Results 1 to 10 of 10
Thread: R8 spoiler de activation
    Jul 2019
    Pakistan
    I recently deactivated the spoiler from 2017 R8 non plus using VCDS. However the warning light is coming on saying that the spoiler is deactivated and drive accordingly. Can I remove this light?
    Please post an Auto-Scan so people can see exactly how this car is equipped. Also, please explain exactly what steps you followed to de-activate the spoiler.
    Jul 2019
    Pakistan
    The following was done to change the coding.
    As mentioned the spoiler is fully retracted now and warning sign is illuminated as mentioned. I am out of the country so can’t do an auto scan.
    You should be able to change the Coding in 46-Cent. Conv. Use the Long Coding helper top uncheck Byte 6, Bit 7. This should change your Coding from:
    011A0E8000B18081E330CA0000050000000000000000000000 0000000000
    Jun 2014
    Swansea, UK
    Quote Originally Posted by Ahsan View Post
    Come back with a scan when you're back in the country then please.
    Without it we know nothing about the configuration of the car so would just be making educated guesses.
  5. Likes PetrolDave, Uwe liked this post
    Jul 2019
    Pakistan
    Quote Originally Posted by Mike@Gendan View Post
    Will do just that once I am back. Tks
  7. Likes Mike@Gendan liked this post
    Jul 2019
    Pakistan
    following is the scan; dont think it mentions anything about the spoiler. the problem i am facing after spoiler de activation one is that a message is activated when i start the car which reads spoiler fault adapt driving style. Secondly, my ESP if i switch it off it automatically is getting turned on at high speeds. dont know if it is related. My scan is below. need your help to sort this out. tks a lot.
    Sunday,06,October,2019,02:36:41:02733
    VIN: WUAZZZFX6H7903331   License Plate:
    Mileage: 23625km-14679mi   Repair Order:
    Chassis Type: FX-AU72 (4S0)
    Scan: 01 02 03 05 06 08 09 11 31 14 15 16 17 19 22 36 3B 42 44 46
              52 53 55 5F 65 6C 81 A6 C2
    VIN: WUAZZZFX6H7903331   Mileage: 23625km-14679miles
    11-Engine II -- Status: Malfunction 0010
    31-Engine other -- Status: Malfunction 0010
    A6-Microphone -- Status: OK 0000
    C2-Auto Trans 2 -- Status: OK 0000
    Address 01: Engine (------CSPB)       Labels: None
       Part No SW: 4S0 907 552 L    HW: 4T0 907 552 A
       Component: 5.2l V10HDZ / H56 0003
       Revision: NHH56---
       Coding: 1A250032052600093000
       ASAM Dataset: EV_ECM52FSI1114S0907552L 001003
       ROD: EV_ECM52FSI1114S0907552L.rod
       VCID: 3FDB405317FD162FF0D-806A
    19305 - Exhaust Pressure Control Valve
              P0475 00 [046] - Electrical Malfunction
                        Fault Frequency: 141
                        Mileage: 23463 km
                        Date: 2019.10.04
                        Time: 14:13:08
                        Coolant temperature: 74 °C
                        Intake air temperature: 65 °C
                        Voltage terminal 30: 11.803 V
                        Engine status: COENG_READY
    7661 - Secondary Air Injection Solenoid Valve (N112)
              P1432 00 [175] - Open Circuit
                        Mileage: 23463 km
                        Date: 2019.10.04
                        Time: 14:13:07
    Readiness: 0010 1001
    Address 02: Auto Trans (J217)       Labels: None
       Part No SW: 4S0 927 155 F    HW: 0BH 927 711 F
       Component: AU 6E SB  RdW H10 3913
       Revision: 00H10V01
       ASAM Dataset: EV_TCMDL800041 001013
       ROD: EV_TCMDL800041_AU72.rod
       VCID: 3A2D31470CDF3307C73-806E
       Part No SW: 4S0 907 379 D    HW: 4S0 907 379 D
       Component: ESP PREMIUM   H09 0300
       Coding: 01A1C10B808583D04B00
       ASAM Dataset: EV_ESPPremiAU57X 004048
       ROD: EV_ESPPremiAU57X_AU72.rod
       VCID: 3E253D5710F71F27FBB-806A
    0668 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_HSP_01_Timeout]
                        Reset counter: 12
                        Mileage: 23463 km
                        Date: 2019.10.04
                        Time: 14:13:22
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E4
                        Uz: 9A
       Part No SW: 4H0 907 064 JD    HW: 4H0 907 064 JD
       Component: BCM2 2.0      H44 0582
       Coding: 05906F06000000000000
       VCID: 74B1DF7F6EBB8577DDF-8020
