Results 1 to 2 of 2
Thread: HID Reps installed in 2015 GTI
    Sep 2019
    I've recently installed ed's replica GTI MK7.5 headlights with the Morimoto HID kit and keep getting bulb out errors, on either the left or right side. I'l restart the car, and sometime the lights will fire correctly.
    "I saw some threads about modifying the leuchte6 and leuchte7 lasttyp codes. It says to set leuchte 6 and leuchte7 lasttyp to: "3 - xenon abblendlicht" That it should help mitigate low volt issues that might trigger beam out code. You can also do the same to the DRL settings (Leuchte 5 and leuchte4) and change them to LED (can't remember number off top of head)."
    Just not sure how to make those changes with VCDS.
    Thanks for any assistance.
    Friday,13,September,2019,18:53:22:01934
    VIN: 3VWTT7AU7FM062206   License Plate:
    Mileage: 37764km-23465mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75 A9
    VIN: 3VWTT7AU7FM062206   Mileage: 37764km-23465miles
    Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0006
       Revision: --H13---
       Coding: 091D00124424002F1000
       Shop #: WSC 00066 790 00218
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
       ROD: EV_ECM20TFS0205G0906259A.rod
       VCID: 2C010412268B4F87461-8078
    17178 - Databus
       Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4511
       Revision: 03253104    Serial number: TFK01411020763
       ROD: EV_TCMDQ250021.rod
       VCID: 290FFD0629795AAFBD7-807C
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 53244000002482
       Coding: 01FA6BA13426096E0079020081C92980D62C9000408194B400430050C009
       Shop #: WSC 01383 790 50316
       VCID: 47CB5BBE9F2D8CDF4B3-8012
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 134
                        Mileage: 30717 km
                        Date: 2018.04.13
                        Time: 00:13:29
       Revision: 00021000    Serial number: 0349842661
       Coding: 030C0C
       VCID: 3A2D324ADCDFE137C4D-806E
       Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
       Component: AC Manuell    H02 1001
       Revision: 00001K01
       Coding: 00020004200100000000000000000000
       VCID: 46D556BA982795D7B05-8012
       Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
       Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86580812142208
       Coding: 001118464001826969644000001407201800000000000000000000000000
       Shop #: WSC 00066 790 00020
       ROD: EV_BCMBOSCH_014.rod
       VCID: 4ACD628A8C3F71B754D-801E
       Component: WWS    141129  043 0581
       Serial number:         150106200549
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S2Y14M10D17H02M54S44
       Coding: 00A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST0000CMYW00000
       Coding: 181801
    6666 - Bulb for Low Beam Headlamp Left
              B1217 15 [008] - Open or Short to Plus
                        Reset counter: 161
                        Mileage: 37589 km
                        Date: 2019.08.18
                        Time: 20:47:48
    6922 - Bulb for Low Beam Headlamp Right
              B1218 15 [008] - Open or Short to Plus
                        Fault Frequency: 10
                        Reset counter: 133
                        Mileage: 37574 km
                        Date: 2019.08.18
                        Time: 19:32:39
    17674 - Bulb for Front Left Side Marker Lamp
              B12BA 15 [009] - Open or Short to Plus
                        Reset counter: 83
                        Mileage: 37574 km
                        Date: 2019.08.18
                        Time: 00:00:44
    17930 - Bulb for Front Right Side Marker Lamp
              B12BB 15 [009] - Open or Short to Plus
                        Reset counter: 83
                        Mileage: 37574 km
                        Date: 2019.08.18
                        Time: 00:00:44
                        Reset counter: 165
                        Mileage: 35483 km
                        Date: 2018.12.20
                        Time: 19:31:15
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM01FWC
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 51FF75E66169426F157-8004
       Occupant Detection:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J1400021SZW0$
       Coding: 303131
       Subsystem 2 - Part No SW: -----------    HW: 480 002 410 14
       Serial number: 35700000000C3980511B
       Subsystem 3 - Part No SW: -----------    HW: 480 002 410 14
       Serial number: 358000000000D894711G
       Subsystem 4 - Part No SW: -----------    HW: 480 402 210 14
       Serial number: 3510002A718166A2512R
       Subsystem 5 - Part No SW: -----------    HW: 480 402 210 14
       Serial number: 3520002B11811BA3538W
       Subsystem 6 - Part No SW: -----------    HW: 480 402 010 14
       Serial number: 3550002B518166B220E$
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 010 14
       Serial number: 3560002B518166B5138$
       Revision: FF032032    Serial number: 20141103500260
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 04518CB2EE9B67C7EE1-8050
       Part No SW: 5G1 920 856     HW: 5G1 920 856
       Component: KOMBI         342 4270
       Coding: 0BAD011A2180CF0502086A001000000000000000
       VCID: 6B83C70EE30588BF0FB-803E
    9456681 - Key
              B104C 29 [008] - Implausible Signal
                        Mileage: 32840 km
                        Date: 2018.05.30
                        Time: 12:50:13
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2203
       Revision: --------    Serial number: 19111410000065
       Coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07027
       ROD: EV_GatewConti_011.rod
       VCID: 71BFD566C129626F357-8024
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 27140002606790094435
       Coding: 29FFFF
       Revision: 00000000    Serial number: 14000318567005
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34311C72FEBB17471E1-8060
       Serial number: 261114060509RK
       Coding: 003E13200000040100000000
       VCID: 40D940A2BA03BBE78A9-8014
       Coding: 8102
       VCID: 372B2B7EEFCDFC5F3B3-8062
       Serial number: 281114060500GP
       VCID: 3FDB435EC7FDC41FF33-806A
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0645
       Serial number: V7B02211142778
       Coding: 027300000000000021220002001800001F0203340100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 6491AC320EDBC7C74E1-8030
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9PS500XHE
              B11CF 53 [009] - Deactivated
                        Reset counter: 62
                        Mileage: 34370 km
                        Date: 2018.09.12
                        Time: 18:40:05
                        Voltage terminal 30: 12.1 V
       Component: OCULowMQBUS   007 0564
       Coding: 02730002C28238017F1E06000000
       Shop #: WSC 00066 790 00123
       ROD: EV_OCULowMQB.rod
       VCID: 43D34FAEAB15A0FF97B-8016
    7170 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Bordcomputer-Setup (0x0F) - BapErr_RetryNotSuccessful]
                        Reset counter: 144
                        Mileage: 37444 km
                        Date: 2019.07.29
                        Time: 08:02:55
       Serial number: 140924200478
    End----------(Elapsed Time: 01:28, VBatt start/end: 13.4V/13.3V)-----------
    Jan 2015
    Bosnia and Herzegovina
    Left Low Beam:
    (1)-Leuchte6ABL LC5-Lasttyp 6 --> 3 - Xenon Abblendlicht If your bcm doiesn't support xenon set it to LED Abblendlicht it will work...
    (5)-Leuchte6ABL LC5-Lichtfunktion B 6 --> Lichthupe generell
    (6)-Leuchte6ABL LC5-Dimmwert AB 6 --> 127
    Right low beam:
    (1)-Leuchte7ABL RB1-Lasttyp 7 --> LED Abblendlicht
    (5)-Leuchte7ABL RB1-Lichtfunktion B 7 --> Lichthupe generell
    (6)-Leuchte7ABL RB1-Dimmwert AB 7 --> 127
