Results 1 to 10 of 14
Thread: Audi Q7 2014 Model Instrument cluster not powering up
    New User
    Sep 2019
    Australia
    Hi
    I have got 2014 Model Audi Q7 - Australian Version. Couple of days ago i was checking some fuses on the left hand side of the dash - Passenger side in Australia.
    I have taken some fuses out and put it back in the right spot after checking them.
    Now I do not have power in the dash cluster. All my dials, fuel gauge and temp gauge are not working.
    I can only see couple of little icons like ABS, Hand brake, Air bags etc. My reverse camera and parking sensors are also not working.
    When i try to reverse i hear a 4-5 seconds beep from the rear side of the car.
    I did a scan and saw a lot of errors which i believe is due to the dash cluster being without power.
    Could you please advise what could be the problem.
    My error codes are attached below
    Sunday,15,September,2019,19:54:37:12214
    VCDS Version: 19.6.1.0 (x64)
    Chassis Type: 4L-AU56 (4F0)
    04-Steering Angle -- Status: Sporadic communication error 1000
    05-Acc/Start Auth. -- Status: Malfunction 1010
    10-Park/Steer Assist -- Status: Malfunction 1010
    16-Steering wheel -- Status: Malfunction 1010
    28-HVAC, Rear -- Status: Malfunction 1010
    4F-Centr. Electr. II -- Status: Malfunction 1010
    6C-Back-up Cam. -- Status: Malfunction 1010
    Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4L2 910 401 B    HW: 4L0 907 401 C
       Component: 3.0TDI EDC17  H41 0003
       Revision: 53H41---    Serial number:
       Coding: 2A2A4012A52701020000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0114L2910401B 001003
       ROD: EV_ECM30TDI0114L1910401H.rod
       VCID: 2345F6B12AFA4E57A4-8076
    7 Faults Found:
    7249 - No Communications with Steering Angle Sender (G85)
              U0126 00 [032] - -
                        Time: 00:00:00
                        Engine speed: 769.50 /min
                        Normed load value: 12.9 %
                        Coolant temperature: 58 °C
                        Intake air temperature: 38 °C
                        Voltage terminal 30: 11.760 V
                        Cruise Control System (CCS): status-Bits 0-7: 15
                        selected gear-Bits 0-7: 0
    4708 - No Communications with HVAC Control Module (J301)
              U0164 00 [032] - -
                        Time: 00:00:00
                        Engine speed: 726.50 /min
                        Normed load value: 27.5 %
                        Voltage terminal 30: 12.740 V
                        Cruise Control System (CCS): status-Bits 0-7: 207
    4713 - No Communication with ABS Brake Control Module
              U0121 00 [032] - -
                        Time: 00:00:00
                        Engine speed: 760.00 /min
                        Normed load value: 15.7 %
                        Coolant temperature: 59 °C
                        Intake air temperature: 39 °C
                        Voltage terminal 30: 11.820 V
                        Cruise Control System (CCS): status-Bits 0-7: 44
    4714 - Steering Column Control Module
              U0212 00 [032] - No Communications
                        Time: 00:00:00
                        Engine speed: 747.50 /min
                        Normed load value: 22.0 %
                        Voltage terminal 30: 12.280 V
    4715 - No Communication with Instrument Cluster
              U0155 00 [175] - -
                        Time: 00:00:00
                        Engine speed: 696.50 /min
                        Normed load value: 22.4 %
                        Coolant temperature: 68 °C
                        Intake air temperature: 48 °C
                        Voltage terminal 30: 13.980 V
                        Cruise Control System (CCS): status-Bits 0-7: 239
    4719 - No Communication with Diagnostic Gateway
              U0146 00 [032] - -
                        Time: 00:00:00
    4720 - Body Control Module (Central Electric 2)
              U0141 00 [032] - No Communications
                        Time: 00:00:00
    Readiness: 1 1 0 0 0
       Part No SW: 0C8 927 750 AL    HW: 0C8 927 750 AL
       Component: AL1000 AISIN  002 2447
       Coding: 001578
       Shop #: WSC 47550 001 1048576
       ASAM Dataset: EV_TCMAL991031 002112
       ROD: EV_TCMAL991031_002.rod
       VCID: 76E3FFE5C9E88BFFB3-8022
    12810 - No Communication with ABS Brake Control Module
              U0121 00 [008] - -
                        Reset counter: 195
                        Engine speed: 840.0 /min
                        Transmission input speed: 660 /min
                        Engine torque: 24 Nm
                        Transmission fluid temperature: 50 °C
                        Accelerator position: 0.0 %
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
                        Lock Up Clutch: Open
                        EOP failure status 2: Normalcy
                        EOP target revolution: 0 /min
                        EOP actual revolution: 65279 /min
                        Engine Speed signal Current: 65279 /min
                        EOP failure status with EOP without HV 1: Motor normal stop
                        EOP target current: 65278 mA
    12812 - Steering Column Control Module
              U0212 00 [008] - No Communications
                        Reset counter: 195
                        Engine speed: 810.0 /min
                        Transmission input speed: 780 /min
                        Engine torque: -4 Nm
                        Transmission fluid temperature: 74 °C
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
    12813 - No Communication with Diagnostic Gateway
              U0146 00 [008] - -
                        Reset counter: 195
                        Engine speed: 720.0 /min
                        Transmission input speed: 690 /min
                        Engine torque: 12 Nm
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
    12814 - No Communication with Instrument Cluster
              U0155 00 [009] - -
                        Reset counter: 201
                        Engine speed: 690.0 /min
                        Engine torque: -12 Nm
                        Transmission fluid temperature: 66 °C
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
       Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
       Component: ESP ALLRAD MK25E1   0020
       Revision: 00H02001
       Coding: 2196593
       VCID: 346705ED5714D9EF4D-8060
                        Reset counter: 81
                        Count: 192
                        Count: 2881
                        Count: 297
                        Count: 32512
                        Reset counter: 81
                        Count: 65
                        Count: 166
                        Count: 43008
                        Reset counter: 41
                        Count: 321
                        Count: 8208
                        Count: 43008
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0200
       Revision: 00H08000    Serial number: 10603702127028
       Coding: 0000151
       VCID: 2541E8A9ECCEB067CA-8070
       Subsystem 1 - Part No: 4F0 910 132 C
       Component: FBSAUDIC6 EZS   H04 0020
       Subsystem 2 - Part No: 4F0 910 335 B
       Component: FBSAUDIC6 KSG   H03 0020
    00193 - Rear Right Door Handle Touch Sensor (G418)
                007 - Short to Ground
                        Fault Status: 01110111
                        Reset counter: 41
                        Reset counter: 81
    02072 - Control Module for Energy Management (J644)
                        Reset counter: 81
    00263 - Transmission
                        Reset counter: 81
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AN
       Component: KLIMA 4 ZONEN H15 0070
       Revision: 00---031    Serial number: 00000030330508
       Coding: 01029456
       VCID: 2541E8A92CCEB067CA-8070
                        Reset counter: 41
                        Fault Status: 00101010
                        Reset counter: 81
                        Temperature: 30.0°C
       Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
       Component: ILM Fahrer      H31 0400
       Coding: 0023121
       VCID: 6FEDCA817EB2BA3770-803A
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H13 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
                        Reset counter: 81
    00456 - Control Module for Access and Start Control (J518)
                        Reset counter: 81
                        Reset counter: 81
    00908 - Control Module for Wiper Motor
                        Fault Frequency: 7
                        Reset counter: 81
    Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55961408700599
       Coding: 28031F
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: 346705ED9F14D9EF4D-8060
    12670224 - Databus
                        Reset counter: 41
                        Time: 00:00:00
    12656936 - Databus
                        Reset counter: 81
                        Time: 00:00:00
       Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
       Component: 70 AIRBAG AUDI8RH45 0230
       Revision: 06H45000    Serial number: 00399D605TYM
       Coding: 0014128
       VCID: 2E531785B938F33F3B-807A
       Subsystem 1 - Serial number: 6332QSME1E3F237EY
       Subsystem 2 - Serial number: 6342QSME204113580
       Subsystem 3 - Serial number: 6352QSME243F5244G
       Subsystem 4 - Serial number: 6362QSME273F165EV
       Subsystem 5 - Serial number: 63734SME3C4C11584
       Subsystem 6 - Serial number: 63834SME3C4C1B72B
    01316 - ABS Control Module
                004 - No Signal/Communication - Intermittent - MIL ON
    01312 - Powertrain Data Bus
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
       Component: J0527               0830
       Revision: 00H09000    Serial number: 90026140670295
       Coding: 0102142
       VCID: 285FE19D9BDCAD0FF1-807C
       Component: E0221           H03 0040
                        Fault Frequency: 6
                        Reset counter: 41
                        Reset counter: 81
                        Date: 2063.15.31
                        Time: 31:63:02
                        Reset counter: 81
                        Date: 2063.15.31
                        Time: 31:63:02
                        Reset counter: 81
    Address 17: Instruments
    Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
       Part No SW: 4L0 910 105     HW: 4L0 815 071 H
       Component: Heizgeraet      H10 0140
       Revision: 0000000A    Serial number: 00000009024928
       Coding: 0000101
       VCID: 60CFB9BDB36C154FF9-8034
       Part No SW: 4F0 907 468 R    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0058
       Revision: LB700037    Serial number: 3700L143290454
       Coding: 00CF07
       VCID: 3E7327C5A95803BFAB-806A
       Subsystem 1 - Part No SW: 8K0 915 181 D    HW: 8K0 915 181 D
       Component: J367-BDM  H07 0125
       Serial number: 31090219564121042614
       Serial number: 14092001342011200181
    11 Faults Found:
                        Reset counter: 79
                        Mileage: 43919 km
                        Date: 2019.09.01
                        Time: 12:18:24
                        Bin. Bits:    10111
                        Voltage: 11.50 V
                        Count: 7
    00381 - Databus Instrument Cluster
                        Fault Frequency: 48
                        Reset counter: 41
                        Mileage: 44099 km
                        Date: 2019.09.14
                        Time: 21:42:39
                        Bin. Bits:    10000
                        Voltage: 12.10 V
                        Count: 11
                        Bin. Bits:    10010
                        Reset counter: 81
                        Mileage: 44099 km
                        Date: 2019.09.14
                        Time: 21:42:39
                        Bin. Bits:    10000
                        Voltage: 12.10 V
                        Count: 11
                        Bin. Bits:    10010
                        Time: 13.50 s
                        Reset counter: 81
                        Mileage: 44099 km
                        Date: 2019.09.14
                        Time: 21:42:39
                        Bin. Bits:    10111
                        Voltage: 11.90 V
                        Count: 7
                        Bin. Bits:    10011
                        Time: 0.40 s
                        Reset counter: 81
                        Bin. Bits:    10111
                        Voltage: 12.00 V
                        Count: 7
                        Bin. Bits:    10000
                        Time: 4.90 s
    01327 - Control Module for Parking Aid (J446)
                        Reset counter: 81
                        Bin. Bits:    10111
                        Voltage: 12.00 V
                        Count: 7
                        Bin. Bits:    10000
                        Time: 5.00 s
    02103 - Control Module 2 for Vehicle Electrical System (J520)
                        Fault Frequency: 6
                        Reset counter: 81
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 11
                        Bin. Bits:    10010
                        Time: 4.90 s
                        Reset counter: 81
