Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 101
Thread: Cascade a electrical failures fixed but now no steering angle signal
  1. #31
    Sep 2019
    Alberta, Canada
    ok i called the dealer using the vin numbers of both cars the replacement part is the same for both cars
    and is 1K0 953 549 AL
    1K0 953 549 AR is what came in the problem car
    and
    1K0 953 549 AJ came in the known good.
    the parts manager said that they should be interchangeable since they are both replaced by the same part.
    But i am thinking maybe you are right and they are not compatible and the new AL version has software for both where the
    originals dont..
    i think i am going to just order a new AL version and see what happens.
    the new one that i ordered before is a AH which no longer shows up for anything that i can find so i have no idea how i ended up with that one.
    will check back once i get the new part and see what happens , what could possibly go wrong? other than spending money.
    matt
  2. #32
    Sep 2019
    Alberta, Canada
    Crap now i am confused again
    this suggests they are interchangeable or am i reading this wrong?
    http://wiki.ross-tech.com/wiki/index...odule_Versions
  3. #33
    Sep 2019
    Alberta, Canada
    so going by the info here
    this suggests that the AJ should work in place of the AR and AH and that the "new" AH should work as well in the place of AR but not AJ
  4. #34
    DROPPED, PART NUMBER IS NOT INTERCHANGEABLE WITH REPLACEMENT ( FORWARD ONLY OR LINEAR SUPER SESSION )
    /\ /\ I have to wonder what that means in quotes don't you? /\ /\
  5. #35
    Sep 2019
    Alberta, Canada
    crap OK
    i missed this line
    on a side note i tried the AH module. set the coding and it seems like it wants to work
    everything is working but the steering doesnt want to reset the flashing yellow and red wheel in the dash is changing with steering changes
    but it wont reset.
    unless i am doing it wrong.. ya ya i know you are going to say the only thing i am doing wrong is using the wrong part
    we might get this figured out yet
  6. #36
    Sep 2019
    Alberta, Canada
    wait a minute!
    the part that came in this car is an AR
    the one that vw would sell me based on the vin is a AL
    is the order in the list not oldest to newest? making the AR newer?
  7. #37
    crap OK
    i missed this line
    but it wont reset.
    wait a minute!
    Please stop equivocating or are you just kidding with me?
    I'll reiterate okay?
    https://forums.ross-tech.com/showthr...l=1#post185390
    Do you walk to school or take a bag lunch?
    https://rationalwiki.org/wiki/Equivocation
  8. #38
    Sep 2019
    Alberta, Canada
    I guess i am that dumb
    wrong column? what exactly is wrong about it? the wiper controls / signal stalk / cruise / ignition switch / mini harness/ are all the same so no issue there,
    maybe an issue with the steering control module not being the right one, will this cause damage elsewhere?
    i reused the old steering wheel and clock spring because this car didnt have controls on the wheel.
    there isnt much else that will create a comparability issue
    as for a legacy scan ya maybe i failed to do this, i am no expert with the vcds .
    you feel i should have changed the ignition switch and mini harness , yes i changed the switch which didnt fix the issue, ok maybe the mini harness might of helped.
    turns out it was a combination of both the steering control module and the mini harness...
    because so much has been changed, more than once for some items in this car,by more than one shop/ person its more difficult to deal with.
    when i tested a column i happened to have, and i appeared to solved the initial issue i threw it in.
    its in now and i might as well work with it. as far as i can see its now just an issue with getting the right steering control module.
    your stand at this point is i need the 1k0 953 549 AL module before i do anything else or is it FOD ed to the point the whole thing should be scrapped?
    my intention isnt to piss anyone off, i appreciate help that can be offered
    assume that, yes i am that dumb and spell it out for me.
  9. #39
    I thought I asked the right questions & that are self evident, further pointed to exact information based from VIN number, no & that you should use the RTFB and correct parts as per required by dealer?
    The forum is not a substitute for using the RTFB and direct answers you seek are there with continuity, are they not?
    Sometimes in life you don't always get exactly what you want, huh?
    May I suggest another approach?
    Do you go here or by bus?
