R8 spoiler de activation
Ahsan
Pakistan
C?ID=348019
I recently deactivated the spoiler from 2017 R8 non plus using VCDS. However the warning light is coming on saying that the spoiler is deactivated and drive accordingly. Can I remove this light?
Please post an Auto-Scan so people can see exactly how this car is equipped. Also, please explain exactly what steps you followed to de-activate the spoiler.
Ahsan
Pakistan
C?ID=348019
The following was done to change the coding.
As mentioned the spoiler is fully retracted now and warning sign is illuminated as mentioned. I am out of the country so can’t do an auto scan.
You should be able to change the Coding in 46-Cent. Conv. Use the Long Coding helper top uncheck Byte 6, Bit 7. This should change your Coding from:
011A0E8000B18081E330CA00000500000000000000000000000000000000
Mike@Gendan
Swansea, UK
C?ID=57030
Come back with a scan when you're back in the country then please.
Without it we know nothing about the configuration of the car so would just be making educated guesses.
Ahsan
Pakistan
C?ID=348019
Will do just that once I am back. Tks
Ahsan
Pakistan
C?ID=348019
following is the scan; dont think it mentions anything about the spoiler. the problem i am facing after spoiler de activation one is that a message is activated when i start the car which reads spoiler fault adapt driving style. Secondly, my ESP if i switch it off it automatically is getting turned on at high speeds. dont know if it is related. My scan is below. need your help to sort this out. tks a lot.
Sunday,06,October,2019,02:36:41:02733
VIN: WUAZZZFX6H7903331   License Plate:
Mileage: 23625km-14679mi   Repair Order:
Chassis Type: FX-AU72 (4S0)
Scan: 01 02 03 05 06 08 09 11 31 14 15 16 17 19 22 36 3B 42 44 46
          52 53 55 5F 65 6C 81 A6 C2
VIN: WUAZZZFX6H7903331   Mileage: 23625km-14679miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
A6-Microphone -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (------CSPB)       Labels: None
   Part No SW: 4S0 907 552 L    HW: 4T0 907 552 A
   Component: 5.2l V10HDZ / H56 0003
   Revision: NHH56---
   Coding: 1A250032052600093000
   ASAM Dataset: EV_ECM52FSI1114S0907552L 001003
   ROD: EV_ECM52FSI1114S0907552L.rod
   VCID: 3FDB405317FD162FF0D-806A
19305 - Exhaust Pressure Control Valve
          P0475 00 [046] - Electrical Malfunction
                    Fault Frequency: 141
                    Mileage: 23463 km
                    Date: 2019.10.04
                    Time: 14:13:08
                    Coolant temperature: 74 °C
                    Intake air temperature: 65 °C
                    Voltage terminal 30: 11.803 V
                    Engine status: COENG_READY
7661 - Secondary Air Injection Solenoid Valve (N112)
          P1432 00 [175] - Open Circuit
                    Mileage: 23463 km
                    Date: 2019.10.04
                    Time: 14:13:07
Readiness: 0010 1001
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 4S0 927 155 F    HW: 0BH 927 711 F
   Component: AU 6E SB  RdW H10 3913
   Revision: 00H10V01
   ASAM Dataset: EV_TCMDL800041 001013
   ROD: EV_TCMDL800041_AU72.rod
   VCID: 3A2D31470CDF3307C73-806E
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4S0 907 379 D    HW: 4S0 907 379 D
   Component: ESP PREMIUM   H09 0300
   Coding: 01A1C10B808583D04B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004048
   ROD: EV_ESPPremiAU57X_AU72.rod
   VCID: 3E253D5710F71F27FBB-806A
0668 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ComScl_PDU_HSP_01_Timeout]
                    Reset counter: 12
                    Mileage: 23463 km
                    Date: 2019.10.04
                    Time: 14:13:22
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E4
                    Uz: 9A
   Part No SW: 4H0 907 064 JD    HW: 4H0 907 064 JD
   Component: BCM2 2.0      H44 0582
   Coding: 05906F06000000000000
   VCID: 74B1DF7F6EBB8577DDF-8020
   Serial number: 3216000217245002
   Part No SW: 4S0 959 760     HW: 4S0 959 760
   Component: MEM-BFS       001 0020
   Revision: AA001003    Serial number: 00000179650048
   Coding: 00201000000420F1000001210101210000000000000000
   VCID: 7BA3F44343E5CA0F9C5-802E
   Part No SW: 4S0 820 043 K    HW: 4S0 820 043 K
   Component: AC Automat    H08 0040
   Revision: 20012000    Serial number: 96800000004731
   Coding: 4100A01400000410
   ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
   ROD: EV_AirCondiVAPrehAU72x.rod
   VCID: 33331C632BB5C24F045-8066
   Operating and display unit 2 for air conditioning:
   Subsystem 1 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Serial number: 00000000000000006004
   Operating and display unit 3 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Operating and display unit 4 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [008] - -
                    Reset counter: 44
                    Mileage: 23364 km
                    Date: 2019.10.01
