I recently deactivated the spoiler from 2017 R8 non plus using VCDS. However the warning light is coming on saying that the spoiler is deactivated and drive accordingly. Can I remove this light?
Please post an Auto-Scan so people can see exactly how this car is equipped. Also, please explain exactly what steps you followed to de-activate the spoiler.
Come back with a scan when you're back in the country then please.I am out of the country so can’t do an auto scan.
Without it we know nothing about the configuration of the car so would just be making educated guesses.
Sunday,06,October,2019,02:36:41:02733
VIN: WUAZZZFX6H7903331 License Plate:
Mileage: 23625km-14679mi Repair Order:
Chassis Type: FX-AU72 (4S0)
Scan: 01 02 03 05 06 08 09 11 31 14 15 16 17 19 22 36 3B 42 44 46
52 53 55 5F 65 6C 81 A6 C2
VIN: WUAZZZFX6H7903331 Mileage: 23625km-14679miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
A6-Microphone -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (------CSPB) Labels: None
Part No SW: 4S0 907 552 L HW: 4T0 907 552 A
Component: 5.2l V10HDZ / H56 0003
Revision: NHH56---
Coding: 1A250032052600093000
ASAM Dataset: EV_ECM52FSI1114S0907552L 001003
ROD: EV_ECM52FSI1114S0907552L.rod
VCID: 3FDB405317FD162FF0D-806A
19305 - Exhaust Pressure Control Valve
P0475 00 [046] - Electrical Malfunction
Fault Frequency: 141
Mileage: 23463 km
Date: 2019.10.04
Time: 14:13:08
Coolant temperature: 74 °C
Intake air temperature: 65 °C
Voltage terminal 30: 11.803 V
Engine status: COENG_READY
7661 - Secondary Air Injection Solenoid Valve (N112)
P1432 00 [175] - Open Circuit
Mileage: 23463 km
Date: 2019.10.04
Time: 14:13:07
Readiness: 0010 1001
Address 02: Auto Trans (J217) Labels: None
Part No SW: 4S0 927 155 F HW: 0BH 927 711 F
Component: AU 6E SB RdW H10 3913
Revision: 00H10V01
ASAM Dataset: EV_TCMDL800041 001013
ROD: EV_TCMDL800041_AU72.rod
VCID: 3A2D31470CDF3307C73-806E
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4S0 907 379 D HW: 4S0 907 379 D
Component: ESP PREMIUM H09 0300
Coding: 01A1C10B808583D04B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004048
ROD: EV_ESPPremiAU57X_AU72.rod
VCID: 3E253D5710F71F27FBB-806A
0668 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_HSP_01_Timeout]
Reset counter: 12
Mileage: 23463 km
Date: 2019.10.04
Time: 14:13:22
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: E4
Uz: 9A
Part No SW: 4H0 907 064 JD HW: 4H0 907 064 JD
Component: BCM2 2.0 H44 0582
Coding: 05906F06000000000000
VCID: 74B1DF7F6EBB8577DDF-8020
Serial number: 3216000217245002
Part No SW: 4S0 959 760 HW: 4S0 959 760
Component: MEM-BFS 001 0020
Revision: AA001003 Serial number: 00000179650048
Coding: 00201000000420F1000001210101210000000000000000
VCID: 7BA3F44343E5CA0F9C5-802E
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4S0 820 043 K HW: 4S0 820 043 K
Component: AC Automat H08 0040
Revision: 20012000 Serial number: 96800000004731
Coding: 4100A01400000410
ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
ROD: EV_AirCondiVAPrehAU72x.rod
VCID: 33331C632BB5C24F045-8066
Operating and display unit 2 for air conditioning:
Subsystem 1 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Serial number: 00000000000000006004
Operating and display unit 3 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Operating and display unit 4 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
B10F0 00 [008] - -
Reset counter: 44
Mileage: 23364 km
Date: 2019.10.01
Time: 23:03:24
Voltage terminal 30: 11.8 V
Compressor shut-off requirement: Engine running time too short: engine start not detected by CAN
B10CD 00 [008] - -
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:31
Blower reduction: No switch-off: no reduction
