Results 1 to 5 of 5
Thread: New VCDS user
    Mar 2014
    New VCDS user
    Hi, everyone, my VCDS just got here, and i'm trying to fix this car that i just bought.
    The car runs, but all the lights in the dash stay on, no window or power door lock operation(the trunk is the only thing that works on the key/control). I found diferent modules in the trunk, that i think were changed, here's the auto-scan:
    VCDS Version: Release 12.12.2
    Data version: 20140212
    Thursday,20,March,2014,07:48:05:50926
    Chassis Type: 1K (3C0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
              72
    VIN: 3VWRZ71KX8M162567   Mileage: 270320km/167969miles
    00-Steering Angle Sensor -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    1C-Position Sensing -- Status: Cannot be reached 1100
    25-Immobilizer -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Cannot be reached 1100
    52-Door Elect, Pass. -- Status: Cannot be reached 1100
    53-Parking Brake -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Cannot be reached 1100
    72-Door, Rear Right -- Status: Cannot be reached 1100
    Address 01: Engine (CBU)       Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 BG    HW: 07K 906 032 Q
       Component: 2,5l R5/4V      G   1565
       Revision: 1NH03---    Serial number: VWX7Z0H324215Z
       Coding: 0000003
       VCID: 6FEDDDA57E5BE26672D-803A
    6 Faults Found:
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 008 -
                        Mileage: 270325 km
                        Time: 23:53:35
                        RPM: 1738 /min
                        Load: 33.3 %
                        Temperature: 15.0C
                        Temperature: 17.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 12.065 V
    001112 - Evap System Purge Control Valve (N80)
                   P0458 - 002 - Short to Ground
                        Fault Status: 01100010
                        Mileage: 270325 km
                        Time: 23:54:04
                        RPM: 126 /min
                        Load: 100.0 %
                        Temperature: 15.0C
                        Temperature: 17.0C
                        Voltage: 10.160 V
    008328 - Bank 1 Camshaft A (Intake) Position Actuator
                   P2088 - 002 - Short to Ground
                        Mileage: 270325 km
                        Time: 23:54:04
                        RPM: 126 /min
                        Load: 100.0 %
                        Temperature: 15.0C
                        Temperature: 17.0C
                        Voltage: 10.160 V
    001681 - Fan 1 Control Circuit
                   P0691 - 002 - Short to GND
                        Mileage: 270325 km
                        Time: 23:54:14
                        RPM: 1569 /min
                        Load: 43.1 %
                        Temperature: 15.0C
                        Temperature: 18.0C
                        Voltage: 14.351 V
    049446 - No Communications with Steering Angle Sender (G85)
                   U0126 - 008 -
                        Temperature: 15.0C
                        Temperature: 16.0C
                        Voltage: 12.573 V
    005668 - MIL Request Signal Active (Check TCM for errors too!)
                   P1624 - 008 -
                        Mileage: 270325 km
                        Time: 00:00:56
                        RPM: 1607 /min
                        Load: 38.4 %
                        Temperature: 15.0C
                        Temperature: 17.0C
                        Voltage: 14.351 V
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 09G-927-750.lbl
       Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
       Component: AQ 250 6F           0920
       Revision: 00H25000    Serial number:
       Coding: 0000072
       VCID: 800F0E19D3C56D1E1B7-80D5
                        Fault Status: 10101000
                        Fault Frequency: 15
                        Reset counter: 44
                        Mileage: 11 km
       Part No SW: 1K0 820 047 HJ    HW: 1K0 820 047 HJ
       Component: Climatic PQ35   141 1010
       Revision: 00141028    Serial number: 00000000000000
       VCID: 73E5D1D51273C686965-8026
    6 Faults Found:
    00532 - Supply Voltage B+
    00229 - Refrigerant Pressure
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 00000000942672
       Coding: 14058E234004150007140000001400000008730B5C000120000000000000
       Component: Wischer 080408 021  0501
       Coding: 00038805
       Shop #: WSC 00066
    10 Faults Found:
                        Fault Status: 01111100
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 11.95 V
    01501 - Bulb for Blinkers; Rear Left (M6)
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.55 V
    01505 - Bulb for Blinkers; Rear Right (M8)
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.55 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.55 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.55 V
                        Reset counter: 204
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.10 V
                        Reset counter: 204
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.10 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.30 V
                        Fault Frequency: 10
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.55 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.55 V
       Revision: 00000000    Serial number: AUZ4Z7H0296153
       Coding: 0000000
       VCID: 336511D552F38686565-8066
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:31:35
    16347 - Control Module - EEPROM Error
                        Fault Status: 00101110
                        Reset counter: 244
                        Mileage: 270325 km
                        Time: 00:28:33
    02788 - Internal Communications Error
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:30:03
                        Bin. Bits: 00000000
                        Bin. Bits: 00000001
       Revision: 05034000    Serial number: 003B6M04PNCK
       Coding: 0013889
       VCID: 6CD7CAA94F4D197E57F-8039
       Subsystem 2 - Serial number: 6332MSME2A0618154
       Subsystem 3 - Serial number: 6342MSME2B2305050
       Subsystem 4 - Serial number: 6351HSME133D43677
       Subsystem 5 - Serial number: 6361HSME133D44578
       Subsystem 6 - Serial number: 637  SME
       Subsystem 7 - Serial number: 638  SME
    11 Faults Found:
    01214 - Crash Data for Belt Tensioner Stored
                000 - - - MIL ON
    00595 - Crash Data Stored
                000 - - - MIL ON
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
    01312 - Powertrain Data Bus
                014 - Defective - Intermittent - MIL ON
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
                008 - Implausible Signal - Intermittent - MIL ON
       Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
       Component: J0527           034 0070
       Coding: 0010021
       VCID: 78FFE6F90B15A5DEA37-802D
       Part No SW: 1K0 920 954 Q    HW: 1K0 920 954 Q
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0002000    Serial number: VWX7Z0H324215Z
       Coding: 0023203
       Shop #: WSC 26108 067 57207
       VCID: 3A7B3CF1759977CE953-806F
    9 Faults Found:
                        Fault Status: 00101010
                        Fault Frequency: 24
                        Reset counter: 242
                        Mileage: 270325 km
                        Time: 00:35:22
                        Fault Frequency: 90
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 16:06:06
