Results 1 to 9 of 9
Thread: Latest VCDSToolbox version
    Here is the latest VCDSToolbox test version.
    Latest change log:
    { 19.8.0}
    { Show German umlaut correct}
    { Model info corrections }
    { 19.9.0}
    { A search icon instead of to short text in some languages}
    { Show differences in color for coding read from coding change log }
    { 19.10.0}
    { Show German (and some other UTF) umlaut correct again - file saved with MAC!}
    { 19.11.0}
    { 19.11.1}
    { Alternator information bottom of autoscan }
    On many new CAN Gateways from 2018, there is LIN data for Alternator.
    First try on decryption of the data (a lot is still missing), here an example from Autoscan:
    • Alternator:
    • Component: 4-00-03-00-04
    If Alternator data is available in the Autoscan, it is showed at the bottom of VCDSToolbox screen.
    Amp data are from PR-codes.
  3. Likes Uwe, Boki Ar, NitrousOxide liked this post
    { 19.11.2}
    { Battery hist. correction }
    { 20.01.0}
    { Model info corrections Golf 8 / ID.3}
    { Search for 2-3 character Acronym }
  5. Likes Eric, Uwe, Mats@MFT, NitrousOxide liked this post
    Feb 2016
    Jamaica
    I'm just looking at these screenshots here.
    Does CFW Injector Coding, mean I can now do some calibration to these new Audi S3 injectors that has been giving me a rather lumpy idle on my MK5 GTI (but OEM smooth everywhere else in the revv range)?
    This is special injector coding for CFWA engines.
    Please make a new thread with autoscan about your problem, for coding new injectors.
  8. Likes Uwe liked this post
  9. #6
    { 20.02.0}
    { Model info corrections}
    { Text changed in "Sendscan"} It is not for support
    Definition and English changed a little in GitLab.
    Link is updated in #1.
  10. Likes Uwe, Eric, Boki Ar, downtime liked this post
  11. #7
    { 20.02.1}
    { New Acronyms added}
    { New controller for Battery history}
    { 20.03.0}
    { Program action button failure improved}
    { First test for comparing two UDS Adaptation Channel files}
    Comparing 2 UDS Adaptation Channel files, can be done from different languages, but must be from same controller.
    For comparing you can either choose the two files (In Explorer) and Drag&Drop them into VCDSToolbox.
    Or choose the two files, Right click > Copy, then Right click in VCDSToolbox and choose [Insert (Paste) 2 UDS adaptation files].
    Drag & Drop:
    Right Click:
    Compared:
  12. #8
    May 2014
    ^^^ NEtech: very impressive indeed - yet another in a long list of VCDS triumphs!!!
    May I ask 3x related questions, please?
    First- Sort Criteria: given that most (all?) instances where a user would seek to compare 2 x admaps is to find instances in which the settings are different, is it possible for your App to sort the compare-results by this variable, rather than by Tag number (which I assume is what happens now) - and is it possible to display those channels with different settings first? This would streamline the subsequent user task greatly, especially in modules with a high channel count - like the BCM for modern MQB vehicles (I think).
    And apropos of my third question below - can the sort criteria for channels with different settings separately identify the "missing channels" as a bunch?
    Second- File Export: Is it possible to export the admap compare results from your App- perhaps as a .CSV file?
    Third- Missing Channels: Can you confirm that the "join-string" in what I assume is an SQL search algorithm in your App - will return ALL the channels in BOTH admaps regardless of whether they appear in both admaps (i.e. how does the compare facility handle channels that appear in only 1 x admap and in particular - if the the channel appears only in the 2nd selected admap)? I ask because this scenario has proven problematic for me in the past (but then I'm terrible with SQL queries!!)
    Again - much kudos for simplifying what can be often a tedious process!!
  13. #9
    It is a very simple search/compare, nothing sql or something like that.
    I check which file is biggest, that goes on the left side (I asume it has most lines).
    I just take one line at a time, so it is not possible to do a lot of search hocus Pocus
    If a line is missing on the right that should mostly be found and show empty cell, if there is an line on the right that is not in the left, it should be showed at the end.
    But there are certainly files, where there will be a problem.
    I will think about csv file, thanks.
  14. Likes Uwe, Dana, DV52 liked this post
