2017 a4 fault code c123e hydraulic brake booster - limit value reached
Jphowden
C?ID=167785
Hi, i have a fault with an a4 that i cant get any info on, any help would be appreciated. erwin vehicle specific info is down at the moment so hopefully someone has some knowledge on this fault.
so far i have replaced the brake sevo/vac sensor but still no joy in getting the fault to erase.
Mark
Wednesday,18,September,2019,17:42:29:21450
VIN: WAUZZZF44HA040130   License Plate: SO16PDV
Mileage: 80519km-50032mi   Repair Order:
Chassis Type: F4-AU49 (4M1)
Scan: 01 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F A5 AC BB BC
          D6 D7
VIN: WAUZZZF44HA040130   Mileage: 80519km-50032miles
Address 01: Engine (J623-DEUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 A    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H34 3332
   Revision: B1H34---
   Coding: 0A194032232405083408
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TDI01104L906026A 004006
   ROD: EV_ECM20TDI01104L906026_004.rod
   VCID: 280904C0327627E7A29-807C
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0593
   Coding: 04AA1C9908A60A96159F4894007D5292E6C19620381050A812004A49678369
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_ESP9BOSCHAU49X 012014
   ROD: EV_ESP9BOSCHAU49X_012.rod
   VCID: 47CBA77C9F28C89F4B3-8012
15381504 - Bulb for Parking Light: Hydraulic Brake Boost
          C123E F0 [175] - Limit Value Reached
                    Mileage: 80521 km
                    Date: 2019.09.18
                    Time: 17:08:09
                    7A 00 04 00 C2 00 00 00 00 00
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 F    HW: 8W0 820 043 F
   Component: Klima Zone 3  H32 0071
   Coding: 141800295544440D02000100880000000000000000000000000000000000
   Shop #: WSC 06325 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 3635DAB8E8C24117205-8062
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000945228
   Serial number: F3D8C83800PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: Klima Heck  H40 0073
   Part No SW: 8W0 907 063 BF    HW: 8W0 907 063 BF
   Component: BCM1 MLBevo   H13 0248
   Coding: 07501143E11800CD014487141B0C00B9110B3108000000000000000020001A810A450122025601
   ASAM Dataset: EV_BCM1BOSCHAU736 016006
   ROD: EV_BCM1BOSCHAU736_016.rod
   VCID: 00597C60FA863FA7CA9-8054
   Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 160531  043 0813
   Serial number: 894253?0301615202617
   Coding: 5BC7F7
   Subsystem 2 - Part No SW: 81A 955 555     HW: 81A 955 555
   Component: G397_RLFSS  H06 0001
   Serial number: 20067134X81A95555500
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 07 05 2016  00345286
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE117051611521137
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B10192423
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H16 0010
   Serial number: 2616000068458004
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655     HW: 8W0 959 655
   Component: Airbag10.44   H72 0086
   Serial number: 003M6005948E
   Coding: AACCF0C00C800000585400F3C08C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 06556A78D8A21197F05-8052
   Subsystem 1 - Part No SW: -----------    HW: 442 062 806 16
   Component: SideSensor_Df  1E2 0887
   Serial number: 3577Y00A11FACC32D2BJ
   Subsystem 2 - Part No SW: -----------    HW: 442 062 806 16
   Component: SideSensor_Pf  1E2 0887
   Serial number: 3587Y009D1FACC30F20K
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 206 16
   Component: SideSensor_Dr  1C7 0148
   Serial number: 3517700A52052194416T
   Subsystem 4 - Part No SW: -----------    HW: 442 0B1 206 16
   Component: SideSensor_Pr  1C7 0148
   Serial number: 3527700A52052190A23U
   Subsystem 5 - Part No SW: -----------    HW: 442 0C1 606 16
   Component: FrontSensor_D  1C5 014A
   Serial number: 3557500A920D33B32083
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C1 606 16
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500AB20D33B052CC
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C1 606 16
   Component: PedP_Sensor_C  1C5 014A
   Serial number: 2307500A920D33B2431Z
   Subsystem 8 - Part No SW: -----------    HW: 442 430 107 16
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00AD1F5EA34933W
   Subsystem 9 - Part No SW: -----------    HW: 442 430 107 16
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00A11FACC31030B
   Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
   Component: Lenks.Modul   H11 0009
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76B51AB8A8420117E05-8022
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8W5 920 941 A    HW: 8W5 920 941 A
   Component: MMA4M17DIEUK  H06 0363
   Revision: 0339v7      Serial number:    PY5FKG47S
