Audi A5 2011 2.0Tfsi esp/traction control light on no fault codes stored
Scottyboyc56
New Member
As above no fault codes stored, wheel alignment checked and steering angle sensor calibrated. Anyone had this fault before?
Could it be a coding issue?
Thanks in advance
Please post an Auto-Scan so people can see how the car is equipped and configured.
Scottyboyc56
New Member
I’ll try and get one posted. Does it sound like a coding issue to you?
Scottyboyc56
New Member
Audi A5 longitudinal sensor calibration
Would you carry out a longitudinal/ yaw rate sensor calibration if the abs module has been replaced?
TIA
Viking
C?ID=151455
Still waiting for a complete autoscan from your previous thread.
Are we to assume that the problems mentioned in your previous thread are a result of changing the ABS module?
If so then please don't start another thread for problems with the same cause - it splits replies and causes confusion :thanks:
Without an Auto-Scan we cannot help you :banghead:
Threads merged. :cool:
