Results 1 to 3 of 3
Thread: 1J - VW Golf ABS CODING
    Verified VCDS User mo_ferwana's Avatar
    Palestine Gaza
    Hi
    ABS has been burned for 1J - VW Golf . tried to read old coding , but No communications, have replaced other one but used one with the same number , have got :
    01044 - Control Module Incorrectly Coded any help how to recode this unit please ?
    thanks
    Monday,16,September,2019,16:09:17:25282
    VCDS Version: 19.6.1.0 (x64)
    Dealer/Shop Name: Gaza Automotive Solutions WorkShop
    Workshop Code: 012 14726 287716
    VIN:    License Plate: ABS
    Mileage: 145830km-90614mi   Repair Order:
    Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
              76
       Mileage: 145830km-90614miles
    Address 01: Engine        Labels: 06A-906-019-AEH.lbl
       Part No: 06A 906 019 BC
       Component: 1.6l 2V/R4 SIMOS AT2523
       Coding: 04030
       Shop #: WSC 00046
       VCID: 65CBD5D6FF0304670A-4ACE
    8 Faults Found:
    00557 - Pressure Switch; Power Steering (F88)
                29-00 - Short to Ground
                79-00 - Please Check Fault Codes
    00520 - Air Mass / Air Flow Sensor (G70)/(G19)
                31-10 - Open or Short to Ground - Intermittent
    00523 - Intake Air Temp Sensor (G42)
                30-00 - Open or Short to Plus
                P1570 - 35-10 -  - Intermittent
    Readiness: N/A
    Address 02: Auto Trans        Labels: 01M-927-733.lbl
       Part No: 01M 927 733 EQ
       Component: AG4 Getriebe 01M    3960
       Coding: 00000
       VCID: 030FEB4E1177DA5784-0956
    7 Faults Found:
    00518 - Throttle Position Sensor (G69)
                16-10 - Signal Outside Specifications - Intermittent
    00281 - Vehicle Speed Sensor (G68)
                03-00 - No Signal
    00529 - Engine Speed Signal Missing
                35-10 - - - Intermittent
    00545 - Engine-Transmission Electrical Connection
    01312 - Powertrain Data Bus
    Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
       Part No: 1J0 907 379 G
       Component: ABS     20 IE CAN  0001
       Coding: 03504
       Shop #: WSC 00046
       VCID: 356B45960F23B4E77A-4AB4
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                35-00 - -
                35-00 - -
    Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
       Part No: 1J0 909 609
       Component:  A AIRBAG VW3 SG   0002
       Coding: 00065
       Shop #: WSC 00046
       VCID: 6CDDA0F21CE9352F55-4AE6
    01284 - Side Airbag; Drivers Side; Disabled
                35-00 - -
    Address 17: Instruments        Labels: 1J0-919-xxx-17.lbl
       Part No: 1J0 919 881 C
       Component: KOMBI+WEGFAHRS. MM0 V14
       Coding: 00142
       Shop #: WSC 00222
       VCID: 32617E8AFE4DA3DF5F-5102
       Subsystem 1 - Part No: Ident
       Component: Nr. WEGFAHRS.:VWZ6Z0W0541746
       Ident.-Nr. WEGFAHRS.:VWZ6Z0W0541746
    01039 - Coolant Temperature Sensor (G2)
                64-10 - Not Currently Testable - Intermittent
    01128 - Immobilizer Pickup Coil (D2)
    01176 - Key
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 N
       Component: 4E Zentral-SG Komf. 0002
       Coding: 04097
       Shop #: WSC 00046
       VCID: 4993396673DBC0070E-4ACE
       Subsystem 1 - Part No: 1J1959801C
       Component: 4E Tőrsteuerger. FS0001r
       Subsystem 2 - Part No: 1J1959802D
       Component: 4E Tőrsteuerger. BF0001B
       Subsystem 3 - Part No: 1J4959811C
       Component: 4E Tőrsteuerger. HL0001r
       Subsystem 4 - Part No: 1J4959812C
       Component: 4E Tőrsteuerger. HR0001r
    7 Faults Found:
    01179 - Incorrect Key Programming
                35-00 - -
    01030 - Central Locking Key Switch; Driver Side; Lock
                29-10 - Short to Ground - Intermittent
    00943 - Heated Exterior Mirror; Driver Side (Z4)
                35-00 - -
    00912 - Window Regulator Switch; Front Left (E40)
                35-00 - -
                27-00 - Implausible Signal
    End-------------------------(Elapsed Time: 05:27)--------------------------
    Regards from Palestine
    VCDS User from 2004
    Are you sure you have installed the correct ABS for this car?
    Please post the car's VIN.
    Please clear all the spurious fault codes.
  3. Likes Jack@European_Parts, PetrolDave liked this post
    Palestine Gaza
    Hi
    here is the VIN :
    WVWZZZ1JXB078165
    and here are an autoscan after delete all dtc and also the DTC for ABS after delete all dtc then start engine without drive
    AUTOSCAN AFTER DELETE ALL DTC :
    Wednesday,18,September,2019,13:34:08:25282
    VCDS Version: 17.1.3.0
    VIN:    License Plate: GOLF 2001
    Mileage: 121350km-75403mi   Repair Order:
              76
       Mileage: 121350km-75403miles
       Coding: 04000
       Shop #: WSC 01317
       VCID: 65CBD5D6FF0304697A-4ACE
    7 Faults Found:
                P1570 - 35-00 -
    01177 - Engine Control Unit
                37-10 - Faulty - Intermittent
                49-00 - No Communications
    00282 - Throttle Position Actuator (V60)
                17-00 - Control Difference
    Readiness: N/A
       Coding: 00000
       VCID: 030FEB4E1177DA59F4-0956
    00811 - System Not Ready for Interrogation (Ross-Tech; Check Fault Codes Later)
                35-00 -  -
       Coding: 03504
       VCID: 356B45960F23B4E90A-4ACE
       Coding: 00065
       Shop #: WSC 00046
       VCID: 6CDDA0F21CE9352125-4AE6
                35-00 -  -
       Part No: 1J0 919 861 E
       Component: KOMBI+WEGFAHRS. MM0 V02
       Coding: 00142
       Shop #: WSC 07300
       VCID: 32617E8AFE4DA3D12F-5102
       Component: Nr. WEGFAHRS.:VWZ6Z0W0437044
       Ident.-Nr. WEGFAHRS.:VWZ6Z0W0437044
       Coding: 04097
       Shop #: WSC 00046
       VCID: 4993396673DBC0097E-4AB4
    End-------------------------(Elapsed Time: 05:28)--------------------------
    ABS READ AFTER START ENGINE :
    Wednesday,18,September,2019,13:35:58:25282
    VIN:    License Plate: ABSS
    Control Module Part Number: 1J0 907 379 G
      Component and/or Version: ABS     20 IE CAN  0001
               Software Coding: 03504
                Work Shop Code: WSC 00000
                          VCID: 356B45960F23B4E90A-4AB4
                35-00 -  -
    Address 03: DTCs cleared
    only have just replaceD ABS , ABS FRONT RIGHT AND LEFT ARE IN VERY GOOD CONDITIONS AND HAVE NO ISSUES
    ANY IDEA ?
    THANKS
    VCDS User from 2004
