This Passat had the egr valve replaced not sure what the fault was at the time, but now sets po405 always sets at high speeds between 70 to 100 kms. It won set at idle or by wiggling the harness or loading the engine. Any thoughts. Thank you ,Mario
Tuesday,17,September,2019,10:42:26:15785
VCDS Version: 19.6.1.0 (x64)
VIN: 1VWCN7A3XDC139151 License Plate: ADRIAN
Mileage: 176990km-109976mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCN7A3XDC139151 Mileage: 176990km-109976miles
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H24 9982
Revision: 71H24--- Serial number:
Coding: 001D0012842400008000
Shop #: WSC 93778 999 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B7E8A76B25809978C-806E
4900 - EGR Sensor 1
P0405 00 [038] - Signal too Low
Mileage: 176998 km
Date: 2019.09.17
Time: 10:38:01
Engine speed: 1891.50 /min
Normed load value: 99.6 %
Vehicle speed: 97 km/h
Coolant temperature: 100 °C
Intake air temperature: 33 °C
Voltage terminal 30: 13.960 V
Air mass: actual value (mg/stroke): 1068.5 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 100.00 %
EGR Solen.val.: actual value: 104.85 %
EGR valve: offset closed: -0.39 %
Actuator for high pressure EGR: status-Bits 0-7: 55
Actuator for high pressure EGR: status-Bits 0-7: 0
Actuator for high pressure EGR: status-Bits 0-7: 2
High press EGR actuator: actual unconditioned volt val: 14.6 mV
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9436
Revision: 05651213 Serial number: 00001302041648
Shop #: WSC 09003 957 00200
VCID: 244C510AE7E6566FDD-8070
Revision: 00H31001
Coding: C54BC0F549250003A30C03E9921A0042271000
VCID: 7DFA446EE4CCC7A7F2-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0205288523
Coding: 130C0C
VCID: 346CA14A9F06C6EF4D-8060
Part No SW: 561 907 044 R HW: 561 907 044 R
Component: Climatronic H03 0405
Revision: 00001K01
Coding: 0010001012
VCID: 26484B0259DAA47FC3-8072
9473297 - Motor for Right Temperature Flap
B108D 11 [009] - Short to Ground
Reset counter: 82
Mileage: 176311 km
Date: 2019.09.11
Time: 12:28:45
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0168
Revision: BL121001
Coding: 6F200E1B882B2AD408880201360085480071008645A005F064806000BC70
VCID: 74EC614AD78686EF8D-8020
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 210313 05 54 0403
Coding: 22300A
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM01MX8E
Coding: 00005033
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75EA5C4ED4FC9FE7BA-8020
Serial number: 6940000Y130000T9UK0G
Coding: 303047
Serial number: 3572MSME65247378ZZZZ
Serial number: 3582MSME35406478ZZZV
Serial number: 3516KSME35627D22ZZZT
Serial number: 3526KSME27472023ZZZH
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME7D646921ZZZ%
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME116C6921ZZZX
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Revision: FF010041 Serial number: 20130221201828
Coding: 001A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DFA446EECCCC7A7F2-8028
Component: E221__MFL-YVJ H07 0022
Coding: E30000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 870 C HW: 561 920 870 C
Component: KOMBI H07 0705
Coding: 331E01
VCID: 193270FE18A41B877E-804C
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 28041303290352
Coding: 461000
VCID: 76E85B42C1FA94FFB3-8022
Component: IMMO H07 0705
Coding: 000007
VCID: 6AD07F328D42401F27-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000013122005
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3064AD5A6B1EFACF29-8064
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664589784
Coding: 010100
VCID: 2A50BF3245C2801FE7-807E
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000055321739
VCID: 60C41D1A737E0A4FF9-8034
Part No SW: 3C0 035 684 G HW: 3C0 035 684 G
Component: RNS-MID H03 3696
Revision: AB001001 Serial number: VWZ6Z7N8064081
Coding: 24090042010000A6000B
VCID: 2756460656D0BD77F8-8072
Fault Frequency: 21
Reset counter: 94
Mileage: 176296 km
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0006532695
Coding: 0405FD
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C3C69EA17966EAF65-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14102630130429161347
Coding: 800000
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 121
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Reset counter: 81
Mileage: 176302 km
Date: 2019.09.10
Time: 08:53:29
B11EE 54 [008] - Missing Calibration / Basic Setting
Reset counter: 121
Mileage: 176302 km
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 290 3305
Revision: 00H22000
VCID: 3776964646702DF768-8062
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0035118
9457664 - Function limitation due to excessive temperature
B1050 00 [008] - -
Reset counter: 130
Mileage: 176375 km
Date: 2019.09.11
Time: 13:18:14
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 01030108
VCID: 6FE66E26BEA0A53770-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011235700831
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0006541800
Coding: 0405FC
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D3A64EE0C8C67A792-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631130430190455
Coding: 800000
Reset counter: 121
Mileage: 176302 km
Fault Frequency: 21
Reset counter: 94
Mileage: 176296 km
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664432633
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A708F72BD62309F97-806E
End-------------------------(Elapsed Time: 03:31)--------------------------
Address 01: DTCs cleared