  10. #40
    United States
    It may, or may not, be of much assistance but I located two scans form this car back in 2015. I wouldn't typically post scans sent via e-mail into forum .. but I will in this instance.
    Per the email description; Before clearing faults
    Thursday,24,September,2015,21:12:29:59579
    VCDS Version: 14.10.2.0
    Data version: 20150311
    VIN: 3VWGT81K06M058178   License Plate: NOEL
    Mileage: 256770km-159549mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: 3VWGT81K06M058178   Mileage: 256770km-159549miles
    15-Airbags -- Status: Sporadic communication error 1000
    44-Steering Assist -- Status: Sporadic communication error 1000
       Part No SW: 03G 906 016 AC    HW: 028 101 223 9
       Component: R4 1,9L EDC G000DG  7551
       Revision: --H05---    Serial number: VWZ7Z0F4544963
       Coding: 0050078
       Shop #: WSC 00066 000 00000
       VCID: 64CDB5F1A7B30401EA7-8031
    Address 02: Auto Trans        Labels: 02E-927-770.lbl
       Part No SW: 02E 300 043     HW: 02E 927 770 AE
       Component: GSG DSG         070 1126
       Revision: 04507000    Serial number: 00000607070561
       VCID: 51A36C25C80181A9B11-8004
    28775 - No Communication with Gear Selector Module
                U0103 - 000 -  - Intermittent
                        Fault Frequency: 255
                        Reset counter: 33
                        Mileage: 256497 km
       Revision: 00H11001
       Coding: 0021122
       VCID: 73EFC6AD125D93B963D-8026
       Part No: 1K0 820 047 FJ
       VCID: 71E3CCA56841A1A9911-8024
       Part No SW: 3C0 937 049 P    HW: 3C0 937 049 P
       Revision: 00H46000    Serial number: 00000000439073
       Coding: 10018E234004150007140000001400000008730B5C0000
       VCID: 36693FB941AFC691843-8063
       Component: Wischer 270906 020  0501
       Coding: 00038805
       Shop #: WSC 00066
    00093 - Terminal 15 for Starting Relevant Consumers
                        Fault Frequency: 31
                        Reset counter: 45
                        Mileage: 256497 km
                        Voltage: 13.65 V
    02403 - Terminal 15 for Interior
                        Fault Status: 00100110
                        Fault Frequency: 27
                        Reset counter: 45
                        Mileage: 256497 km
                        Voltage: 13.65 V
       Component: 6C AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D05WCD9
       Coding: 0013891
       VCID: 6CDDDDD14F634C41A27-8039
       Subsystem 1 - Serial number: 6332MSME121A7E74H
       Subsystem 2 - Serial number: 6342MSME1251677FG
       Subsystem 3 - Serial number: 6351HSME0A591B3BH
       Subsystem 4 - Serial number: 6361HSME0A6362566
       Subsystem 5 - Serial number: 63727SME0A565251.
