Results 1 to 10 of 10
Thread: VW Scirocco 1.4L 7speed gearbox slipping
    Dec 2018
    Bahrain
    Dear,
    I would like your help in the troubleshooting of the following code for that gearbox:
    Address 02: Auto Trans Labels: 0AM-927-769.clb
    Part No SW: 0AM 300 048 N
    HW: 0AM927769D
    Component: GSG DSG AG7 403 9056
    Revision: 00040034
    Serial Number: TFK01101200561
    Shop #: WSC 33962 001 1048576
    VCID: 3B39A4EF0097B091264015-806E
    1. 006300 - Function Restriction due to Insufficient Pressure Build-Up P189C - 000 - -
    2. 006079 - Hydraulic Pump P17BF - 000 - Play Protection
    3. 006079 - Hydraulic Pump P17BF - 001 - Play Protection
    Address 01:
    Engine Labels: 03C-906-027-CAV.clb
    Part No SW: 03C 906 027 BB
    HW: 03C907309B
    WSC 71500 819 100930
    1. 049409 - No Communication with Transmission Control Module U0101 - 000 - - - Intermittent
    2. 001092 - EVAP Purge Control Valve (N80) P0444 - 000 - Circuit Open - MIL ON
    Regards,
    Please post a full unedited Auto-Scan not just two tiny sections
    Dec 2018
    Bahrain
    VIN: WVWAC2135AV431700 Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4F 52 55 56 77 VIN: WVWAC2135AV431700 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Communication Error 1010 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Xenon Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 77-Telephone -- Status: OK 0000 ----------------------------------------------------------------- Address 01: Engine Labels: 03C-906-027-CAV.clb Part No SW: 03C 906 027 BB HW: 03C907309B Component: MED17.5.5 G 9703 Revision: LAH08--- Serial Number: Coding: 0000077 Shop #: WSC 71500 819 100930 VCID: 6287398BC7BDA15945C6A0-8037 2 Faults Found: 049409 - No Communication with Transmission Control Module U0101 - 000 - - - Intermittent 001092 - EVAP Purge Control Valve (N80) P0444 - 000 - Circuit Open - MIL ON ----------------------------------------------------------------- Address 02: Auto Trans Labels: 0AM-927-769.clb Part No SW: 0AM 300 048 N HW: 0AM927769D Component: GSG DSG AG7 403 9056 Revision: 00040034 Serial Number: TFK01101200561 Coding: 0000020 Shop #: WSC 33962 001 1048576 VCID: 3B39A4EF0097B091264015-806E 3 Faults Found: 006300 - Function Restriction due to Insufficient Pressure Build-Up P189C - 000 - - 006079 - Hydraulic Pump P17BF - 000 - Play Protection 006079 - Hydraulic Pump P17BF - 001 - Play Protection ----------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ Component: ESP MK60EC1 H30 0107 Revision: 00H30001 Coding: 743B60F5612500FB2E1206E486190040310000 Shop #: WSC 00020 790 00000 VCID: 7AB761EB4F2DC9997DD6D8-802F 1 Fault Found: 01315 - Transmission Control Module 004 - No Signal/Communication - Intermittent ----------------------------------------------------------------- Address 08: Failed to respond ----------------------------------------------------------------- Address 09: Failed to respond
    HQ
    Please try that again and use the directions post here:
    https://forums.ross-tech.com/showthr...t-an-Auto-Scan
    Jef
    Dec 2018
    Bahrain
    sure
    Monday,16,September,2019,16:56:05:57315
    VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4505.4
    VIN: WVWAC2135AV431700   License Plate:
    Chassis Type: 13-VW36 (1K0)
    02-Auto Trans -- Status: Malfunction 1010
    Address 01: Engine (CAV)       Labels: 03C-906-027-CAV.clb
       Part No SW: 03C 906 027 BB    HW: 03C 907 309 B
       Revision: LAH08---    Serial number:
       Coding: 0000077
       VCID: 628844B9BD90525FEF-8036
                   U0101 - 000 -  - Intermittent
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 25.0C
                        Temperature: 25.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 12.065 V
                        Fault Status: 11100000
                        Date: 2047.15.31
                        Time: 31:63:63
                        RPM: 244 /min
                        Load: 50.6 %
                        Temperature: 26.0C
                        Temperature: 25.0C
                        Voltage: 10.922 V
    Readiness: 0110 0101
