Results 1 to 3 of 3
Thread: 2013 Passat 2.0 p0405 egr circuit
    Jun 2014
    Canada
    This Passat had the egr valve replaced not sure what the fault was at the time, but now sets po405 always sets at high speeds between 70 to 100 kms. It won set at idle or by wiggling the harness or loading the engine. Any thoughts. Thank you ,Mario
    Tuesday,17,September,2019,10:42:26:15785
    VCDS Version: 19.6.1.0 (x64)
    VIN: 1VWCN7A3XDC139151   License Plate: ADRIAN
    Mileage: 176990km-109976mi   Repair Order:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
              52 56 62 72 77
    VIN: 1VWCN7A3XDC139151   Mileage: 176990km-109976miles
    Address 01: Engine (J623-CKRA)       Labels:. 03L-906-022-CFC.clb
       Part No SW: 03L 997 009 J    HW: 03L 907 309 S
       Component: R4 2.0l TDI   H24 9982
       Revision: 71H24---    Serial number:
       Coding: 001D0012842400008000
       Shop #: WSC 93778 999 00000
       ASAM Dataset: EV_ECM20TDI01103L997009J 004005
       ROD: EV_ECM20TDI01103L997009J.rod
       VCID: 3B7E8A76B25809978C-806E
    4900 - EGR Sensor 1
              P0405 00 [038] - Signal too Low
                        Mileage: 176998 km
                        Date: 2019.09.17
                        Time: 10:38:01
                        Engine speed: 1891.50 /min
                        Normed load value: 99.6 %
                        Vehicle speed: 97 km/h
                        Coolant temperature: 100 C
                        Intake air temperature: 33 C
                        Voltage terminal 30: 13.960 V
                        Air mass: actual value (mg/stroke): 1068.5 mg/stroke
                        EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                        EGR Solen.val.: actual value: 104.85 %
                        EGR valve: offset closed: -0.39 %
                        Actuator for high pressure EGR: status-Bits 0-7: 55
                        Actuator for high pressure EGR: status-Bits 0-7: 0
                        Actuator for high pressure EGR: status-Bits 0-7: 2
                        High press EGR actuator: actual unconditioned volt val: 14.6 mV
       Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 9436
       Revision: 05651213    Serial number: 00001302041648
       Shop #: WSC 09003 957 00200
       VCID: 244C510AE7E6566FDD-8070
       Revision: 00H31001
       Coding: C54BC0F549250003A30C03E9921A0042271000
       VCID: 7DFA446EE4CCC7A7F2-8028
       Component: VWKESSYPQ35GP 086 1101
       Revision: 00086000    Serial number: 0205288523
       Coding: 130C0C
       VCID: 346CA14A9F06C6EF4D-8060
       Part No SW: 561 907 044 R    HW: 561 907 044 R
       Component: Climatronic   H03 0405
       Revision: 00001K01
       Coding: 0010001012
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: 26484B0259DAA47FC3-8072
    9473297 - Motor for Right Temperature Flap
              B108D 11 [009] - Short to Ground
                        Reset counter: 82
                        Mileage: 176311 km
                        Date: 2019.09.11
                        Time: 12:28:45
       Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
       Component: BCM PQ35 H+   121 0168
       Revision: BL121001
       Coding: 6F200E1B882B2AD408880201360085480071008645A005F064806000BC70
       VCID: 74EC614AD78686EF8D-8020
       Component: RLS 210313 05  54  0403
       Coding: 22300A
       Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
       Component: AirbagVW10G   014 0851
       Serial number: 003MWM01MX8E
       Coding: 00005033
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 75EA5C4ED4FC9FE7BA-8020
       Serial number: 6940000Y130000T9UK0G
       Coding: 303047
       Serial number: 3572MSME65247378ZZZZ
       Serial number: 3582MSME35406478ZZZV
       Serial number: 3516KSME35627D22ZZZT
       Serial number: 3526KSME27472023ZZZH
       Serial number: 3556LSME7D646921ZZZ%
       Serial number: 3566LSME116C6921ZZZX
       Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
       Revision: FF010041    Serial number: 20130221201828
       Coding: 001A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DFA446EECCCC7A7F2-8028
       Component: E221__MFL-YVJ  H07 0022
       Coding: E30000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 870 C    HW: 561 920 870 C
       Component: KOMBI         H07 0705
       Coding: 331E01
       VCID: 193270FE18A41B877E-804C
       Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
       Component: J533  Gateway H50 1634
       Revision:   H50       Serial number: 28041303290352
       Coding: 461000
       VCID: 76E85B42C1FA94FFB3-8022
       Component: IMMO          H07 0705
       Coding: 000007
       VCID: 6AD07F328D42401F27-803E
       Revision: 00000000    Serial number: 13000013122005
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 3064AD5A6B1EFACF29-8064
       Component: SG EXT.PLAYER H19 0550
       Revision: A1001003    Serial number: 7664589784
       Coding: 010100
       VCID: 2A50BF3245C2801FE7-807E
       Part No SW: 561 959 760     HW: 561 959 760
       Component: MEM-FS        H04 0181
