Results 1 to 8 of 8
Thread: Headlight problem...
    Oct 2018
    Getting a standard AFS error beep few seconds after starting a car (2016GTI SE).
    Left headlight is on, low beams, high beams turn on, when toggled. Cornerning light doesn't turn on anymore when making a turn.
    However, I noticed that starting the car, the light beam does not come up from low level to car level, like it used to, for a self test. The left light beam is shining to the side of the road, not toward the center.
    After erasing trouble codes, these still come back:
    Address 55: Headlight Range Labels: 7P6-907-357.clb
     Control Module Part Number: 7P6 907 357 D HW: 7P6 907 357 A
    Component and/or Version: AFS-ECU H07 0090
    Software Coding: 021A01010B000400
    Work Shop Code: WSC 01383 790 50316
    ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120 (VW37)
    VCID: 40D9BC92FA0020478A9-8014
     Fault Codes have been Erased
    U1014 00 [137] - -
    [Steuergeraet falsch codiert]
    Reset counter: 102
    Mileage: 36105 km
    Date: 2019.09.19
    Time: 00:37:59
     5276145 - Power Output Module for Left Headlamp
    C1081 F1 [137] - Incorrectly Coded
    Reset counter: 102
    Mileage: 36105 km
    Date: 2019.09.19
    Time: 00:37:59
     5275220 - Headlight
    Reset counter: 102
    Mileage: 36105 km
    Date: 2019.09.19
    Time: 00:38:00
    In advanced Measuring Values in VCDS:
    Right headlight leveling control value -1.5mm
    Left headlight leveling control value 1022.0mm
    Headlamp power output stage supply voltage 11.4V for both right and left
    Left headlight beam adjusting motor:specif…..5.00%
    Right headlight beam adjusting motor: spe…..0.00%.
    Also, when I compared in the Long Coding window, the right module has a code of 2E0000 but the left module coding is 00000 now. Here is my initial scan before this problem began:
    Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
    Component: LeiMo rechts H01 0004
    Coding: 2E0000
    Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
    Component: LeiMo links H01 0004
    Coding: 2E0000 <------------------*
    * this is now 00000 and any attempt to paste a 2E0000 is met with an error, something like "out of range"...etc. Is the left module dead..and why it throws an error?
    Interestingly, when first starting the car, I do visually see the lens of the left headlight move down, and back up, so it does have power to it, but the lens is all the way to the left, not centered and illuminates left side of the road and oncoming traffic.
    I'm new to all this and the terminology, and not sure how to reset the lens?
    In VCDS, can I set a value somewhere to have the lens be centered? (I'm guessing comparing above leveling control values of right lamp -1.5 vs. left lamp 1022.0mm, is that the reason why the left lamp is cocked to the left?)
    Are there any high level steps I can do in VCDS to reset things to factory settings? (I do have my very first initial AUTO-SCAN log, from which I can grab values for this problem with left headlamp began.)
    Any tests can I run to determine what's the problem? Because of the module not coded correctly, would that be the reason why my cornering lights don't come on anymore?
    Any suggestions, are greatly appreciated.
    Thank you.
    HQ
    Jef
  3. Likes Uwe, Dana liked this post
    16.4905° S, 151.7375° W
    While we are waiting for an Auto-Scan, please try and recode the [55-Headlight Range] controller with the same coding.
    [Software Coding: 021A01010B000400]
    The coding in this controller appears to be plausible, so if the headlights are communicating, they will be re-coded when you re-code the master controller.
    Once the coding is accepted and the coding faults are gone, please follow the Basic Settings procedure on the Ross-Tech wiki page to clear C107E fault code.
    VW MQB Headlight Regulation, Basic Settings
    We still would like to see the Auto-Scan on this vehicle, maybe we could get a before and after?
    Hope this helps,
    drpeter
  5. Likes Uwe, Gremling, Dana liked this post
  6. #4
    Oct 2018
    Thanks for the info, got a chance finally to do an Auto-Scan.
    55-Headlight Range section, has now 5 codes...the other 2 about the Right Swivel module were always present, but headlights worked fine with just those two codes.
    But again, there 3 new left headlight codes, I think are causing basic lighting issues, that the left lamp is cocked to the left. I just drove an hour ago, and during that drive the lamp was not cocked to the left, illuminating left side of the road, instead they were illimunating maybe 10-15 feet infront of the car, not far away as they should...so they do have a life of their own, depending on mood or weather:-)
    I'll proceed to do your coding suggestions..but here is the BEFORE snapshot...once I attemt to code it...I'll post a AFTER snapshot of auto-scan.
    Thanks much!