       Serial number: 3216000217245002
       Part No SW: 4S0 959 760     HW: 4S0 959 760
       Component: MEM-BFS       001 0020
       Revision: AA001003    Serial number: 00000179650048
       Coding: 00201000000420F1000001210101210000000000000000
       VCID: 7BA3F44343E5CA0F9C5-802E
       Part No SW: 4S0 820 043 K    HW: 4S0 820 043 K
       Component: AC Automat    H08 0040
       Revision: 20012000    Serial number: 96800000004731
       Coding: 4100A01400000410
       ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
       ROD: EV_AirCondiVAPrehAU72x.rod
       VCID: 33331C632BB5C24F045-8066
       Operating and display unit 2 for air conditioning:
       Subsystem 1 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
       Component: E775 BuA_2  H07 0020
       Serial number: 00000000000000006004
       Operating and display unit 3 for air conditioning:
       Subsystem 2 - Part No SW: 8S0 820 359     HW: 8S0 820 359
       Component: E776 BuA_3  H07 0020
       Operating and display unit 4 for air conditioning:
       Subsystem 3 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
       Component: E777 BuA_4  H07 0020
    1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
              B10F0 00 [008] - -
                        Reset counter: 44
                        Mileage: 23364 km
                        Date: 2019.10.01
                        Time: 23:03:24
                        Voltage terminal 30: 11.8 V
                        Compressor shut-off requirement: Engine running time too short: engine start not detected by CAN
              B10CD 00 [008] - -
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:31
                        Blower reduction: No switch-off: no reduction
    459029 - Databus
              [Motor_06 - Motorsteuergerät - Datenbus fehlende Botschaft]
                        Fault Frequency: 12
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:01
                        Voltage terminal 30: 11.9 V
                        System run time-Terminal 15 on: 253 s
       Part No SW: 4H0 907 063 HK    HW: 4H0 907 063 EK
       Component: BCM1 2.0      H21 0725
       Revision: 2502102S    Serial number: 00001497773402
       Coding: 010DC01410349FE06D0140C380001800C59DC2882308320100040814E1101100004000340B0000
       VCID: 78A9EB4F72D3E117F17-802C
       Subsystem 1 - Part No SW: 4S2 955 119 B    HW: 8V2 955 119 A
       Component: WWS624 160904  043 0081
       Serial number: 90248163160912225137
       Coding: 3247FD
       Serial number: 62343591
       Coding: 02005D
       Subsystem 3 - Part No SW: 4S0 941 531     HW: 4S0 941 531
       Component: E1 - LDS  H01 0044
       Serial number: 10 10 2016  00000097
       Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0005
       Serial number: 28788E4800PAG0MUFU03
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:01
    Address 11: Engine II (-----)       Labels: None
       Revision: NHH56---
       ASAM Dataset: EV_ECM52FSI2114S0907552L 001003
       ROD: EV_ECM52FSI2114S0907552K.rod
    12694 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 2
              P2436 00 [101] - Implausible Signal
                        Mileage: 23534 km
                        Date: 2019.10.05
                        Time: 14:04:51
                        Engine speed: 1416.00 /min
                        Normed load value: 32.2 %
                        Coolant temperature: 36 °C
                        Intake air temperature: 30 °C
                        Voltage terminal 30: 13.264 V
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 4S0 907 376 D    HW: 4S0 907 376 C
       Component: DAEMPFUNGS-SG H06 0064
       Serial number:       161016019
       ASAM Dataset: EV_AudiMagneRide 002008
       ROD: EV_AudiMagneRide.rod
       VCID: 3B23344303E50A0FDC5-806E
    7 Faults Found:
    10506241 - Databus
              [Motor_07_Timeout]
                        Reset counter: 49
                        Mileage: 22316 km
                        Date: 2019.08.23
                        Time: 19:52:53
                        COM: 0E 0F 0E 2D 00 03 C6 BD 00 00
                        Voltage terminal 30: 12.2 V
                        Terminal 15 status via CAN: Terminal 15 on
                        Engine run: Not available
                        Engine torque: Not available
