Results 1 to 7 of 7
Thread: DPF pressure sensor adaptation procedure (BRE engine)
    Jan 2016
    Norway
    audi 2006 A6 Avant (4F5, C6) 2.0tdi pd bre vin WAUZZZ4F16N155133
    how to do adaptation for dpf and dpf pressure sensor??
    vcds didnt have map for this ecu.
    and everything i need to do manually...
    First thing we need to answer those questions is for you to post an Auto-Scan.
  3. Likes Uwe, Jack@European_Parts liked this post
    Jan 2016
    Norway
    Thursday,19,September,2019,18:41:40:61642
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUZZZ4F16N155133   License Plate:
    Chassis Type: 4F (4F0)
    Scan: 01 03 05 07 08 09 0E 15 16 17 18 19 37 42 46 47 4F 52 53 55
              56 61 62 69 72 77
    VIN: WAUZZZ4F16N155133   Mileage: 201330km-125100miles
       Part No SW: 03G 906 016 GB    HW: 03G 906 016 GB
       Component: R4 2,0L EDC G000SG  9663
       Revision: --H02---    Serial number:
       Coding: 0020072
       Shop #: WSC 00011 888 81093
       VCID: 69D9DE7E408928072E-803C
    001139 - Exhaust Pressure Sensor 1
                   P0473 - 000 - Signal too High
                        Mileage: 201338 km
                        Date: 2019.09.19
                        Time: 18:39:27
                        Voltage: 11.86 V
                        Mileage: 10 km
                        Temperature: 36.0°C
                        Absolute Pres.: 999.6 mbar
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
       Component: ESP 8.0 front   H05 0090
       Coding: 0004471
       Shop #: WSC 02325 785 00200
       VCID: 2C57676A8FFBFD2F15-8078
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10604000355589
       Coding: 0000129
       Shop #: WSC 35228 001 1048576
       VCID: 63C5CC56A2A57257E4-8036
       Subsystem 1 - Part No: 4F0 910 131 D
       Component: FBSAUDIC6 IDG   H39 0040
       Part No SW: 4F0 910 730 F    HW: 4E0 035 729
       Component: Interfacebox    H43 2120
       Revision: 00000000    Serial number: 350BF067653060
       Coding: 0001001
       Shop #: WSC 02335 785 00200
       VCID: 24478F4AE72B356FDD-8070
       Component: Bedienteil MMIC6H08 0050
       Subsystem 2 - Serial number: 00000000343899
       Subsystem 3 - Serial number: 0116.02.060000000100011212˙
       Subsystem 4 - Serial number: 011212˙
       Part No SW: 4F0 910 043     HW: 4F1 820 043 S
       Component: KLIMABETAETIGUNGH12 0170
       Revision: 00000030    Serial number: 00000000234270
       Coding: 0002324
       VCID: 5BB5F4B69AD54A97AC-800E
                        Fault Status: 00101010
                        Reset counter: 6
                        Mileage: 200949 km
                        Date: 2019.09.04
                        Time: 17:24:32
                        Temperature: 18.0°C
       Part No SW: 4F0 910 279 D    HW: 4F0 907 279
       Component: ILM Fahrer      H15 0190
       Coding: 0002121
       VCID: 2A5B6172850FE31FE7-807E
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Component: REGENLICHTSENSORH11 0050
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBF8062634
       VCID: 1C37B7AADF5B0DAF65-8048
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 43 AIRBAG AUDI8RH29 0280
       Revision: 08H29000    Serial number: 0037LD0D5SJN
       Coding: 0013363
       VCID: 29599E7E8009E807EE-807C
       Subsystem 1 - Serial number: 6332CSME0E3E630CD
       Subsystem 2 - Serial number: 6342CSME0E193440/
       Subsystem 3 - Serial number: 6352QSME054B3447F
       Subsystem 4 - Serial number: 6362QSME0430211F4
       Subsystem 5 - Serial number: 63734SME09724B0F6
       Subsystem 6 - Serial number: 63834SME097A2E63A
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90026060380193
       Coding: 0002042
       Shop #: WSC 02323 785 00200
       VCID: 66C3D5425197077F03-8032
       Part No SW: 4F0 910 930 A    HW: 4F0 920 931 B
       Component: KOMBIINSTR. M73 H17 0660
       Revision: 00200000    Serial number: 4PT54ZD26
       Coding: 2052143
       Shop #: WSC 80093 222 69422
       VCID: 2149865EF8392047B6-8074