    Friday,20,September,2019,23:27:10:15924
    VIN: 3VW5T7AU0GM0xxxxx   License Plate:
    Mileage: 9.20.19   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75 A9
    VIN: 3VW5T7AU0GM0xxxxx   Mileage: -22494miles
    Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0004
       Revision: --H13---
       Coding: 091900122424002F1000
       Shop #: WSC 00066 790 00215
       ASAM Dataset: EV_ECM20TFS0205G0906259D 001005
       ROD: EV_ECM20TFS0205G0906259D.rod
       VCID: 2F3BEF2E579EAF3F633-807A
       Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
       Component: ESC           H32 0393
       Revision: 00000000    Serial number: 53165000000469
       Coding: 01FA6BA13424096D007F020381CA2980D62C9000408194B400430050C009
       Shop #: WSC 01383 790 50316
       VCID: 4BC39BBEC346F31F6FB-801E
       Revision: 00021000    Serial number: 0379255716
       Coding: 030C0C
       VCID: 3A2DCE7A9CDC7A97C4D-806E
       Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
       Component: AC Manuell    H02 1001
       Revision: 00001K01
       Coding: 00020004200100000000000000000002
       VCID: 46D5AA8AD8240E77B05-8012
       Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
       Revision: --------    Serial number: 86582909151526
       Coding: 00110A464041A26969E44000001407201800000000000000000000000000
       Shop #: WSC 00066 790 00219
       ROD: EV_BCMBOSCH_015.rod
       VCID: 7AAD0E7ADC5CBA9784D-802E
       Component: WWS    150801  043 0581
       Serial number:         151211183514
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S5Y15M11D19H09M35S27
       Coding: 96A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
       Component: J245 PS60.036  H06 0150
       Serial number: 03691620680808151504
       Coding: 181803
       Serial number: 003GCR03J01
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CBA78EDF2E177F4B3-8012
       Occupant Detection:
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH000000000003W73FK
       Coding: 303131
       Subsystem 2 - Part No SW: -----------    HW: 480 001 510 15
       Serial number: 35700000000B4491671F
       Subsystem 3 - Part No SW: -----------    HW: 480 001 510 15
       Serial number: 358000000003A691671G
       Subsystem 4 - Part No SW: -----------    HW: 480 402 310 15
       Serial number: 3510002BD1CF1D14329A
       Subsystem 5 - Part No SW: -----------    HW: 480 402 010 15
       Serial number: 3520002C71CF1D108185
       Subsystem 6 - Part No SW: -----------    HW: 480 400 309 15
       Serial number: 3550002C71D1B621833/
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 309 15
       Serial number: 3560002C91D1B6237184
       Revision: FF033033    Serial number: 20151015500318
       Coding: 0400
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 04517082AE98FC67EE1-8050
       Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
       Component: KOMBI         342 6420
       Coding: 0BAD0912A980CF0502087E001000000000000000
       Shop #: WSC 00066 790 00221
       VCID: 2C01F8226688D427461-8078
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 11101510521988
       Coding: 0101000830085900FB00002A080F00000001050000000000000000000000
       ROD: EV_GatewConti_013.rod
       VCID: 79AF1176D95AB18F8D7-802C
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29150001917490025397
       Coding: 30FFFF
       Revision: 00000000    Serial number: 15000214153002
       Coding: 5500000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3431E042BEB88CE71E1-8060
       Serial number: 201115060509I4
       Coding: 003E13200000020000000000
       VCID: 43D3B39EEB163B5F97B-8016
       Serial number: 00000000000002349087
       Coding: 011000
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 8102
       VCID: 392FD17699DA718FCD7-806C
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H20 0130
       Revision: 00000001    Serial number: VWZ8Z1FBA0132HT
       Coding: 2200000000AAAAAA000000000000
       ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
       ROD: EV_AMPMst12C1Gen2ALPI.rod
       VCID: 6D8735269D121D2F11F-8038
       Serial number: 20111506050D23
       Coding: 003E13200C00020000000000
       VCID: 42DDB69AF40C32579CD-8016
       Serial number: 00000000000002391874
       Coding: 091000
       Coding: 2E0000
              U1014 00 [137] - -
                        Reset counter: 102
                        Mileage: 36105 km
                        Date: 2019.09.19
                        Time: 00:37:59
                        Reset counter: 102
                        Mileage: 36105 km
                        Date: 2019.09.19
                        Time: 00:37:59
    5275220 - Headlight
                        Reset counter: 102
                        Mileage: 36105 km
                        Date: 2019.09.19
                        Time: 00:38:00
    5278761 - Position Sensor for Right Swivel Module
              C108C 29 [137] - Signal Implausible
                        Reset counter: 102
                        Mileage: 36105 km
                        Date: 2019.09.19
                        Time: 00:38:05