                        AMR state: 6
                        Damping adjustment indicator lamp: OFF
                        ESP automatic engagement: not activated
                        Fall-back level: 00 70 20 00
    10518529 - Databus
              [Motor_Code_01_Timeout]
                        Reset counter: 49
                        Mileage: 22316 km
                        Date: 2019.08.23
                        Time: 19:52:53
                        AMR state: 6
    10563585 - Databus
              [Motor_03_Timeout]
                        Reset counter: 49
                        Mileage: 22316 km
                        Date: 2019.08.23
                        Time: 19:52:49
                        COM: 0E 0F 0E 2D 00 03 B5 5B 00 00
                        Engine torque: -5 Nm
                        AMR state: 0
                        Fall-back level: 00 00 00 00
    10563587 - Databus
              [init value Fahrerwusch]
                        Reset counter: 44
                        Mileage: 22316 km
                        Date: 2019.08.23
                        Time: 20:01:05
                        COM: 0E D6 0E F5 00 0B 46 E5 00 00
                        Engine run: 0
                        AMR state: 6
                        Fall-back level: 00 F8 20 00
    10563589 - Databus
              [init value Moment Verlust]
                        Reset counter: 44
                        Mileage: 22316 km
                        Date: 2019.08.23
                        Time: 20:01:05
                        Engine run: 0
                        AMR state: 6
    10563591 - Databus
              [init value Mom_m_ex]
                        Reset counter: 44
                        Mileage: 22316 km
                        Date: 2019.08.23
                        Time: 20:01:05
                        Engine run: 0
                        AMR state: 6
    10567681 - Databus
              [Motor_03_Timeout]
                        Reset counter: 49
                        Mileage: 22316 km
                        Date: 2019.08.23
                        Time: 19:52:49
                        AMR state: 0
       Part No SW: 4S0 959 655     HW: 4S0 959 655
       Component: Airbag10.43   H62 0204
       Revision: --------    Serial number: 003NJ0014M4X
       Coding: 30333845303430303639554A305234533053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
       VCID: 7EA5FD575077DF27BBB-802A
       Serial number: 3575HRB404P4529MG8QS
       Serial number: 3585HRB405N45HVKB10P
       Serial number: 3515JRB401A57ACIMP9M
       Serial number: 3525JRB4002578J6S8UH
       Serial number: 3554VRB400C57EUIQ9B7
       Serial number: 3564VRB400C57EUIR9B9
    1057536 - Databus
              [CAN: 0x105 Motor_03 Timeout]
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:01
       Part No SW: 4S0 907 129 J    HW: 4S0 907 129 J
       Component: Lenks.Modul   H06 0007
       Revision: C0071527    Serial number: 91335PJL01657-
       Coding: 000034
       VCID: 3D273A5B1D71043FE21-8068
       Part No SW: 4S0 920 790 A    HW: 4S0 920 790 A
       Component: FBenRDW       H14 0251
       Coding: 242D30C0BA8200080120ECC41000801000000000
       ASAM Dataset: EV_DashBoardBOSCHAU724 001022
       ROD: EV_DashBoardBOSCHAU724.rod
    16776971 - Databus
              [Motor_04 communication error can_error_timeout]
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:01
    16777088 - Databus
              [HSP_01 communication error can_error_timeout]
                        Fault Frequency: 63
                        Reset counter: 14
                        Mileage: 23350 km
                        Date: 2019.09.16
                        Time: 08:58:42
       Part No SW: 4S0 907 468 B    HW: 4S0 907 468 A
       Component: J533--Gateway H15 0074
       Revision: --------    Serial number: 00000002409533
       Coding: 802103161C
       Subsystem 1 - Part No SW: 4S0 915 181     HW: 4S0 915 181
       Component: J367-BDM  H08 0270
       Serial number: 53265G13192871626747
    5186 - Second (Slave) Engine Control Module
              U0115 00 [008] - No Communication
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 12:05:28
                        Voltage terminal 15: 11.8 V
                        Control Module temperature: 39 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    4224 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [008] - -
