Results 1 to 3 of 3
Thread: Issues with ACC, Pre sense after removing tow bar hitch
    Aug 2014
    After wasting a lot of time to try and resolve this I am now at a loss!
    I had retrofitted this and as the car is being sold back to Audi they preferred it to be removed as they cant really warrant it despite it being genuine parts as it was not factory.
    So I carefully removed all wiring and thought I had captured all coding but I must be missing something, sadly I don't have the reference scan from when car was sourced prior to install as old PC long since died.
    Cant use lane assist, pre-sense keeps advising of a fault and stop start will not work.
    Scan:
    Sunday,15,September,2019,19:28:13:38198
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4513.4
    VIN: WAUZZZF40JA124225   License Plate:
    Chassis Type: F4-AU49 (8W7)
    Scan: 01 02 03 08 09 13 15 16 17 19 29 2B 39 42 44 46 52 5F 6C 6D
              81 82 8B A5 AC BB BC D6 D7
    VIN: WAUZZZF40JA124225   Mileage: 15546km-9659miles
    Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
       Part No SW: 8W0 907 401 E    HW: 059 907 309 F
       Component: 3.0TDI MD1    H24 0004
       Revision: C7H24---
       Coding: 122A40320576050324080000000000000000000000000000
       ASAM Dataset: EV_ECM30TDI0118W0907401E 001004
       ROD: EV_ECM30TDI0118W0907401E.rod
       VCID: 392F2EF8E9D0C1AFCD7-806C
    Address 02: Auto Trans (J217)       Labels:* Redir Fail!
       Part No SW: 8W0 927 158     HW: 0D5 927 156 H
       Component: 0D5  30TDIRdW H05 1010
       Revision: --H05---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 7F5B00E0B7742F9FB33-802A
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
       Part No SW: 8W0 907 379 M    HW: 8W0 907 379 D
       Component: ESP9 Premium  H13 0767
       Coding: 14AA309930A40A9A11A04893008252A2E4A5D2280C0C508812004A4527A54B
       Shop #: WSC 06324 790 00001
       ASAM Dataset: EV_ESP9BOSCHCMP 002013
       ROD: EV_ESP9BOSCHCMP_002.rod
       VCID: 4FFB702047547F1F033-801A
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
       Component: Klima Zone 3  H60 0210
       Coding: 2618002D5544450D02000100880000000000000000000000000000000000
       Shop #: WSC 06335 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 44D14F0C9E128C47AE1-8010
       Subsystem 1 - Part No SW: 4M2 820 021 B    HW: 4M2 820 021 B
       Component: J126 FLuftV  H09 0003
       Serial number: 00000000000002043849
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 1AB1190900PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: E265 Kli Fond  H40 0080
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0267
       Coding: 07501343E17900CD054D57195FAE80F9110B3104000000000000000020001A810A45012B025605
       VCID: 025D8914C4864277DCD-8056
       Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS491 171122  043 0813
       Serial number: 89425300401732600688
       Coding: 5BC7F7
       Serial number: 21025295X81A955555A0
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AH    HW: 4M0 941 531 AH
       Component: E1 - LDS  H06 0008
       Serial number: 22 08 2017  01102510
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE115111723611409
       Coding: 230000
       Interior Light Module:
       Subsystem 5 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: B00641630
       Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2617000195697005
    66649 - Local Data Bus 3
              U10C8 00 [009] - No Communications
                        Reset counter: 170
                        Mileage: 15546 km
                        Date: 2019.09.15
                        Time: 19:20:04
                        average_Voltage_terminals: 12.90 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 19.50 °C
                        interior_temperature: 23.00 °C
                        Vehicle speed: 0.00 km/h
       Part No SW: 8W0 907 561 C    HW: 8W0 907 561
       Component: LRR4          H10 0340
       Coding: 3473FFE258FFEC0A959A81A0
       ASAM Dataset: EV_ACCBOSCHAU49X 003022
       ROD: EV_ACCBOSCHAU49X.rod
       VCID: 3E253DE4F0FEE697F85-806A
    2153 - Databus
              [FAULT_HC_STA_FAIL]
                        Fault Frequency: 9
                        Reset counter: 170
                        Mileage: 15541 km
                        Date: 2019.09.15
                        Time: 19:07:48
                        Control Module temperature: 37 °C
                        Voltage terminal 15: 12.7 V
                        Status_ACC_System: ACC_irreversible error
    2068 - Databus
              [FAULT_TSK_IRREV_FAIL]
                        Reset counter: 170
                        Mileage: 15541 km
                        Date: 2019.09.15
                        Time: 19:07:48
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
       Component: Airbag10.44   H03 0107
       Serial number: 003UP00BT9G.
