Results 1 to 10 of 19
Thread: Audi A4 B9 10 Park Assist option missing
    Jan 2017
    Hi Guys,
    I am in a bit of dilemma a fella came to me in his Audi A4 B9 chassis to get his Front Park assist enabled after a retrofit. The owner has rear parking assist installed from factory.
    So thought no worried will go into address 10-Park Assist and checkout the options available. On the installed modules page I can't see any option for Address 10? Which is strange as if he has rear parking sensor then there's got to be the option for accessing Address 10?
    I have not worked on the newer B9's so unless there is another way of enabling the sensors then please kindly point me in the right direction
    Here is a scan from the A4. I didn't get to check the rear parking sensors but I have a feeling the guy has aftermarket sensors installed
    Sunday,15,September,2019,18:15:45:14442
    VIN: WAUZZZF46GA074035   License Plate:
    Chassis Type: F4-AU49 (4M1)
    Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 81 A5 AC
              BB BC D6 D7
    VIN: WAUZZZF46GA074035   Mileage: 52720km-32758miles
    Address 01: Engine (J623-DETA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 AG    HW: 04L 907 309 L
       Component: R4 2.0l TDI   H33 1969
       Revision: B1H33---
       Coding: 0A254032232605083408
       Shop #: WSC 06314 790 00001
       ASAM Dataset: EV_ECM20TDI01104L906026AG 001006
       ROD: EV_ECM20TDI01104L906026AG_001.rod
       VCID: 6FBBD1B2071E8ADF233-803A
       Part No SW: 8W0 927 155 K    HW: 0CK 927 156 S
       Component: 0CL 20TDIRdWH06 0002
       Revision: --H06---    Serial number: 0000000643
       Coding: 000001
       ASAM Dataset: EV_TCMDL382021 002021
       ROD: EV_TCMDL382021_AU49.rod
       VCID: 47CB59124F2E729F4B3-8012
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
       Component: V553 MTFP  002 0572
       Serial number: 75117071160063000735
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
       Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
       Component: ESP9 Plus     H06 0593
       Coding: 0CAA489928A90A9A159E489400825292E6A59230121450A812004A4967A549
       Shop #: WSC 42178 002 1048576
       ASAM Dataset: EV_ESP9BOSCHAU49X 012014
       ROD: EV_ESP9BOSCHAU49X_012.rod
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 F    HW: 8W0 820 043 F
       Component: Klima Zone 3  H32 0052
       Coding: 141800285544440D02000100800000000000000000000000000000000000
       Shop #: WSC 06325 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 363524D638C4FB17205-8062
       Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000000761148
       Component: AQ_Hum_Sensor  H01 0003
       Serial number: 64584618000000000001
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: Klima Heck  H34 0050
       Part No SW: 8W0 907 063 AF    HW: 8W0 907 063 F
       Component: BCM1 MLBevo   H12 0228
       Coding: 07501143E11800CD014487141B2C00B910033100000000000000000000001A810A450122003000
       ASAM Dataset: EV_BCM1BOSCHAU736 015005
       ROD: EV_BCM1BOSCHAU736_015.rod
       VCID: 7F5B01F2577EFA5FB33-802A
       Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS491 151127  043 0813
       Serial number: 894253?0301533101237
       Coding: 5BC7F7
       Serial number: 61433588
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
       Component: E1 - LDS  H06 0008
       Serial number: 22 12 2015  00188934
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE131121511520385
       Coding: 210000
       Interior Light Module:
       Subsystem 5 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
       Component: J528-Dachele  H13 0082
       Serial number: B00084873
       Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
       Component: SL-B9/Q5NF  H13 0010
       Serial number: 20141202000000000800
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655     HW: 8W0 959 655
       Component: Airbag10.44   H52 0084
       Serial number: 003M60028TL5
       Coding: AECCF0C00C800000585400F3C08C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       VCID: 0655941608A4AB97F05-8052
       Subsystem 1 - Part No SW: -----------    HW: 442 060 302 16
       Serial number: 3577Y00A31B1C0E1C0C4
       Subsystem 2 - Part No SW: -----------    HW: 442 060 302 16
       Serial number: 3587Y00C11DE13E342A6
       Subsystem 3 - Part No SW: -----------    HW: 442 0B2 502 16
       Serial number: 3517700C51FB2C65305E
       Subsystem 4 - Part No SW: -----------    HW: 442 0B2 502 16
       Serial number: 352770020295445808B$
       Subsystem 5 - Part No SW: -----------    HW: 442 0C2 902 16
       Serial number: 3557500C31EA9BB1B2BZ
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C2 902 16
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500C31EA9BB0F20S
       Pedestrian Protection Center:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 902 16
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500A71EA9BB2D1BV
       Subsystem 8 - Part No SW: -----------    HW: 442 432 701 16
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M00A31AA1C8483DP
       Subsystem 9 - Part No SW: -----------    HW: 442 432 701 16
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M00A31AA1C84836J
       Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 76B5E4D67844BB17E05-8022
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 941     HW: 8W5 920 941
       Component: MM--M--DSLUK- H06 0267
       Revision: 0263v8      Serial number:    RW2F0+43S
