Results 1 to 6 of 6
Thread: Passat B8 Electronic Parking Brake activation
    New User
    Sep 2019
    Hi all,
    I can't access the Parking Brake controller on my Passat B8 (2015, G3) to open the electronic parking brake (EPB) and change the rear brake pads. There's no reference to EPB in the scan log either. Has anyone found out how to do it on this model? Scan log below.
    Thanks,
    pojic
    Friday,13,September,2019,19:26:34:08713
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVWZZZ3CZFE513958   License Plate:
    Mileage: 190993km-118677mi   Repair Order:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
    VIN: WVWZZZ3CZFE513958   Mileage: 190993km-118677miles
    Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 AS    HW: 04L 907 309 R
       Component: R4 2,0L EDC   H21 1147
       Revision: B5H21---
       Coding: 0119001203451D083000
       Shop #: WSC 05311 115 00301
       ASAM Dataset: EV_ECM20TDI01104L906026AS 001006
       ROD: EV_ECM20TDI01104L906026AS_VW48.rod
       VCID: 7BF47E5CF2C76997CC-802E
    20004 - Oxygen (Lambda) Sensor B1 S2
              P0136 00 [237] - Malfunction in Circuit
                        Fault Frequency: 16
                        Mileage: 188910 km
                        Date: 2019.08.16
                        Time: 15:38:25
                        Engine speed: 1713.50 /min
                        Normed load value: 83.1 %
                        Vehicle speed: 65 km/h
                        Coolant temperature: 90 °C
                        Intake air temperature: 106 °C
                        Voltage terminal 30: 13.100 V
                        Oxyg.sens.bank 1 after oxi cat: signal qual.pump current regul.: 14
                        Oxyg.sensor bank 1 after oxi cat: signal quality temp regulator: 6
                        O2 bank 1 dwnstrm. of oxi cat: elec. corrected pump current: 0.0000000 A
                        Oxygen sensor bank 1 after oxi cat: heater activation: 83.990 %
                        O2 sensor bank 1 dwnstrm oxi cat: adjustable resistor value: 1231.1 Ohm
                        Oxyg.sens.bank 1 after oxi cat: curr.pump curr.adaptat.: 1.0276
    20005 - Oxygen (Lambda) Sensor B1 S2
              P0136 00 [096] - Malfunction in Circuit
                        Mileage: 190020 km
                        Date: 2019.09.02
                        Time: 16:43:26
                        Engine speed: 1807.00 /min
                        Normed load value: 42.0 %
                        Vehicle speed: 48 km/h
                        Coolant temperature: 57 °C
                        Intake air temperature: 56 °C
                        Voltage terminal 30: 12.580 V
                        Unlearning counter according OBD: 23
                        Oxygen sensor bank 1 after oxi cat: heater activation: 92.249 %
                        O2 sensor bank 1 dwnstrm oxi cat: adjustable resistor value: 1229.9 Ohm
                        Oxyg.sens.bank 1 after oxi cat: curr.pump curr.adaptat.: 1.0176
    19998 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit
              P0141 00 [096] - Malfunction
                        Mileage: 189491 km
                        Date: 2019.08.24
                        Time: 21:38:44
                        Engine speed: 1432.50 /min
                        Normed load value: 80.0 %
                        Vehicle speed: 70 km/h
                        Coolant temperature: 60 °C
                        Intake air temperature: 60 °C
                        Ambient air pressure: 960 mbar
                        Voltage terminal 30: 13.260 V
                        Unlearning counter according OBD: 34
                        Mass airflow sensor 1 bank 1 airflow: raw value: 412.4 mg/stroke
                        Mean injection quantity: 22.39 mg/stroke
                        Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 36 hPa
                        O2 bank 1 dwnstrm. of oxi cat: elec. corrected pump current: 0.0009660 A
                        Oxygen sensor bank 1 after oxi cat: heater activation: 82.724 %
                        Oxygen sensor bank 1 after oxi cat: status signal quality: 14
                        Oxyg.sens.bank 1 after oxi cat: curr.pump curr.adaptat.: 1.0239
    Readiness: 1 1 0 0 0
       Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
       Component: ESC           H42 0625
       Revision: 00000000    Serial number: 61115000002900
       Coding: 0FEC928F34210B6F0780060541CB49F0492CD0E0608292F11460F078C002
       VCID: 7EF27748E1D57CBFEB-802A
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 140
                        Mileage: 158093 km
                        Date: 2018.07.22