                    Time: 23:03:24
                    Voltage terminal 30: 11.8 V
                    Compressor shut-off requirement: Engine running time too short: engine start not detected by CAN
          B10CD 00 [008] - -
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:31
                    Blower reduction: No switch-off: no reduction
459029 - Databus
          [Motor_06 - Motorsteuergerät - Datenbus fehlende Botschaft]
                    Fault Frequency: 12
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:01
                    Voltage terminal 30: 11.9 V
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 HK    HW: 4H0 907 063 EK
   Component: BCM1 2.0      H21 0725
   Revision: 2502102S    Serial number: 00001497773402
   Coding: 010DC01410349FE06D0140C380001800C59DC2882308320100040814E1101100004000340B0000
   VCID: 78A9EB4F72D3E117F17-802C
   Subsystem 1 - Part No SW: 4S2 955 119 B    HW: 8V2 955 119 A
   Component: WWS624 160904  043 0081
   Serial number: 90248163160912225137
   Coding: 3247FD
   Serial number: 62343591
   Coding: 02005D
   Subsystem 3 - Part No SW: 4S0 941 531     HW: 4S0 941 531
   Component: E1 - LDS  H01 0044
   Serial number: 10 10 2016  00000097
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 28788E4800PAG0MUFU03
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:01
Address 11: Engine II (-----)       Labels: None
   Revision: NHH56---
   ASAM Dataset: EV_ECM52FSI2114S0907552L 001003
   ROD: EV_ECM52FSI2114S0907552K.rod
12694 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 2
          P2436 00 [101] - Implausible Signal
                    Mileage: 23534 km
                    Date: 2019.10.05
                    Time: 14:04:51
                    Engine speed: 1416.00 /min
                    Normed load value: 32.2 %
                    Coolant temperature: 36 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 13.264 V
                    Engine status: COENG_RUNNING
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 4S0 907 376 D    HW: 4S0 907 376 C
   Component: DAEMPFUNGS-SG H06 0064
   Serial number:       161016019
   ASAM Dataset: EV_AudiMagneRide 002008
   ROD: EV_AudiMagneRide.rod
   VCID: 3B23344303E50A0FDC5-806E
7 Faults Found:
10506241 - Databus
          [Motor_07_Timeout]
                    Reset counter: 49
                    Mileage: 22316 km
                    Date: 2019.08.23
                    Time: 19:52:53
                    COM: 0E 0F 0E 2D 00 03 C6 BD 00 00
                    Voltage terminal 30: 12.2 V
                    Terminal 15 status via CAN: Terminal 15 on
                    Engine run: Not available
                    Engine torque: Not available
                    AMR state: 6
                    Damping adjustment indicator lamp: OFF
                    ESP automatic engagement: not activated
                    Fall-back level: 00 70 20 00
10518529 - Databus
          [Motor_Code_01_Timeout]
                    Reset counter: 49
                    Mileage: 22316 km
                    Date: 2019.08.23
                    Time: 19:52:53
                    AMR state: 6
10563585 - Databus
          [Motor_03_Timeout]
                    Reset counter: 49
                    Mileage: 22316 km
                    Date: 2019.08.23
                    Time: 19:52:49
                    COM: 0E 0F 0E 2D 00 03 B5 5B 00 00
                    Engine torque: -5 Nm
                    AMR state: 0
                    Fall-back level: 00 00 00 00
10563587 - Databus
          [init value Fahrerwusch]
                    Reset counter: 44
                    Mileage: 22316 km
                    Date: 2019.08.23
                    Time: 20:01:05
                    COM: 0E D6 0E F5 00 0B 46 E5 00 00
                    Engine run: 0
                    AMR state: 6
                    Fall-back level: 00 F8 20 00
10563589 - Databus
          [init value Moment Verlust]
                    Reset counter: 44
                    Mileage: 22316 km
                    Date: 2019.08.23
                    Time: 20:01:05
                    Engine run: 0
                    AMR state: 6
10563591 - Databus
          [init value Mom_m_ex]
                    Reset counter: 44
                    Mileage: 22316 km
                    Date: 2019.08.23
                    Time: 20:01:05
                    Engine run: 0
                    AMR state: 6
10567681 - Databus
          [Motor_03_Timeout]
                    Reset counter: 49
                    Mileage: 22316 km
                    Date: 2019.08.23
                    Time: 19:52:49
                    AMR state: 0
   Part No SW: 4S0 959 655     HW: 4S0 959 655
   Component: Airbag10.43   H62 0204
   Revision: --------    Serial number: 003NJ0014M4X
   Coding: 30333845303430303639554A305234533053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