                        Bin. Bits:    10000
                        Voltage: 11.90 V
                        Count: 12
                        Bin. Bits:    10010
                        Time: 25.40 s
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 81
                        Bin. Bits:    00000
                        Voltage: 12.20 V
                        Count: 19
                        Bin. Bits:    10010
    00565 - Rear A/C Control Head (Climatronic) (E265)
                        Reset counter: 81
                        Bin. Bits:    10000
                        Voltage: 12.00 V
                        Count: 12
                        Bin. Bits:    10011
                        Time: 25.40 s
                        Reset counter: 81
                        Bin. Bits:    11111
                        Voltage: 12.00 V
                        Count: 7
                        Bin. Bits:    10011
                        Time: 0.40 s
    Address 28: HVAC, Rear        Labels: None
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AD
       Component: KLIMABETAETIGUNGH06 0060
       Revision: 00---011    Serial number: 00000030330555
       Coding: 0000006
       VCID: 68DFA19D5B5C6D0F31-803C
    00003 - Control Module
                        Fault Status: 00100011
                        Fault Frequency: 15
                        Mileage: 34059 km
                        Date: 2018.08.28
                        Time: 15:12:12
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 41
                        Mileage: 44099 km
                        Date: 2019.09.14
                        Time: 21:39:19
                        Reset counter: 41
                        Mileage: 44099 km
                        Date: 2019.09.14
                        Time: 21:42:39
       Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000098720608
       Coding: 011E52200141440004
       Shop #: WSC 14644 002 104857
       VCID: 489F411DFB9C4D0F11-801C
                        Fault Status: 01101100
                        Fault Frequency: 19
                        Reset counter: 41
                        Reset counter: 81
                        Reset counter: 81
                        Reset counter: 81
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 01945953440000
       Coding: 3539341
       VCID: 387F31DD4B7C3D8F61-806C
                        Reset counter: 81
                        Reset counter: 81
                        Fault Frequency: 7
                        Reset counter: 81
                        Reset counter: 81
                        Reset counter: 81
       Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
       Component: BOSE G3 Q7    H04 0160
       Revision: CH004001    Serial number: 00000000038453
       Coding: 030000
       VCID: 2959E49940D69407EE-807C
       Part No SW: 4F0 910 280     HW: 4F0 907 280
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000740665
       Coding: 0011001
       VCID: 5EB38745891823BFCB-800A
                        Reset counter: 81
                        Voltage: 12.100 V
                        Temperature: 35.0°C
                        Reset counter: 81
                        Voltage: 12.000 V
                        Temperature: 33.0°C
                        Fault Frequency: 84
                        Reset counter: 41
                        Mileage: 44096 km
                        Date: 2019.09.14
                        Time: 21:42:00
                        Voltage: 12.200 V
                        Temperature: 77.0°C
                        Reset counter: 81
                        Voltage: 9.700 V
                        Temperature: 77.0°C
       Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000097819635
       Coding: 011F52204C41440004
       VCID: 479D4221F682427718-8012
                        Fault Frequency: 12
                        Reset counter: 41
                        Reset counter: 81
                        Reset counter: 81
                        Reset counter: 81
       Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
       Serial number: 140407-0002-128
       Coding: 1147A71010000500
       ROD: EV_HeadlRegulBasic.rod
       VCID: 428B5335D5A0675FCF-8016
    0074 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 81
    0076 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 81
    0078 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 81