       Coding: AACCF0C00C800000985400F3D0CC00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 006016
       ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
       VCID: 4CC1672CB6424407661-8018
       Subsystem 1 - Part No SW: -----------    HW: 442 062 811 17
       Serial number: 3577Y00C126D2BC2D304
       Subsystem 2 - Part No SW: -----------    HW: 442 062 911 17
       Serial number: 3587Y00C926068A152A%
       Subsystem 3 - Part No SW: -----------    HW: 442 0B1 511 17
       Serial number: 3517700B127DA976339I
       Subsystem 4 - Part No SW: -----------    HW: 442 0B0 712 17
       Serial number: 3527700B728B79E4613L
       Subsystem 5 - Part No SW: -----------    HW: 442 0C2 507 17
       Serial number: 3557500AF275CB2631BO
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C2 507 17
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500AF275CB2520CN
       Pedestrian Protection Center:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 507 17
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 23075009F2772296E27D
       Subsystem 8 - Part No SW: -----------    HW: 442 430 212 17
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M00B92532143E0B7
       Subsystem 9 - Part No SW: -----------    HW: 442 430 212 17
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M00B9253214341D1
       Part No SW: 4M0 907 129 ME    HW: 4M0 907 129 ME
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
       Component: FBenRDW       H18 0373
       Coding: 258669D06C82060001A3E9601000400000000000
       ASAM Dataset: EV_DashBoardAU736 001027
       VCID: 43D34C109B1C8B7F97B-8016
       Part No SW: 8W7 907 468 F    HW: 8W7 907 468 E
       Component: Gateway       H42 0123
       Revision: 7C000001    Serial number: 0187C027718109
       Coding: 03010001000086407F07000000590012D8180007100000000175078E10000000
       ASAM Dataset: EV_CGateCONTIAU491 003111
       ROD: EV_CGateCONTIAU491_003_AU49.rod
       VCID: 4EC56D24405E7617085-801A
       Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20180108184828 21851
       Serial number: 5191156004
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
       Component: LCM_MLBevoH05 0024
       VCID: 78A9EBFC925A18A7F29-802C
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 17000379963004
       Coding: 8800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 323D19D434A632F70CD-8066
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
       Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
       Component: TSG FS        005 0129
       Serial number: 0000295268633
       Coding: 005D9A215001000000001082
       Shop #: WSC 06325 790 00001
       Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0410
       Coding: 0D008380008080
       ASAM Dataset: EV_EPSZFAU49X 003023
       ROD: EV_EPSZFAU49X_003.rod
       VCID: 42DD4914840682779CD-8016
       Part No SW: 8W0 907 064 EC    HW: 8W0 907 064 DC
       Component: BCM2 MLBevo   025 0387
       Coding: 013500006FB100406309A0000E00080233024010804706502F0400000504803F001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 014014
       ROD: EV_BCM2HellaAU736_014_AU49.rod
       VCID: 015F8618C180596FC57-8054
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY173384HQP
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000099906688
       Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
       Component: GEB.F.Heckoef  H16 0905
       Serial number: >1194400
       Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
       Component: TSG BFS       005 0129
       Serial number: 0000278938534
       Coding: 005D9A215C01000000001080
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
       Part No SW: 8W5 035 035 B    HW: 8W5 035 035
       Component: MU-P-LND-EU   034 1177
       Serial number: A829A0JB050759
       Coding: 019402010000000053111102000A00332F0002E701700100BE
       VCID: 363525C4D8CE2ED7205-8062
       Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Subsystem 2 - Part No SW: 8W8 919 605     HW: 8W8 919 605