       Part No SW: 0AM 300 048 N    HW: 0AM 927 769 D
       Revision: 00040034    Serial number: TFK01101200561
       VCID: 3B36D9DD7ABA43978C-806E
                   P189C - 000 -
                        Reset counter: 10
                        Mileage: 118867 km
                        Date: 2046.14.00
                        Time: 00:16:54
                   P17BF - 000 - Play Protection - Intermittent
                        Reset counter: 10
                        Mileage: 118867 km
                        Date: 2046.14.00
                        Time: 08:04:45
       Revision: 00H30001
       VCID: 7AB81CD9F500BA9FD7-802E
                        Reset counter: 18
                        Mileage: 118867 km
                        Date: 2045.14.31
                        Time: 00:29:02
                        Count: 16386
                        Count: 14
                        Count: 28672
                        Count: 8195
                        Count: 43776
                        Count: 10081
    Address 08: Auto HVAC (J255)       Labels:. 5K0-907-044.clb
       Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
       Component: Climatronic   H15 1012
       Revision: 00003001
       Coding: 0000001002
       Shop #: WSC 35435 001 1048576
       ROD: N/A
       VCID: 7EB010C9E12896BFEB-802A
    No ASAM data for: "EV_Climatronic" (VW36 *)
       Part No SW: 5K0 937 087 D    HW: 5K0 937 087 D
       Component: BCM PQ35 H    011 0028
       Revision: BE011001
       Coding: 40100A3B98250A0040080080340049E643550A88736D8D60648000000000
       Shop #: WSC 99900 715 86054
       VCID: 3620C8E981989EFF73-8062
       Subsystem 1 - Part No: 1K8 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 14110  22  0614
       Coding: 009795
       Component: RLS 221209 05  54  0402
       Coding: 0330ED
                        Reset counter: 58
                        Mileage: 118867 km
                        Date: 2045.14.31
                        Time: 00:29:04
                        Voltage: 12.20 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 18
                        Mileage: 118867 km
                        Date: 2045.14.31
                        Time: 00:29:03
                        Voltage: 12.20 V
    Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
       Part No SW: 1K0 919 475 K    HW: 1K0 919 475 K
       Component: PARKHILFE     005 1706
       Revision: 00005000    Serial number: 0 263 004 388
       Coding: 100101
       VCID: 3A38DCD9B5807A9F97-806E
                        Reset counter: 18
                        Mileage: 118867 km
                        Date: 2045.14.31
                        Time: 00:29:01
       Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
       Component: 0G AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 003D1D01YHMI
       Coding: 0012359
       VCID: 6FAE3D8D7E42EF3770-803A
       Subsystem 1 - Serial number: 6332MSME4C657509J
       Subsystem 2 - Serial number: 6342MSME4C660F48R
       Subsystem 3 - Serial number: 6352QSME1A4A2724H
       Subsystem 4 - Serial number: 6362QSME264A3D06M
    Address 16: Steering wheel (J527)       Labels:. 5K0-953-569.clb
       Part No SW: 5K0 953 521 F    HW: 5K0 953 569 B
       Component: LENKS.MODUL   009 0122
       Revision: FF010035    Serial number: 20100104100117
       Coding: 189A140000
       Shop #: WSC 00020 999 00000
       ASAM Dataset: EV_SMLSNGVOLWS A01002
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 2F2EFD8D76C2AF3730-807A
       Coding: 830000
    No ASAM data for: "EV_SMLSNGVOLWS" (VW36)
    Unable to open the following:
    IV_EV_SMLSNGVOLWS_A3,IV_EV_SMLSNGVOLWS_D2,IV_EV_SMLSNGVOLWS_M23,IV_EV_SMLSNGVOLWS_X4
    Internal ROD error:
    EV_SMLSNGVOLWS.rod:FFMUX
    0516 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 58
                        Mileage: 118867 km
                        Date: 2109.14.31
                        Time: 00:29:02
    Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
       Part No SW: 1K8 920 871 B    HW: 1K8 920 871 B
       Component: KOMBI         H05 0305
