Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 101
Thread: Cascade a electrical failures fixed but now no steering angle signal
  1. #51
    Sep 2019
    Alberta, Canada
    I had the door wiring connected and unplugged it because it was doing weird stuff ( interior lights were not coming on) and i wanted to check the wiring.
    then forgot to plug it back in when i did the auto scan.
    its acting exactly the same door wiring plugged in as unplugged.
    did you want another autoscan with the door wiring plugged in ?
    i was checking for steering angle sensing in abs measuring blocks as well as the steering assist and angle = 0
  2. #52
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    I don't know if you have fixed this problem or, you still have it I just wanted to point out one thing which you might have over looked at it is the following the Software Coding in your Steering Module which you have replaced doesn't match with your original coding,
    This is your Original according to your Scan:
    Part No SW: 1K0 953 549 AR HW: 1K0 953 549 AR
    Component: J0527 035 0070
    Coding: 0010021
    VCID: 020193695DE7AA5FB1-8056
    And this is your replacement one..
    Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
    Component: J0527 034 0070
    Coding: 0011021
    VCID: 7AF1EB893537E29FE9-802E
    That could be the reason you having a fault code for the Steering Angle Sensor, I may be wrong but worth looking in to this
  3. Likes Uwe liked this post
  4. #53
    Sep 2019
    Alberta, Canada
    Quote Originally Posted by Ashraf6119 View Post
    Coding: 0010021
    Coding: 0011021
    Part No SW: 1K0 953 549 AL HW: 1K0 953 549 AL
    Component: J0527 036 0070
    Coding: 0010021
    VCID: 7CFDED913F03DCAFFB-8028
    is the original scan
    part number ending in AJ was coded wrong for which steering wheel was in the car and when changed to 0010021 it made no difference
    thanks for the effort in trying to help.
    odd thing is that the steering assist is working fine without steering angle signal.
    as far as i can see this car could be driven as it is with this steering module (the AL) the transmission no longer goes into neutral as it was with the AH even though the
    steering angle signal appears to be the same with either module.
    I have a couple more ideas but once i have used them up i am to the point of giving up unless other suggestions come along.
    matt
  5. #54
    Coding: 0010021
    matt
    Have you traced the tracks and tested the SAS G85 correct location and verified its function with DVOM?
    Show us what you did in WD okay?
  6. #55
    Sep 2019
    Alberta, Canada
    i have not mostly due to the fact i have no wiring diagram
    if you enlightened me as to where to verify function, i am more than capable or operating a digital volt meter
  7. #56
    Don't you see you are your own worst enemy here & it is a problem to not have the RTFB and than raise hands up in luft & saying I give up but I don't have the RTFB?
    I'll see if I can find something, it is the holidays okay?
  8. Likes Ashraf6119 liked this post
  9. #57
    Sep 2019
    Alberta, Canada
    just as a note.
    when the original problem presented with the original steering control module electrical items would get shut down in a predictable order
    heater a/c
    windows
    signal lights
    and the list would continue till almost nothing was working.
    tried a new steering control module ( albeit the wrong part) which made no difference
    at this time (early on) the car could be driven with NO fault codes
    steering angle sensing was NEVER a problem.
    after trying many things, tried by many different people and shops all having failed .
    i am here with the NEW CORRECT steering control module installed in a different column which HAS seemingly solved the original issues
    but has presented this new problem of no steering angle
    my logic still says the problem isnt in wiring or the car side its something to do with the steering control module and or that area.
    why would changing parts around the steering column have created a problem somewhere else ?
    if there is somewhere that i can test to give info for someone who has an idea by all means point me in that direction with instructions so i can return with
    the info needed to come up with an idea.
    i am at a total loss and having been haunted by this car for 4 years when everyone else has given up
    i hate to give up myself but i am within a couple ideas away from giving up .
  10. #58
    Sep 2019
    Alberta, Canada
    another point
    with the AH steering control module installed the steering assist light would flash yellow and orange (i think or yellow and red) and would change
    with steering input, trying to reset steering limits etc the flashing of the light would indicate that something was seeing steering angle input.
    with this CORRECT AL steering control module the steering assist light stays yellow and does not respond at all to steering wheel movement like the AH module did
    which suggests that its not completely happy with the new steering control module.
  11. #59
    just as a note.
    heater a/c
    windows
    signal lights
    another point
    MERRY XMAS!
    ARE YOU GOING TO STOP YOUR BULLSHIT SPECULATION ALREADY?
    https://i.postimg.cc/ssJL1hS7/SAS.png?dl=1
  12. Likes Ashraf6119 liked this post
  13. #60
    Do you see the FOD yet?
  14. Likes Ashraf6119 liked this post
