Page 1 of 11 123 ... LastLast
Results 1 to 10 of 101
Thread: Cascade a electrical failures fixed but now no steering angle signal
    Sep 2019
    Alberta, Canada
    I have been working on this 2006 jetta for years. No one has been able to figure it out and more than one shop gave up on it.
    Started out with the a/c stopping then mins later the heater fan would quit.
    At time progressed more and more items would shut down. After swapping out many different parts I have narrowed the issue down to the steering control module.
    I tried a known good one with no change. Changed out the complete steering column with a known good one and low and behold problem is solved.
    I put the original steering control module on the newly installed column and issues returned. Yet the known good steering control module tried on the old column didnt fix the issues. Strange.
    Anyhow the new known good column in in the car and the cascade of electrical issues is gone. But I have a new issue.
    The transmission doesnt like the new column. Vcds says missing steering angle signal so the trans starts the dash flashing the PND123 indicator and the trans goes out of gear into I assume neutral.
    What do I have to do to get the steering angle signal back??
    Apr 2018
    ITALY
    first thing to do is always to post an autoscan
    my Golf left the factory with 23 ECUs. now she has 36. and counting
  3. Likes Uwe liked this post
    Sep 2019
    Alberta, Canada
    No one has any input on this issue?
    Matt
    Quote Originally Posted by Nowback View Post
    Chances that someone might have input would be higher if you'd post an Auto-Scan as suggested in post #2.
  6. Likes Gremling, PetrolDave, dieseldub liked this post
    Sep 2019
    Alberta, Canada
    omg this has been a massive effort to get this auto scan
    laptop i used with the vcds craps out the moment i tried to update the vcds . hard drive failed
    setup another old paltop that i had which wasnt easy because it lost networking completely but i got it done
    put txt on a memory card went to my desk top and boom wifi adapter decided to die. its like the gods didnt want me to post this.
    but here it is hope someone can help after all this.
    Tuesday,10,December,2019,14:26:50:59579
    VCDS Version: 19.6.2.0
    VIN: 3VWGT81K06M058178   License Plate: JETTA
    Mileage: 258380km-160549mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: 3VWGT81K06M058178   Mileage: 258380km-160549miles
    00-Steering Angle Sensor -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Sporadic communication error 1000
       Part No SW: 03G 906 016 AC    HW: 028 101 223 9
       Component: R4 1,9L EDC G000DG  7551
       Revision: --H05---    Serial number: VWZ7Z0F4544963
       Coding: 0050078
       Shop #: WSC 00066 000 00000
       VCID: 64CDB5F1A7B3046F23-8030
       Part No SW: 02E 300 043     HW: 02E 927 770 AE
       Component: GSG DSG         070 1126
       Revision: 04507000    Serial number: 00000607070561
       VCID: 51A36C25C80181C778-8004
       Coding: 0021122
       VCID: 73EFC6AD125D93D7AA-8026
       Subsystem 1 - Part No: 1K0 907 379 AC
       Part No: 1K0 820 047 FJ
       VCID: 71E3CCA56841A1C758-8024
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Revision: 00H37000    Serial number: 00000000335953
       Coding: 10018E234004150000140000001400000008730B5C
       Shop #: WSC 91590 999 58568
       VCID: 2A511BC98517921FD9-807E
       Component: Wischer 270906 020  0501
       Coding: 00038805
       Shop #: WSC 91590
       Component: 6C AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D05WCD9
       Coding: 0013891
       VCID: 6CDDDDD14F634C2F6B-8038
       Subsystem 1 - Serial number: 6332MSME121A7E74H
       Subsystem 2 - Serial number: 6342MSME1251677FG
       Subsystem 3 - Serial number: 6351HSME0A591B3BH
       Subsystem 4 - Serial number: 6361HSME0A6362566
       Subsystem 5 - Serial number: 63727SME0A565251.