    0082 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 41
    0084 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 41
    0092 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 41
       Part No SW: 4G1 035 053 J    HW: 4G1 035 053
       Component: Radio U Basic H41 0133
       Revision: AB001007    Serial number: 227D90E7988906
       Coding: 040003010000000000
       VCID: 2643EFA551C8BB7FC3-8072
       Part No SW: 4L2 035 764 G    HW: 4L2 035 764 G
       Component: H-BNT-RW      H48 0793
       Revision: --------    Serial number: 222DQ0E7516151
       Coding: 180A01060004C3FF010007456F7720035C0000000000000000
       VCID: 326B03F56D00D7DF5F-8066
       Subsystem 1 - Part No: 8R0 060 884 BN
       Component: ROW 2014  0605
       Component: DU7 High  H42 0104
       Serial number: A130D%0E2999726
       Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
       Component: E0380 Bedient  H01 0060
       Serial number: 00000002176053
       Component: CD-Database  5571
                        Reset counter: 81
                        Voltage: 12.10 V
                        Reset counter: 41
                        Bin. Bits: 10000000 00000000
                        Bin. Bits: 00000000 00000100
                        Bin. Bits: 00000000 00000000
                        Reset counter: 41
                        Bin. Bits: 00000000 10000100
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000098742385
       Coding: 010850204041230004
       Shop #: WSC 14644 002 1048576
       VCID: 46834F25F1885B7FE3-8012
                        Reset counter: 81
       Part No SW: 4L0 907 428     HW: 7P6 907 441 D
       Component: TopView       H05 0293
       Revision: 11001001    Serial number: 82330JF0141287
       Coding: 020C010001000100000102000000
       ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
       ROD: EV_CamSysteCorneViewAUDI.rod
       VCID: 6ED3D785B1B8B33F7B-803A
    13701381 - Databus
                        Reset counter: 81
                        Time: 00:00:00
                        Voltage terminal 30: 11.5 V
    13701382 - Databus
                        Reset counter: 81
                        Time: 00:00:00
    13701383 - Databus
                        Reset counter: 81
                        Voltage terminal 30: 12.3 V
                        Terminal 15 status: Terminal 15 off
    13701385 - Databus
                        Reset counter: 81
    13701386 - Databus
                        Reset counter: 81
       Part No SW: 4L0 910 945     HW: 4L0 827 851 F
       Component: ValeoHeckdeckel H58 0500
       Revision: --H58001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6CD7DD8D4FA4412F55-8038
       Subsystem 2 - Serial number: 5ó
       Subsystem 3 - Serial number: RD05.04.14--H58001002E0119˙
       Subsystem 4 - Serial number: 2E0119˙
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 0097987843----
       Coding: 0003587
       VCID: 2643EFA591C8BB7FC3-8072
       Component: J_245_EE16_SKB10H14 0220
       Subsystem 2 - Part No: 4L0 910 591 A
       Component: J_394_EE16_SKB10H14 0220
       Subsystem 3 - Part No: 4L0 910 591 A
       Component: J_392_EE16_SKB10H14 0220
                        Reset counter: 81
                        Reset counter: 81
                        Reset counter: 81
    00927 - Terminal 30 (Right)
                        Fault Status: 00101100
                        Reset counter: 81
    01516 - Terminal 30; Left
                        Reset counter: 81
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000098742384
                        Reset counter: 81
    End-------------------------(Elapsed Time: 03:42)--------------------------
    Many of those errors are intermittent, so try clearing all DTCs and see which ones come back, the post a new Auto-Scan showing those.
    Are you 100% certain you put all the fuses back in the correct place?
    New User
    Sep 2019
    Australia
    Thanks PetrolDave
    I actually cleared all DTCs before and i keep getting these errors back.
    I may do it once again and get a full scan and post again in about an hour or less
    I think i did put all the fuses back to where they were but i can be wrong now as i am questioning myself too
    It would be handy if i can get a picture of the left hand side of the dash fuse pictures. Because the first fuse at the top bracket (out of 3) do not have power when i checked with voltage tester. I pulled that fuse out and checked - the fuse is ok.
