Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 101
Thread: Cascade a electrical failures fixed but now no steering angle signal
  1. #41
    Wouldn't it be extremely wise to install the correct parts and isolate all systems bringing them up one by one on gateway and verifying each controllers function?
    I like what Dana recommended for the drivers door, but I would unplug them all & additionally right at BCM too, wouldn't you?
  2. #42
    Sep 2019
    Alberta, Canada
    It may, or may not, be of much assistance but I located two scans form this car back in 2015. I wouldn't typically post scans sent via e-mail into forum .. but I will in this instance.
    Per the email description; Before clearing faults
    Thursday,24,September,2015,21:12:29:59579
    VCDS Version: 14.10.2.0
    Data version: 20150311
    VIN: 3VWGT81K06M058178   License Plate: NOEL
    Mileage: 256770km-159549mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: 3VWGT81K06M058178   Mileage: 256770km-159549miles
    15-Airbags -- Status: Sporadic communication error 1000
    44-Steering Assist -- Status: Sporadic communication error 1000
       Part No SW: 03G 906 016 AC    HW: 028 101 223 9
       Component: R4 1,9L EDC G000DG  7551
       Revision: --H05---    Serial number: VWZ7Z0F4544963
       Coding: 0050078
       Shop #: WSC 00066 000 00000
       VCID: 64CDB5F1A7B30401EA7-8031
    Address 02: Auto Trans        Labels: 02E-927-770.lbl
       Part No SW: 02E 300 043     HW: 02E 927 770 AE
       Component: GSG DSG         070 1126
       Revision: 04507000    Serial number: 00000607070561
       VCID: 51A36C25C80181A9B11-8004
    28775 - No Communication with Gear Selector Module
                U0103 - 000 -  - Intermittent
                        Fault Frequency: 255
                        Reset counter: 33
                        Mileage: 256497 km
       Revision: 00H11001
       Coding: 0021122
       VCID: 73EFC6AD125D93B963D-8026
       Part No: 1K0 820 047 FJ
       VCID: 71E3CCA56841A1A9911-8024
       Part No SW: 3C0 937 049 P    HW: 3C0 937 049 P
       Revision: 00H46000    Serial number: 00000000439073
       Coding: 10018E234004150007140000001400000008730B5C0000
       VCID: 36693FB941AFC691843-8063
       Component: Wischer 270906 020  0501
       Coding: 00038805
       Shop #: WSC 00066
    00093 - Terminal 15 for Starting Relevant Consumers
                        Fault Frequency: 31
                        Reset counter: 45
                        Mileage: 256497 km
                        Voltage: 13.65 V
    02403 - Terminal 15 for Interior
                        Fault Status: 00100110
                        Fault Frequency: 27
                        Reset counter: 45
                        Mileage: 256497 km
                        Voltage: 13.65 V
       Component: 6C AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D05WCD9
       Coding: 0013891
       VCID: 6CDDDDD14F634C41A27-8039
       Subsystem 1 - Serial number: 6332MSME121A7E74H
       Subsystem 2 - Serial number: 6342MSME1251677FG
       Subsystem 3 - Serial number: 6351HSME0A591B3BH
       Subsystem 4 - Serial number: 6361HSME0A6362566
       Subsystem 5 - Serial number: 63727SME0A565251.
