Results 1 to 2 of 2
Thread: 2017 Audi Allroad Awd Clutch Fault
    Sep 2019
    Have a 17 allroad that had light front and rear damage, nothing that should have effected the drivetrain but I have a code for the add clutch system. I am not sure what the security code is and therefore haven't been able to access some of the adaptions or output tests. Module won't allow codes to clear either. I have inspected the wiring under the car and don't see anything out of place not that the codes are pointing to that. Anyone know the security code?
    Tuesday,17,September,2019,18:12:48:50381
    VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4505.4
    VIN: WA18NAF4XHA065295   License Plate:
    Mileage: 52309km-32503mi   Repair Order:
    Chassis Type: F4-AU49 (8W8)
    Scan: 01 02 03 08 09 15 16 17 19 22 29 36 39 3C 42 44 46 47 52 5F
              6C 6D 74 81 A5 BB BC CA CF D6 D7
    VIN: WA18NAF4XHA065295   Mileage: 52309km-32503miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CYMC)       Labels:. 06K-907-425-V2.clb
       Part No SW: 8W0 906 259 C    HW: 06L 907 425
       Component: 2.0l R4 TFSI  H13 0005
       Revision: --H13---
       Coding: 326500322326010E34280000000000000000000000000000
       Shop #: WSC 06314 790 00001
       ASAM Dataset: EV_ECM20TFS0208W0906259C 001006
       ROD: EV_ECM20TFS0208W0906259C.rod
       VCID: 41CA46DDD04D0747D6-8014
    Readiness: 0000 0100
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 80A 927 155 J    HW: 0CK 927 156 AA
       Component: 0CJ 20TFSINAR H04 0001
       Revision: --H04---    Serial number: 0000000038
       Coding: 000001
       ASAM Dataset: EV_TCMDL382021 002023
       ROD: EV_TCMDL382021_AU49.rod
       VCID: 302C13196BE79ECF29-8064
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
       Component: V553 MTFP  002 0572
       Serial number: 75117071160231000188
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
       Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
       Component: ESP9 Plus     H06 0593
       Coding: 18AA409928A82A9B96A0489A20825292E6259A180214546912044A4967A459
       Shop #: WSC 06334 790 00001
       ASAM Dataset: EV_ESP9BOSCHAU49X 012014
       ROD: EV_ESP9BOSCHAU49X_012.rod
       VCID: 47DE58C5FE69397718-8012
    413696 - TPMS Display
              C1146 F4 [175] - Basic Setting Unsuccessful
                        Mileage: 52119 km
                        Date: 2019.09.03
                        Time: 19:44:22
                        8C 00 80 3C 88 24 00 00 20 50
    15390464 - Databus
              U1122 00 [104] - Implausible Message
              [Signal_ALR_Ist_Proz_invalid_(252_or_254)]
                        Fault Frequency: 23
                        Mileage: 52084 km
                        Date: 2019.08.30
                        Time: 16:26:11
                        73 C0 80 00 C2 00 00 00 00 00
    483840 - Databus
              [Signal_ALR_Systemstatus_invalid_(0.3]
                        Fault Frequency: 23
                        Mileage: 52084 km
                        Date: 2019.08.30
                        Time: 16:26:11
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
       Component: Klima Zone 3  H32 0071
       Coding: 240809085548000D10000100880000000000000000000000000000000000
       Shop #: WSC 06335 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 373E28058E8949F768-8062
       Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000001017448
       Component: AQ_Hum_Sensor  H01 0005
       Serial number: 42C8444800PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
       Component: Klima Heck  H40 0073
       Part No SW: 8W0 907 063 BG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0248
       Coding: 07500363E0081CCD0115871558AE98B9110B3D080000000000000000200016010A690122025705
       ASAM Dataset: EV_BCM1BOSCHAU736 016006
       ROD: EV_BCM1BOSCHAU736_016.rod
       VCID: 014A86DD90CDC74796-8054
       Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS491 160728  043 0813
       Serial number: 89435300301621003076
       Coding: 5BC7F7
       Serial number: 20016522X81A955555A0
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
       Component: E1 - LDS  H06 0008