                        Reset counter: 210
                        Date: 2064.00.00
                        Time: 00:00:00
                        Fault Frequency: 90
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 16:06:06
                        Reset counter: 242
                        Mileage: 270325 km
                        Time: 16:36:12
                        Reset counter: 242
                        Mileage: 270325 km
                        Time: 16:36:12
                        Reset counter: 242
                        Mileage: 270325 km
                        Time: 16:36:12
                        Fault Frequency: 22
                        Reset counter: 244
                        Mileage: 270325 km
                        Time: 01:02:44
                        Fault Frequency: 7
                        Reset counter: 242
                        Mileage: 270325 km
                        Time: 01:31:12
    Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C059190940
       Coding: 3FFD0E04D31002
       Shop #: WSC 00028 028 00001
       VCID: 2149EB9DF80F0416B49-8074
    13 Faults Found:
    02638 - Enabling Steering Column Lock
                        Fault Frequency: 42
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 03:55:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 03:55:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 03:55:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 03:55:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 03:55:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 03:55:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 03:55:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 03:55:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 03:55:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 03:55:12
    00484 - Vehicle Position Recognition Control Module (J603)
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 03:55:16
                        Reset counter: 244
                        Mileage: 270325 km
                        Time: 00:14:18
                        Reset counter: 244
                        Mileage: 270325 km
                        Time: 00:38:01
       Coding: 13900F880186281B0904058FB0880F0488DCA0
       Shop #: WSC 00066 067 57207
       VCID: 84070209C7DD713E3FF-80D1
    7 Faults Found:
                        Fault Frequency: 10
                        Reset counter: 244
                        Reset counter: 242
                        Fault Frequency: 31
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:35:26
                        Fault Frequency: 29
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:35:26
                        Fault Frequency: 31
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:35:26
                        Fault Frequency: 29
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:35:26
    00625 - Vehicle Speed Signal
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:28:34
       Component: Radio ZSW       019 0035
       Revision: 00019000    Serial number: VWZ5Z7H6075349
       Coding: 0040402
       VCID: 2959F3BD803FCC56EC9-807C
                        Fault Frequency: 19
                        Reset counter: 244
                        Mileage: 270325 km
                        Time: 01:13:48
                        Fault Status: 00111011
                        Reset counter: 244
                        Mileage: 270325 km
                        Time: 00:14:44
       Coding: 0100101
                        Fault Status: 01111000
                        Fault Frequency: 7
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:00:53
    Last edited by Uwe; 03-23-2014 at 02:02 PM. Reason: Wrapped CODE tags around Auto-Scan
    That car is a MESS! The first thing I would do is to go to each and every module and clear fault codes in every one of them. Then cycle the ignition at least once, and re-scan to see what comes back.
    Based on the data posted above, you've got more problems than the convenience system not working, e.g. you ABS controller being unaccounted for.
    PS: I made you a "Verified VCDS user" and will eventually move this thread to the car repair section, once we figure out what actually needs to be repaired.
    Mar 2014
    Well after resseting all modules, this is what came back (only the radio and digital radio stated ok):
    Monday,24,March,2014,09:37:32:50926
              72
       Coding: 0000072
                        Fault Frequency: 17
                        Reset counter: 0
                        Mileage: 11 km
       Coding: 00038805
       Shop #: WSC 00066
    10 Faults Found:
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.10 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.10 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.10 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.15 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.15 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.15 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.15 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.25 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.25 V
                        Reset counter: 204
                        Mileage: 270325 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.25 V
       Coding: 0000000
                014 - Defective
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:16:38
                        Reset counter: 244
                        Mileage: 270325 km
                        Time: 00:24:26
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:15:06
                        Bin. Bits: 00000000
                        Bin. Bits: 00000001
       Coding: 0013889
       Subsystem 1 - Part No: 1K0 909 605 AB
       Subsystem 2 - Part No: 1K0 959 339 F
    No Faults Found
       Coding: 0010021
       Coding: 0023203
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:21:36
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:21:36
    11 Faults Found:
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:11
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:12
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:16
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:27:39
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:27:41
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:27:41
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:27:41
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:27:41
       Coding: 0040402
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:25:46
       Coding: 0100101
                        Reset counter: 204
                        Mileage: 270325 km
                        Time: 00:29:24
    I think everything is related to the engine computer and the ABS module, do you think if i disconect both, and try to comunicate with the rest of the modules, i'll be able to start my car again later(once conected again)? because the weird thing is that i cant reach the inmobilizer unit(how is the car starting?) and i'm afraid i wont be able to start the car after i reconect the modules.
    Last edited by Uwe; 03-24-2014 at 02:56 PM. Reason: Wrapped CODE tags around Auto-Scan
    Mar 2014
    Well, got rid of the car because of some mechanical problems as well. Uwe was right, that car was a MESS!
    But i'm now a proud owner of VCDS, and i will try to learn how to use it properly since i don't do much Euros in my shop (i guess i will in the near future).
    Thank You.
    We will certainly try to help. It's pretty rare to see a car that's as screwed up as the one you posted a scan from above.
