2011 JSW and stupid TPMS question with VCDS
carboncow
Central Ohio
C?ID=266014
I'm not sure why VW makes this so hard on us. My 2008 Toareg told me what the pressure was on each tire. Now I got the dummy light on for 2011 Jetta Sportwagen and I pulled out my trusty VCDS to only find out it will not tell me which wheel is offending.
Also the error code message stated something about pressure (forgot to take screenshot). Is there a different message if the sender is offline (dead battery?) such as low signal or does it just give a generic low pressure message?
FYI I put my tire gauge on all 4 tires and really cannot figure out which one may have lower pressure...although I'm questioning the health of my ancient pressure gauge.
Is there a live pressure value I can track in the system?
Have you posted an Auto-Scan from this car? Does it actually have sensor-based ("direct") TPMS? Because that's kind of a per-requisite in order for it to be able to show you (or know) the individual pressures. Lots of newer cars have indirect TPMS based on a crazy analysis of wheel speed measurements.
carboncow
Central Ohio
C?ID=266014
Uwe,
Thanks for jogging my brain on that tech...now that you say this I seem to recall reading about that kind of tech...just never thought my lowly Jetta would have that. I've only got the mobile scanner handy this week since my laptop is offline. I've included a couple screenshots from the version. Maybe someone can tell me if data shows what type of TPMS I have.
When I got home last night I reset the TPMS with the button in the glove box and after a 60 mile commute to work it didn't return. (this is the 2nd time in two weeks the light has come on). So wondering if the issue is the sensor itself or in the case of wheel speed measurement maybe it's getting a bad value.
QUESTION: Does a full Auto-Scan show more information about a singular module more then what I just shared from the ABS/Brake screens?
QUESTION #2: Is there no way to upload a screenshot to this forum? It's all txt and URL based for such needs?
If there's reset button in the glovebox, I think chances are quite good that this car has an indirect system. Another thing you can do is look at the valve stems. Direct systems use metal valve stems connected to the sensors inside the wheels. Indirect systems use traditional rubber valve stems.
A full Auto-Scan shows how the entire car is equipped. A direct TPMS system will ususally have its own control module, although in some case they are integrated into the BCM or CCM.
That is correct. We do not wish to be responsible for hosting content that might infringe on someone's IP right (particularly VW's!)
carboncow
Central Ohio
C?ID=266014
Button in glove box
Black mental vale stems
The low tire fault code showed up in the ABS module
I'd saw we prob have individual old school TPMS based on your points.
Does a bad sensor throw a low value code or does it show another code such as missing signal?
I don't think so. The ABS is not involved in a direct (sensor-based) system.
PetrolDave
Westbury, UK
C?ID=1423
That's indicative that you have an INDIRECT TPMS system which doesn't have wheel pressure sensors, with a direct TPMS system the fault code would show in the separate TPMS module.
carboncow
Central Ohio
C?ID=266014
That's indicative that you have an INDIRECT TMPS system which doesn't have wheel pressure sensors, with a direct TPMS system the fault code would show in the separate TPMS module.
OK...so the metal valve stems really doesn't confirm much then.
So with the fault code in the ABS and the button in the glove box I'm INDIRECT then.
Are we then stating I should (or should not) be able to get individual pressure values in live data? As I'm not seeing it as a check box option anywhere in the ABS module.
What is the failure trend with the INDIRECT system? I got a error (low pressure) a few weeks back, rotated the tires and got another error (low pressure) this week.
PetrolDave
Westbury, UK
C?ID=1423
Since an INDIRECT system does not have pressure sensors in the wheels, there is no way to see pressure values as live data.
The indirect systems have software that analyses the data from all the ABS wheel speed sensors and looks for changes in the patterns of wheel rotation (not just speed but also vibration, etc.).
It sounds to me like you may have a deformed wheel (hit any large objects or curbs recently?) or a tire that either has some uneven wear patterns or some sidewall damage. I would inspect each wheel/tire carefully.
Any possibility they are aftermarket?