    5278215 - Swivel Module Right
              C108A 07 [137] - Mechanical Failure
                        Reset counter: 102
                        Mileage: 36105 km
                        Date: 2019.09.19
                        Time: 00:38:05
       Part No SW: 3Q0 035 844     HW: 3Q0 035 844
       Component: MU-S-S-US     620 0613
       Coding: 027300000000000051220002001808001F0203F40120010002
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 6C813822A6081427061-8038
       Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
       Component: ABT_Std-2  H52 1028
       Serial number: VWZ8Z9RES0101G
              B11CF 53 [009] - Deactivated
                        Reset counter: 102
                        Mileage: 36105 km
                        Date: 2019.09.19
                        Time: 00:10:15
                        Voltage terminal 30: 11.6 V
                        SDARS_tuner_status_2-Audio Signal: Available
                        SDARS_tuner_status_2-Antenna current: 133 mA
                        SDARS_tuner_status_2-Reception quality: good_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
       Component: OCULowMQBUS   007 0568
       Coding: 02730002C2823A017F1E06000000
       Shop #: WSC 00066 790 07030
       ROD: EV_OCULowMQB.rod
       Serial number: 150916200878
       VCID: 6B833B3EA306131F0FB-803E
    End----------(Elapsed Time: 01:29, VBatt start/end: 12.2V/12.1V)-----------
  7. Likes Dana liked this post
  8. #5
    Oct 2018
    Awesome! That coded the left module 2E0000 code. The lights started working as before, illuminating the road far ahead as they should! Side/cornering lights didn't turn on, when turning the wheel.
    Only 3 codes remained. Then I proceeded to do the Basic Settings and Acknowledge Settings and that got rid of C107E 54 code. That fixed the side/cornering illumination when turning the wheel.
    I'm back in business! Thank you very much, I and many drivers (that I have been blinding with the cocked left lamp) appreciate it greatly:-)
       Coding: 2E0000
       Coding: 2E0000
    5275220 - Headlight
                        Reset counter: 109
                        Mileage: 36202 km
                        Date: 2019.09.20
                        Time: 23:47:00
                        Reset counter: 109
                        Mileage: 36202 km
                        Date: 2019.09.20
                        Time: 23:47:06
                        Reset counter: 109
                        Mileage: 36202 km
                        Date: 2019.09.20
                        Time: 23:47:06
    So the only two codes remain are the Right Swivel Module ones. Since I got the car from the 1st owner, these codes were always present. I always got a beep and yellow caution light, unless I shut off AFS in the Car > Light Settings.
    Is it possible to troubleshoot, recode, reinitialize, replace Swivel motor in the right headlamp? I did see an exploded view of Headlamp parts and one of them being the Swivel motor...that can be bought from VW merchants.
    Can I get to that Swivel motor...take the headlamp apart? At first glance it seems the lamp housing is welded shut, except for few rubber caps in the back.
    I guess I don't fully understand what this swivel motor does, is that the same one that illuminates the sides of the car when cornering? But that function works great!!
    Or is this tied to AFS, when driving at fast speeds and the light swivels and illuminates toward the direction of the gentle turn? Not sure if "AFS"(that throws a beep/error) and "Cornering" lights(which works great!) are one and the same.
    Any advice on how to proceed?
    Thank you very much.
  9. Likes Uwe, Gremling, DrPeter, Dana liked this post
  10. #6
    Cool! - Glad the coding of the [55-Headlight Range] / (J745 controller) worked for you, thanks for the feedback.
    As far as the V319-Right adaptive cornering lamp motor, the Official Factory Repair manual has this to say about it:
    The adaptive cornering lamp motor sits in the headlamp housing and cannot be replaced separately if it is faulty.
    - The parts catalog agrees with this statement, the only motor that is available for replacement is the "range control" motor (up/down movement). The cornering lamp motor is responsible for the side to side movement of the headlight.
    So to answer your question, can you get to it? - Maybe? I would have a good look inside, keep an eye out for wiring/connection concerns as they maybe the cause of the failure.
    Sometimes you can find used/damaged headlights for cheap from accident vehicles where the internals are fine, just the lens/tabs are damaged and you can experiment on the damaged headlight, taking it apart and using it for parts
    Hope this helps,
    drpeter
  11. Likes Dana liked this post
  12. #7
    Oct 2018
    ...the "range control" motor that you mention, is that the "Left/Right Headlamp Beam Adjustment Motor - V48- / -V49-" per repair manual.
    Trying to sort out different naming conventions...if its the same thing. Thanks for your reply.
  13. #8
    Range control = up/down not left/right.
