Results 1 to 3 of 3
Thread: A6 C7/4G Lights humidity sensor ?
    May 2017
    Luxembourg
    Exclamation A6 C7/4G Lights humidity sensor ?
    Hi
    For some time I see that my driving lights are on during normal sunny day.
    Also on autoroute where there is limit during rain - sign recognition shows my a limit for a rain.
    Navi don't go dark (night/tunnel)
    Lights on speedometer are on.
    I suspect humidity sensor - or something similar.
    No errors are shown in any module.
    What was done recently in a car ?
    Update of MMI from 928 to 1425.
    I scan is necessary I will provide one.
    Could you tell me in which module (09, 46?) I can see actual humidity used for detection of rain ?
    ---------AUTOSCAN---------
    Sunday,15,September,2019,20:18:36:45479
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 28 34 36 3B 3C 42 44 46 52
              53 55 5F 62 69 6C 6D 72 85 8B 8E 8F 90 A9 AC C0
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: -
       Coding: 0105001440349FE2C90140C380001800CF9C6708AE08022100000894E10117020040003D030000
       Shop #: WSC 21239 003 1048576
       VCID: 71BCDC6DD1A200FF357-8024
       Component: WWS57X 141122  H37 0080
       Coding: 0045F7
       Coding: 0B006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 14 12 2014  00000285
       Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
       Component: EHL2 V07.03  H30 0030
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Part No SW: 4G9 920 950 T    HW: 4G9 920 950 T
       Component: TDieRdwAccNv  H07 0043
       Revision: 03001036    Serial number: -
       Coding: 138622081F550008000600
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 41DC4CADA102D07F857-8014
       Part No SW: 4G8 907 468     HW: 4G8 907 468
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: -
       Coding: C0CD078118
       ASAM Dataset: EV_GatewPkoUDS 001024
       VCID: 75B4E87DA54A2CDFE9F-8020
       Serial number: 4745765203
       Voltage stabilizer:
       Serial number: 1410070000000000026C
       Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 EP
       Component: BCM2 2.0      H36 0560
       Revision: 00002001    Serial number: -
       Coding: 01000E3820B97095C32009042E010F470000000000000000000000000000
       VCID: 7CA2FD5986E07D97961-8028
       Component: GTO BF  H01 0081
       Serial number: -
       Subsystem 2 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J245 PS20.008  H02 0007
       Serial number:    -
       Coding: 901F00
       Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J394 PS20.008  H02 0007
       Serial number:     -
       Coding: 801F00
       Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0081
       Coding: 04FA02202A170200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
       VCID: 33301665EBBE72EF07B-8066
       Coding: E01F00
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E01F00
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 043 M    HW: 4G1 035 043 D
       Component: MU-H-N-EU     051 ????
       Serial number: -
       Coding: 01754201FF0A000033110001000E04232F000AE5F1700100BF
       VCID: 280AF10922780137A29-807C
       Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
       Component: ECE 2019/2020  --- 0177
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Multimedia Operating Unit:
       Component: Gracenote2  --- 1012
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: FA160000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C020D1936802D17461-8078
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H33 0092
       Serial number: -
       Coding: 04C0BB1C1111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    Seat Leon X-perience 5F TDI 184PS
    Audi A6 AllRoad 4G TDI 320PS
    We'll definitely need you to post an Auto-Scan.
    That should also show the humidity sensor as a slave module
  3. Likes Uwe, Gremling liked this post
    May 2017
    Luxembourg
    I removed not relevant modules.
