Results 1 to 3 of 3
Thread: Golf Mk 7 DSG Trouble
    Jul 2019
    Hi guys,
    i'm used to check measuringblocks 95-115 to check the condition of clutch 1 and 2 of the dsg gearbox.
    Can u tell me how to check the condition of clutch 1 and 2 using measuringblocks on this golf 7 it uses a different protocol?
    The problem with this car is that it doesn't shift smooth, it slams into 1st and Reverse.
    After a basic setting, it drives/shifts like it's supposed to.
    when i let it sit a coupple of days, it shifts rough again.
    i have been told that there is a TPI for the code i have ( P189A) i cant find it..
    I'm suspecting the clutch, that's why i want to check te condition using the measuringblocks
    Thnx
    Tuesday,17,September,2019,10:19:07:64070
    VIN: WVWZZZAUZFP574488   License Plate:
    Mileage: 155021km-96325mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZFP574488   Mileage: 155021km-96325miles
    Address 01: Engine (J623-CJZA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 016 A    HW: 04E 907 309 A
       Component: 1.2l R4 TSI   H10 7697
       Revision: WAH10---
       Coding: 01250032232405082000
       Shop #: WSC 00028 028 00074
       ASAM Dataset: EV_ECM12TFS01104E906016A 001008
       ROD: EV_ECM12TFS01104E906016A.rod
       VCID: 20191D366A4C4767EA9-8074
    5604 - Park/Neutral Switch Input Circuit
              P0850 00 [032] - Open or Short to Plus
                        Mileage: 155020 km
                        Date: 2019.09.16
                        Time: 15:57:31
                        Engine speed: 873.00 /min
                        Normed load value: 32.9 %
                        Coolant temperature: 35 °C
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 14.277 V
                        Brake actuated status-Bits 0-7: 3
                        Selector lever position-Bits 0-7: 8
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    Readiness: 0110 0001
       Part No SW: 0CW 300 047 D    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 5203
       Revision: 00043014    Serial number: CU501411065326
       Shop #: WSC 00028 028 00066
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 3C21C946E6E40387D61-8068
    10817 - Clutch 1
              P189A 00 [072] - Clearance too Small
                        Mileage: 155020 km
                        Date: 2019.09.16
                        Time: 15:58:15
                        Engine speed: 5126.00 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 72 km/h
                        Control Module temperature: 91 °C
                        CURRENT pressure: -9.5 bar
                        Clutch: primary stat: Anfahren - Gangwechsel
                        selected gear: GANG_6
                        Driving position: N
                        Accelerator position: 0.0 %
                        DTC memory status: 47616
       Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
       Component: ESC           H42 0609
       Revision: 00000000    Serial number: 63174000003171
       Coding: 04FA6AA114271170077B060841CB2520562888E06082A4F300220078C202
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
       VCID: 3D27C442FDFE0A8FE1F-8068
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 02020004200100011005000000101000
       VCID: 6A8D3F1EDCF04D3774D-803E
       Part No SW: 5Q0 937 086 AD    HW: 5Q0 937 086 AD
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86580611140255
       Coding: 00001846C24102FB4BE44080B10403081000000000000000000000000000
       ROD: EV_BCMBOSCH_014.rod
       VCID: 7CA10946A664C387961-8028
       Component: WWS    141027  043 0551
       Serial number:         141108074854
       Component: RLHS  037 0059
       Serial number: S5Y14M11D20H08M01S47
       Coding: 00A8DD
       Serial number: 000000000ZY142741A3Z
       Serial number: 00000000000061015905
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 118
                        Mileage: 155020 km
                        Date: 2019.09.16
                        Time: 15:00:23
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39331431103932
       Coding: 0031151011
       Component: AirbagVW20    014 0386
       Serial number: 003MLR0A9D4N
       Shop #: WSC 00028 028 00061
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F5BFE4AB772D89FB33-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34169667B14111480878
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34169668B14111470903
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 811 14
       Serial number: 357670000002A9F0911W
       Subsystem 4 - Part No SW: -----------    HW: 480 001 211 14
       Serial number: 35867000000834A0C11P
       Subsystem 5 - Part No SW: -----------    HW: 480 401 111 14
       Serial number: 3516502A3188FC0161CD
       Subsystem 6 - Part No SW: -----------    HW: 480 401 111 14
       Serial number: 3526502B9188FC02A32I
       Subsystem 7 - Part No SW: -----------    HW: 480 403 110 14
       Serial number: 3556502B71860BC1B0EM
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20141112400579
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3FDBBE4AF7F2189FF33-806A
       Part No SW: 5G1 920 750     HW: 5G1 920 750
       Component: KOMBI         304 4270
       Coding: 07A412082380000800086A001400000000000000
       VCID: 649151263ED41B474E1-8030
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2203
       Revision: --------    Serial number: 10111410800878
       Coding: 030100042F085700EF00024C1C0F00010001050000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 71BF2872F126BEEF357-8024
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H16 0038
       Serial number: 21140000169980064462
       Coding: 28FFFF
       Serial number: 3277405003
       Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
       Component: TSG FS        009 0015
       Serial number: 0000126292382
       Coding: 003A03208000028000001000
       VCID: 45D7ACA2952E424FB9F-8010
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000007186499
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0102
       VCID: 43D3B2BA9B1A7C7F97B-8016
       Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0015
       Serial number: 0000126302200
       Coding: 003A01208E00028000801000
       VCID: 44D1B1A69E147B47AE1-8010
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000007117573
       Coding: 090000
       Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
       Component: MU-S-N-ER     041 0430
       Serial number: V1F01611140255
       Coding: 02730201FF00000021110001000800001F0100140100010045
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 270B062A0F62B05FAB3-8072
       Component: ABT_Std_Nav  H60 0030
       Serial number: VWZ8Z9PS4049LB
       Subsystem 2 - Part No SW: 5G0 919 866 Q    HW: -----------
       Component:  ECE 2015  --- 0045
    0008 - Connection between Antenna Amp 2 for Radio and Antenna
              B1273 13 [009] - Open Circuit
                        Reset counter: 115
                        Mileage: 154987 km
                        Date: 2019.09.13
                        Time: 08:14:10
                        Voltage terminal 30: 11.4 V
                        Status of antenna 2 for radio-Antenna current: 0 mA
                        Status of antenna 2 for radio-Connection between radio and antenna amplifier: Electrical OK
                        Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Open circuit
                        Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
    End----------(Elapsed Time: 01:36, VBatt start/end: 11.9V/12.0V)-----------
    There's a crazy amount of data regarding the clutches in the measuring values of that TCU, but I'm not sure exactly what it is you're looking for. Have you got an example of the data you like from an older, non-UDS DSG?
    Jul 2019
    I Would like to see the clutch adaptions like in MB 115-3 95-3 (new 11mm worn 17mm)
