted ?
    What was the message after coding is saved ?
    First:
    [Options]
    [User Interface and Identification]
    write numbers for wsc, importer, device no.
    For example 12345 123 23456
    [Save]
    [Close VCDS]
    Start VCDS
    Use batterycharger.
    Ignition OFF
    Wait
    Ignition ON
    Try again.
  5. Likes Uwe, Jack@European_Parts, Dana, Pedja liked this post
    Also:
    Please use a battery charger!
  7. Likes Jack@European_Parts liked this post
    Dec 2015
    Serbia
    Coding rejected
    error 13 Incorrect message length or invalid format.
  9. Likes Dana liked this post
  10. #7
    Dec 2015
    Serbia
    06A19F016085F980DB00 coding ok
    Monday,23,September,2019,10:32:56:64546
    Workshop Code: 123 12345 023456
    VIN: WAUZZZ4G1EN161697   License Plate: A6 4G 2014 ABS OK NIKOLA
    Mileage: 188382km-117055mi   Repair Order:
              5F 62 69 6C 6D 72
    VIN: WAUZZZ4G1EN161697   Mileage: 188382km-117055miles
       Revision: 45H25---
       Coding: 06A19F016085F980DB00
       Shop #: WSC 12345 123 23456
       Coding: 34020078A1
       Coding: 0045F7
       Coding: 02006D
       Coding: A9C308
       Coding: 000015
       Coding: 00CD074400
       Voltage stabilizer:
       Coding: 20
       ROD: EV_SARA2.rod
       Coding: 112296101002A300C
       Coding: 1090005
       Coding: 097205C011
              B2010 00 [137] - -
                        Reset counter: 129
                        Mileage: 188382 km
                        Date: 2019.09.21
                        Time: 01:46:35
                        Voltage terminal 30: 13.85 V
                        Reset counter: 129
                        Mileage: 188382 km
                        Date: 2019.09.21
                        Time: 01:46:35
    End----------(Elapsed Time: 02:01, VBatt start/end: 13.9V/14.2V)-----------
  11. Likes Boki Ar, Uwe, Dana, Fredrick Awuor liked this post
