Results 1 to 2 of 2
Thread: Seat Exeo abs coding
    Verified VCDS User AurimasFr's Avatar
    Jan 2018
    Lithuania
    I need recode Seat Exeo abs from auto transmission to manual. Engine i have recode. Can some on help with abs?
    Monday,16,September,2019,17:53:51:06635
    VIN: VSSZZZ3RZDR002320   License Plate: SEAT EXEO
    Mileage: 208970km-129847mi   Repair Order:
    Chassis Type: 3R-SE41 (3R - Seat Exeo (2010 >))
    Scan: 01 02 03 08 09 10 15 16 17 25 37 36 45 46 4C 55 56 77
    VIN: VSSZZZ3RZDR002320   Mileage: 208970km-129847miles
    Address 01: Engine (J623-CJCA)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 ME    HW: 03L 906 018 LD
       Component: R4 2.0l TDI   H24 9978
       Revision: 46H24---    Serial number:
       Coding: 13194012233400080000
       ASAM Dataset: EV_ECM20TDI01103L906018ME 003007
       ROD: EV_ECM20TDI01103L906018LD.rod
       VCID: 79AFEF3CF958CC7F8D7-802C
    Address 03: ABS Brakes        Labels: None
       Part No SW: 3R0 907 379     HW: 3R0 614 517
       Component: ESP8 FRONT      H06 0050
       Coding: 0004402
       Shop #: WSC 06441 785 00200
       VCID: 78A9EA38CED2D577F29-802C
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x0702
                        Hex Value: 0x0013
                        Hex Value: 0x44B1
                        Hex Value: 0x0000
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x0702
                        Hex Value: 0x0014
                        Hex Value: 0x21B1
                        Hex Value: 0x0000
    18055 - Check Coding of ECUs on Powertrain Data Bus
                P1647 - 000 -
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x0702
                        Hex Value: 0x0014
                        Hex Value: 0x10B1
                        Hex Value: 0x0000
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   3233
       Coding: 00000
       Shop #: WSC 06441
       VCID: 6D87CB6CB48060DF11F-5160
                30-00 - Open or Short to Plus
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  ECE 1107
       Coding: 11101
       Shop #: WSC 06441
       VCID: 3D273B2CA460305FE1F-4B1E
       Part No SW: 3R0 919 475     HW: 8P0 919 475 M
       Component: PARKHILFE 4K  H08 0005
       Revision: --------    Serial number: 36861216901672
       Coding: 010002
       Shop #: WSC 04941 000 00000
       VCID: 78A9EA38C2D2D577F29-802C
    Address 15: Airbags        Labels: 3R0-959-655.clb
       Part No SW: 3R0 959 655     HW: 3R0 959 655
       Component: 02 Airbag 9.41  H15 0010
       Revision: 91H15001    Serial number: 003E90026VT8
       Coding: 0012338
       VCID: 7CA1F628FAEAF957961-8028
       Subsystem 1 - Serial number: 6332DRB40EB3531FZ
       Subsystem 2 - Serial number: 6342DRB40EB21420I
       Subsystem 3 - Serial number: 6352ARB406BB8CA30
       Subsystem 4 - Serial number: 6362ARB406BB36A0U
       Subsystem 5 - Serial number: 63747RB406B53BAA$
       Subsystem 6 - Serial number: 63847RB406B51CE7/
       Part No: 8E0 953 549 Q
       Component: Lenksįulenmodul     0902
       Coding: 02042
       Shop #: WSC 11111
       VCID: 41DF47DCD89854BF857-4B1E
    Address 17: Instruments        Labels: 3R0-920-xxx-17.clb
       Part No SW: 3R0 920 830 L    HW: 3R0 920 830 L
       Component: KOMBI+WFS 4     H06 0040
       Revision: 0040        Serial number: 00000000000000
       Coding: 0006018
       Shop #: WSC 12345 111 45725
       VCID: 372B2904835C1A0F3B3-5184
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0006018
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 3R0 035 192     HW: 3R0 035 192
       Component: RNS-E PU EU     H07 0220
       Revision: 0000013S    Serial number: SEZBZ7M6903464
       Coding: 0318157
       VCID: 698FBF7C85687CFF7D7-5118
       Part No: 8E0 959 433 CL
       Component: Komfortgerįt T01    4336
       Coding: 07024
       Shop #: WSC 06441
       VCID: 7DA7FB2CE4E0F05FA1F-4B1E
       Component: Tőrsteuer.FS BRM 0706
       Subsystem 2 - Part No: 8E1959802G
       Component: Tőrsteuer.BF BRM 0706
       Component: Tőrsteuer.HL BRM 0606
       Component: Tőrsteuer.HR BRM 0606
    00955 - Key 1
                35-00 - -
    Address 4C: Tire Pressure II        Labels: 3R0-907-274.clb
       Part No SW: 3R0 907 274     HW: 3R0 907 274
       Component: J793  RKA+      H04 0002
       Revision: 00000528    Serial number: 00005280169166
       Coding: 0000577
       VCID: 72BDD810A8AEBF27CCD-8026
                        Fault Status: 11101101
                        Fault Frequency: 34
                        Reset counter: 108
                        Mileage: 208976 km
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0001
                        Voltage: 11.10 V
                        Temperature: 15.0°C
                        (no units): 0.0
                        Reset counter: 144
                        Mileage: 208976 km
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0001
                        Voltage: 14.50 V
                        Temperature: 20.0°C
                        (no units): 0.0
                        Fault Status: 00101101
                        Reset counter: 141
                        Mileage: 208976 km
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0001
                        Voltage: 12.00 V
                        Temperature: 22.0°C
                        (no units): 0.0
                        Fault Status: 11100100
                        Reset counter: 75
                        Mileage: 208976 km
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0001
                        Voltage: 12.00 V
                        Temperature: 22.0°C
                        (no units): 0.0
    End----------(Elapsed Time: 03:07, VBatt start/end: 14.4V/14.4V)-----------
    Jan 2018
    Lithuania
    I found. Its 0004401
  3. Likes Uwe liked this post