459029 - Databus
[Motor_06 - Motorsteuergerät - Datenbus fehlende Botschaft]
Fault Frequency: 12
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:01
Voltage terminal 30: 11.9 V
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 HK HW: 4H0 907 063 EK
Component: BCM1 2.0 H21 0725
Revision: 2502102S Serial number: 00001497773402
Coding: 010DC01410349FE06D0140C380001800C59DC2882308320100040814E1101100004000340B0000
VCID: 78A9EB4F72D3E117F17-802C
Subsystem 1 - Part No SW: 4S2 955 119 B HW: 8V2 955 119 A
Component: WWS624 160904 043 0081
Serial number: 90248163160912225137
Coding: 3247FD
Component: G397_RLFS H06 0004
Serial number: 62343591
Coding: 02005D
Subsystem 3 - Part No SW: 4S0 941 531 HW: 4S0 941 531
Component: E1 - LDS H01 0044
Serial number: 10 10 2016 00000097
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 28788E4800PAG0MUFU03
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:01
Address 11: Engine II (-----) Labels: None
Revision: NHH56---
ASAM Dataset: EV_ECM52FSI2114S0907552L 001003
ROD: EV_ECM52FSI2114S0907552K.rod
12694 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 2
P2436 00 [101] - Implausible Signal
Mileage: 23534 km
Date: 2019.10.05
Time: 14:04:51
Engine speed: 1416.00 /min
Normed load value: 32.2 %
Coolant temperature: 36 °C
Intake air temperature: 30 °C
Voltage terminal 30: 13.264 V
Engine status: COENG_RUNNING
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 4S0 907 376 D HW: 4S0 907 376 C
Component: DAEMPFUNGS-SG H06 0064
Serial number: 161016019
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide.rod
VCID: 3B23344303E50A0FDC5-806E
7 Faults Found:
10506241 - Databus
[Motor_07_Timeout]
Reset counter: 49
Mileage: 22316 km
Date: 2019.08.23
Time: 19:52:53
COM: 0E 0F 0E 2D 00 03 C6 BD 00 00
Voltage terminal 30: 12.2 V
Terminal 15 status via CAN: Terminal 15 on
Engine run: Not available
Engine torque: Not available
AMR state: 6
Damping adjustment indicator lamp: OFF
ESP automatic engagement: not activated
Fall-back level: 00 70 20 00
10518529 - Databus
[Motor_Code_01_Timeout]
Reset counter: 49
Mileage: 22316 km
Date: 2019.08.23
Time: 19:52:53
AMR state: 6
10563585 - Databus
[Motor_03_Timeout]
Reset counter: 49
Mileage: 22316 km
Date: 2019.08.23
Time: 19:52:49
COM: 0E 0F 0E 2D 00 03 B5 5B 00 00
Engine torque: -5 Nm
AMR state: 0
Fall-back level: 00 00 00 00
10563587 - Databus
[init value Fahrerwusch]
Reset counter: 44
Mileage: 22316 km
Date: 2019.08.23
Time: 20:01:05
COM: 0E D6 0E F5 00 0B 46 E5 00 00
Engine run: 0
AMR state: 6
Fall-back level: 00 F8 20 00
10563589 - Databus
[init value Moment Verlust]
Reset counter: 44
Mileage: 22316 km
Date: 2019.08.23
Time: 20:01:05
Engine run: 0
AMR state: 6
10563591 - Databus
[init value Mom_m_ex]
Reset counter: 44
Mileage: 22316 km
Date: 2019.08.23
Time: 20:01:05
Engine run: 0
AMR state: 6
10567681 - Databus
[Motor_03_Timeout]
Reset counter: 49
Mileage: 22316 km
Date: 2019.08.23
Time: 19:52:49
AMR state: 0
Address 15: Airbags (J234) Labels:* None
Part No SW: 4S0 959 655 HW: 4S0 959 655
Component: Airbag10.43 H62 0204
Revision: -------- Serial number: 003NJ0014M4X
Coding: 30333845303430303639554A305234533053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
VCID: 7EA5FD575077DF27BBB-802A
Serial number: 3575HRB404P4529MG8QS
Serial number: 3585HRB405N45HVKB10P
Serial number: 3515JRB401A57ACIMP9M
Serial number: 3525JRB4002578J6S8UH
Serial number: 3554VRB400C57EUIQ9B7
Serial number: 3564VRB400C57EUIR9B9
1057536 - Databus
[CAN: 0x105 Motor_03 Timeout]
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:01
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4S0 907 129 J HW: 4S0 907 129 J
Component: Lenks.Modul H06 0007