Maybe you could post an Auto-Scan? VCDS-Mobile can do an Auto-Scan. ;)
Did you reset the system after rotating the tires? Make sure they are inflated properly, reset using the button, and let it learn. I would not be at all surprised to see a warning from an indirect system sometime after after rotating the tires if it has not been told to re-learn after the rotation.
carboncow
Central Ohio
C?ID=266014
1. Very posible as this car was bought used and they are 16" OEM wheels, not the standard setup for the JSW SE
2. Yeah...yeah...yeah. I got it, I just find it to be a mild PIA when in AP mode! Plus, isn't there a way to have it appear in a scrollable window on this forum?
3. The warning occurred before and after the rotate with a reset/relearn in between. With that said I've always had vibration in one of the wheels. Sometimes my tech gets it balanced out and sometimes (like now) it's pronounced above 65MPH...so good chance this is a culprit and although not any worse some variable has prob changed. Been kicking around the idea of new wheels to eliminate the vibration (as it's not tie rods, ball joints, inner drivers, ect).
VCDS Mobile 0.4508.0.4
VIN: 3VWPZ7AJ5BM612681
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
Address 01: Engine    Labels: 07K-906-055-CBT.clb
    Part No SW: 07K 906 055 BE    HW: 07K906055
    Component: 2,5l R5/4V      G01  9213
    Revision: T4H04---    Serial Number:
    Coding: 0000075
    Shop #: WSC 08151 444 84507
    VCID: 72A749CB3BDE31D11D6675-8027
No fault codes found.
Address 02: Auto Trans    Labels: 09G-927-750.lbl
    Part No SW: 09G 927 750 LM    HW: 09G927750LM
    Component: AQ 250 6F            1734
    Revision: 00H90000    Serial Number:
    Coding: 0000840
    VCID: 8751881FA05CA479DA584C-80D2
Address 03: ABS Brakes  (J104)    Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
    Component: ESP MK60EC1   H30 0106
    Revision: 00H30001
    Coding: 114B400C492300FC881102EC921A0041B70000
    VCID: 74AB4FD341CABFE10F9A63-8021
Address 08: Auto HVAC  (J301)    Labels: 3C8-907-336.clb
    Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
    Component: Climatic      H14 0305
    Revision: 00009001
    Coding: 0000001002
    Shop #: WSC 00066 000 00146
    ROD: N/A
    VCID: 75AD72D74AB0BEE9388496-8020
    No ASAM data for: "EV_Climatic"
Address 09: Cent. Elect.  (J519)    Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 084 E    HW: 5K0 937 084 E
    Component: BCM PQ35 B    011 0035
    Revision: BG011001
    Coding: 2D380E1F902F3EC400080081600000C401000086435D8D60648020000040
    VCID: 342B8FD3014AFFE1CF1AA3-8061
    Subsystem 1 -  Part No SW: 1K1-955-119-F    Labels: 1Kx-955-119.clb
    Component: Wischer 2907121  0512
    Coding: 009795
Address 15: Airbags  (J234)    Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
    Component: AirbagVW10G   021 0706
    Coding: 00003044
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
    ROD: N/A
    VCID: 3935BEE726281A891C2CEA-806C
    No ASAM data for: "EV_AirbaVW10SMEVW360"
    Subsystem 1 -  Part No SW: 1KM-959-339
    Component: BF-Gewichtss.007 0001
    Serial Number: ---0000R--0005BXZ300
    Subsystem 2 -  Part No SW: 1KM-955-557
    Component: S.Sens.Fahr.VH01 ----
    Serial Number: 3572MSME6A0E3154ZZZ-
    Subsystem 3 -  Part No SW: 1KM-955-557
    Component: S.Sens.Beif.VH01 ----
    Serial Number: 3582MSME03393654ZZZR
    Subsystem 4 -  Component: S.Sens.Fahr.H--- ----
    Serial Number: 3511HSME5C675422ZZZO
    Subsystem 5 -  Component: S.Sens.Beif.H--- ----
    Serial Number: 3521HSME16094A22ZZZG