    New User
    Sep 2019
    Australia
    Hi again
    I cleared all DTC and rescanned
    The errors still came up
    Pls see the new errors below
    Tuesday,17,September,2019,19:54:33:12214
    VIN: WAUZZZ4L7ED035153   License Plate:
    Scan: 01 02 03 05 08 09 10 15 16 17 18 19 28 42 46 47 4F 52 55 56
              5F 62 6C 6D 6F 72
    01-Engine -- Status: Cannot be reached 1100
    02-Auto Trans -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    04-Steering Angle -- Status: Cannot be reached 1100
    10-Park/Steer Assist -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    17-Instruments -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    6C-Back-up Cam. -- Status: Cannot be reached 1100
              U0155 00 [175] - -
                        Time: 00:00:00
                        Coolant temperature: 64 °C
                        Intake air temperature: 36 °C
                        Voltage terminal 30: 12.300 V
                        Cruise Control System (CCS): status-Bits 0-7: 236
       Coding: 001578
              U0155 00 [009] - -
                        Reset counter: 201
                        Engine speed: 0.0 /min
                        Transmission input speed: 0 /min
                        Engine torque: -52 Nm
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
       Revision: 00H02001
       Coding: 2196593
                        Reset counter: 41
                        Count: 128
                        Count: 321
                        Count: 8208
                        Count: 44288
       Coding: 0000151
       Coding: 01029456
                        Reset counter: 41
       Coding: 0023121
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
       Coding: 28031F
    12670224 - Databus
                        Reset counter: 41
                        Time: 00:00:00
       Coding: 0014128
       Coding: 0102142
                        Reset counter: 41
       Coding: 0000101
       Coding: 00CF07
                        Reset counter: 41
                        Bin. Bits:    10000
                        Voltage: 12.70 V
                        Count: 12
                        Bin. Bits:    10011
       Coding: 0000006
                        Reset counter: 41
                        Reset counter: 41
       Coding: 3539341
       Coding: 030000
       Coding: 0011001
                        Reset counter: 41
                        Voltage: 12.800 V
                        Temperature: 20.0°C
              U1111 00 [009] - -
                        Reset counter: 41
              U1111 00 [137] - -
                        Reset counter: 41
              U1111 00 [137] - -
                        Reset counter: 41
                        Reset counter: 41
                        Reset counter: 41
       Coding: 0003587
    End-------------------------(Elapsed Time: 03:33)--------------------------
    Jan 2018
    Cheshire UK
    Recheck the fuses, check your manual for location and numbers. All the faults appear to be from no power to the modules
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  6. Likes PetrolDave liked this post
    New User
    Sep 2019
    Australia
    Quote Originally Posted by morski View Post
    Thank You Morski
    I checked all fuses
    On the left hand side fuse block the A1 fuse - Supposed to be for Voltage stabiliser - J532 has no power. I thought it was a blown fuse but its not the fuse as i tried that fuse in other locations and also i tried a new fuse for this.
    Now I am pretty sure my J532 module is gone. As i read that this provides constant 10V power to the dash clusters on these cars.
    I could not find anywhere on internet the location of this Module. Does anyone know where this module is and how i can access it?
    I am guessing behind the dash clusters , Battery under the seat or around the spare tyre at the back.
    Thank you
    Jan 2018
    Cheshire UK
    Check near the battery. Not 100% sure where it is on the Q7 but a5,a6,a4's etc are all near the battery. There are/should be some fuses by the battery terminal check them as well. Also have you used a voltage light stick where you can probe to check for power presence on each of the fuses whilst still physically in place? Could be a old fuse that looks ok but is broken inside.
    Have you got the workshop manual for the car as it will the location of all fuse boxes and fuses
    A6 BiTdi Avant MTM
  9. Likes PetrolDave liked this post
  10. #8
    Apr 2018
    ITALY
    free hint: before pulling out one entire row, or the whole fusebox, take pictures with your cell phone. been there :P
  11. Likes PetrolDave, Uwe liked this post
  12. #9
    New User
    Sep 2019
    Australia
    Thanks again Morski
    I checked all the fuse locations except the one near battery as the battery in this car is located under the passengers seat - so i got to remove the seat or unless there is any easy access there.
    Yes i used the voltage light to check the fuses and thus concluded that VOLTAGE STABILIZER FUSE port is dead and is not feeding power to the fuse. The fuse itself is good as i tried couple of new fuses too - just in case.
    I do not have the workshop manual but i know the locations of all fuses. The only thing that's left for me to try is to test fuses near battery area under the seat and if fuses are good there start hunting for J532 Module which i don't know where its located - because in this case this module may need to be replaced.
    please anyone help me show me an easy way to test fuses under the seat and tell me where J532 is located
    Thank you
  13. #10
    New User
    Sep 2019
    Australia
    good idea