       Subsystem 6 - Serial number: 63827SME0A5F12510
       Part No SW: 1K0 953 549 AR    HW: 1K0 953 549 AR
       Component: J0527           035 0070
       Coding: 0010021
       VCID: 020193695DE7AA3178B-FFFF
       Part No SW: 1K0 920 853 K    HW: 1K0 920 853 K
       Revision: V0003000    Serial number: VWZ7Z0F4544963
       Coding: 0023303
       Shop #: WSC 91590 999 52559
       VCID: 326103A9ADC7DAB1A8B-8067
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Revision:   H12       Serial number: 31001068020403
       Coding: 3F3F0B4007001002
       VCID: 2C5D1DD18FE38C41E27-8079
                        Reset counter: 37
                        Mileage: 256497 km
                        Time: 03:14:29
                        Reset counter: 37
                        Mileage: 256497 km
                        Time: 03:15:38
                        Reset counter: 37
                        Mileage: 256497 km
                        Time: 03:17:53
                        Reset counter: 45
                        Mileage: 256497 km
                        Time: 03:27:20
                        Reset counter: 37
                        Mileage: 256497 km
                        Time: 03:27:53
       Component: IMMO            3HL 1610
    01176 - Key
                        Mileage: 31987 km
                        Time: 03:15:07
       Component: J386  TUER-SG FT    1127
       Revision: 12007001    Serial number: 00000584968925
       Coding: 0001205
       VCID: 3B7F2E8D7A8D1BF97BD-806E
                        Fault Status: 00100101
                        Reset counter: 41
                        Fault Status: 01101000
                        Reset counter: 5
                        Mileage: 195985 km
                        Fault Frequency: 38
                        Reset counter: 43
                        Mileage: 254645 km
                        Reset counter: 38
                        Mileage: 256497 km
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       Shop #: WSC 02069 000 90108
       VCID: 346D05B157D3D481BA7-8061
    Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
       Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
       Component:    KSG PQ35 G2  020 0202
       Coding: 1F900F880106083F0D040F8FB0880F0488FCA0
       Shop #: WSC 00066 123 12345
    00830 - Convertible Top Control Module (J256)
                        Fault Status: 00110100
                        Reset counter: 38
                        Mileage: 256497 km
                        Time: 03:14:36
                        Reset counter: 38
                        Mileage: 256497 km
                        Time: 03:15:39
       Component: J387  TUER-SG BT    1127
       Revision: 12007001    Serial number: 00000563068925
       Coding: 0001204
       VCID: 3C7D2D917F831CC1727-8069
                        Fault Status: 01100101
                        Reset counter: 5
                        Fault Status: 01101100
                        Reset counter: 5
                        Mileage: 249278 km
                        Reset counter: 38
                        Mileage: 256497 km
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
       Component: Radio DE2       014 0017
       Revision: 00014000    Serial number: VWZ4Z7F6166885
       Coding: 0040401
       VCID: 1E39C719C95F6ED17C3-804B
       Component: J388   TUER-SG HL   1115
       Revision: 12004001    Serial number: 00000000298069
       Coding: 0001168
       VCID: 3E792799699F0ED15C3-806B
                        Reset counter: 41
       Component: J389   TUER-SG HR   1115
       Revision: 12005001    Serial number: 00000000369924
       Coding: 0001168
       VCID: 3F875A9D6E9507D9575-806A
       VCID: 2D5B10D5B4F98549F59-8078
    End-------------------------(Elapsed Time: 04:29)--------------------------
    After clearing faults:
    Thursday,24,September,2015,21:15:55:59579
    VIN: 3VWGT81K06M058178   License Plate: NOEL2
       Coding: 0050078
       Revision: 00H11001
       Coding: 0021122
       Coding: 00038805
       Shop #: WSC 00066
                        Reset counter: 5
                        Mileage: 256776 km
                        Voltage: 12.10 V
                006 - Short to Plus
                        Fault Status: 01100110
                        Reset counter: 5
                        Mileage: 256776 km
                        Voltage: 12.10 V
       Coding: 0013891
       Coding: 0010021
       VCID: 020193695DE7AA3178B-8057
       Coding: 0023303
       Coding: 0023303
    Address 56: Radio
    End-------------------------(Elapsed Time: 02:09)--------------------------
    At a quick glance it would appear as if 09 and 16 were replaced. Although address 44 communicated it had communication errors in the GVL so I'm inclined to suspect that's a preexisting issue. It would be highly unlikely in my opinion that the factory steering rack decided to fail during the diagnosis and/or be directly related to which 16 module is installed.
    Matt, have you ruled out the possibility that this car has driver's door wiring harness issues that could be feeding back on to the Comfort bus? Broken (1K) Jetta harnesses were extremely common, and typically only cause comfort issues, however we had a caller with an (8P) A3 that had AC compressor shutdown problems due to broken door wiring. I believe that was due to 08-Auto HVAC and 42-Driver's door (among several other modules) using the same Comfort bus network. Address 16-Steering wheel is on that network so I'm wondering if any of the original symptoms may be pointing us at something like shorting wiring in a door?
    I don't believe that would directly explain the lack-of 44 communication presently but it would be easy enough to unplug the entire door harness at the A pillar to see if any changes are noticed.
  11. Likes Jack@European_Parts, Uwe, PetrolDave liked this post