    Subsystem 6 -  Component: F.Sens.Fahr  --- ----
    Serial Number: 35527SME361D7721ZZZG
    Subsystem 7 -  Component: F.Sens.Beif  --- ----
    Serial Number: 35627SME2C4A4421ZZZG
Address 16: Steering wheel  (J527)    Labels: 5K-16.lbl
    Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
    Component: Lenks.Modul   007 0080
    Revision: --------
    Coding: 188A140000
    Shop #: WSC 00066 000 00186
    ROD: N/A
    VCID: 76AF75DB57B6B5F1318E89-8023
    No ASAM data for: "EV_SMLSNGKUDS"
Address 17: Instruments  (J285)    Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 971 B    HW: 5K0 920 971 B
    Component: KOMBI         H03 0406
    Coding: 270F01
    ROD: N/A
    VCID: 2E1F9DBBEF66CD31B9DE61-807B
    No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
Address 19: CAN Gateway    Labels: 7N0-907-530-V1.clb
    Part No SW: 7N0 907 530 A    HW: 1K0907951
    Component: J533  Gateway   H25  5603
    Revision:   H25    Serial Number: 03081001200958
    Coding: ED807F0600160300002002
    Shop #: WSC 00066 123 12345
    VCID: 2E1F9DBBEF665531B9DE61-807B
Address 1C: Position Sensing    Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 5N0 919 879    HW: 5N0919879
    Component: Kompass         001  0001
    Revision: 00001000    Serial Number: 1225223R99HH06
    VCID: FEBFEDFBFF86E5B1E9FE71-80AB
Address 25: Immobilizer  (J334)    Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234    HW: 5K0 953 234
    Component: IMMO          H03 0406
    ROD: N/A
    VCID: EA97D1AB930EE11125368D-80BF
    No ASAM data for: "EV_Immo_UDS_VDD_RM09"
Address 42: Door Elect, Driver  (J386)    Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C0 959 701 B    HW: 3C0 959 793
    Component: TUER-SG FT    002 0307
    Revision: 13101005
    Coding: 0004B5
    Shop #: WSC 01383 790 50316
    ASAM Dataset: EV_DCU42BroseDriveSide A03004
    ROD: N/A
    VCID: 2711689FC09C9C797A982C-8072
    No ASAM data for: "EV_DCU42BroseDriveSide"
Address 44: Steering Assist    Labels: 1Kx-909-14x-44.clb
    Part No SW: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 70      3001
    Revision: 00H17000
    VCID: 312586C7FE584AC9A4FC82-8064
Address 46: Failed to respond
Address 4F: Centr. Electr. II  (J520)    Labels: 1K0-907-532.clb
    Part No SW: 7N0 907 532    HW: 1K0 907 951
    Component: EZE_2         H25 5603
    Revision:   H25
    Coding: 000B0500
    VCID: EFA1C0BFA8EC1C397248D4-80BA
02071 - Local Databus
Address 52: Door Elect, Pass.  (J387)    Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C0 959 702 B    HW: 3C0 959 792
    Component: TUER-SG BT    002 0307
    Revision: 15101005
    Coding: 0004B4
    ASAM Dataset: EV_DCU52BrosePasseSide A03004
    ROD: N/A
    VCID: 28136BA3CD829301738227-807D
    No ASAM data for: "EV_DCU52BrosePasseSide"
Address 56: Radio  (J503)    Labels: 5M0-035-1xx-56.clb
    Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
    Component: MIB2-S-R-CN   036 0317
    Revision: -----001
    Coding: 1700040004000A
    Shop #: WSC 00081 790 00117
    VCID: 46CFC51B67D67D7161AE99-8013
00856 - Radio Antenna
    007 - Short to Ground
Address 77: Telephone  (J412)    Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
    Component: TELEFON       H05 0440
    Revision: 1B001001
    Coding: 0A00000000010100
    ASAM Dataset: UHVNA A01007
    ROD: N/A
    VCID: 322789CBFB5EE9D1DDE6B5-8067
    No ASAM data for: "UHVNA"
9457427 - ROD - Unknown faultcode
9457171 - ROD - Unknown faultcode
End--(Elapsed Time: 02:11, VBatt start/end: 12.2/12.0 Vign: 0.0)-
I see no TPMS module.
