Results 1 to 10 of 11
Thread: Should I Up date my old cable
    May 2014
    Australia
    Hi
    One of my first posts.
    I'm looking for advice as to whether I should or if I need to up date to the latest Ross-Tech cable. My cable is about 10 years old but still works great. Does the new tool do anything the old one cant do?
    Thanks in advance and apologise if I posted in the wrong area for my question .
    Cheers
    Ron
    Quote Originally Posted by Ron View Post
    If/when you buy a 2019 or later vehicle then you will need either a HEX-V2 or HEX-NET cable (VAG changed so much that it no longer possible to make the older cables such as HEX-CAN work with just software/firmware updates).
    The newer cables are needed with some modules built from 2016 onwards as they use messages that are longer than the older cables can handle.
    The newer cables also scan much faster.
    So if your cable works fine with your current vehicle then there's no need to update (but you might like to), but when you change to a newer vehicle then it's quite likely you will benefit from or need a newer cable.
  3. Likes Uwe, jyoung8607, Dana, myounus liked this post
    As Dave stated in the post above, it very much depends on what vehicle(s) you're working on. Starting at about MY 2015, there are some Adaptation channels in some infotainment systems that the HEX+CAN won't be able to change. Starting at MY 2016 (RDW) and 2017 (NAR), there are some control modules in some models of cars that the HEX+CAN can't access at all. And last, but not least, MY 2019 and newer cars are not supported with the HEX+CAN at all.
  5. Likes PetrolDave, Dana liked this post
    May 2014
    Australia
    Hi, Thanks for the advice guys, I use it in my business so it may be a good idea to up date...... better to have it and not need it yet than not having it and needing it
  7. Likes Uwe, PetrolDave, Dana, myounus liked this post
  8. #5
    Verified VCDS User RUZDO.O's Avatar
    Podgorica - MNE
    Does Ross-Tech work to improve: adaptations, coding, basic settings, block measurements, and so on, for cars below 2016?
    What I'm asking is that few people will service with a vcds car from 2016 - 2019, when they have a factory warranty.
  9. Likes Boki Ar liked this post
  10. #6
    Oct 2014
    Arandjelovac, Serbia
    Arrow
    Dear Ruzdo.O, as I know, Ross-Tech work on this job every single day.
  11. Likes Uwe, myounus, Dana liked this post
  12. #7
    Oct 2017
    Northwest UK
    Hi Ron
    I updated mine and love the V2. VCDS is by far the best tool.
  13. #8
    Podgorica - MNE
    The German version of the PCI vcds distributor restricted the use of HEX-CAN with version 17.8.1. Which is the English version of vcds latest for HEX - CAN. Why add a new version of vcds when the new data is not recognized by HEX - CAN.
  14. #9
    Quote Originally Posted by RUZDO.O View Post
    Huh? Please explain what you mean. There has been nothing that worked before restricted in any new version. Moreover, a distributor simply does not have the ability to do that.
  15. #10
    Podgorica - MNE