    Address 18: Aux. Heat        Labels: None
       Part No SW: 4F0 910 105 A    HW: 4F0 265 081 L
       Component: Heizgeraet      H08 0060
       Revision:        B    Serial number: 09011480
       Coding: 0000111
       VCID: 1B35B4B6DA550A976C-804E
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 1300806204806D
       Coding: 6DEE73C61B3104
       Shop #: WSC 02334 785 00200
       VCID: 275D9846961DDE77F8-8072
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
       Component: MNS ECE         H47 1060
       Revision: 00000000    Serial number: 364BQ067531980
       VCID: 3B7554367A956A978C-806E
       Part No SW: 4F0 910 793 F    HW: 4F0 959 793 F
       Component: TSG FA          H21 0050
       Coding: 0001546
       Shop #: WSC 02327 785 00200
       VCID: 2D516A6EB4E1F42702-8078
       Part No SW: 4F0 910 289 F    HW: 4F0 907 289 F
       Component: Komfortgeraet   H19 0140
       Revision: 01400019    Serial number: 01010666820000
       Coding: 0131717
    Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
       Part No SW: 4F0 910 223 C    HW: 4F0 035 223
       Component: Amp.-ASK        H10 0320
       Revision: 33S00001    Serial number: 01402060222818
       Coding: 0000108
       VCID: 1E33BDA2C9471FBF8B-804A
       Part No SW: 4F0 910 280     HW: 4F0 907 280
       Revision:             Serial number: 00000000120852
       Coding: 0001004
       VCID: 5EB3FDA289C75FBFCB-800A
       Part No SW: 4F0 910 792 F    HW: 4F0 959 792 F
       Component: TSG BF          H21 0050
       Coding: 0001546
       Part No SW: 4F0 910 801 A    HW: 4F0 907 801
       Component: EPB  CA3C0040   H03 0040
       Revision: --H03---
       Coding: 0000111
       Shop #: WSC 00000 785 00200
       Part No: 8P0 907 357 C
       Coding: 0000003
       VCID: 3A7B513275AF539F97-806E
       Part No SW: 4E0 910 541 L    HW: 4F0 035 541 E
       Component: TUNER EU/US/RDW H42 0560
       Revision: 00000000    Serial number: 352BK067624452
       Revision: 00000000    Serial number: 00000000025199
       Shop #: WSC 22222 111 59065
       VCID: 23458C56E2253257A4-8076
       Component: von VA0  1602051024
       Coding: 344630393135313035442056413031363032303531303234
       Shop #: WSC 00000 384 00290
    02272 - Quiescent Current Stage 1
                        Mileage: 201325 km
                        Date: 2019.09.18
                        Time: 22:51:40
       Part No SW: 4F0 910 795 F    HW: 4F0 959 795 F
       Coding: 0001026
       VCID: 2F6D7066BEED863730-807A
    Address 69: Trailer        Labels: 4F0-910-383.lbl
       Part No SW: 4F0 910 383     HW: 4F0 907 383
       Component: ANHAENGERELEKTR H02 0020
       Coding: 0000331
       VCID: 62CBC952BDBF7B5FEF-8036
       Part No SW: 4F0 910 795 F    HW: 4F0 959 794 F
       Coding: 0001026
       Part No SW: 4E0 910 336 F    HW: 4E0 862 335
       Component: Handyvorb2      H13 0580
       Revision: 00000000    Serial number: 00000007614157
       Coding: 0010900
       VCID: 2541924EEC11CC67CA-8070
    End-------------------------(Elapsed Time: 02:27)--------------------------
  5. Likes Uwe liked this post
  6. #4
    Differential Pressure Sensor Adaptation:
    Key on, engine not running. Coding-II: Put in 30605.
    Wait a bit (not sure how long). Then turn off ignition for at least 10 seconds and turn it back on.
    DPF itself:
    Adaptation Channel 12:
    Set New Value to 0.
    You may need to do a Coding II with 12233 in order for this to be possible.
  7. Likes Jack@European_Parts, jyoung8607 liked this post
  8. #5
    Jan 2016
    Norway
    DPF itself:
    Set New Value to 0.
    are you shore?? its not help
  9. #6
    Jan 2016
    Norway
    I will try disconnect batteri and try one more time. In signal kabel is 5,6v and its going from edc....
  10. #7
    Jan 2016
    Norway
    i have adaptation dpf pressure sensor done. The procedure is correct. probably the driver has stopped. it helped to disconnect the battery overnight
    time to wait its about 30s. Thank you very much for your help.
  11. Likes jyoung8607, Uwe liked this post