       Subsystem 6 - Serial number: 63827SME0A5F12510
       Part No SW: 1K0 953 549 AR    HW: 1K0 953 549 AR
       Component: J0527           035 0070
       Coding: 0010021
       VCID: 020193695DE7AA3178B-FFFF
       Part No SW: 1K0 920 853 K    HW: 1K0 920 853 K
       Revision: V0003000    Serial number: VWZ7Z0F4544963
       Coding: 0023303
       Shop #: WSC 91590 999 52559
       VCID: 326103A9ADC7DAB1A8B-8067
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Revision:   H12       Serial number: 31001068020403
       Coding: 3F3F0B4007001002
       VCID: 2C5D1DD18FE38C41E27-8079
                        Reset counter: 37
                        Mileage: 256497 km
                        Time: 03:14:29
                        Reset counter: 37
                        Mileage: 256497 km
                        Time: 03:15:38
                        Reset counter: 37
                        Mileage: 256497 km
                        Time: 03:17:53
                        Reset counter: 45
                        Mileage: 256497 km
                        Time: 03:27:20
                        Reset counter: 37
                        Mileage: 256497 km
                        Time: 03:27:53
       Component: IMMO            3HL 1610
    01176 - Key
                        Mileage: 31987 km
                        Time: 03:15:07
       Component: J386  TUER-SG FT    1127
       Revision: 12007001    Serial number: 00000584968925
       Coding: 0001205
       VCID: 3B7F2E8D7A8D1BF97BD-806E
                        Fault Status: 00100101
                        Reset counter: 41
                        Fault Status: 01101000
                        Reset counter: 5
                        Mileage: 195985 km
                        Fault Frequency: 38
                        Reset counter: 43
                        Mileage: 254645 km
                        Reset counter: 38
                        Mileage: 256497 km
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       Shop #: WSC 02069 000 90108
       VCID: 346D05B157D3D481BA7-8061
    Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
       Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
       Component:    KSG PQ35 G2  020 0202
       Coding: 1F900F880106083F0D040F8FB0880F0488FCA0
       Shop #: WSC 00066 123 12345
    00830 - Convertible Top Control Module (J256)
                        Fault Status: 00110100
                        Reset counter: 38
                        Mileage: 256497 km
                        Time: 03:14:36
                        Reset counter: 38
                        Mileage: 256497 km
                        Time: 03:15:39
       Component: J387  TUER-SG BT    1127
       Revision: 12007001    Serial number: 00000563068925
       Coding: 0001204
       VCID: 3C7D2D917F831CC1727-8069
                        Fault Status: 01100101
                        Reset counter: 5
                        Fault Status: 01101100
                        Reset counter: 5
                        Mileage: 249278 km
                        Reset counter: 38
                        Mileage: 256497 km
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
       Component: Radio DE2       014 0017
       Revision: 00014000    Serial number: VWZ4Z7F6166885
       Coding: 0040401
       VCID: 1E39C719C95F6ED17C3-804B
       Component: J388   TUER-SG HL   1115
       Revision: 12004001    Serial number: 00000000298069
       Coding: 0001168
       VCID: 3E792799699F0ED15C3-806B
                        Reset counter: 41
       Component: J389   TUER-SG HR   1115
       Revision: 12005001    Serial number: 00000000369924
       Coding: 0001168
       VCID: 3F875A9D6E9507D9575-806A
       VCID: 2D5B10D5B4F98549F59-8078
    End-------------------------(Elapsed Time: 04:29)--------------------------
    After clearing faults:
    Thursday,24,September,2015,21:15:55:59579
    VIN: 3VWGT81K06M058178   License Plate: NOEL2
       Coding: 0050078
       Revision: 00H11001
       Coding: 0021122
       Coding: 00038805
       Shop #: WSC 00066
                        Reset counter: 5
                        Mileage: 256776 km
                        Voltage: 12.10 V
                006 - Short to Plus
                        Fault Status: 01100110
                        Reset counter: 5
                        Mileage: 256776 km
                        Voltage: 12.10 V
       Coding: 0013891
       Coding: 0010021
       VCID: 020193695DE7AA3178B-8057
       Coding: 0023303
       Coding: 0023303
    Address 56: Radio
    End-------------------------(Elapsed Time: 02:09)--------------------------
    At a quick glance it would appear as if 09 and 16 were replaced. Although address 44 communicated it had communication errors in the GVL so I'm inclined to suspect that's a preexisting issue. It would be highly unlikely in my opinion that the factory steering rack decided to fail during the diagnosis and/or be directly related to which 16 module is installed.
    Matt, have you ruled out the possibility that this car has driver's door wiring harness issues that could be feeding back on to the Comfort bus? Broken (1K) Jetta harnesses were extremely common, and typically only cause comfort issues, however we had a caller with an (8P) A3 that had AC compressor shutdown problems due to broken door wiring. I believe that was due to 08-Auto HVAC and 42-Driver's door (among several other modules) using the same Comfort bus network. Address 16-Steering wheel is on that network so I'm wondering if any of the original symptoms may be pointing us at something like shorting wiring in a door?
    I don't believe that would directly explain the lack-of 44 communication presently but it would be easy enough to unplug the entire door harness at the A pillar to see if any changes are noticed.
    I have tried seeing if door wiring has any effect if disconnected and it made no change.
    on the topic of other items that might cause a problem like this
    i had been talking to a tech at a shop who seen weird feedback causing all kinds of problems much like what i am seeing caused
    by an issue with the rad fan control. so i tried seeing if any change would be seen with that disconnected. made no change.