   VCID: 7EA5FD575077DF27BBB-802A
   Serial number: 3575HRB404P4529MG8QS
   Serial number: 3585HRB405N45HVKB10P
   Serial number: 3515JRB401A57ACIMP9M
   Serial number: 3525JRB4002578J6S8UH
   Serial number: 3554VRB400C57EUIQ9B7
   Serial number: 3564VRB400C57EUIR9B9
1057536 - Databus
          [CAN: 0x105 Motor_03 Timeout]
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:01
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 4S0 907 129 J    HW: 4S0 907 129 J
   Component: Lenks.Modul   H06 0007
   Revision: C0071527    Serial number: 91335PJL01657-
   Coding: 000034
   VCID: 3D273A5B1D71043FE21-8068
   Part No SW: 4S0 920 790 A    HW: 4S0 920 790 A
   Component: FBenRDW       H14 0251
   Coding: 242D30C0BA8200080120ECC41000801000000000
   ASAM Dataset: EV_DashBoardBOSCHAU724 001022
   ROD: EV_DashBoardBOSCHAU724.rod
16776971 - Databus
          [Motor_04 communication error can_error_timeout]
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:01
16777088 - Databus
          [HSP_01 communication error can_error_timeout]
                    Fault Frequency: 63
                    Reset counter: 14
                    Mileage: 23350 km
                    Date: 2019.09.16
                    Time: 08:58:42
   Part No SW: 4S0 907 468 B    HW: 4S0 907 468 A
   Component: J533--Gateway H15 0074
   Revision: --------    Serial number: 00000002409533
   Coding: 802103161C
   ASAM Dataset: EV_GatewPkoUDS 002000
   Subsystem 1 - Part No SW: 4S0 915 181     HW: 4S0 915 181
   Component: J367-BDM  H08 0270
   Serial number: 53265G13192871626747
5186 - Second (Slave) Engine Control Module
          U0115 00 [008] - No Communication
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 12:05:28
                    Voltage terminal 15: 11.8 V
                    Control Module temperature: 39 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:01
                    Voltage terminal 15: 11.9 V
                    Control Module temperature: 36 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 22: AWD (J492)       Labels: None
   Part No SW: 4S0 907 160     HW: 4S0 907 160
   Component: 4 Wheel Drive H07 0207
   Revision: 00001002    Serial number: BBP133Q
   ASAM Dataset: EV_AllWheelContrBORGLB724 006012
   ROD: EV_AllWheelContrBORGLB724.rod
   VCID: 6E85CD170017AFA72BB-803A
   Component: MEM-FS        001 0020
   Revision: AA001003    Serial number: 00000179650305
   Coding: 00381900000420F1C00001210101210000000000000000
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E02FNMY
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372B28733FCD2E6F38D-8062
   Component: TSG FA        H03 0511
   Coding: 011C52425001000300080402
   VCID: 47CB58B34FAD5EEF48D-8012
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:05
   Part No SW: 4S0 909 144 H    HW: 4S0 909 144 B
   Component: EPS           H13 0905
   Revision: 00000000    Serial number:      L00157683
   Coding: 0802
   ASAM Dataset: EV_EPSZFAU72X 003010
   ROD: EV_EPSZFAU72X_003.rod
12656642 - Databus
          U1121 00 [040] - Missing Message
          [BDE_CAN_Timeout]
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:01
                    Expanded ambient data 1-Terminal 30 voltage filtered: 12.00 V
                    Expanded ambient data 1-Internal voltage supply 5V: 0.00 V
                    Expanded ambient data 1-Vehicle speed: 0 km/h
                    Expanded ambient data 1-Control module temp: internal sensor: 40 °C
                    Expanded ambient data 1-Speed source: CAN ESP speed
                    Expanded ambient data 1-Combustion engine: status: Motor not running
                    Expanded ambient data 1-AD converter reference voltage: 1.50 V
                    Expanded ambient data 1-Voltage terminal 30 unfiltered: 12.00 V
                    Expanded ambient data 1-AD converter reference voltage 2: 1.50 V
                    Expanded ambient data 1-Switched voltage terminal 30 unfiltered: 12.06 V
                    Expanded ambient data 1-KFA: 00 00
                    Expanded ambient data 1-KFC: 00 3B
   Revision: 00002001    Serial number: 0420549296
   Coding: 011A0E8000B10081E330CA00000500000000000000000000000000000000
   Subsystem 1 - Part No: 4S0 951 177
   Component: Sensor, DWA  005 0002
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:01
                    Fault Status: 00101100
                    Reset counter: 42
                    Mileage: 23358 km
                    Date: 2019.09.26
                    Time: 16:10:27
   Coding: 011C52425E01000300080400
   VCID: 46D555B748A747E7B3B-8012
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:05
   Part No SW: 4S0 907 801     HW: 8K0 907 801 J
   Component: EPB-4         H03 0001
   Revision: --------    Serial number: 20000000002697
   ROD: EV_ParkiBrake_AU72.rod
   VCID: 70B9D36F1A23B957397-8024
334080 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_MOTOR_02_MESSAGE_TIMEOUT]