   Coding: 24A4509028800600012069601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU49.rod
   VCID: 3E25C298C0F28957F85-806A
   Part No SW: 4M1 907 468 C    HW: 4M1 907 468 A
   Component: Gateway       H15 0098
   Revision: 4R040002    Serial number: 0244R002516704
   Coding: 0301000100008E40410700000059001248080007000000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002060
   ROD: EV_GatewCONTIAU736_002_AU49.rod
   VCID: 372BD7BCEFC8B81F3B3-8062
   Subsystem 1 - Part No SW: 8W0 951 523 C    HW: 8W0 951 523 C
   Component: J453 MFL  H02 0002
   Serial number: 20160630202653 02531
   Serial number: 7733300804
Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0023
   ROD: EV_LCMLeftHELLAAU736_VW48.rod
   VCID: 78A91480A2567767F29-802C
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 16000143403008
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323DE6A804AA5D370CD-8066
Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
   Part No SW: 8W0 959 593 G    HW: 8W0 959 593
   Component: TSG FS        005 0052
   Serial number: 0000207992470
   Coding: 001F8A204001000000001082
   ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
   VCID: 4EC59258705219D7085-801A
196660 - Motor for Window Regulator
          B1487 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 104
                    Mileage: 80521 km
                    Date: 2019.09.18
                    Time: 17:08:12
   Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0407
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X_002.rod
   VCID: 40D9BC60BA06FFA78A9-8014
   Part No SW: 8W0 907 064 BB    HW: 8W0 907 064 B
   Component: BCM2 MLBevo   018 0328
   Coding: 012D00002F100000630180000600000031020010004302500F04000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 011012
   ROD: EV_BCM2HellaAU736_011_AU49.rod
   VCID: 7DA705948D74524FA1F-8028
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY161602J40
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000035980839
   Part No SW: 8W0 959 592 G    HW: 8W0 959 592
   Component: TSG BFS       005 0052
   Serial number: 0000207623228
   Coding: 001F8A204001000000001080
   ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
   VCID: 4DC795547D5422CF71F-8018
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
   Part No SW: 8W0 035 192 A    HW: 8W0 035 192 A
   Component: MU-HS-LND-EU  045 0148
   Coding: 01940101FF0A000013111101000A00102F0001C601F00100CE
   ASAM Dataset: EV_MUHigScl6C3DELP 001011
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 3431E0B0FEBE53071E1-8060
   Subsystem 1 - Part No SW: V03 959 801 PC    HW: -----------
   Component: ECE 2016/2017  --- 0020
   Subsystem 2 - Part No SW: 8W2 919 604     HW: 8W2 919 604
   Component: AU49x_DU_STD  H40 0008
   Serial number: AUZ8Z9GBH00CCX
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 J    HW: 8W0 919 614 J
   Component: ControlUnit_B  H21 0134
   Serial number: APVAK116061600020065
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 B    HW: 8W0 907 217
   Component: BVS           H14 0042
   Coding: 0404090100000403024023A0A40000FC00F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 3B23CB8CD3E09C7FDFB-806E
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736_AU49.rod
   VCID: 6E8532D8D01239D7285-803A
   Part No SW: 8W0 959 595 G    HW: 8W0 959 595
   Component: TSG HFS       005 0052
   Serial number: 0000208145078
   Coding: 000F88200001000000001080
   ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
   VCID: 50F98C206A660F271A9-8004
   Component: TSG HBFS      005 0052
   Serial number: 0000208145146
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 16753A388802A117005-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 01:33, VBatt start/end: 12.2V/12.2V)-----------
DrPeter
16.4905° S, 151.7375° W
Thanks for posting the vehicle's Auto-Scan! By the way, the VIN says this is a 2017 WAUZZZF44HA040130 [H = 2017]
Date of production: 21.07.2016
Model year: 2017
I would suggest to have a look at the Advanced Measuring Values in the J104-ABS Controller for the [Pressure in brake booster] and see what it is reading.
With the engine idling, the G608-Vacuum Sensor should be around [-800 to -950mbar] providing there is a decent amount of vacuum at the brake booster.
- The value should change when the pressure (positive or negative) changes.
If not, check the wiring, connections for any concerns, including but not limited to coolant migration and or corrosion.
Hope this helps,
drpeter
Jphowden
C?ID=167785
turns out its a flaw in the abs software that does not allow this fault to clear after it has been seen too many times. apparently the only way to fix it is to fit a new module.
Nikkysan
C?ID=57526
Did you fit a new module and fix the car or was it done under waranty?