Revision: C0071527 Serial number: 91335PJL01657-
Coding: 000034
VCID: 3D273A5B1D71043FE21-8068
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4S0 920 790 A HW: 4S0 920 790 A
Component: FBenRDW H14 0251
Coding: 242D30C0BA8200080120ECC41000801000000000
ASAM Dataset: EV_DashBoardBOSCHAU724 001022
ROD: EV_DashBoardBOSCHAU724.rod
16776971 - Databus
[Motor_04 communication error can_error_timeout]
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:01
16777088 - Databus
[HSP_01 communication error can_error_timeout]
Fault Frequency: 63
Reset counter: 14
Mileage: 23350 km
Date: 2019.09.16
Time: 08:58:42
Part No SW: 4S0 907 468 B HW: 4S0 907 468 A
Component: J533--Gateway H15 0074
Revision: -------- Serial number: 00000002409533
Coding: 802103161C
ASAM Dataset: EV_GatewPkoUDS 002000
Subsystem 1 - Part No SW: 4S0 915 181 HW: 4S0 915 181
Component: J367-BDM H08 0270
Serial number: 53265G13192871626747
5186 - Second (Slave) Engine Control Module
U0115 00 [008] - No Communication
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 12:05:28
Voltage terminal 15: 11.8 V
Control Module temperature: 39 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:01
Voltage terminal 15: 11.9 V
Control Module temperature: 36 °C
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Address 22: AWD (J492) Labels: None
Part No SW: 4S0 907 160 HW: 4S0 907 160
Component: 4 Wheel Drive H07 0207
Revision: 00001002 Serial number: BBP133Q
ASAM Dataset: EV_AllWheelContrBORGLB724 006012
ROD: EV_AllWheelContrBORGLB724.rod
VCID: 6E85CD170017AFA72BB-803A
Component: MEM-FS 001 0020
Revision: AA001003 Serial number: 00000179650305
Coding: 00381900000420F1C00001210101210000000000000000
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E02FNMY
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372B28733FCD2E6F38D-8062
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011C52425001000300080402
VCID: 47CB58B34FAD5EEF48D-8012
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:05
Part No SW: 4S0 909 144 H HW: 4S0 909 144 B
Component: EPS H13 0905
Revision: 00000000 Serial number: L00157683
Coding: 0802
ASAM Dataset: EV_EPSZFAU72X 003010
ROD: EV_EPSZFAU72X_003.rod
12656642 - Databus
U1121 00 [040] - Missing Message
[BDE_CAN_Timeout]
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:01
Expanded ambient data 1-Terminal 30 voltage filtered: 12.00 V
Expanded ambient data 1-Internal voltage supply 5V: 0.00 V
Expanded ambient data 1-Vehicle speed: 0 km/h
Expanded ambient data 1-Control module temp: internal sensor: 40 °C
Expanded ambient data 1-Speed source: CAN ESP speed
Expanded ambient data 1-Combustion engine: status: Motor not running
Expanded ambient data 1-AD converter reference voltage: 1.50 V
Expanded ambient data 1-Voltage terminal 30 unfiltered: 12.00 V
Expanded ambient data 1-AD converter reference voltage 2: 1.50 V
Expanded ambient data 1-Switched voltage terminal 30 unfiltered: 12.06 V
Expanded ambient data 1-KFA: 00 00
Expanded ambient data 1-KFC: 00 3B
Revision: 00002001 Serial number: 0420549296
Coding: 011A0E8000B10081E330CA00000500000000000000000000000000000000
Subsystem 1 - Part No: 4S0 951 177
Component: Sensor, DWA 005 0002
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:01
Fault Status: 00101100
Reset counter: 42
Mileage: 23358 km
Date: 2019.09.26
Time: 16:10:27
Component: TSG BF H03 0511
Coding: 011C52425E01000300080400
VCID: 46D555B748A747E7B3B-8012
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:05
Part No SW: 4S0 907 801 HW: 8K0 907 801 J
Component: EPB-4 H03 0001
Revision: -------- Serial number: 20000000002697
ROD: EV_ParkiBrake_AU72.rod
VCID: 70B9D36F1A23B957397-8024