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:01
                        Voltage terminal 15: 11.9 V
                        Control Module temperature: 36 °C
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    Address 22: AWD (J492)       Labels: None
       Part No SW: 4S0 907 160     HW: 4S0 907 160
       Component: 4 Wheel Drive H07 0207
       Revision: 00001002    Serial number: BBP133Q
       ASAM Dataset: EV_AllWheelContrBORGLB724 006012
       ROD: EV_AllWheelContrBORGLB724.rod
       VCID: 6E85CD170017AFA72BB-803A
       Component: MEM-FS        001 0020
       Revision: AA001003    Serial number: 00000179650305
       Coding: 00381900000420F1C00001210101210000000000000000
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E02FNMY
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 372B28733FCD2E6F38D-8062
       Coding: 011C52425001000300080402
       VCID: 47CB58B34FAD5EEF48D-8012
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:05
       Part No SW: 4S0 909 144 H    HW: 4S0 909 144 B
       Component: EPS           H13 0905
       Revision: 00000000    Serial number:      L00157683
       Coding: 0802
       ASAM Dataset: EV_EPSZFAU72X 003010
       ROD: EV_EPSZFAU72X_003.rod
    12656642 - Databus
              U1121 00 [040] - Missing Message
              [BDE_CAN_Timeout]
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:01
                        Expanded ambient data 1-Terminal 30 voltage filtered: 12.00 V
                        Expanded ambient data 1-Internal voltage supply 5V: 0.00 V
                        Expanded ambient data 1-Vehicle speed: 0 km/h
                        Expanded ambient data 1-Control module temp: internal sensor: 40 °C
                        Expanded ambient data 1-Speed source: CAN ESP speed
                        Expanded ambient data 1-Combustion engine: status: Motor not running
                        Expanded ambient data 1-AD converter reference voltage: 1.50 V
                        Expanded ambient data 1-Voltage terminal 30 unfiltered: 12.00 V
                        Expanded ambient data 1-AD converter reference voltage 2: 1.50 V
                        Expanded ambient data 1-Switched voltage terminal 30 unfiltered: 12.06 V
                        Expanded ambient data 1-KFA: 00 00
                        Expanded ambient data 1-KFC: 00 3B
       Revision: 00002001    Serial number: 0420549296
       Coding: 011A0E8000B10081E330CA00000500000000000000000000000000000000
       Subsystem 1 - Part No: 4S0 951 177
       Component: Sensor, DWA  005 0002
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:01
                        Fault Status: 00101100
                        Reset counter: 42
                        Mileage: 23358 km
                        Date: 2019.09.26
                        Time: 16:10:27
       Coding: 011C52425E01000300080400
       VCID: 46D555B748A747E7B3B-8012
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:05
       Part No SW: 4S0 907 801     HW: 8K0 907 801 J
       Component: EPB-4         H03 0001
       Revision: --------    Serial number: 20000000002697
       ROD: EV_ParkiBrake_AU72.rod
       VCID: 70B9D36F1A23B957397-8024
    334080 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_MOTOR_02_MESSAGE_TIMEOUT]
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:00
                        Voltage terminal 30: 12.0 V
                        Internal Fault ID: 51
                        Function light in parking brake button: On
                        Red operating lamp: On
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
                        Status ParkingBrake left: Set
                        Status ParkingBrake right: Set
    331264 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_MOTOR_01_MESSAGE_TIMEOUT]
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:00
                        Internal Fault ID: 99
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    331520 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_MOTOR_03_MESSAGE_TIMEOUT]
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:00
                        Internal Fault ID: 100
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    331776 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [FC_MOTOR_CODE_01_MESSAGE_TIMEOUT]