ABS Coding indicates "Tire Pressure Monitoring (TPMS/PR-7K6)", which I think is indirect.
carboncow
Central Ohio
C?ID=266014
Thx. So you ran that code thru something on your side that spits out the TPMS/PR-7k6?
Well, that something is my brain, against the few bits in the MK60EC1 coding that I have familiarity with.
Also, with the VIN, there are people here who can pull the complete PR-Codes from an official parts catalog site, but I'm not one of them.
MasterTommy
Amsterdam
C?ID=295586
One of the many online PR decoders spits out ‘7K6 RDK Indirect Tire Pressure Monitoring System’.
PetrolDave
Westbury, UK
C?ID=1423
Sounds like you may be closer to finding the cause...
Dana
Western PA, USA
Any deviation in WSS readings (i.e. wheel/tire issues, wheel speed sensor issues, rusted wheel bearing pick-up, etc) will prevent indirect TPMS from learning pressures and/or set false pressure codes so the guys already have you on the right path.
I can confirm your vehicle was factory equipped with 7K6 Indirect (ABS based) TPMS.
2006 - 2010 Golf 5 and 6 based US models used direct TPMS however they did NOT have wheel position recognition like your T'reg. PR-Codes can be obtained using PartsLink24. Your full list is:
Vehicle Identification No.3VWPZ7AJ5BM612681
ModelJetta Variant GOV
Date of production05.08.2010
Model year2011
Sales typeAJ53S3
Engine CodeCBUA
Transmission CodeMAN
Axle drive6A
EquipmentNT
Roof color4Y
Carpet color code
Exterior color / Paint Code4Y / A3H
Seat combination no.
Number of Z-Orders
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0HMVehicle class differentiation -1KM- Build status corresponds to production in Mexico
tail pipe0P1Rear side exhaust tailpipe
drive-off assistanceUG1Hill hold control
Emission standard0GTEmission standard SULEV
Trailer hitch1D0without trailer towing
airbag4UMDriver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
Aktivkohlebehälter / Ottopartikelfilter1E7Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
Aerials8L6"diversity" window antenna
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA8CComfort equipment
Brake type in rear1KSDisc brakes in rear (Geomet D)
batteriesJ1LBattery 280 A (60 Ah)
Brake type, front1ZPDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0DAssembly kit, USA corresponding vehicle version (not California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
brake wear indicator9U1brake wear indicator
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H0Without "drive select"
Chrome packageQJ1Chrome package
General operating permit, alterationsC18Operating permit, alteration
Roof rails/roof load rack3S2Black roof rails
Roof insert/convertible top3FUBig roof system
Suspension system in rear1JARear shock absorption, basic design 1
Suspension system in frontG46Shock absorption in front
Load-through hatch/ski bag3X0without load through system
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for components0ERInstallation differentiation for transmission AQ250 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts5MBDecorative inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X0Without park distance control
Electric interface for external useUF0Without electric interface
Manufacturing sequence differentiation0FLMexico manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K4Separate daytime running lights NAR
Vehicle tracing system7G0Without preparation for VTS (Vehicle Tracing System)
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YJWeight range 9 installation control only, no requirement forecast
Weight category front axleL13Suspension range 13 installation control only, no requirement forecast
Base engineT8K5-cylinder SI engine 2.5 l unit 07K.1
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U2Sliding trunk cover
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Luggage compartment trim5A2Comfort luggage compartment trim
Transmission specificationsG1A6-speed automatic transmission
Brackets3P0Without bracket for first aid kit and warning triangle
handle for hand brake lever6PChandbrake lever grip (leather)
Rear spoiler5J0Without rear spoiler
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear seats3NERear seat bench/backrest, split folding with center armrest
Heating and air-conditioning system9APClimatic air-conditioning system (semi-automatic)
Headlamps8ESTwin headlamps for driving on the right, with integrated high beam (US design)
Customized installationFC0Without individual installation
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8DWagon/Avant
Cassette and CD storage unit4W0without cassette / CD tray
coolbox1W2Glove compartment cooling system
child safety4H3Manual child lock
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y2Tropical zones