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:00
                    Voltage terminal 30: 12.0 V
                    Internal Fault ID: 51
                    Network management state: normal
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    General Inspection Function: not active
                    Internal Parking Brake state: static
                    Status of parking brake button: Not operated
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
331264 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_MOTOR_01_MESSAGE_TIMEOUT]
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:00
                    Internal Fault ID: 99
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
331520 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_MOTOR_03_MESSAGE_TIMEOUT]
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:00
                    Internal Fault ID: 100
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
331776 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_MOTOR_CODE_01_MESSAGE_TIMEOUT]
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:00
                    Internal Fault ID: 101
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 38
                    Mileage: 23168 km
                    Date: 2019.09.10
                    Time: 09:45:22
                    Voltage terminal 30: 14.0 V
                    Internal Fault ID: 188
                    Vehicle speed: 134 km/h
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Internal Parking Brake state: Dynamic
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 077E001022200200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
   VCID: 3635257738C7D76723B-8062
   Subsystem 1 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0008
   Coding: E02200
   Subsystem 2 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0008
   Coding: E02200
13705475 - Databus
          [Timeout CAN-Message Motor_03 (0x105)]
                    Reset counter: 49
                    Mileage: 22777 km
                    Date: 2019.09.06
                    Time: 11:57:01
   Part No SW: 4S0 035 045 C    HW: 4S0 035 045 B
   Component: MU-H-N-RW     053 0909
   Serial number: A730J0GB000506
   Coding: 012704070000000013110002000A00212F0000E2007000005E
   ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
   ROD: EV_MUHig6C8Gen2HBAS.rod
   VCID: 2B030403F3859A8F4C5-807E
   Subsystem 1 - Part No SW: V03 959 801 FQ    HW: -----------
   Component: ROW 2017  --- 0062
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 4S2 919 614 D    HW: 4S2 919 614 D
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK126081600010016
   Component: Gracenote2---  --- 4011
6708 - Databus
          [Engine: no communication]
                    Reset counter: 49
                    Mileage: 22316 km
                    Date: 2019.08.23
                    Time: 19:52:53
                    Network diagnosis-Status: Enabled
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 D    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0900
   Serial number: 10000000033742
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2C01071FF68B9DB745F-8078
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556 A    HW: 95B 980 551 L
   Component: RVC Compact   H12 0201
   Coding: 0275040102000001000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
   ROD: EV_CamSysRVRVCPANAAU57X_002_AU72.rod
   VCID: 392F2E4B09D9381FCE9-806C
   Part No SW: 4S2 713 041 C    HW: 4M2 713 041 F
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20160913001070
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736.rod
Address A6: Microphone (J886)       Labels:. 420-907-394.clb
   Part No SW: 420 907 394 A    HW: 420 907 394
   Component: BELTMICBOX    H10 0600
   Coding: 0101030202
   ASAM Dataset: EV_BeltMicPARAGAU335 003011
   ROD: EV_BeltMicPARAGAU335.rod
   VCID: 176BC8F35F0D0E6F18D-8042
Address C2: Auto Trans 2 (J217)       Labels: None
   Part No SW: 4S0 927 109     HW: 4S0 927 109
   Component: DL800 ZSG     H11 0002
   Revision: --H11---    Serial number: 0000000122
   ASAM Dataset: EV_TCMDL800421 001024
   ROD: EV_TCMDL800.rod
   VCID: 73B3DC636B35824FC45-8026
End----------(Elapsed Time: 01:50, VBatt start/end: 13.2V/13.4V)-----------
NEtech
C?ID=56995
Try and remove Byte 14 Bit 7 in [17-Instrument] Coding, if that change anything.
Ahsan
Pakistan
C?ID=348019
Tks for replying! I can get to instrument 17. Can’t understand beyond that. Sorry but can u kindly help me as I am very new to this. Tks once again.
NEtech
C?ID=56995
You write about change in 46 that you did, it is similar in 17.
You can copy and insert this as new Coding in 17 Instrument.
Byte 14 Bit 7 is unchecked:
242D30C0BA8200080120ECC41000001000000000
Ahsan
Pakistan
C?ID=348019
That worked like magic. Changed the coding and the fault sign is all but gone. Thank you so very much. VCDS is awesome!