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:00
                        Internal Fault ID: 101
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    464384 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                        Reset counter: 38
                        Mileage: 23168 km
                        Date: 2019.09.10
                        Time: 09:45:22
                        Voltage terminal 30: 14.0 V
                        Internal Fault ID: 188
                        Vehicle speed: 134 km/h
                        Red operating lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Internal Parking Brake state: Dynamic
       Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0115
       Coding: 077E001022200200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
       VCID: 3635257738C7D76723B-8062
       Subsystem 1 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0008
       Coding: E02200
       Subsystem 2 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0008
       Coding: E02200
    13705475 - Databus
              [Timeout CAN-Message Motor_03 (0x105)]
                        Reset counter: 49
                        Mileage: 22777 km
                        Date: 2019.09.06
                        Time: 11:57:01
       Part No SW: 4S0 035 045 C    HW: 4S0 035 045 B
       Component: MU-H-N-RW     053 0909
       Serial number: A730J0GB000506
       Coding: 012704070000000013110002000A00212F0000E2007000005E
       ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
       ROD: EV_MUHig6C8Gen2HBAS.rod
       VCID: 2B030403F3859A8F4C5-807E
       Subsystem 1 - Part No SW: V03 959 801 FQ    HW: -----------
       Component: ROW 2017  --- 0062
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 4S2 919 614 D    HW: 4S2 919 614 D
       Serial number: APVAK126081600010016
       Component: Gracenote2---  --- 4011
    6708 - Databus
              [Engine: no communication]
                        Reset counter: 49
                        Mileage: 22316 km
                        Date: 2019.08.23
                        Time: 19:52:53
    Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
       Part No SW: 4H0 907 273 D    HW: 4H0 907 273 B
       Component: RDKBERU25     H10 0900
       Serial number: 10000000033742
       ROD: EV_RDKBERU25_AU57.rod
       VCID: 2C01071FF68B9DB745F-8078
    Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
       Part No SW: 4S0 980 556 A    HW: 95B 980 551 L
       Component: RVC Compact   H12 0201
       Coding: 0275040102000001000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
       ROD: EV_CamSysRVRVCPANAAU57X_002_AU72.rod
       VCID: 392F2E4B09D9381FCE9-806C
       Part No SW: 4S2 713 041 C    HW: 4M2 713 041 F
       Component: GSM-LL        H09 0073
       Revision: 0L0D5012    Serial number: 20160913001070
       ROD: EV_GSMWaehlZFAU736.rod
    Address A6: Microphone (J886)       Labels:. 420-907-394.clb
       Part No SW: 420 907 394 A    HW: 420 907 394
       Component: BELTMICBOX    H10 0600
       Coding: 0101030202
       ASAM Dataset: EV_BeltMicPARAGAU335 003011
       ROD: EV_BeltMicPARAGAU335.rod
       VCID: 176BC8F35F0D0E6F18D-8042
    Address C2: Auto Trans 2 (J217)       Labels: None
       Part No SW: 4S0 927 109     HW: 4S0 927 109
       Component: DL800 ZSG     H11 0002
       Revision: --H11---    Serial number: 0000000122
       Coding: 000001
       ASAM Dataset: EV_TCMDL800421 001024
       ROD: EV_TCMDL800.rod
       VCID: 73B3DC636B35824FC45-8026
    End----------(Elapsed Time: 01:50, VBatt start/end: 13.2V/13.4V)-----------
    Try and remove Byte 14 Bit 7 in [17-Instrument] Coding, if that change anything.
  10. Likes Uwe liked this post
  11. #8
    Jul 2019
    Pakistan
    Tks for replying! I can get to instrument 17. Can’t understand beyond that. Sorry but can u kindly help me as I am very new to this. Tks once again.
  12. #9
    You write about change in 46 that you did, it is similar in 17.
    You can copy and insert this as new Coding in 17 Instrument.
    Byte 14 Bit 7 is unchecked:
    242D30C0BA8200080120ECC41000001000000000
  13. Likes Uwe liked this post
  14. #10
    Jul 2019
    Pakistan
    That worked like magic. Changed the coding and the fault sign is all but gone. Thank you so very much. VCDS is awesome!
  15. Likes Uwe liked this post