    I will have a new steering control module to try Monday as repeatedly suggested by Jack
    i am hoping this will solve the issue.
    no point in jacking around with it, without trying whats said to be the correct part
    will report back as soon as i have a chance to try it, which will depend on recovery time
    matt
  3. Likes Dana liked this post
  4. #43
    Sep 2019
    Alberta, Canada
    are you thinking harm will come to the new steering control module if there is an issue in one of the controllers?
    i suspect that the issue has always been in the steering control module because early on everything worked until the steering control module would warm up
    if the module was kept cold with freeze spray the issues would be kept at bay till the module would warm up.
    now it doesnt matter if its warm of cold
  5. #44
    What was causing it to become warm, did you isolate tracks yet to see what was pulling amperage through a DVOM or load light?
  6. #45
    Sep 2019
    Alberta, Canada
    no unusual loads but having the a/c on and heater fan on high early on would speed up the failures occurring
    a/c and heater fan checked out fine.
    Note:
    known replacement column (wrong parts)the failure issue couldnt be reproduced with everything on a/c on high heater fan on hi all electric items on high running for 3 hours
  7. #46
    Oh sigh .......and your tests me what if the car isn't fixed?
    Do you want to fix the car or debate installing incorrect parts & with who knows what behavior as outcome, seems to have been working for you so far, huh?
  8. #47
    Sep 2019
    Alberta, Canada
    yes but you cant ignore the fact that the initial issue has not returned and can not be replicated with this wrong part installed (so to be rectified )
    fingers crossed the right part solves the initial issue as well as the missing steering angle issue which i am attributing to said wrong part.
  9. #48
    Did you know I can indeed , JPPSG rule violation Section 2 part 7 & section 3 part 1?
    Better learn how to use the 3 seashells, huh?
    https://m.youtube.com/watch?v=CFxCGyNbBdM
  10. #49
    Sep 2019
    Alberta, Canada
    ok i was feeling up to trying out the "correct" part #1K0 953 549 AL
    no change as far as i can see . only difference now is the steering assist light is solid yellow now rather than switching between yellow and red.
    and is non responsive to reset.
    (drivers door is unplugged )
    VIN: 3VWGT81K06M058178   Mileage: 258390km-160556miles
    00-Steering Angle Sensor -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Cannot be reached 1100
       Coding: 0050078
       VCID: 64CDB5F1A7B3046F23-8030
       VCID: 51A36C25C80181C778-8004
    18036 - Powertrain Data Bus
                P1628 - 000 - Missing Message from Steering Angle Sensor
                        Reset counter: 40
                        Mileage: 258399 km
       Revision: 00H11001
       Coding: 0021122
       VCID: 73EFC6AD125D93D7AA-8026
       VCID: 71E3CCA56841A1C758-8024
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Revision: 00H37000    Serial number: 00000000335953
       Coding: 10018E234004150000140000001400000008730B5C
       Shop #: WSC 91590 999 58568
       VCID: 2A511BC98517921FD9-807E
       Coding: 00038805
       Shop #: WSC 91590
                        Reset counter: 57
                        Mileage: 258399 km
                        Voltage: 12.10 V
                        Reset counter: 57
                        Mileage: 258399 km
                        Voltage: 12.10 V
       Coding: 0013891
       VCID: 6CDDDDD14F634C2F6B-8038
       Subsystem 1 - Serial number: 633  SME
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
                008 - Implausible Signal - MIL ON
       Part No SW: 1K0 953 549 AL    HW: 1K0 953 549 AL
       Coding: 0010021
       Shop #: WSC 12345 123 12345
       VCID: 7CFDED913F03DCAFFB-8028
       Coding: 0023303
       VCID: 326103A9ADC7DADF61-8066
       VCID: 2C5D1DD18FE38C2F2B-8078
                        Reset counter: 57
                        Mileage: 258399 km
                        Time: 10:24:37
                        Reset counter: 57
                        Mileage: 258399 km
                        Time: 10:24:38
                        Reset counter: 57
                        Mileage: 258399 km
                        Time: 10:24:38
       VCID: 346D05B157D3D4EF73-8060
                        Reset counter: 57
                        Mileage: 258399 km
                        Time: 10:24:39
                        Reset counter: 57
                        Mileage: 258399 km
                        Time: 10:24:39
       Coding: 0001204
       VCID: 3C7D2D917F831CAFBB-8068
       Coding: 0040401
       VCID: 1E39C719C95F6EBFB5-804A
       Coding: 0001168
       VCID: 3F875A9D6E9507B79E-806A
       VCID: 2D5B10D5B4F985273C-8078
    End-------------------------(Elapsed Time: 02:05)--------------------------
  11. #50
    Yes, however, everything is alive now other than doors due to being unplugged and terminal faults are gone?
    Shouldn't you plug in stuff and see if SAS is faulty for wiring or active in blocks now?
    WTF are you such a pessimist?