       Serial number: 02 06 2016  00391692
       Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
       Component: USHL5  H04 0050
       Serial number: 0000009600335Z1OPM02
       Coding: 350000
       Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
       Component: GTO BF  H01 0010
       Serial number: 20160624164105 00872
       Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
       Component: Y7_Innenspieg  H01 0002
       Serial number: GX1CE109061612010892
       Coding: 030000
       Interior Light Module:
       Subsystem 7 - Part No SW: 8W0 947 135 CS    HW: 8W0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: B10219952
       Subsystem 8 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
       Component: SL-B9/Q5NF  H16 0010
       Serial number: 2616000071852007
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655 A    HW: 8W0 959 655 A
       Component: Airbag10.44   H74 0086
       Serial number: 003N80011YSC
       Coding: BFCCF0C000800000A0000033C24C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
       Component: BeltPretRevFL  306 2033
       Serial number: 8W0857705C0226Q00074
       Coding: 80000D
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
       Component: BeltPretRevFR  306 2033
       Serial number: 8W0857706D0229Q00593
       Coding: 80000D
       Occupant Detection:
       Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
       Component: BF-Gewichtss.  H11 0022
       Serial number: IBH0000J160005Q0IZ0R
       Subsystem 4 - Part No SW: -----------    HW: 442 060 208 16
       Serial number: 3577Y00BD1F9D10163DD
       Subsystem 5 - Part No SW: -----------    HW: 442 061 008 16
       Serial number: 3587Y00991FB75F3C13J
       Subsystem 6 - Part No SW: -----------    HW: 442 0B2 207 16
       Serial number: 3517700A72106CB3A346
       Subsystem 7 - Part No SW: -----------    HW: 442 0B2 307 16
       Serial number: 3527700AF2106CB1E3FS
       Subsystem 8 - Part No SW: -----------    HW: 442 0C2 707 16
       Serial number: 3557500C120BEED0829P
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 442 0C2 707 16
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500AB20F7C24F06O
       Part No SW: 4M0 907 129 GM    HW: 4M0 907 129 GM
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 890 C    HW: 8W5 920 890 C
       Component: FBenUSA       H15 0307
       Coding: 08E699C3B888CF05022369601800000008000000
       ASAM Dataset: EV_DashBoardAU736 001022
       VCID: 43C64CD5CA511557C4-8016
       Part No SW: 8W8 907 468 C    HW: 8W8 907 468 C
       Component: Gateway       H27 1298
       Revision: 4Q080005    Serial number: 0584Q044816805
       Coding: 0301000100000E4029070000005900304CB20007000000000175078E00000000
       ASAM Dataset: EV_CGateCONTIAU491 002060
       ROD: EV_CGateCONTIAU491_002_AU49.rod
       VCID: 4CD467E9E70FDA2F35-8018
       Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
       Component: J453 MFL  H06 0002
       Serial number: 20160725222246 02837
       Serial number: 3968831104
    Address 22: AWD (J492)       Labels:* None
       Part No SW: 8W9 927 755     HW: 0CJ 927 749
       Component: B9_DL3_H_SD5  H01 0004
       Serial number: 1602113283
       Coding: 11040000
       ASAM Dataset: EV_AWDCQUOD31 001048
       ROD: EV_AWDCQUOD31.rod
       VCID: 0B56A4F5A2819D17FC-805E
    29855 - Clutch 1 for AWD
              C05E6 00 [109] - Position Control Error
                        Fault Frequency: 13
                        Mileage: 52086 km
                        Date: 2019.09.03
                        Time: 14:05:03
                        Battery voltage: 11.529 V
                        Engine current: 0.0000 A
                        Internal system status: 05
                        Actuator angle: actual value: 0.796875
                        Vehicle speed: 0.00 km/h
                        Processor load: 77 %
                        Stack store: 00 00 00
                        Engine speed: 1316 /min
                        Operating time: 0 min
                        Ambient temperature: 30 °C
                        End stage temperature: 69 °C
                        HW KL15 Debounce Time: 50 ms
                        Combined KL15: 1
