Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 101
Thread: Cascade a electrical failures fixed but now no steering angle signal
    Sep 2019
    Alberta, Canada
    as per the first comment in this thread
    recap
    cascade of failures means:
    starts with a/c and heater fan quitting
    then power windows
    then signals
    then wipers
    then tail lights
    then radio
    not in any particular order but usually a/c and heater fan first
    this cascade of failures happened with the column that came with the car as well as with 2 other steering control modules
    i changed out the complete column with a known working one which solved the cascade of failures
    put the old steering control module on the new column and failures return along with steering angle sensing
    put module back on known working column and failures stop but sensing gone.
  2. #12
    Sep 2019
    Alberta, Canada
    Did you know the steering 0x44 is offline and is the rack itself?
    Did you check fuses and wires to the rack yet and all communication wiring using RTFB and WD?
    Did you JPPSG yet?
    re: the steering 0x44 is offline and is the rack itself?"
    I will try to do an auto scan with the old steering control module on the new column and see what it says
    it never had this fault before the new column went in.
    if i can keep the module cold enough it wont start to shut stuff off and if i am lucky i can get a scan of the before.
    there were no issues with the steering at all with the old column in the car before,
    it was just the shutting off of a range of items which was the problem
    A dealer and 2 shops that specialize on vw repair gave up on this car and i am going to persist till i figure this out
    matt
  3. #13
    Matt,
    I am not talking about the steering column, I am speaking of the "steering rack"
    0x44", don't you see that and this is outside the car, you know right, the part connected to the tie rods and contains the electric power steering pump?
    Sounds like you dealt with some real schmucks huh?
  4. #14
    Sep 2019
    Alberta, Canada
    Matt,
    yes i know what you are saying but why was the rack not a problem before the column change?
    i will try to scan with the old column steering control module to be sure but i dont remember seeing any issues
    with steering function before the column swap
    just the shutting off of electrical items was the issue before
    matt
  5. #15
    matt
    Where is your legacy scan? ...............
    Maybe you installed the wrong steering column and it's FOD, what's the part number?
    44-Steering Assist -- Status: Sporadic communication error 1000
    Address 44: Steering Assist Labels: None
    VCID: 55AB9835BCE9EDE7A4-FFFE
    No Faults Found
    Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
    Component: J0527 034 0070
    Coding: 0011021
    VCID: 7AF1EB893537E29FE9-802E
    Part Information
    PART NUMBER ILLUSTRATION DESCRIPTION
    1K0 953 549 AL electronic modul for steering
    col. combination switch
    Vehicle Identification No. 3VWGT81K06M058178
    Model Jetta
    JEM
    Date of production 11.10.2006
    Model year 2007
    Sales type 1K2733
    Engine Code BRM
    Transmission Code HXU
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0HM Vehicle class differentiation -1KM- Build status corresponds to production in Mexico
    tail pipe 0P1 Rear side exhaust tailpipe
    drive-off assistance UG0 Without hill start assist/hill descent control/comfort driving assist
    Emission standard 7GJ Emission standard TIER 2
    Trailer hitch 1D0 without trailer towing
    airbag 4UM Driver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E0 Without activated charcoal canister
    Aerials 8ZM Antenna
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8X US comfort equipment
    Brake type in rear 1KE Disc brakes in rear
    batteries J1D Battery 380 A (72 Ah)
    Brake type, front 1ZP Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0E Component parts set, complying with vehicle type for Canada, various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0XZ Information kit in English/French
    Operating voltage 9Z0 Operating voltage 12 V
    brake wear indicator 9U1 brake wear indicator
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    Chrome package QJ1 Chrome package
    General operating permit, alterations C05 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Suspension system in rear 1JA Rear shock absorption, basic design 1
    Suspension system in front G46 Shock absorption in front
    Load-through hatch/ski bag 3X0 without load through system
    Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
    Installation differentiation for components 0ES Installation differentiation for transmission DQ250 -- vehicle components --
    Theft protection system 7AG Electronic immobilizer with anti-theft alarm system (for USA)
    Inserts 5MA Decorative inserts
    Scuff plates 7M5 Without impact protection film for door sill
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FL Mexico manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Without extended pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K4 Separate daytime running lights NAR
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YF Weight range 6 installation control only, no requirement forecast
    Weight category front axle L14 Suspension range 14 installation control only, no requirement forecast
    Base engine TG0 4-cylinder diesel engine 1.9 l unit 03G.6
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U0 Without luggage compartment cover
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Luggage compartment trim 5A7 Comfort luggage compartment trim with service lid/snap-on cover
    Transmission specifications G1A 6-speed automatic transmission