334080 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_MOTOR_02_MESSAGE_TIMEOUT]
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:00
Voltage terminal 30: 12.0 V
Internal Fault ID: 51
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Set
Status ParkingBrake right: Set
331264 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_MOTOR_01_MESSAGE_TIMEOUT]
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:00
Internal Fault ID: 99
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331520 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_MOTOR_03_MESSAGE_TIMEOUT]
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:00
Internal Fault ID: 100
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331776 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_MOTOR_CODE_01_MESSAGE_TIMEOUT]
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:00
Internal Fault ID: 101
RWU: not active
DSD: not active
HTR: not active
ECD: not active
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
Reset counter: 38
Mileage: 23168 km
Date: 2019.09.10
Time: 09:45:22
Voltage terminal 30: 14.0 V
Internal Fault ID: 188
Vehicle speed: 134 km/h
Function light in parking brake button: OFF
Red operating lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Internal Parking Brake state: Dynamic
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Coding: 077E001022200200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
VCID: 3635257738C7D76723B-8062
Subsystem 1 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0008
Coding: E02200
Subsystem 2 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0008
Coding: E02200
13705475 - Databus
[Timeout CAN-Message Motor_03 (0x105)]
Reset counter: 49
Mileage: 22777 km
Date: 2019.09.06
Time: 11:57:01
Part No SW: 4S0 035 045 C HW: 4S0 035 045 B
Component: MU-H-N-RW 053 0909
Serial number: A730J0GB000506
Coding: 012704070000000013110002000A00212F0000E2007000005E
ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
ROD: EV_MUHig6C8Gen2HBAS.rod
VCID: 2B030403F3859A8F4C5-807E
Subsystem 1 - Part No SW: V03 959 801 FQ HW: -----------
Component: ROW 2017 --- 0062
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 4S2 919 614 D HW: 4S2 919 614 D
Component: ControlUnit_H H30 0206
Serial number: APVAK126081600010016
Component: Gracenote2--- --- 4011
6708 - Databus
[Engine: no communication]
Reset counter: 49
Mileage: 22316 km
Date: 2019.08.23
Time: 19:52:53
Network diagnosis-Status: Enabled
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 D HW: 4H0 907 273 B
Component: RDKBERU25 H10 0900
Serial number: 10000000033742
ROD: EV_RDKBERU25_AU57.rod
VCID: 2C01071FF68B9DB745F-8078
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 A HW: 95B 980 551 L
Component: RVC Compact H12 0201
Coding: 0275040102000001000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
ROD: EV_CamSysRVRVCPANAAU57X_002_AU72.rod
VCID: 392F2E4B09D9381FCE9-806C
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4S2 713 041 C HW: 4M2 713 041 F
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20160913001070
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736.rod
Address A6: Microphone (J886) Labels:. 420-907-394.clb
Part No SW: 420 907 394 A HW: 420 907 394
Component: BELTMICBOX H10 0600
Coding: 0101030202
ASAM Dataset: EV_BeltMicPARAGAU335 003011
ROD: EV_BeltMicPARAGAU335.rod
VCID: 176BC8F35F0D0E6F18D-8042
Address C2: Auto Trans 2 (J217) Labels: None
Part No SW: 4S0 927 109 HW: 4S0 927 109
Component: DL800 ZSG H11 0002
Revision: --H11--- Serial number: 0000000122
ASAM Dataset: EV_TCMDL800421 001024
ROD: EV_TCMDL800.rod
VCID: 73B3DC636B35824FC45-8026
End----------(Elapsed Time: 01:50, VBatt start/end: 13.2V/13.4V)-----------