       Coding: 670E00
       ROD: N/A
       VCID: 312AFBF560F6B9C726-8064
    No ASAM data for: "EV_Kombi_UDS_VDD_RM09" (VW36 *)
    12648704 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 58
                        Mileage: 118867 km
                        Date: 2109.14.31
                        Time: 00:29:02
       Part No SW: 1K0 907 530 AE    HW: 1K0 907 951
       Component: J533  Gateway   H06 0112
       Revision:   H06 01    Serial number: 181209F1000967
       Coding: EDA11F06000603004000
       VCID: 6A982C9945A00A1F27-803E
                        Fault Status: 00110100
                        Reset counter: 58
                        Mileage: 118867 km
                        Date: 2046.14.00
                        Time: 05:12:42
       Component: IMMO          H05 0305
       VCID: 6A982C998DA00A1F27-803E
    Internal ROD error:
    EV_Immo_UDS_VDD_RM09.rod:FFMUX,EV_Immo_UDS_VDD_RM09.rod:MWB,EV_Immo_UDS_VDD_RM09.rod:XPL
       Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
       Component: Tuer-SG         009 2123
       Coding: 0020535
       VCID: 393AC3D5708671879E-806C
       Part No: 1K0 909 144 J
       Revision: 00H17000
       VCID: 312AFBF5A8F6B9C726-8064
       Part No SW: 1K0 907 532     HW: 1K0 907 951
       Component: EZE_2         H06 0112
       Coding: 01030100
       VCID: 668058A991B82E7F03-8032
       Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
       Component: J245/J878  H04 0054
       Serial number: 947200093561
       Coding: 000005
       Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
       Coding: 0020790
       VCID: 3A38DCD975807A9F97-806E
       Part No: 8P0 907 357 K
       Coding: 0000015
       VCID: 42C8A4391D50325FCF-8016
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
                        Fault Status: 11101010
                        Reset counter: 18
                        Mileage: 118872 km
                        Date: 2045.14.30
                        Time: 21:09:18
    01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
                        Reset counter: 18
                        Mileage: 118872 km
                        Date: 2045.14.30
                        Time: 21:09:18
       Part No SW: 5K0 035 190     HW: 5K0 035 190
       Component: Radio RCD510  040 0167
       Revision: 00000001    Serial number: VWZ1Z3I7312823
       Coding: 0500040004
       VCID: 628844B97D90525FEF-8036
    Address 77: Telephone        Labels: 3C0-035-730.lbl
       Part No SW: 5N0 035 730 B    HW: 5N0 035 730 B
       Component: J412                8502
       Revision: 00015000    Serial number: 0000B7A138941
       Coding: 0020145
       VCID: 271E15AD9632F777F8-8072
    End----------(Elapsed Time: 01:20, VBatt start/end: 13.5V/13.5V)-----------
    Dec 2018
    Bahrain
    The dealership recommend to change the mechatronic...and 2 litters of gearbox oil. I am thinking maybe it is a harness fault.
    What is the part i need to search for ? ebay..second hand what will be the coding to replace that part ?
    Regards
  7. #7
    HQ
    OK, first questions:
    Did you do something to cause the TCM to go offline? Unplug something or pull fuse(s)? If you go and clear out all the codes, do the ones for dead TCM come back?
    Jef
  8. Likes Uwe liked this post
  9. #8
    Jul 2014
    Tallinn, Estonia
    The fault codes in the transmission pretty much tell the tale of the common mechatronic fault of the DQ200 DSG. The pressure accumulator valve housing inside the mechatronic develops cracks and hydraulic pressure needed for correct operation is not attained.
    Either replace or repair the mechatronic unit.
  10. Likes Golftwincharged liked this post
  11. #9
    Jun 2016
    Guyana
    Another Failed DSG7 mech unit, valve accumulator plate issues, replacing plate will fix this, but can this cause gearbox slipping?? in cases like this you get no gears..
  12. #10
    Dec 2018
    Bahrain
    Yes dear, it comes back as soon as s reset all codes. I didn't remove anything but maybe dealership did as I got it out of the dealership, second hand fresh purchased..
