Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Audi A4 B9 10 Park Assist option missing
    Jan 2017
    Quote Originally Posted by vastechnics View Post
    8W is B9 friend.
    No where in my autoscan it mentions 8w? Only thing I can see is F4-AU49 (4M1)?
    Skoda Octavia VRS DSG Blackline (CEGA)
    Retrofitted RLS, Autolights, Footwell Lights, RVC, W8 Passat interior lights
  2. #12
    Quote Originally Posted by kjrehsi View Post
    How do you know if it is the 8w model? Most of audi forums are saying VCDS can be used to code the front pdc in Address 9 Centl Elect.
    You believe "the internet" more than siLc and vastechnics.
    It is an 8W.
    Audi show it:
    You can try and choose the car in "AutoScan" Selection, it shows:
    8W - Audi A4/S4/RS4 B9 (2016 >)
  3. Likes PetrolDave, Uwe liked this post
  4. #13
    Jan 2017
    It is an 8W.
    Audi show it:
    Thank you NEtech not doubting anybody's intelligence I am just gathering information as I go along.
    Thank you for confirming its an 8w as AutoScan was not clear.
    I guess VCDS is limited in this case as per siLc and vastechnics
  5. #14
    If it should be possible with Coding, try:
    [09] make Byte 28 Bit 5 and Byte 38 Bit 0 active.
    Experimental coding is available.
  6. #15
    Jul 2014
    Tallinn, Estonia
    Almost every module's part number begins with 8W in the vehicle's autoscan.
    Chassis type at the start of every autoscan used to be a good indicator of the vehicle model but it no longer is because different vehicles sharing a common platform may have similar elements in the chassis type code. Hence the "4M1", which is the current Q7 type 4M but it's not a Q7...
  7. Likes Uwe liked this post
  8. #16
    The "4M1" comes from the car's Gateway part number, which is of course the first thing that VCDS needs to talk to in order to figure out what else it can talk to.
    When I want to see what chassis a car is, I usually look at the instrument cluster part number; those almost always start with the "Real" chassis code.
    Unfortunately, the standards for VINs have made it impractical to use '8' in the 7th digit. This started in the US, but it seems to have spread. See the section under the model-year chart here:
    https://en.wikipedia.org/wiki/Vehicl..._year_encoding
    Specifically:
    "if position seven is numeric, the model year in position 10 of the VIN refers to a year in the range 1980–2009. If position seven is alphabetic, the model year in position 10 of VIN refers to a year in the range 2010–2039."
  9. #17
    Mar 2016
    Yup. Done it too on a number of A4 B9 (8W)'s. You need a new parameter set for the BCM1 Module (09) to get full park assist working. You can code it up in Module 09 and it may "sort of" work but the full config you need new/additional parameter data. Once that is done and applied you'll find the whole lot works.
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dynamic Pack | Matrix Lights | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | N-Vision | BOSE | DVD Changer | Homelink | Soft Door Close | Heat+Sound Ins Glass | Priv Glass | Heated Windscreen | Heated Steer Wheel | Adv Key | Elec Boot Cover | Side Assist | Air Suspension | Ambient Lighting | Heated+Fold Mirrors | Park Assist Pack | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap
  10. Likes m87a liked this post
  11. #18
    Dec 2018
    Quote Originally Posted by andyhud View Post
    Andy
    Andy,
    Can you give me some more info on how to load the new parameter set into the BCM1 module? I installed the park assist in my B9 S5 and it is working sort of like you said. I am able to select the park assist and it shows on the MMI but as soon as I shift to reverse it turns off. I think it is because it is not parameterized for 12 sensors. I have access to tools that I may need.
    Thanks
    Akos
  12. #19
    Mar 2016
    Quote Originally Posted by ahorvath View Post
    Andy,
    Thanks
    Akos
    Hi Akos
    Yep, that sounds about right. If you have access to the tools, then you should have the files too, and therefore you should be good to upload them
    Assuming of course your thinking the same thing as I'm saying without actually "saying" it