       Subsystem 6 - Serial number: 63827SME0A5F12510
       Part No SW: 1K0 953 549 AJ    HW: 1K0 953 549 AJ
       Component: J0527           034 0070
       Coding: 0011021
       VCID: 7AF1EB893537E29FE9-802E
       Part No SW: 1K0 920 853 K    HW: 1K0 920 853 K
       Revision: V0003000    Serial number: VWZ7Z0F4544963
       Coding: 0023303
       Shop #: WSC 91590 999 52559
       VCID: 326103A9ADC7DADF61-8066
       Revision:   H12       Serial number: 31001068020403
       Coding: 3F3F0B4007001002
       VCID: 2C5D1DD18FE38C2F2B-8078
       Component: IMMO            3HL 1610
       Component: J386  TUER-SG FT    1127
       Revision: 12007001    Serial number: 00000584968925
       Coding: 0001205
       VCID: 3B7F2E8D7A8D1B97B2-806E
    Address 44: Steering Assist        Labels: None
       VCID: 55AB9835BCE9EDE7A4-FFFE
    No Faults Found
       Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
       Component:    KSG PQ35 G2  020 0202
       Coding: 1F900F880106083F0D040F8FB0880F0488FCA0
       Shop #: WSC 00066 123 12345
       Component: J387  TUER-SG BT    1127
       Revision: 12007001    Serial number: 00000563068925
       Coding: 0001204
       VCID: 3C7D2D917F831CAFBB-8068
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
       Component: Radio DE2       014 0017
       Revision: 00014000    Serial number: VWZ4Z7F6166885
       Coding: 0040401
       VCID: 1E39C719C95F6EBFB5-804A
       Component: J388   TUER-SG HL   1115
       Revision: 12004001    Serial number: 00000000298069
       Coding: 0001168
       VCID: 3E792799699F0EBF95-806A
       Component: J389   TUER-SG HR   1115
       Revision: 12005001    Serial number: 00000000369924
       Coding: 0001168
       VCID: 3F875A9D6E9507B79E-806A
       VCID: 2D5B10D5B4F985273C-8078
                014 - Defective
    End-------------------------(Elapsed Time: 02:57)--------------------------
    Did you know the steering 0x44 is offline and is the rack itself?
    Did you check fuses and wires to the rack yet and all communication wiring using RTFB and WD?
    Did you JPPSG yet?
    Sep 2019
    Alberta, Canada
    as i said above. car would have a cascade of electrical failures
    tried 3 different steering control modules on the column that came with the car cascade of failures persisted
    changed out the complete column with a known working one. cascade of failures is now gone
    tried the old steering control module on the new column and cascade of failures returns.
    with the old module on the new column the steering angle sensing is working but electrical items start to cascade fail
    put the module that was with this new column back on cascade of failures stops but no steering angle sensing
    i have adapted the steering wheel controls out ( new column has steering wheel controls old didnt) made no difference still no sensing
    wire to the module is good ends were all replaced with the gold connections.
    i need to know how to adapt what ever the difference is between the 2 steering control modules
    i cant read the old one because it immediately starts to have failures
    i am sure its a coding issue just not sure how to go about coding i guess.
    oh and i checked compatibility of the steering control modules with the 2 vin numbers with the dealer and its the same part number for both
  10. #8
    Sep 2019
    Alberta, Canada
    looking closer at the auto scan its looking like something maybe needs to be adapted in the abs to get this different steering control module to work with it?
    Coding: 0021122
    wiki says:
    00778 - Steering Angle Sensor (G85): No Signal/Communication
    Possible Causes
    Steering Angle Sensor (G85) faulty
    Steering Angle Sensor (G85) configured incorrectly due to replacement control modules or incorrect coding
    Buggy ABS controller software
    Possible Solutions
    Check Steering Angle Sensor (G85)
    Check Steering Angle Sensor (G85) location and configuration on the vehicle in question
    Check ABS controller software per TPIs, TSBs and recall publications .
  11. #9
    Not the steering column, the "steering rack" & with combined pump 0x44 are you not paying attention, it costs nothing to do the dirty dishes to clean up with Cascade?
  12. #10
    Sep 2019
    Alberta, Canada
    so why with the column that came with the car do i get steering angle sensing and everything works fine until the issue with the steering control module causes things like the power
    windows , heater, wipers, .... to stop working.
    the replacement column everything works nothings starts to fail but i am now missing steering angle sensing?
    matt