                        HW KL15 Filtered: 1
                        HW KL15 Raw: 1
                        SW KL15: 1
                        SW KL15 Timeout: 0
                        System status: 00 00
                        XCP-DAQ OdtEntryCount: 0
                        UDS Session: OBDII And VW Default Diagnostic Session
                        Standard Seed and Key unlocked: 0
                        Advanced Seed and Key unlocked: 0
                        XCP Calibration activated: 0
                        XCP Measurement active: 0
                        DEV_X_06 enabled: 0
                        Reserved: FF FF FF FF FF FF
                        Unlearning counter according OBD-OBD unlearning counter: 40
                        CC Error Dump (EVENT_CC_PHI_TUBE)-CC Error Dump: 02 06 00 21 00 00 00 00 13 0E 02 11 01 06 2B 80 00 86 36 02 0B 80 00 00
    29941 - Clutch 1 for AWD
              C05DD 00 [040] - Stuck Open
                        Fault Frequency: 24
                        Mileage: 52084 km
                        Date: 2019.08.30
                        Time: 16:24:09
                        Battery voltage: 12.004 V
                        Engine current: 63.9980 A
                        Actuator angle: actual value: 0.843750
                        Engine speed: 0 /min
                        Operating time: 32 min
                        Ambient temperature: 28.5 °C
                        End stage temperature: 76 °C
                        Combined KL15: 1
                        HW KL15 Filtered: 1
                        HW KL15 Raw: 1
                        SW KL15: 1
                        SW KL15 Timeout: 0
                        UDS Session: Extended Diagnostic Session
                        DEV_X_06 enabled: 0
                        CDD Error Dump (EVENT_PMSM_GD_OC_SHDWN)-CDD Error Dump: FF 00 00 00 00 00 04 11 FF 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
       Component: LCM_MLBevoH05 0024
       VCID: 78BCEB39C317868FA1-802C
       Part No SW: 4M1 959 760     HW: 4M1 959 760
       Component: MEM-FS        008 0031
       Serial number: 00000214760072
       Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
       VCID: 76A0E501C903F0FFB3-8022
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 4M0 907 566 B    HW: 4M0 907 566
       Component: MRR1Rear      H13 0230
       Revision: --------
       Coding: 0E8002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001015
       ROD: EV_RearRadarS1BoschAU736.rod
       VCID: 34241F099FFFA2EF4D-8060
       Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
       Component: TSG FS        009 0052
       Serial number: 0000214905986
       Coding: 005F1B205E001080000100B2
       VCID: 42C849D1D54B1C5FCF-8016
       Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0407
       Coding: 09000380008000
       ASAM Dataset: EV_EPSZFAU49X 002015
       ROD: EV_EPSZFAU49X_002.rod
       VCID: 40CC43D9DB470E4FD9-8014
       Part No SW: 8W0 907 064 CC    HW: 8W0 907 064 C
       Component: BCM2 MLBevo   018 0344
       Coding: 013400004F9100C0650BA0006E01080233004000010027502F0400000F04803F001E0001000000
       ASAM Dataset: EV_BCM2HellaAU736 012013
       ROD: EV_BCM2HellaAU736_012_AU49.rod
       VCID: 7F4E0025E639B1B7E0-802A
       Ignition key:
       Subsystem 1 - Part No SW: 4M0 959 754 AA    HW: 4M0 959 754 AA
       Component: ID-Geber  H40 0105
       Serial number: 3616000156131004
       Subsystem 2 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY162043DVU
       Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000036220439
       Subsystem 4 - Part No SW: 3AA 962 243 G    HW: 3AA 962 243 G
       Component: GEB.F.Heckoef  H16 0903
       Serial number: 84430262
       Part No SW: 8W0 035 465     HW: 8W0 035 465
       Component: MIB2_amp_P_B9 H11 0420
       Revision: 00000001    Serial number: AUZ8ZAGJA00CN2
       Coding: 0194420800AFAAAFAA0000010000
       ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
       ROD: EV_AMPMst16C2Gen2ALPI.rod
       Part No SW: 4M0 959 792 G    HW: 4M0 959 792 C
       Component: TSG BFS       009 0052
       Serial number: 0000214532764
       Coding: 005F1B205E001080000100B0