Compass/road sign displayQR1With compass
headrest for seat, rear3Q9Three rear head restraints
Head restraints3J2Height-adjustable headrests
Fuel tank treatment2LFFuel tank with special material treatment (coextrusion) with changed protective layer
Fuel quantity for initial filling1Z0Initial standard fuel filling
Fuel systems1A1Fuel system for fuel-injected SI engine, injection system without fuel return
Body measures5C1Body measures for increased safety requirements
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
Radiator grille6KCRadiator grille
Rear license plate bracket6P2License plate bracket, rear (NAR)
Front license plate bracket6W3License plate bracket front (small, NAR)
Paint preservative/transit coating5K5Transport protection film with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GDPlane rear cargo area
Steering system arrangementL0LLeft-hand drive
Reading lamp8S4Two reading lights front, two rear
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Air duct, front areaVK1Air duct, type 1
Light control systems8G0Without Light Assist
Load edge protection2P1Plastic loading edge protection
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels2PPLeather-wrapped multi-function steering wheel
Speaker installation8RW10 speakers (passive)
Headlight range control8Q0without beam length regulator
Center armrest6E3Center armrest in front
Marten repellerUM0Without marten repeller
Multi-function display/trip computer9Q5Multi-function display with control
Engine cooling8Z6Hot country
Engine specificationsD775-cylinder SI engine 2.5 l/125 kW (20V) (R-5) base engine is T8K
Left vanity mirror4SHLeft vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
Right vanity mirror4TQVanity mirror, right, illuminated, with cover and special mirror imprint (NAR)
Navigation device7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WAWithout fog lights
Upgrading measuresGP1Vehicles with special upgrade measures
Rear of platform module base4P3Rear floor panel module, type 4
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsCV0Alloy wheels 7J x 17
Radios8AXRadio Premium 8
Smoker's/non-smoker's package9JFNon-smoking package (NAR)
Tire pressure monitoring system7K6Tire pressure monitoring system
tireH7KAll-season tires 225/45 R17 91H (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G1Space-saving spare wheel
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
P75Panoramic sunroof & 17-inch alloy wheelspackage
PMCCalifornia emission standard
WSEWAGON SE (US)
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SSLabels in English and French
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TFFront left comfort seat
Front seat, right3SFComfort seat, front right
Nameplates for sales nameQD3Lettering for sales name
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
Center rear seat belts3C83-point seat belt, center rear with US label
seat coversN2QSeat trim covers in leatherette
Seat adjustment3PTManual height adjustment for front seats
seat heater4A3seat heating for front seats separat controlable
Safety head restraint system3K0w/o safety head restraint system
Side lights7R4Side marker lamps and turn signal repeaters (turn signals with white lens)
Start-stop system/regenerative braking7L3Without start/stop system without regenerative braking
Horns8Y1Two-tone horn
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B0with no protective side strip
Sunroof roller blind for rear/side windows3Y0without roller blind
Supertone system and tone sequence control9J0Without supertone system and tone sequence control
power outlet7B212 volt socket in luggage compartment
Bumper2JBStandard bumpers
Rear stabilizer0BGRear stabilizer
Front stabilizer bar0AHFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Special approval measures3M0Without special measures
Nameplate set0QMNameplate set "SE"
Special alarm systems9A0Without taxi alarm system
Door storage compartments in front3YRDoor pockets with insert mats
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5Hz
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsB38Legal requirements California
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
doors0A24 doors
TV reception/digital radio receptionQU4Satellite radio reception NAR integrated in device
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W7Mobile phone interface (NAR)
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG0without service interval extension
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional child seat anchors3B7Child seat anchors as per Canadian requirements a. ISOFIX child seat system
Auxiliary heating system9M0Without auxiliary heater/parking heater
P.S. If you haven't coded 4F to 050B0500 I would do so to see if any of those problems are resolved.