                        Time: 14:03:33
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0524
       Revision: 00023000    Serial number: 0367869139
       Coding: 000F0F0603
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       VCID: 77FC626CCEEF4DF7A8-8022
       Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
       Component: AC Manuell    H02 1001
       Revision: 00001K06
       Coding: 12120104202100002000400000000002
       Shop #: WSC 00015 115 00001
       VCID: 3C76BD40B749AEAF85-8068
       Part No SW: 5Q0 937 086 BB    HW: 5Q0 937 086 BB
       Component: BCM PQ37BOSCH 028 0146
       Revision: --------    Serial number: 86580904150653
       Coding: 03010842C241027F0BA44084B10407281880000000000000000000000000
       ROD: EV_BCMBOSCH_014.rod
       Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    150325  043 0607
       Serial number:         150401022523
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S2Y15M04D16H08M23S24
       Coding: 90A8DD
       Light switch:
       Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
       Serial number: 01 03 2015  00000043
       Serial number: 000000000ZY150751UQT
       Serial number: 00000000000032223138
    6 Faults Found:
    6666 - Bulb for Low Beam Headlamp Left
              B1217 15 [008] - Open or Short to Plus
    8458 - Bulb for Right DRL
              B121E 15 [008] - Open or Short to Plus
                        Fault Frequency: 41
                        Reset counter: 92
                        Mileage: 186081 km
                        Date: 2019.07.15
                        Time: 16:36:40
    8711 - Bulb for Left Fog Lamp
              B121F 11 [008] - Short to Ground
    8202 - Bulb for Left DRL
              B121D 15 [008] - Open or Short to Plus
                        Reset counter: 92
                        Mileage: 188660 km
                        Date: 2019.08.13
                        Time: 19:10:50
    204290 - Remote key 1
              B1479 18 [008] - Current Too Low
    262664 - Switch for Interior Monitoring / Inclination Sensor
              B131B 29 [008] - Signal Implausible
       Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0053
       Revision: --------    Serial number: 39391510505903
       Coding: 0071051001
       Shop #: WSC 05311 115 00073
       VCID: 408EC9B0DBA1CA4FD9-8014
       Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
       Component: ACC BOSCH MQB H04 0130
       Coding: 2A40608110FFC428949C804C
       ASAM Dataset: EV_ACCBOSCHVW48X 001007
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3364967C9A1761D754-8066
       Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
       Component: Airbag VW20   012 0195
       Revision: --------    Serial number: 003R1P7HQ0S5
       Coding: 98FCC0C0000000005C5400CC008800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 01080CB4902B034796-8054
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 3G2857705C0120P00450
       Coding: 80000A
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 3G2857706C0125P00162
       Coding: 80000A
       Subsystem 3 - Part No SW: -----------    HW: 454 001 404 15
       Serial number: 3576U000000A407D0414
       Subsystem 4 - Part No SW: -----------    HW: 454 001 504 15
       Serial number: 3586U00000092370241.
       Subsystem 5 - Part No SW: -----------    HW: 454 801 604 15
       Serial number: 3516R64486606000000$
       Subsystem 6 - Part No SW: -----------    HW: 454 801 504 15
       Serial number: 3526R3E416B060000002
       Subsystem 7 - Part No SW: -----------    HW: 454 802 903 15
       Serial number: 3556VFC705406000000D
       Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150418400772
       Coding: 0400
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3D70B044AC53A7A7B2-8068
       Part No SW: 3G0 920 941     HW: 3G0 920 941
       Component: KOMBI         209 4311
       Coding: 27A409102780260001886A001000000000000000
       VCID: 63C4263C6A77B157E4-8036
       Revision: --------    Serial number: 25041510800463
       Coding: 030300044F087300EF00005C080F00010001070000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72EA5378A58D28DF9F-8026
       Component: E221__MFL-DC1  H16 0040
       Serial number: 29150000790720055166
       Coding: 2CFFFF
       Serial number: 2880236403
       Analog clock:
       Component: Analoguhr  209 2002
       Serial number: 15000069608008
       Coding: 0000000000000000
       Shop #: WSC 00015 115 08193
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71E85C74A08B13C766-8024
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 070415BD504189
       Coding: 00350A20D001028000001000
       VCID: 428AC3B8D5ADD85FCF-8016
       Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000001286180
       Coding: 0D0000
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 8103
       Shop #: WSC 00015 115 00301
       VCID: 4384C6BCCAB7D157C4-8016
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 100415BD917516
       Coding: 00350020D001028000001000
       VCID: 4188CCB4D0ABC347D6-8014
       Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000001295693
       Coding: 050000
       Part No SW: 3Q0 035 874     HW: 3Q0 035 874
       Component: MU-S-ND-ER    H10 0138
       Serial number: VWZAZ2R8523748
       Coding: 02840201FF00000011111201000808001F0100C601200100CC
       ASAM Dataset: EV_MUStd4CTSAT 001018
       ROD: EV_MUStd4CTSAT_VW48.rod
       VCID: 6FEC5A0CB6BF053770-803A
       Component: ABT_Std-2_Nav  H44 1017
       Serial number: VWZ8Z9RD801X41
       Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
    End-------------------------(Elapsed Time: 04:13)--------------------------
    Saturday,14,September,2019,12:44:16:08713
    VIN: WVWZZZ3CZFE513958   License Plate: WL15CSO
       Revision: B5H21---
                        Fault Frequency: 16
                        Mileage: 188910 km
                        Date: 2019.08.16
                        Time: 15:38:25
                        Mileage: 190020 km
                        Date: 2019.09.02
                        Time: 16:43:26
                        Mileage: 189491 km
                        Date: 2019.08.24
                        Time: 21:38:44
              C102D 00 [008] - -
                        Reset counter: 140
                        Mileage: 158093 km
                        Date: 2018.07.22
                        Time: 14:03:33
       Coding: 000F0F0603
       Revision: 00001K06
       Coding: 90A8DD
       Light switch:
    6 Faults Found:
                        Fault Frequency: 42
                        Reset counter: 92
                        Mileage: 186081 km
                        Date: 2019.07.15
                        Time: 16:36:40
                        Reset counter: 92
                        Mileage: 188660 km
                        Date: 2019.08.13
                        Time: 19:10:50
       Coding: 0071051001
       Coding: 80000A
       Coding: 80000A
       Coding: 0400
       Coding: 2CFFFF
       Analog clock:
       Coding: 0D0000
       Coding: 8103
       Coding: 050000
    Saturday,14,September,2019,13:32:06:08713
       Revision: B5H21---
       Coding: 000F0F0603
       Revision: 00001K06
       Coding: 90A8DD
       Light switch:
                        Reset counter: 92
                        Mileage: 190993 km
                        Date: 2019.09.14
                        Time: 13:00:16
                        Reset counter: 92
                        Mileage: 190993 km
                        Date: 2019.09.14
                        Time: 13:00:20
       Coding: 0071051001
       Coding: 80000A
       Coding: 80000A
       Coding: 0400
       Coding: 2CFFFF
       Analog clock:
       Coding: 0D0000
       Coding: 8103
       Coding: 050000
    End-------------------------(Elapsed Time: 04:08)--------------------------
    Tartu, Estonia
    Because there isn't one.
    I wanna write the solution here, but uncertain because of the unverified status.
    The world is my oyster...
  3. Likes Uwe, Ashraf6119 liked this post
    Looks to be a borrowed or second-hand VCDS. I'm confident it's legit.
    ABS is "MK100IPB". I believe IPB stands for Integrated Parking Brake.
    Should work just like the Mk.7 Golf and other MQB cars with EPB:
    wiki.ross-tech.com/wiki/index.php/VW_Golf_VII_(5G/AU)_ABS_Brakes
  6. #4
    New User
    Sep 2019
    Thanks for the vote of confidence Uwe, much appreciated. And yes, the VCDS cable is borrowed. To give you confidence in that, the owner (Mr Andrew R. from Barry in the UK) informs me that the lead was on invoice number [redacted] dated 07/11/2016, paid for on credit card. Although not an owner, is this enough to have me verified? Verified user that is, not insane or daft. Although the latter is definitely a moot point.
    I'll look into MK100IPB and let you know how I get on.
    Thanks again for the response,
    Jason (aka pojic)
    New User
    Sep 2019
    That Golf Mk7 link worked a treat. I'll be changing the pads this weekend.
    Should I use the Golf Mk7 forums for VCDS info about the Passat B8 systems?
    Thanks,
    Jason
  8. Likes Uwe liked this post
  9. #6
    Quote Originally Posted by pojic View Post
    I'm afraid not. Only registered users are eligible for "Verified" status here. But that doesn't prevent you from asking questions, or even getting answers.
  10. Likes PetrolDave liked this post