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
       Part No SW: 8W0 035 880 A    HW: 8W0 035 880
       Component: MU-P-LNS-US   052 0692
       Serial number: A400H0G7513973
       Coding: 019442020000000053220002041A00102F000CE501700904FE
       VCID: 383C2B398397468F61-806C
       Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
       Component: NAR 2018  --- 0063
       Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
       Component: DU High AU49x  H31 0160
       Serial number: TPO00122061600820930
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
       Serial number: APVAK129071600050343
       Component: Gracenote2---  --- 3009
              B11CF 53 [009] - Deactivated
                        Reset counter: 112
                        Mileage: 52092 km
                        Date: 2019.09.03
                        Time: 17:12:40
                        Voltage terminal 30: 13.9 V
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                        Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
    3084 - GSM antenna 2
              B1533 13 [009] - Open Circuit
                        Reset counter: 112
                        Mileage: 52092 km
                        Date: 2019.09.03
                        Time: 16:26:42
                        Voltage terminal 30: 11.7 V
    Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
       Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
       Component: RVC Compact   H12 0240
       Coding: 0294020102002001400040
       ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
       ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
       VCID: 33261C159AF1A5D754-8066
       Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
       Component: HDSG-Modul    H13 0161
       Revision: --------    Serial number: 30900428500000
       Coding: 0570
       VCID: 3228191165EBACDF5F-8066
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 8W0 907 777 H    HW: 8W0 907 777 C
       Component: Fahrwerk-SG   H35 1214
       Serial number: 1507160248
       Coding: 1051486158
       ASAM Dataset: EV_ChassContrContiAU426 001003
       ROD: EV_ChassContrContiAU426.rod
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 8W1 713 041 E    HW: 8W1 713 041 E
       Component: GSM-LL        H08 0068
       Revision: 0L0D5012    Serial number: 20160824000509
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 3522220D9485BBE77A-8060
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 8W0 907 217 B    HW: 8W0 907 217
       Component: BVS           H15 0042
       Coding: 0404090200000202022023A2AD0000FC00F0C020C000
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
       VCID: 3B363435B2A16D978C-806E
       Part No SW: 4M0 959 795 G    HW: 4M0 959 795 C
       Component: TSG HFS       009 0052
       Serial number: 0000215047793
       Coding: 000F1B2000001080400000A0
       VCID: 44C44FC9CF5F126FFD-8010
       Component: TSG HBFS      009 0052
       Serial number: 0000215052055
       Part No SW: 4M0 907 594     HW: 4M0 907 594
       Component: SAD_STG_1     011 0003
       Coding: 208000049202
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_004.rod
       VCID: 73A6DC15DA71E5D794-8026
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 4M0 907 590 B    HW: 4M0 907 590
       Revision: --------
       Coding: 0E8002
       ASAM Dataset: EV_RearRadarS2BoschAU736 001015
       ROD: EV_RearRadarS2BoschAU736.rod
       VCID: 312A161D60ED97C726-8064
       VCID: 1660C581E94350FF53-8042
    End----(Elapsed Time: 02:09, VBatt start/end: 11.5V/11.6V. VIgn 11.5V)-----
    HQ
    I've done a bit of digging this and I come up with nothing. The two fault codes, C05E6 and C05DD, I don't find any cases of anyone having those codes, you are patent ZERO! At best I see a wiring diagram for the J492 but that doesn't really help to come up with useful suggestions.
    There are some basic settings that might be helpful, but without knowing the correct procedure, it can be risky to just do random test/request.
    Hopefully some one else will chime in.
    I will point out, good job on posting a full Auto-Scan on your very first post!
    Jef
  3. Likes Uwe liked this post