       Revision: AA000000    Serial number: 00000055321739
       Coding: 00581B0000000000000021010100202020202120202020
       VCID: 60C41D1A737E0A4FF9-8034
       Part No SW: 3C0 035 684 G    HW: 3C0 035 684 G
       Component: RNS-MID       H03 3696
       Revision: AB001001    Serial number: VWZ6Z7N8064081
       Coding: 24090042010000A6000B
       VCID: 2756460656D0BD77F8-8072
                        Fault Frequency: 21
                        Reset counter: 94
                        Mileage: 176296 km
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0525
       Revision: 12110009    Serial number: 0006532695
       Coding: 0405FD
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 1C3C69EA17966EAF65-8048
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  006 5470
       Serial number: 14102630130429161347
       Coding: 800000
              B11EC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 121
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [009] - Electrical Failure
                        Reset counter: 81
                        Mileage: 176302 km
                        Date: 2019.09.10
                        Time: 08:53:29
    131584 - Motor for Rear Window Regulator
              B11EE 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 121
                        Mileage: 176302 km
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 290    3305
       Revision: 00H22000
       VCID: 3776964646702DF768-8062
       Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
       Component: KonzernAmp10K H07 6813
       Revision: --------    Serial number: EAA098A0035118
    9457664 - Function limitation due to excessive temperature
              B1050 00 [008] - -
                        Reset counter: 130
                        Mileage: 176375 km
                        Date: 2019.09.11
                        Time: 13:18:14
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
       Component: EZE_2         H50 1634
       Coding: 01030108
       VCID: 6FE66E26BEA0A53770-803A
       Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
       Component: J245 P05 FFD7  H07 0004
       Serial number: 53388786011235700831
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0525
       Revision: 14110009    Serial number: 0006541800
       Coding: 0405FC
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 1D3A64EE0C8C67A792-8048
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  006 5470
       Serial number: 14202631130430190455
       Coding: 800000
                        Reset counter: 121
                        Mileage: 176302 km
                        Fault Frequency: 21
                        Reset counter: 94
                        Mileage: 176296 km
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007664432633
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3A708F72BD62309F97-806E
    End-------------------------(Elapsed Time: 03:31)--------------------------
    Address 01: DTCs cleared
    Jun 2014
    Canada
    Quote Originally Posted by machado View Post
              52 56 62 72 77
    4900 - EGR Sensor 1
                        Mileage: 176998 km
                        Date: 2019.09.17
                        Time: 10:38:01
       Revision: 00H31001
       Coding: 130C0C
       Revision: 00001K01
       Coding: 0010001012
                        Reset counter: 82
                        Mileage: 176311 km
                        Date: 2019.09.11
                        Time: 12:28:45
       Revision: BL121001
       Coding: 22300A
       Coding: 00005033
       Coding: 303047
       Coding: 001A140000
       Coding: E30000
       Coding: 331E01
       Coding: 461000
       Coding: 000007
       Coding: 010100
                        Fault Frequency: 21
                        Reset counter: 94
                        Mileage: 176296 km
       Coding: 0405FD
       Slave Driver:
       Coding: 800000
                        Reset counter: 121
                        Reset counter: 81
                        Mileage: 176302 km
                        Date: 2019.09.10
                        Time: 08:53:29
                        Reset counter: 121
                        Mileage: 176302 km
       Revision: 00H22000
              B1050 00 [008] - -
                        Reset counter: 130
                        Mileage: 176375 km
                        Date: 2019.09.11
                        Time: 13:18:14
       Coding: 01030108
       Coding: 181100
       Coding: 0405FC
       Slave Passenger:
       Coding: 800000
                        Reset counter: 121
                        Mileage: 176302 km
                        Fault Frequency: 21
                        Reset counter: 94
                        Mileage: 176296 km
    I removed the air box and found a few wires running from boost sensor to ECU, i believe there are more broken wires but customer has denied any further work.
  3. Likes Dana liked this post
    HQ
    4900 - EGR Sensor 1
    In many cases a "Signal too Low" description is due to an open circuit, so yeah, a failing wire is possible.
    Jef
  5. Likes PetrolDave, Uwe, Dana liked this post