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear spoiler 5J0 Without rear spoiler
    Rear window wiper and washer system 8M0 Without rear window wiper and washer system
    Rear seats 3NQ Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AP Climatic air-conditioning system (semi-automatic)
    Headlamps 8ES Twin headlamps for driving on the right, with integrated high beam (US design)
    Customized installation FC0 Without individual installation
    Interior light in footwell 6T0 Without interior light in footwell
    Instrument clusters U5D Instrument cluster, km/h speedometer - Canada -
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8B Notchback
    Cassette and CD storage unit 4W0 without cassette / CD tray
    coolbox 1W2 Glove compartment cooling system
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Climatic zones 0Y3 Cold zones
    Compass/road sign display QR0 Without compass
    headrest for seat, rear 3Q6 Three rear head restraints
    Head restraints 5ZF Front head restraints
    Fuel tank treatment 2LC Fuel tank with special material treatment (coextrusion)
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Fuel systems 0F8 Cooled fuel system for diesel engine
    Body measures 5C1 Body measures for increased safety requirements
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Rear license plate bracket 6P2 License plate bracket, rear (NAR)
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K0 with no paint conversation
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S4 Two reading lights front, two rear
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H2 Backrest release for right front seat
    Air duct, front area VK0 Air duct, standard
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 1MH Leather-wrapped steering wheel
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q0 without beam length regulator
    Center armrest 6E3 Center armrest in front
    Multi-function display/trip computer 9Q0 Without multi-function display/ trip computer
    Engine cooling 8Z4 moderately hot country
    Engine specifications MS7 4-cyl. turbo diesel eng. 1.9 l/74 kW TDI unit-injector system base engine is T5X/T21/T71/TG0
    Left vanity mirror 4SH Left vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
    Right vanity mirror 4TH Vanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WA Without fog lights
    Rear of platform module base 4P1 Rear floor panel module, type 2
    Platform group class 7PA Platform group class 1
    Hubcaps 1NL Trims for alloy wheels
    Wheels C7C Alloy wheels 6.5J x 16
    Radios 8UF Radio with CD drive (double DIN)
    Smoker's/non-smoker's package 9JA Non smoker version
    Tire pressure monitoring system 7K0 Without tyre pressure monitor
    tire H4B All-season tires 205/55 R16 H (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G4 Space-saving spare wheel
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    PSE Special model package TDI Canada
    Side airbag 4X4 Side airbag in front and rear with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SS Labels in English and French
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Front seat, left 3TF Front left comfort seat
    Front seat, right 3SF Comfort seat, front right
    Nameplates for sales name QD3 Lettering for sales name
    Seat belt check 9P6 Seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
    Center rear seat belts 3C8 3-point seat belt, center rear with US label
    seat covers N0C Seat trim covers in leatherette
    Seat adjustment 3PD Manual height adjustment for front seats, electric backrest adjustment for left front seat
    seat heater 4A3 seat heating for front seats separat controlable
    Safety head restraint system 3K0 w/o safety head restraint system
    Side lights 7R4 Side marker lamps and turn signal repeaters (turn signals with white lens)
    Horns 8Y1 Two-tone horn
    Control number (no PR family) S3T Current MY, previous year vehicle identification number
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B0 with no protective side strip
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
    power outlet 7B5 12-volt outlet(s)
    Bumper 2JC Comfort bumpers
    Rear stabilizer 0BG Rear stabilizer
    Front stabilizer bar 0AG Front stabilizer bar
    Drawers under front seats QN0 Without drawers under front seats
    Heavy-duty/sports version 2UA Standard design
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Nameplate set 1DG Nameplate set "TDI"
    Special alarm systems 9A0 Without taxi alarm system
    Door storage compartments in front 3YR Door pockets with insert mats
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4K0 Central locking w/ radio remote control and interior controls
    Type approval countries/countries with special requirements B35 Legal requirements Canada
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA without partition
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    doors 0A2 4 doors
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Identification plates 1EB without identification plate
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG0 without service interval extension
    Heat accumulator system/auxiliary heater 7E6 Electric auxiliary air heater
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  6. #16
    Sep 2019
    Alberta, Canada
    ok i tried to do an auto scan with the old steering control module installed but it started shutting stuff off before i could do much of anything.
    things to note that i noticed,
    transmission no longer starts flashing the displace and no longer goes into neutral
    steering wheel warning in dash is only yellow unlike the changing colors with the other steering control module.
    It would have been nice to get a scan of everything before it started to fail but as you can see in this scan things are not readable as they shut down.
