Results 1 to 9 of 9
Thread: 2003 audi a6 3.0 quattro (01V Transmssion)
Hybrid View
    Sep 2019
    Maine, USA
    How to fix Tc open
    Quote Originally Posted by frankb View Post
    How to fix Tc open
    Please explain better what you are trying to do AND post a full unedited Auto-Scan of your 2003 A6
  3. Likes Uwe liked this post
    Sep 2019
    Maine, USA
    here is autoscan
    Tuesday,17,September,2019,16:10:03:57287
    VIN: WAULT64B83N010248   License Plate:
    Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
              75 76 77
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E0 909 559 E    HW: 8E0 909 059
       Component: 3.0L V6/5V      G   0004
       Coding: 0016752
       Shop #: WSC 08376 444 101330
       VCID: 372B2B69C35078CF3B3-5160
    16840 - EVAP System
                P0456 - 002 - Very Small Leak Detected - MIL ON
    16815 - Warm Up Catalyst; Bank 2
                P0431 - 001 - Efficiency Below Threshold - MIL ON
    18032 - MIL Request Signal Active (Check TCM for errors too!)
                P1624 - 008 -
       Part No: 4B0 927 156 FF
       Component: AG5 01V 3.0l5V  USA 1213
       Coding: 0001002
       Shop #: WSC 01115 444 59106
       VCID: 70B9D075E6BEEFF73A9-5160
    17125 - Torque Converter Clutch
                P0741 - 003 - Stuck OFF / No Power being transferred - Intermittent - MIL ON
       Part No: 4B0 614 517 R
       Component: ABS/ESP allrad      2330
       Coding: 06497
       VCID: 30391075233EAFF77A9-51F2
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AD
       Component: A6-Klimavollautomat 0105
       Coding: 00110
       Shop #: WSC 02325
       VCID: 5CE194C51F067B97F61-2586
                57-00 - Electric Circuit Failure
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4B0 959 655 Q
       Component: Airbag 8.4EP        2001
       Coding: 0000607
       Shop #: WSC 02325 785 00200
       VCID: 3E253E4DEC6A4987F85-5184
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 F
       Component: Lenkradelektronik   D01
       Coding: 01002
       Shop #: WSC 02325
       VCID: 2F3B13093E30B00F633-51F2
       Part No: 4B0 920 981 N
       Component: KOMBI+WEGFAHRS. VDO D11
       Coding: 02262
       Shop #: WSC 08376
       VCID: 313F15712834A6FF757-5184
       WAULT64B83N010248     AUZ7Z0B2160242
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0102
       Coding: 00001
       VCID: 2C0104050F26CB17461-4B1E
       Part No: 4Z7 907 357
       Component: dynamische LWR       D07
       Coding: 00050
       Shop #: WSC 02325
       VCID: 04518CA5C736E357EE1-4B5C
    Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
       Part No: 4B0 035 195 L
       Component: symphony II NP2    0051
       Coding: 00205
       Shop #: WSC 08376
       VCID: 290FFD1100D4DE3FBD7-4E62
    End----------(Elapsed Time: 04:55, VBatt start/end: 12.1V/12.1V)-----------
    Sep 2019
    Maine, USA
    Tuesday,17,September,2019,13:33:30:57287
              75 76 77
       Coding: 0016752
    16840 - EVAP System
                P1624 - 008 -
       Coding: 0001002
       Coding: 06497
       Coding: 00110
       Shop #: WSC 02325
       Coding: 0000607
       Coding: 01002
       Shop #: WSC 02325
       Coding: 02262
       Shop #: WSC 08376
    Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D37
       Coding: 15885
       Shop #: WSC 02325
       VCID: 33331F79D21894EF07B-4F50
    01560 - Passenger Door
                59-10 - Can't Unlock - Intermittent
    01561 - Rear left door
                59-00 - Can't Unlock
       Coding: 00001
       Coding: 00050
       Shop #: WSC 02325
       Coding: 00205
       Shop #: WSC 08376
    End----------(Elapsed Time: 04:56, VBatt start/end: 12.2V/12.2V)-----------
    HQ
    Thank you for posting a full Auto-Scan.
    Is there something specific you are wanting to address?
    Jef
    Sep 2019
    Maine, USA
    Trans issue
    16.4905 S, 151.7375 W
    Thanks for posting the Auto-Scan, we have a Ross-Tech wiki page for that fault code in the Transmission controller, see below.
    P0741 - Torque Converter Clutch: Stuck OFF / No Power being transferred
    Is is possible there is a fault with the torque converter internal oil seal, it may have failed. If so the transmission need to be pulled out to repair this concern, typically the torque converter needs to be replaced.
    For more information see the Audi Technical Service Bulletin 2010879, you can find them in the Official Factory Repair information websites, a subscription is required.
    Hop this helps,
    drpeter
  9. #8
    Been here?
    http://wiki.ross-tech.com/wiki/index...5/P0741/001857
    PS: Please refrain from opening multiple threads with the same question about the same car. I've now merged them.
  10. Likes DrPeter liked this post
  11. #9
    Sometimes a trans fluid flush with thickening agent or changing the TQ converter lock up solenoid fixes this too, wouldn't this be worth a shot?
    You could log TQ converter request lock up in VCDS to see the gear and RPM failure event & too find the respective solenoid that might be also causing a PSI drop if watching a mechanical gauge, huh?