       Component: DU High AU49x  H32 0170
       Serial number: TPO00106091700820864
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
       Serial number: APVAK129111700020827
       Component: Gracenote2  --- 1016
    3086 - Antenna for Telephone Mount
              B1564 01 [009] - Electrical Failure
                        Reset counter: 170
                        Mileage: 15533 km
                        Date: 2019.09.15
                        Time: 12:00:56
                        Voltage terminal 30: 11.6 V
                        Status of telephone-Antenna diagnostic: OK
                        Status of telephone-Telephone baseplate diagnostic: not connected
                        Status of telephone-Handset in handset holder (cradle): not selected
                        Status of telephone-Handset holder (cradle): not connected
    Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
       Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
       Component: RVC Compact   H12 0250
       Coding: 0294020102002001400040
       ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
       ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
       VCID: 33331CD0CBBC3BFF07B-8066
       Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
       Component: HDSG-Modul    H13 0163
       Revision: --------    Serial number: 31709534400000
       Coding: 0570
       ASAM Dataset: EV_DeckLidCONTIAU736 001015
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 8W2 713 041 F    HW: 4M2 713 041 F
       Component: GSM-LL        H09 0077
       Revision: 0L0D5012    Serial number: 17121145195270
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 372B28C0DFC4D7DF3B3-8062
       Part No SW: 8W5 919 617 C    HW: 8W5 919 617 C
       Component: HeadUpDisplay H18 1640
       Coding: 4F01C0
       ASAM Dataset: EV_HudNSEIKAU736 001017
       ROD: EV_HudNSEIKAU736.rod
       VCID: 48C95B3CA23AA827429-801C
    Address 8B: Adaptive Cruise 2 (J850)       Labels: None
       Part No SW: 8W0 907 541 C    HW: 8W0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU49X 003022
       ROD: EV_ACC2BOSCHAU49X.rod
       VCID: 3C2137ECE6E2F487D61-8068
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 8W0 907 217 C    HW: 8W0 907 217 C
       Component: BVS           H17 0050
       Coding: 0404090200000403024023A5A50000FCB0F0C020C020
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
    1122565 - Databus
              [TIMEOUT_Anhaenger_01]
                        Reset counter: 170
                        Mileage: 15541 km
                        Date: 2019.09.15
                        Time: 19:08:52
                        Control Module temperature: 29 °C
                        Voltage terminal 15: 12.80 V
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
       Component: SCR-Stg-G3H04 0006
       ASAM Dataset: EV_RDCMINERGAU736 005012
       ROD: EV_RDCMINERGAU736_AU49.rod
       Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
       Component: TSG HFS       005 0129
       Serial number: 0000297723583
       Coding: 000D98200001000000001080
       VCID: 51FF7658516069EF157-8004
       Component: TSG HBFS      005 0129
       Serial number: 0000297723312
       VCID: 1675C544B80ECED7005-8042
    End----------(Elapsed Time: 01:57, VBatt start/end: 13.0V/13.0V)-----------
    Here you have your AutoScan, without trailer coding.
    Coding without trailer:
    [01] > 122A40320566050324080000000000000000000000000000
    [09] > 07501143E17900CD054D51195BAE80F9110B3108000000000000000020001A810A45012B025605
    [17] > 258469D06C80060001A3E9601000400000000000
    [46] > 013500002FB100406309A0000E00080233024010804706502F0400000504803F001F0001000000
    [A5] > 0404090200000403024023A4A50000FCB0F0C020C020
  3. Likes paul, Uwe liked this post
    Aug 2014
    Absolute legend, will be engine coding for starters! Sometimes the answer is right under our noses. Will scan through and adjust as required.