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: 3VWGT81K06M058178   Mileage: 258380km-160549miles
    00-Steering Angle Sensor -- Status: Cannot be reached 1100
    Address 01: Engine        Labels: 038-906-016-BEW.lbl
       Part No SW: 03G 906 016 AC    HW: 028 101 223 9
       Component: R4 1,9L EDC G000DG  7551
       Revision: --H05---    Serial number: VWZ7Z0F4544963
       Coding: 0050078
       VCID: 64CDB5F1A7B3046F23-8030
       Part No SW: 02E 300 043     HW: 02E 927 770 AE
       Component: GSG DSG         070 1126
       Revision: 04507000    Serial number: 00000607070561
       VCID: 51A36C25C80181C778-8004
    18036 - Powertrain Data Bus
                P1628 - 000 - Missing Message from Steering Angle Sensor
                        Fault Frequency: 255
                        Reset counter: 40
                        Mileage: 258389 km
       Revision: 00H11001
       Coding: 0021122
       VCID: 73EFC6AD125D93D7AA-8026
       Part No: 1K0 820 047 FJ
       Component: Climatic PQ35   120 0606
       VCID: 71E3CCA56841A1C758-8024
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000000335953
       Coding: 10018E234004150000140000001400000008730B5C
       Shop #: WSC 91590 999 58568
       VCID: 2A511BC98517921FD9-807E
       Component: Wischer 270906 020  0501
       Coding: 00038805
       Shop #: WSC 91590
    00093 - Terminal 15 for Starting Relevant Consumers
                        Reset counter: 57
                        Mileage: 258389 km
                        Voltage: 14.30 V
    02403 - Terminal 15 for Interior
                006 - Short to Plus
                        Fault Status: 01100110
                        Reset counter: 57
                        Mileage: 258389 km
                        Voltage: 14.30 V
    02401 - Terminal 75x
                006 - Short to Plus
                        Reset counter: 57
                        Mileage: 258389 km
                        Voltage: 14.30 V
       Component: 6C AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D05WCD9
       Coding: 0013891
       VCID: 6CDDDDD14F634C2F6B-8038
       Subsystem 1 - Serial number: 6332MSME121A7E74H
       Subsystem 2 - Serial number: 6342MSME1251677FG
       Subsystem 3 - Serial number: 6351HSME0A591B3BH
       Subsystem 4 - Serial number: 6361HSME0A6362566
       Subsystem 5 - Serial number: 63727SME0A565251.
       Subsystem 6 - Serial number: 63827SME0A5F12510
       Part No SW: 1K0 953 549 AR    HW: 1K0 953 549 AR
       Component: J0527           035 0070
       Coding: 0010021
       VCID: 020193695DE7AA5FB1-8056
       Part No SW: 1K0 920 853 K    HW: 1K0 920 853 K
       Component: KOMBIINSTRUMENT 3HL 1610
       Revision: V0003000    Serial number: VWZ7Z0F4544963
       Coding: 0023303
       Shop #: WSC 91590 999 52559
       VCID: 326103A9ADC7DADF61-8066
       Part No SW: 1K0 907 530 H    HW: 1K0 907 951
       Component: J533__Gateway   H12 0150
       Revision:   H12       Serial number: 31001068020403
       Coding: 3F3F0B4007001002
       VCID: 2C5D1DD18FE38C2F2B-8078
                        Reset counter: 57
                        Mileage: 258389 km
                        Time: 05:40:06
       Component: IMMO            3HL 1610
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       VCID: 346D05B157D3D4EF73-8060
    Address 46: Central Conv.
    Address 52: Door Elect, Pass.
    Address 56: Radio
    Address 62: Door, Rear Left
    Address 72: Door, Rear Right
       Revision: 00800000    Serial number:
       VCID: 2D5B10D5B4F985273C-8078
                014 - Defective
    End-------------------------(Elapsed Time: 02:05)--------------------------
  7. #17
    Reset counter: 57
    Mileage: 258389 km
    Voltage: 14.30 V
    006 - Short to Plus
    Reset counter: 57
    Mileage: 258389 km
    Voltage: 14.30 V
    006 - Short to Plus
    Reset counter: 57
    Mileage: 258389 km
    Voltage: 14.30 V
    You could just change the mini harness and ignition switch to it & to sort this, no?
    Do you see now the rack is back online?
  8. #18
    Sep 2019
    Alberta, Canada
    thats the odd things with the original column in the car with its steering control module the cascade of electrical items dropping is the problem
    swapped in a "new" steering control module problem persists
    swapped in a used one problem persists
    swapped in the known good module problem persists
    swapped the complete column with its module the dropping of electrical items is gone
    install the original steering control module on the new known good column electrical items start to drop
    I can not explain how thats possible !
    whats new is the issue with no steering angle sensing with the original steering control module. maybe i got the steering angle sensor mixed up
    and need to swap in the ones i have and see if i can get this back even with the old module .
    yes the rack is back online, it was never an issue with the old column and its steering control module
    i am almost sure something needs to be adapted in this new steering control module for it to work
    i have a feeling it has something to do with the abs module needing the new steering modules part number set in it??
    I am at a loss
    i will swap in the other angle sensors and see if i can get sensing back after than i am unsure where to go next.
    tell me what to try or do
    matt
  9. #19
    Did you even read the last post of questions Matthew, did you know your clouded judgement is your own worst enemy?
  10. #20
    Sep 2019
    Alberta, Canada
    new ignition switch had no effect. this was the first thing i tried
    I KNOW the problem is in the steering control module , how do i know this, because if the car is started with the key stuff slowly gets shut off
    if the remote start is used (bypassing the steering control module) everything remains on
    yes i did see this which i kind of knew it would be cause the steering was never a problem. only issue is the lack of steering angle sensing as far as i can tell.
    please make suggestions as to what i should try. based on the last auto scan?
    matt