       Coding: 24A451D028800600012369601000000000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       VCID: 7DA7FBFA5D72E84FA1F-8028
       Part No SW: 4M1 907 468 A    HW: 4M1 907 468 A
       Component: Gateway       H13 1079
       Revision: 3B060055    Serial number: 5543B03E716224
       Coding: 0301000100008F40440000000059001248100007000000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002040
       ROD: EV_GatewCONTIAU736_002_AU49.rod
       VCID: 353723DA25C2F00F29F-8060
       Subsystem 1 - Part No SW: 8W0 951 523 D    HW: 8W0 951 523 D
       Component: J453 MFL  H02 0002
       Serial number: 20160210045446 RD165
       Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
       Component: J367-BDMHella  H10 9052
       Serial number: 0473459403
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
       Component: LCM_MLBevoH05 0023
       VCID: 78A9EAEE7250CD67F29-802C
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 15000172341010
       Coding: 8800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 323D18C6D4ACE7370CD-8066
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
       Part No SW: 8W0 959 593 G    HW: 8W0 959 593
       Component: TSG FS        005 0052
       Serial number: 0000186568808
       Coding: 001F8A205001000000001082
       VCID: 4EC56C36A054A3D7085-801A
       Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0407
       Coding: 09000080008000
       Shop #: WSC 06324 790 00001
       ASAM Dataset: EV_EPSZFAU49X 002015
       ROD: EV_EPSZFAU49X_002.rod
       VCID: 40D9420E6A0045A78A9-8014
       Part No SW: 8W0 907 064 CB    HW: 8W0 907 064 B
       Component: BCM2 MLBevo   016 0344
       Coding: 013500002F100000630980000600000033020010004302502F04000000040030001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 012013
       ROD: EV_BCM2HellaAU736_012_AU49.rod
       VCID: 7EA5FCF65074F357B85-802A
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY1104603V1
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000034680916
       Part No SW: 8W0 959 592 G    HW: 8W0 959 592
       Component: TSG BFS       005 0052
       Serial number: 0000189254294
       Coding: 001F8A205C01000000001080
       VCID: 4DC76B3AAD5298CF71F-8018
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
       Part No SW: 8W0 035 192 B    HW: 8W0 035 192 B
       Component: MU-HS-LND-EU  042 0113
       Coding: 01940101FF0A000013111101000A00102F0002C601700100CE
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP.rod
       Subsystem 1 - Part No SW: 8W0 919 866 C    HW: -----------
       Component: ECE 2016  --- 0009
       Subsystem 2 - Part No SW: 8W8 919 604     HW: 8W8 919 604
       Component: DU Std AU49x  H31 0160
       Serial number: TPO00128091500720207
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 N    HW: 8W0 919 614 N
       Component: ControlUnit_B  H22 0134
       Serial number: C1000019111500030008
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 8W2 713 041 E    HW: 8W2 713 041 E
       Component: GSM-LL        H07 0068
       Revision: 0L0D5012    Serial number: 20160111000991
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: EV_GSMWaehlZFAU736.rod
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 8W0 907 217 A    HW: 8W0 907 217
       Component: BVS           H14 0030
       Coding: 0404090100000403024023A0850000FC00F0C020C000
       ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
       VCID: 3A2D30E60CDC1F77C4D-806E
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355     HW: 4M0 907 355
       Component: SCR-Stg-G3H10 0003
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736_AU49.rod
       VCID: 6E85CCB6001483D7285-803A
       Part No SW: 8W0 959 595 G    HW: 8W0 959 595
       Component: TSG HFS       005 0052
       Serial number: 0000189996492
       Coding: 000F88200001000000001080
       VCID: 50F9724EBA60B5271A9-8004
       Component: TSG HBFS      005 0052
       Serial number: 0000189996740
       VCID: 1675C45658041B17005-8042
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.2V/14.6V)-----------
    Skoda Octavia VRS DSG Blackline (CEGA)
    Retrofitted RLS, Autolights, Footwell Lights, RVC, W8 Passat interior lights
    Jan 2017
    Just remembered the fella had option in his MMI for rear parking sensors so pretty sure it is factory fitted.
    Jan 2015
    Bosnia and Herzegovina
    a4 b9 park sensors works as a sub system of bcm 09, in order to finish retrofit you need to upload parameters for 8k ops to bcm 09 and code them, the you will have ops system in mmi
  4. Likes Bogdan.audi liked this post
    Jan 2017
    Quote Originally Posted by m87a View Post
    Can you please help with coding the parameters please?
    Jan 2015
    it's not just coding, you need to upload parameters, vcds can't do that, to upload parameters you need vcp...
    Jan 2017
    I guess I will need access to the parameterised file aswell.
    May 2016
    Only for audi a4 8k model parameterize is needed. For 8w model not just coding only. Done a lot of times!
  9. #8
    Jan 2017
    Quote Originally Posted by vastechnics View Post
    How do you know if it is the 8w model? Most of audi forums are saying VCDS can be used to code the front pdc in Address 9 Centl Elect.
  10. #9
    Jul 2014
    Tallinn, Estonia
    Quote Originally Posted by kjrehsi View Post
    A4 B9 is otherwise known as "Type 8W". You'll see it many modules of your own autoscan.
  11. #10
    May 2016
    8W is B9 friend.
